we do see similar issue and trying to open http://www.ti.com/lit/an/snva689/snva689.pdf but not able open please do help
Hi John,
The file is not accessible for us as well. Can the link below help you?
Excel
Hi John,
If you don't have any further query, I will close this thread. Feel free to post your additional query anytime.
Excel
Hi
Still we have issue, we are noticed that the during our Burn In test some time units is going to sleep mode and after some time it starts again,
during debug we saw that the 3.3V is low.
Hi John,
What is the ambient temp during Burn-in test? Can you share the schematic diagram and layout for review?
Excel
Hi John,
Any update on the items below.
1. What is the ambient temp during Burn-in test?
2. Can you share the schematic diagram and layout for review?
Excel
Hi John,
Any update on the requested data.
Excel
Hi John,
I will close this thread if you don't have further query.
Excel
Hi John,
First, the Vout setting is 3.3V hence you should be using is LM3670xx-3.3. LM3670xx-ADJ supports only Vout from 0.7V to 2.5V.
Once you replace the IC, can you check the loop stability (measure the phase margin) because the recommended output capacitor is 10uF while in the schematic diagram, the output cap directly connected to the output is 2.2uF + 270uF.
Can you provide your email add so we can discuss privately?
Excel
Hi
my email is John.Paul@se.com.
I have one more doubt TPS62200DBVR is equivalent to LM3670MF-ADJ
please do confirm
thanks
John Paul I
Hi John,
I already sent a private email to discuss your issue in details.
Thank you.
Excel
