Part Number: TDA4VM
Hi TI expert;
TDAAvM device
VPAC module support RAW10 image process On <VHWA_Overview.pdf>;When I process Raw10 image, error occurred;
Logs As Flow:
[MCU2_0] 5169.146715 s: VX_ZONE_ERROR:[tivxVpacVissCreate:599] Failed to set Params in driver
My config parameters as flow:
obj->raw_params.width = 1920;
obj->raw_params.height = 1440;
obj->raw_params.num_exposures = 1;
obj->raw_params.line_interleaved = vx_false_e;
obj->raw_params.format[0].pixel_container = TIVX_RAW_IMAGE_16_BIT;
obj->raw_params.format[0].msb = 9;
obj->raw_params.format[1].pixel_container = TIVX_RAW_IMAGE_8_BIT;
obj->raw_params.format[1].msb = 7;
obj->raw_params.format[2].pixel_container = TIVX_RAW_IMAGE_P12_BIT;
obj->raw_params.format[2].msb = 11;
obj->raw_params.meta_height_before = 0;
obj->raw_params.meta_height_after = 0;
Do you some advise for me ?
I searched likely problems On E2E, I found that RAWFE can convert RAW10 to RAW12 By shift 2.
Where Can I get this demo code ?
