  • TI Thinks Resolved
TPS61041-Q1: Test method
Mastermind 6770 points
Part Number: TPS61041-Q1
Hi TI-team
1:Is it possible to apply 10mA to each terminal from the GND terminal ?
Is there a possibility that the IC will be damaged ?
Also, can you guarantee on all terminals after this test ?
IC assumes non-energization.
2:Is there a current value or voltage value that can be guaranteed if the current value can not be guaranteed at 10mA ?
3:Please tell us if there are min, typ and max data about Vf value of each terminal when 10mA of No. 1 is energized.
Koji Hayashi
  • Hi Koji,
    Can you specialize which pin?
    EN pin maximum input leakage current is 1uA. FB pin maximum input bias current is 1uA.
    I don't understand why you ask this question. Did you meet any issues when using it?
    Zack Liu
    Boost Converter Solution
  • In reply to Zack Liu:
    Hi Zack-san
    Thank you for response.
    It is for confirmation of the protection diode.
    Therefore, all pins are targeted.
    For example, when a current of 10 mA is applied from EN to GND.
    Koji Hayashi
  • In reply to Koji Hayashi92:
    Hi Koji,
    What kind of protection diode do you mean? Do you have a schematic?
    It is more common to give a absolute maximum voltage rating on each pins. You can refer to part 6.1 Absolute Maximum Ratings in datasheet.
    If the voltage applied on EN pin is not higher than maximum voltage rating, the current will not bigger than 1uA because this pin inside is high resistance.
    Zack Liu
    Hi Zack-san
    It will check the internal protection diode.
    My customer would like to check by sending 10mA from the EN pin to GND with no voltage applied to VIN.
    Koji Hayashi
    Hi Koji-san,
    Sending 10mA from EN pin to GND will break the IC because EN pin is high resistance.
    Zack Liu
    Hi Zack-san
    How much current is it okay ?
    Koji Hayashi
    Hi Koji,
    You can get these information in datasheet Electrical Specification Table.
    Zack Liu
    Hi Zack-san
    I'm sorry,
    My customer would like to check by sending 10mA from the GND  to EN pin with no voltage applied to VIN.
    (GND to SW pin etc)
    What about this case ?
    Koji Hayashi
    Hi Koji,
    Please don't do this test. EN pin is high resistance, 10mA current will cause very high voltage and will break down this pin.
    I haven't never heard any customer used to do this test. I don't understand why your customer need to do that. And TI doesn't have a protection diode for it.
    Zack Liu
    Hi Zack-san
    How much amperage can safely conduct ? 1mA ?
    Customer wants to do an open / short test.
    Koji Hayashi
