Part Number: TMS320C6657
Hi experts,
We have developed a custom board in 8 years ago.
We really appericated your support like you.
However
we have sometimes found very long DDR3 auto levelling problem with below codes recently
There is 20 ~ 30% boards which boots sometimes very long like 30 seconds.
There is not any boards in a year ago.
We must improve this ratio, and could please give a comment what points is important.
/*""FILE INCLUDE""*************************************************************/
#include "ddr3_p.h"
//#include "csl_emif4f.h"
//#include "csl_bootcfgAux.h"
/*""FILE INCLUDE END""*********************************************************/
/*""Function Define""**********************************************************/
INT32 DDR3_TestMemory_s32(void)
UINT32 *pWork = (UINT32 *)DDR3_TEST_START_ADDRESS; //point to start of DDR3
UINT32 u32Tmp;
BOOL bError = FALSE;
printf ( "DDR3 memory test... Started. \n" );
while (pWork < (UINT32 *)DDR3_TEST_END_ADDRESS)
*pWork = u32Tmp = ~(*pWork);
if (u32Tmp != *pWork)
bError = TRUE;
break;
pWork += 0x1;
if (bError == TRUE)
printf("DDR3 memory test... Failed. \n");
return -1;
printf ( "DDR3 memory test... Passed. \n" );
return 0;
INT32 DDR3_Init1_s32 (void)
INT32 i;
UINT32 TEMP;
printf("DDR3 Configuration... \n");
/*Unlock Boot Config*/
CSL_BootCfgUnlockKicker();
/* Wait for PLL to lock = min 500 ref clock cycles.
With refclk = 100MHz, = 5000 ns = 5us */
/////////for(i=0; i< 1000; i++)
for(i=0; i< 1250; i++) // ADD test_w
asm(" nop 5");
/***************** 3.2 DDR3 PLL Configuration ************/
/* Done before */
/**************** 3.0 Leveling Register Configuration ********************/
/* Using partial automatic leveling due to errata */
/**************** 3.3 Leveling register configuration ********************/
boot_cfg_regs->DDR3_CONFIG_REG[0] &= ~(0x007FE000U); // clear ctrl_slave_ratio field
boot_cfg_regs->DDR3_CONFIG_REG[0] |= 0x00200000U; // set ctrl_slave_ratio to 0x100
boot_cfg_regs->DDR3_CONFIG_REG[12] |= 0x08000000U; // Set invert_clkout = 1
boot_cfg_regs->DDR3_CONFIG_REG[0] |= 0xFU; // set dll_lock_diff to 15
//From 4.2.1 Executing Partial Automatic Leveling -- Start
boot_cfg_regs->DDR3_CONFIG_REG[52] |= 0x00000200U; //Set bit 9 = 1 to use forced ratio leveling for read DQS
boot_cfg_regs->DDR3_CONFIG_REG[53] |= 0x00000200U;
boot_cfg_regs->DDR3_CONFIG_REG[54] |= 0x00000200U;
boot_cfg_regs->DDR3_CONFIG_REG[55] |= 0x00000200U;
boot_cfg_regs->DDR3_CONFIG_REG[60] |= 0x00000200U;
//From 4.2.1 Executing Partial Automatic Leveling -- End
//Values with invertclkout = 1
/**************** 3.3 Partial Automatic Leveling ********************/
/*WRLVL_INIT_RATIO*/
boot_cfg_regs->DDR3_CONFIG_REG[2] = 0x5DU;
boot_cfg_regs->DDR3_CONFIG_REG[3] = 0x5CU;
boot_cfg_regs->DDR3_CONFIG_REG[4] = 0x51U;
boot_cfg_regs->DDR3_CONFIG_REG[5] = 0x48U;
boot_cfg_regs->DDR3_CONFIG_REG[8] = 0x00U;
/*GTLVL_INIT_RATIO*/
boot_cfg_regs->DDR3_CONFIG_REG[14] = 0xADU;
boot_cfg_regs->DDR3_CONFIG_REG[15] = 0xAEU;
boot_cfg_regs->DDR3_CONFIG_REG[16] = 0x93U;
boot_cfg_regs->DDR3_CONFIG_REG[17] = 0x9DU;
boot_cfg_regs->DDR3_CONFIG_REG[22] = 0x00U;
//Do a PHY reset. Toggle DDR_PHY_CTRL_1 bit 15 0->1->0
DDR_Regs->DDR_PHY_CTRL_1 &= ~(0x00008000U);
DDR_Regs->DDR_PHY_CTRL_1 |= (0x00008000U);
/***************** 3.4 Basic Controller and DRAM Configuration ************/
DDR_Regs->SDRAM_REF_CTRL = 0x00005161U; // enable configuration
/* SDRAM_TIM_1 */
TEMP = 0U;
TEMP |= 0x08U << 25; // T_RP bit field 28:25
TEMP |= 0x08U << 21; // T_RCD bit field 24:21
TEMP |= 0x09U << 17; // T_WR bit field 20:17
TEMP |= 0x17U << 12; // T_RAS bit field 16:12
TEMP |= 0x20U << 6; // T_RC bit field 11:6
TEMP |= 0x7U << 3; // T_RRD bit field 5:3
TEMP |= 0x4U; // T_WTR bit field 2:0
DDR_Regs->SDRAM_TIM_1 = TEMP;
/* SDRAM_TIM_2 */
TEMP = 0U;
TEMP |= 0x3U << 28; // T_XP bit field 30:28
TEMP |= 0x71U << 16; // T_XSNR bit field 24:16
TEMP |= 0x1ffU << 6; // T_XSRD bit field 15:6
TEMP |= 0x4U << 3; // T_RTP bit field 5:3
TEMP |= 0x3U; // T_CKE bit field 2:0
DDR_Regs->SDRAM_TIM_2 = TEMP;
/* SDRAM_TIM_3 */
TEMP = 0U;
TEMP |= 0x5U << 28; // T_PDLL_UL bit field 31:28 (fixed value)
TEMP |= 0x5U << 24; // T_CSTA bit field 27:24 (fixed value)
TEMP |= 0x4U << 21; // T_CKESR bit field 23:21
TEMP |= 0x3fU << 15; // T_ZQCS bit field 20:15
TEMP |= 0x6AU << 4; // T_RFC bit field 12:4
TEMP |= 0xfU; // T_RAS_MAX bit field 3:0 (fixed value)
DDR_Regs->SDRAM_TIM_3 = TEMP;
DDR_Regs->DDR_PHY_CTRL_1 = 0x0010010FU;
DDR_Regs->ZQ_CONFIG = 0x70073214U;
DDR_Regs->PWR_MGMT_CTRL = 0x0U;
/* DDR_SDCFG */
/* New value with DYN_ODT disabled and SDRAM_DRIVE = RZQ/7 //0x63222A32; // last config write DRAM init occurs */
TEMP = 0U;
TEMP |= 0x3U << 29; // SDRAM_TYPE bit field 31:29 (fixed value)
TEMP |= 0x0U << 27; // IBANK_POS bit field 28:27
TEMP |= 0x3U << 24; // DDR_TERM bit field 26:24
TEMP |= 0x0U << 21; // DYN_ODT bit field 22:21
TEMP |= 0x0U << 18; // SDRAM_DRIVE bit field 19:18
TEMP |= 0x2U << 16; // CWL bit field 17:16
TEMP |= 0x1U << 14; // NM bit field 15:14
TEMP |= 0xAU << 10; // CL bit field 13:10
TEMP |= 0x5U << 7; // ROWSIZE bit field 9:7
TEMP |= 0x3U << 4; // IBANK bit field 6:4
TEMP |= 0x0U << 3; // EBANK bit field 3:3
TEMP |= 0x2U; // PAGESIZE bit field 2:0
DDR_Regs->SDRAM_CONFIG = TEMP;
//Wait 600us for HW init to complete
//for(i=0; i< 600*200; i++)
for(i=0; i< 750*200; i++) // ADD test_w
asm(" nop 5");
DDR_Regs->SDRAM_REF_CTRL = 0x00001458U; //Refresh rate = (7.8*666MHz)
/**************** 4.2.1 Executing Partial Automatic Leveling ********************/
DDR_Regs->RDWR_LVL_RMP_CTRL = 0x80000000U; //enable full leveling
DDR_Regs->RDWR_LVL_CTRL = 0x80000000U; //Trigger full leveling - This ignores read DQS leveling result and uses ratio forced value
//(0x34) instead
//Wait for min 1048576 DDR clock cycles for leveling to complete = 1048576 * 1.5ns = 1572864ns = 1.57ms.
//Actual time = ~10-15 ms
//for(i=0; i<15*200000; i++)
for(i=0; i<15*250000; i++) // ADD test_w
asm(" nop 5");
i=0;
while ((DDR_Regs->STATUS & 0x00000070U) && (i<0xf)) {
i++;
asm(" nop 5");
///if (i>3000000){ break; }
if (i>3,750,000){ break; } // ADD test_w
// Lock the kicker mechanism
CSL_BootCfgLockKicker();
//if (i>3000000)
if (i>3,750,000) // ADD test_w
printf("write leveling is failed! \n");
return -1;
printf("DDR3 configuration is done! \n");
return 0;
Hidehiko
