DRA821U: [CCS debug] how to pause OS timer when break debug, and resume OS timer when continue debug?
Part Number: DRA821U
Other Parts Discussed in Thread: DRA821
Dear Ti expert,
When we debug the code on the R5F core , the OS would work abnormally once we break the debug. We thought that would caused by the OS timer which wouldn't pause at the time we break the debug.
We have  tried the command below using Lauterbach debugger and it could suspend the timer successfully when we break the debug.
    Data.Set AXI:0x4C:0x3D300168 %LE %Long (0x10000|17.)
But the CCS debuger doesn't support the command line. So we want to know that if there is any method could replace the command when debuging with the CCS debuger.
And we also want know if you could please provide some technical reference about the hardware's debug suspend router that your expert mentioned on the below URL? Because I couldn't found any information about it on the J7200 DRA821 technical reference manual.
DRA821U: [Lauterbach debug] how to pause OS timer when break debug, and resume OS timer when continue debug? - Processors forum - Processors - TI E2E support forums
Best Regards
JiGuo
