Hi team,
what is the behavior after TPS7B6701-Q1 overcurrent gets triggered? More specifically, will it shutdown and retry? or will the device limit the current to Ilim until thermal shutdown is triggered? Or other reaction?
Hi team,
When overcurrent is detected, the current limit loop will kick in and the current will indeed be reduced and limited to the output current-limit in the datasheet. If this is sustained, the part may eventually cycle in and out from thermal shutdown as you suggested.
Nick
