Hi Team,
I would like to ask the following.
1)
The datasheet shows 470nF for CB to VSW however typical application shows 10nF.
Which is correct value? I believe 10nF is correct however would like to confirm just in case.
2)
Absolute Maximum Ratings shows the following however my customer said CB pin voltage exceed VSW+8V in normal operation.
Is it problem?
Could you also tell me CB to VSW voltage that should be observed when Vin=13.8V, Vout=5V application?
Yaita
