Hi team
The datasheet states the following, but should this be handled by the RGP(S-PVQFN-N20) package?
”Connection of Two Grounds: GND (analog ground) and PGND (power ground). Two grounds should be connected using a net tie right between GND pin and PGND pin at IC, and there should be only this connection between two grounds.”
,defined in datasheet 11.1 Layout Guidelines.
Regard.
