Other Parts Discussed in Thread: BQ78350, GPCCEDV, BQSTUDIO
Hi Sir
May I know BQ78350 have design guide for LiFePO4? or is it the same with Li-ion?
Hello Hsiao,
The BQ78350 is using CEDV algorithm, that is different with impedance track that need to match the chemID in our library. it could refer to same development process, please check the GPCCEDV http://www.ti.com/lit/ug/sluub45b/sluub45b.pdf as your reference.
Our expert could give more explanation when he is back on Monday.
Thank you,
Hi Kai,
The app note Using the BQ78350-R1 will help guide you through the first steps in setting up the device for your battery. The process will be the same for Li-ion and LiFePO4. After you configure the ChemID and find the optimal CEDV parameters, you can look through the other settings in BQStudio. The default values for the voltages are based on a Li-Ion battery (for example, the over-voltage and under-voltage protection levels), so you should modify these values based on your LiFePO4 battery specifications.
Matt
