Hi Expert,
My customer asks some questions for TPS62813-Q1 operation.
Could you please support below items?
1, Could you please provide the deviation range for SS function?
2, TPS6281320-Q1 can be worked SS function at PFM mode?
3, PG pin can be left Open if the customer doesn't need PG function?
4, The datasheet mentions that 0.47uH inductor should be selected.
But, the customer wants to know how much ripple is required for TPS62813-Q1?
5, There are 3 comp setting. Which setting is the best selection at first evaluation?
6, What does MHz.kohm mean, for equation of Rcf calculation?
7, TPS62813-Q1 has to generate gate voltage for high side FET to keep 100% duty?
8, when output discharge is working, is Low side FET tuned on?
9, Could you please provide the equation how to calculate Cff value?
Yuki
