In this file Excel, I find the value of Rfs/Rf1 is swapped , would we have any effect on the calculation other components?
BR
BR
What is the Rfs you refer to? I didn't find it in the excel. Could you please upload a screenshot?
Wendy
The calculator is correct. The FB is 2.5V. With the value of RFB1 and RFB2, we can get the Vout.
Wendy
I am Ok with u the Vout is correct, but when we calculate the RFB2 from RFB1 isn't correct:
example: for giver (Vout=42 Volts, and RFB1=10Kohms) ===> RFB2=634ohms (DATASHEET) not 158Kohms (EXCEL), so the Step 2 should be RFB1/RFB2=15.8.
Best Regards
Hussein
Both the calculator and the datasheet are correct. While for the datasheet, upper one is R1, lower one is R2. For the excel, upper one is R2 and lower one is R1. So you can't use the same equation.
Wendy
