Hi Team,
Can you review my design?
Total current is 2.65A at 1.8v.
Vin is 3.3v
I not assembly R527.
Shlomi
Hi Team,
Vin is 3.3v
Shlomi
Hi Shlomi,
I would like to point out four different things on your schematic:
- We recommend a total output capacitance value of 150uF max for the TPS82085, It would be beneficial to your system especially at startup to lower the output capacitance. You should then retrieve 2x47 uF caps per rail.
- FT4 needs to be placed after the output caps it is really important to have the output caps as close as possible to the IC.
- Regarding the ferrite beads used, they have a 40mOhm DCR resistance. Knowing you want to have 2.65A max at the output current. You will acknowledged a non-negligible voltage drop across it. I would then recommend to have a slightly higher output regulation and then modify the resistor bridge at feedback.
- Depending on what consideration interests you the most between output accuracy and efficiency. I recommend you read this App Note explaining you how to design best your resistor bridge at the feedback pin: http://www.ti.com/lit/an/slyt469/slyt469.pdf
If you have any other questions please ask.
Thank you!
Dorian
Hi Shlomi,
I haven't heard back from you. Do you have any further questions on this topic?
Have you made changes to your schematic implementing the feedback I gave you ?
Thank you very much!
Dorian
Hi Dorian,
Shlomi
Hello Shlomi,
I am not certain to understand every changes you have made. Can you send back the schematic with the changes?
Dorian
Hello Shlomi,
I haven't heard back from you. Did make the changes on your schematic?
Could share it with us ?
Dorian
Hi Dorian,
Shlomi
Hello Shlomi,
When we state in Datasheet 150uF max of output cap, it is for every power line the system is using. So you are fine here!
For the DCR of about 40 mill-ohm of F.B=L1 it is not a problem, you just need to be aware that you will have a voltage drop across it. As mentioned before, you could compensate it by rising the output voltage regulation, if you change the resistor bridge at feedback.
Do you have any further questions?
Thank you!
Dorian
Hello Shlomi,
I agree with your changes.
Do you have other questions?
Thank you!
Dorian
