Hi Team,
I meet a urgent problem about PGOOD noise impact when start up.
I tried to change the pull high resistor from 4.7k , 10k ...100k ohm, the issue still exist. this phenomenon happened on five projects.
I also to check layout & schematic again, i didn't found any abnormal on this.
Pls see below waveform, Could you help to know what does cause by?
Just let me know if you need board file & schematic, I can share with you..
Mark
