Hi Sir,
From the datasheet, the delay time tolerance is ~+/-40%.
Will it be similar if using CT = 10nF? when set 10nF, the delay time is 57.5ms by equation which should be typical value.
Thank you.
Allen
Hi Sir,
Thank you.
Allen
Hi Allen,
The variation for the capacitor will be similar to the other capacitor values listed on the timing table. In this case, the delay time should vary by about 40% each way.
Abhinav.
