Hi Team,
According to the specification.CHARGER BEHAVIOR will be Reduce VBATREG by 140 mV at TS_FAULT WARM,
So there are two scenarios.
1: If the battery voltage at 3.7V occurs TS_FAULT WARM, then the BQ will continue to charge according to the fast charging current at this time.
2: If TS_FAULT WARM occurs when the battery voltage is 4.06mV, then the BQ will stop charging at this time.But there is no charge done interrupt sends to host;
How do the Host know if the BQ is charging when TS_FAULT WARM is running?
We need to do some UI actions when stop charging.
Thanks;
Wayne
