I did find the formula used on the calculation of Zo is different in the Datasheet SLUS794F than in the application report SLUA479B.
1. In the application report, the ripple voltage is calculated using 2*Pin. The ripple voltage formula is then used in the calculation for Zo. While in the datasheet there is a reference to a 0 to Peak ripple voltage, where only Pin is used in the ripple calculation, then this formula is used to calculate Zo. There is a factor 2 missing.
2. In the datasheet is mentioned the amount of k3rd third harmonic content, while in the application report is not mentioned at all.
Could you please help me with some clarification about this?
Thank you
