Hi Team,
Would you advise how to understand about EN Toff description in datasheet?
Is this MAX 1ms value means we should give less than 1ms low pulse
OR more than 1ms is needed?
Shidara
Hi Shidara:
It's the maximum time for response.
When the EN pin is pulled low for 1 ms, the IC stops the PWM switch and turns off the isolation switch, providing
isolation between input and output.
Hi Minqiu-san
Thank you so much for your advice.
I understood.
For making sure, I'll inform the customer to pull EN to low for more than 1mS.
Shidara
Hi Shidara:
It's glad to see such careful questions. It's great to double check that.
Hi Minqiu-san
Could you close this thread because it was resolved.
Shidara
