Other Parts Discussed in Thread: TPS7A8300,
Team,
TPS7A8300ARGW datasheet is missing the dimension for thermal pad, thus we are stuck at make the footprint.
Thank you for your fast support.
Hi Kevin,
Yes apparently the packaging addendum in the TPS7A83A datasheet is missing the last page which contains the thermal pad dimensions. Thankfully I looked at the TPS7A8300 datasheet and it has it on page 43 for the same RGW package and you can use that.
We'll work with the Digital Documentation team to find out why the TPS7A83A datasheet isn't pulling this page from the packaging database.
