TDA4VM: Device tree - OSPI0 node properties for cypress device S28HS01GT-GA-B-H-B-01
Part Number: TDA4VM
Hi Karan,
I found a SDK document link for the cypress flash part: S28HS512TGABHM010.
Link: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-j7200/latest/exports/docs/j7200/linux/Foundational_Components/Kernel/Kernel_Drivers/QSPI.html
If we are using Part no: S28HS01GT-GA-B-H-B-01. Can I reuse the ospi0 properties from the link.
Few queries:
  1. In the sdk ospi0 node found in following dts/dtsi files - k3-j721e-r5-common-proc-board.dts & k3-j721e-som-p0.dtsi. The properties seems to be different, which one is taken for EVM?.
  2. For cypress 256KB is reserved for “ospi.phypattern”. How is this decided between 128 KB (micron-512Mb) vs 256 KB(cypress - 512Mb).
Thanks & Regards,
Sankar M
  • Hi Karan,
    Please ingore question 1. i got the answer and it is my misunderstanding
  • Hi Sankar,
    The PHY tuning data needs to be flashed to the last sector of the flash. On the MT35XU512ABA1G12 flash the sector size is 128KB and hence the last sector starts at 0x3fe0000 whereas on the S28HS01GT-GA-B-H-B-01 the sector size is 256KB and hence the last sector starts at 0x3fc0000.
    The below parameter is also different, let me check on what needs to be the value for that for the flash you are using:
    cdns,read-delay
    Karan
  • Hi Sankar,
    For now, lets use the OSPI node properties as mentioned in j7200 device tree as the part on your custom hw is similar to the one on j7200 EVM.
    Karan
