Other Parts Discussed in Thread: LM25085, TL431, TLV431, , LM321
We would to use TL431 (TL431ACDBZR) instead of LMV431A in the attached schematic for current limit circuit as noted in blue added to LM25085. can you please advice if that is possible?
In Addition, if using TL431, is it correct to short the cathode to Vref to get 1.24v in this circuit to get the same result as with LMV431A (as the TL431 alternative circuit on the left side)?
By replacing to TL431, Is it possible also to take out from this circuit R1, R2, R3 and C1?
Thank you in advance,
Barg
