Hello team,
My customer is trying to use TPS55340 for 12V-to-24V conversion with very small Io=73mA.
He concerns about the output overvoltage risk when the top resistor of the output resistor divider is open.
Do you think additional component such as Schottky diode at FP pin should be usually considered to support this type of overvoltage situation?
Also, I found that overshoot can be seen when input voltage SR is high and no output load from this thread.
Is it better to tell my customer to take care about the input voltage in advance?
Itoh
