Part Number: DRA785
I found there is same min & Max timing limit value of td(SCLK-D1) , it seems can’t make sense.
Part Number: DRA785
One more concern for McSPI timing parameter: why separated SM6 but with the same MIN/MAX value?
Hi Kyle
About Q9 td(SCLK-D1) in MODE 0 READ Sequence, the actually test result is similia with Q4 td(CS-SCLK) which can't meet the spec Min : -23.2ns , Max -21.2 ns. (P =22.2ns)
According the timing diagram , Q9 seems same with Q4, can you help double confirm my test result whether is fail from your view?
BR Jingcheng
