I have a design using the TPS2501 and limiting USB charge current to 500 mA. Our design only uses 10 uF output capacitor, but I found several mentions that 120 uF minimum is required. We are somewhat space constrained so using a 120 uF capacitor is a challenge. What can I expect for effects if I only use 10 uF? If I can use a 22 uF capacitor will that improve things?
