Hi, my customer is using UCC27524 to drive 2 IGBT. The schematic is as below: Solar-0 is connected to GND through 0 ohm resistor.
The main topology is a non-synchronous boost, BUS+ is the output of the boost converter.
At light load, there is no ringing on the waveform of Vge(gate side to emit side of IGBT's voltage).
But at heavy load, the waveform becomes:
What may be the cause of the ringing and what more information is needed to help identify the root cause?
