I am trying to properly use the excel calculator that is provided for this part, but I am running into a few uncertainties.
- The tab containing the Gm lookup table only contains data for DDR1. This is a DDR3 application. I noticed with all the cells populated, if you simply change between DDR1-4, the Gm recommendation does not change...
- What's the method for selecting the appropriate crossover frequency?
- Is the ESR that gets calculated in the bottom a minimum or maximum value we should have? Or is it simply a target?
Thank you!
Ryan B.
