Part Number: TDA4VM
hi,
I want to use SPL/Uboot(Linux Bootloader) to boot our program of mcu2_1 from SD card.
We have unlinked the J7-main-r5f0_1-fw in the rootfs/lib/firmware folder.
Then, we link our program to J7-main-r5f0_1-fw like the following figure.
We found that our program seems to be successfully started(like the following figure)from log, but we can not see any Can messages through Canoe.
I uploaded the information printed by the serial port, please help me analyze what went wrong when using SPL to start the program.
U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 23:32:00 +0000)
Model: Texas Instruments K3 J721E SoC
Board: J721EX-PM2-SOM rev E8
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.5(release):08.00.00.004-dirty
NOTICE: BL31: Built : 22:30:09, Aug 4 2021
U-Boot SPL 2021.01-g53e79d0e89 (Aug 04 2021 - 22:33:28 +0000)
Detected: J7X-BASE-CPB rev E3
Detected: J7X-GESI-EXP rev E3
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2021.01-g53e79d0e89 (Aug 04 2021 - 22:33:28 +0000)
SoC: J721E SR2.0
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: am65_cpsw_nuss_slave ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
eth0: ethernet@46000000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
39 bytes read in 7 ms (4.9 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 798 ms (22.9 MiB/s)
97586 bytes read in 13 ms (7.2 MiB/s)
Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.41-g4c2eade9f7 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Aug 4 22:47:28 UTC 2021
[ 0.000000] Machine model: Texas Instruments K3 J721E SoC
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a8ffffff]
[ 0.000000] node 0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[ 0.000000] node 0: [mem 0x00000000aa000000-0x00000000abbfffff]
[ 0.000000] node 0: [mem 0x00000000abc00000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57344k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=cf7296cb-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[ 0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008800b0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008361] Console: colour dummy device 80x25
[ 0.012922] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023593] pid_max: default: 32768 minimum: 301
[ 0.028339] LSM: Security Framework initializing
[ 0.033082] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.040647] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[ 0.049590] rcu: Hierarchical SRCU implementation.
[ 0.054640] Platform MSI: msi-controller@1820000 domain created
[ 0.060878] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.070173] EFI services will not be available.
[ 0.074918] smp: Bringing up secondary CPUs ...
[ 0.080099] Detected PIPT I-cache on CPU1
[ 0.080124] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.080135] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[ 0.080167] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.080217] smp: Brought up 1 node, 2 CPUs
[ 0.109562] SMP: Total of 2 processors activated.
[ 0.114367] CPU features: detected: 32-bit EL0 Support
[ 0.119621] CPU features: detected: CRC32 instructions
[ 0.133491] CPU: All CPU(s) started at EL2
[ 0.137686] alternatives: patching kernel code
[ 0.142668] devtmpfs: initialized
[ 0.150881] KASLR disabled due to lack of seed
[ 0.155533] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.165495] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[ 0.173126] pinctrl core: initialized pinctrl subsystem
[ 0.178699] DMI not present or invalid.
[ 0.182929] NET: Registered protocol family 16
[ 0.190431] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.197731] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.205733] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.214035] thermal_sys: Registered thermal governor 'step_wise'
[ 0.214037] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.220451] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.234092] ASID allocator initialised with 65536 entries
[ 0.256154] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[ 0.263008] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[ 0.269769] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.277665] cryptd: max_cpu_qlen set to 1000
[ 0.283654] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.292481] vsys_3v3: supplied by evm_12v0
[ 0.296791] vsys_5v0: supplied by evm_12v0
[ 0.301407] iommu: Default domain type: Translated
[ 0.306585] SCSI subsystem initialized
[ 0.310703] mc: Linux media interface: v0.10
[ 0.315074] videodev: Linux video capture interface: v2.00
[ 0.320702] pps_core: LinuxPPS API ver. 1 registered
[ 0.325772] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.335108] PTP clock support registered
[ 0.339127] EDAC MC: Ver: 3.0.0
[ 0.342858] FPGA manager framework
[ 0.346368] Advanced Linux Sound Architecture Driver Initialized.
[ 0.352969] clocksource: Switched to clocksource arch_sys_counter
[ 0.359379] VFS: Disk quotas dquot_6.6.0
[ 0.363427] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[ 0.373121] NET: Registered protocol family 2
[ 0.377706] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[ 0.386301] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[ 0.395081] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[ 0.403274] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[ 0.411070] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.417818] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.424710] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[ 0.432104] NET: Registered protocol family 1
[ 0.436787] RPC: Registered named UNIX socket transport module.
[ 0.442847] RPC: Registered udp transport module.
[ 0.447651] RPC: Registered tcp transport module.
[ 0.452454] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.459038] PCI: CLS 0 bytes, default 64
[ 0.463404] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.473621] Initialise system trusted keyrings
[ 0.478235] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[ 0.486441] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.492658] NFS: Registering the id_resolver key type
[ 0.497879] Key type id_resolver registered
[ 0.502152] Key type id_legacy registered
[ 0.506271] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.513120] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.520756] 9p: Installing v9fs 9p2000 file system support
[ 0.545852] Key type asymmetric registered
[ 0.550038] Asymmetric key parser 'x509' registered
[ 0.555035] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.562594] io scheduler mq-deadline registered
[ 0.567219] io scheduler kyber registered
[ 0.572469] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.578644] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.587059] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.593326] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.601139] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.609243] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.618200] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[ 0.627030] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[ 0.634745] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.647550] brd: module loaded
[ 0.653455] loop: module loaded
[ 0.657262] megasas: 07.714.04.00-rc1
[ 0.662158] libphy: Fixed MDIO Bus: probed
[ 0.666816] tun: Universal TUN/TAP device driver, 1.6
[ 0.672226] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.678631] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.684701] sky2: driver version 1.30
[ 0.688941] VFIO - User Level meta-driver version: 0.3
[ 0.694597] i2c /dev entries driver
[ 0.698776] sdhci: Secure Digital Host Controller Interface driver
[ 0.705091] sdhci: Copyright(c) Pierre Ossman
[ 0.709777] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.716108] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.722418] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.729537] optee: probing for conduit method.
[ 0.734096] optee: revision 3.12 (3d47a131)
[ 0.734329] optee: initialized driver
[ 0.743631] NET: Registered protocol family 17
[ 0.748243] 9pnet: Installing 9P2000 support
[ 0.752628] Key type dns_resolver registered
[ 0.757070] Loading compiled-in X.509 certificates
[ 0.766333] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[ 0.772661] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[ 0.780784] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[ 0.807424] random: fast init done
[ 0.833212] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 0.840688] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.846750] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.852789] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[ 0.859221] pca953x 3-0020: supply vcc not found, using dummy regulator
[ 0.866052] pca953x 3-0020: using no AI
[ 0.893756] pca953x 3-0022: supply vcc not found, using dummy regulator
[ 0.900554] pca953x 3-0022: using AI
[ 0.904818] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high
[ 0.910793] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low
[ 0.917035] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high
[ 0.923519] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.929968] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.940114] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.946406] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 0.953224] pca953x 6-0020: using no AI
[ 0.981651] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.987690] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[ 0.993632] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[ 0.999880] pca953x 9-0020: supply vcc not found, using dummy regulator
[ 1.006691] pca953x 9-0020: using no AI
[ 1.033586] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[ 1.039980] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 1.049944] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 1.058740] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 1.068562] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 1.088289] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[ 1.095980] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[ 1.103646] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000
[ 1.111922] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[ 1.120199] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 2.121133] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[ 2.127554] pci_bus 0000:00: root bus resource [bus 00-0f]
[ 2.133160] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[ 2.142850] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[ 2.149900] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.156039] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.165909] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.175798] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits
[ 2.185759] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.195728] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits
[ 2.205688] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits
[ 2.215672] pci 0000:00:00.0: supports D1
[ 2.219765] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.225637] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits
[ 2.237264] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.245450] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.255409] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.265367] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits
[ 2.276808] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[ 2.283577] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.288850] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 2.295170] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 2.302841] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000
[ 2.311120] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000
[ 2.319396] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 3.329538] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[ 3.335947] pci_bus 0001:00: root bus resource [bus 00-0f]
[ 3.341553] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[ 3.351420] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 3.358464] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
[ 3.364663] pci 0001:00:00.0: supports D1
[ 3.368757] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[ 3.376233] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.385907] pci_bus 0001:01: busn_res: [bus 01-0f] end is updated to 01
[ 3.392674] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.397928] pcieport 0001:00:00.0: PME: Signaling with IRQ 59
[ 3.404218] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[ 3.411886] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000
[ 3.420163] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[ 3.428439] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[ 4.436978] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00
[ 4.443384] pci_bus 0002:00: root bus resource [bus 00-0f]
[ 4.448988] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff])
[ 4.458238] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff])
[ 4.469013] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400
[ 4.475211] pci 0002:00:00.0: supports D1
[ 4.479305] pci 0002:00:00.0: PME# supported from D0 D1 D3hot
[ 4.486767] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.496435] pci_bus 0002:01: busn_res: [bus 01-0f] end is updated to 01
[ 4.503202] pci 0002:00:00.0: PCI bridge to [bus 01]
[ 4.508457] pcieport 0002:00:00.0: PME: Signaling with IRQ 62
[ 4.515143] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 4.525026] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 4.531786] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.540675] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 4.550828] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 4.557587] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 4.565526] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 4.574889] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[ 4.583635] printk: console [ttyS2] enabled
[ 4.592074] printk: bootconsole [ns16550a0] disabled
[ 4.602507] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[ 4.611432] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[ 4.621797] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.632310] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[ 4.642465] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[ 4.652706] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[ 4.663468] scsi host0: ufshcd
[ 4.685204] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
[ 4.708974] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 4.716624] libphy: 46000f00.mdio: probed
[ 4.721965] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 4.730277] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 4.744173] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 4.753029] mmc0: CQHCI version 5.10
[ 4.753324] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 4.764333] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
[ 4.768229] vdd_mmc1: supplied by vsys_3v3
[ 4.780076] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0
[ 4.780692] pca953x 4-0020: supply vcc not found, using dummy regulator
[ 4.797851] pca953x 4-0020: using no AI
[ 4.801720] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.810494] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
[ 4.819178] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
[ 4.820981] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 4.834981] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 4.841822] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 4.848669] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 4.855482] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 4.862325] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 4.872344] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 4.882346] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[ 4.895502] spi-nor spi0.0: mt35xu512aba (65536 Kbytes)
[ 4.900746] mtd: 47040000.spi.0: partitioning exceeds flash size, truncating
[ 4.907799] mtd: 47040000.spi.0: skipping zero sized partition
[ 4.913702] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[ 4.920319] Creating 7 MTD partitions on "47040000.spi.0":
[ 4.925799] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 4.931811] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 4.937495] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 4.943292] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 4.948788] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw"
[ 4.954517] 0x0000007c0000-0x000000800000 : "ospi.env.backup"
[ 4.960610] 0x000000800000-0x000004000000 : "ospi.rootfs"
[ 4.968618] spi-nor spi1.0: mt25qu512a (65536 Kbytes)
[ 4.989940] mmc0: Command Queue Engine enabled
[ 4.994384] mmc0: new HS400 MMC card at address 0001
[ 4.999602] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 5.004229] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[ 5.010240] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[ 5.016160] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 5.023842] libphy: 46000f00.mdio: probed
[ 5.027869] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[ 5.036528] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 5.045284] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 5.058929] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 5.065878] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 5.073086] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 5.079351] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 5.089574] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[ 5.095616] mmc1: CQHCI version 5.10
[ 5.107283] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 5.114636] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 5.121976] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 5.129337] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 5.137401] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.153523] ALSA device list:
[ 5.156483] No soundcards found.
[ 6.157887] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 6.166030] Waiting for root device PARTUUID=cf7296cb-02...
[ 6.223132] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[ 6.229962] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[ 6.239763] mmcblk1: p1 p2
[ 6.582522] EXT4-fs (mmcblk1p2): recovery complete
[ 6.588318] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.596424] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 6.608607] devtmpfs: mounted
[ 6.611878] Freeing unused kernel memory: 1856K
[ 6.616474] Run /sbin/init as init process
[ 6.772415] systemd[1]: System time before build time, advancing clock.
[ 6.831431] NET: Registered protocol family 10
[ 6.836329] Segment Routing with IPv6
[ 6.854501] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 6.876223] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[ 6.911666] systemd[1]: Set hostname to <j7-evm>.
[ 7.104386] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[ 7.173810] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.180541] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 7.192866] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 7.202728] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 7.225042] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.232261] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 7.253032] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.260151] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 7.281140] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ 7.305075] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ 7.329065] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 7.345025] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 7.365015] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 7.381017] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 7.404490] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 7.425048] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 7.449102] systemd[1]: Listening on Process Core Dump Socket.
[ OK ] Listening on Process Core Dump Socket.
[ 7.469145] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 7.503397] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 7.511744] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.533248] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.549297] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 7.573197] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 7.593130] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.615815] systemd[1]: Mounting Huge Pages File System...
[ 7.635272] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.659387] systemd[1]: Mounting Kernel Debug File System...
[ 7.682147] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 7.699706] systemd[1]: Starting Create list of static device nodes for the current kernel...
Starting Create list of st…odes for the current kernel...
[ 7.727646] systemd[1]: Starting Start psplash boot splash screen...
[ 7.752755] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ 7.775294] systemd[1]: Starting RPC Bind...
[ 7.789166] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.817411] systemd[1]: Starting Journal Service...
[ 7.836718] systemd[1]: Starting Load Kernel Modules...
[ 7.859283] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.867593] cryptodev: loading out-of-tree module taints kernel.
[ 7.890898] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[ 7.891427] systemd[1]: Starting udev Coldplug all Devices...
[ 7.913705] cryptodev: driver 1.10 loaded.
[ 7.920639] systemd[1]: Started RPC Bind.
[ OK ] Started RPC Bind.
[ 7.942058] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of sta… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Mounting Kernel Configuration File System...
Starting Flush Journal to Persistent Storage...
[ 8.150018] systemd-journald[170]: Received client request to flush runtime journal.
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /media/ram.
[ OK ] Mounted /var/volatile.
[ OK ] Started udev Coldplug all Devices.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started udev Kernel Device Manager.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Docker Socket for the API.
[ OK ] Listening on dropbear.socket.
Starting Reboot and dump vmcore via kexec...
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Job spooling tools.
[ OK ] Started Periodic Command Scheduler.
[ OK ] Started D-Bus System Message Bus.
Starting Print notice about GPLv3 packages...
Starting IPv6 Packet Filtering Framework...
Starting IPv4 Packet Filtering Framework...
[ OK ] Started irqbalance daemon.
Starting Telephony service...
Starting rc.pvr.service...
Starting Login Service...
[ OK ] Started Reboot and dump vmcore via kexec.
[ OK ] Started IPv6 Packet Filtering Framework.
[ OK ] Started IPv4 Packet Filtering Framework.
[ OK ] Reached target Network (Pre).
Starting Network Service...
[ 9.069246] ina2xx 5-0040: power monitor ina226 (Rshunt = 10000 uOhm)
[ 9.150604] PVR_K: 257: Read BVNC 22.104.208.318 from HW device registers
[ 9.160719] PVR_K: 257: RGX Device registered with BVNC 22.104.208.318
[ 9.171460] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[ OK ] Started Telephony service.
[ OK ] Started Network Service.
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ 9.258501] Bluetooth: Core ver 2.22
[ 9.264279] NET: Registered protocol family 31
[ 9.272240] Bluetooth: HCI device and connection manager initialized
[ OK ] Started Login Service.
[ 9.284319] Bluetooth: HCI socket layer initialized
[ 9.295437] Bluetooth: L2CAP socket layer initialized
[ 9.302635] ina2xx 5-0041: power monitor ina226 (Rshunt = 10000 uOhm)
[ 9.309106] Bluetooth: SCO socket layer initialized
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Network.
[ OK ] Reached target Host and Network Name Lookups.
Starting Avahi mDNS/DNS-SD Stack...
Starting Enable and configure wl18xx bluetooth stack...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Reached target Login Prompts.
Starting Synchronize System and HW clocks...
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 9.610619] ina2xx 5-0042: power monitor ina226 (Rshunt = 10000 uOhm)
[ 9.690032] ov5640 9-003c: supply DOVDD not found, using dummy regulator
[ 9.751363] ina2xx 5-0043: power monitor ina226 (Rshunt = 10000 uOhm)
[ 9.778502] ov5640 9-003c: supply AVDD not found, using dummy regulator
[ 9.827424] ina2xx 5-0044: power monitor ina226 (Rshunt = 10000 uOhm)
[ 9.855271] ov5640 9-003c: supply DVDD not found, using dummy regulator
[ 9.918674] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 10.014702] ina2xx 5-0046: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.032007] ov5640 9-003c: ov5640_read_reg: error: reg=300a
[ 10.075105] ov5640 9-003c: ov5640_check_chip_id: failed to read chip identifier
[ 10.152775] ina2xx 5-0047: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.178543] ov5640: probe of 9-003c failed with error -121
[ 10.213008] random: crng init done
[ 10.216404] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.242527] ina2xx 5-0048: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.265170] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[ 10.269920] ina2xx 5-0049: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.289303] ina2xx 5-004a: power monitor ina226 (Rshunt = 10000 uOhm)
[ OK ] Started Load/Save Random Seed.
[ 10.360331] ina2xx 5-004b: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.388959] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[ 10.411735] ina2xx 5-004c: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.441099] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[ 10.466549] ina2xx 5-004d: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.487705] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[ 10.541110] ina2xx 5-004e: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.550956] remoteproc remoteproc0: 4d80800000.dsp is available
[ 10.573551] ina2xx 5-004f: power monitor ina226 (Rshunt = 10000 uOhm)
[ 10.588581] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[ 10.606169] remoteproc remoteproc0: powering up 4d80800000.dsp
[ 10.612071] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 187480
[ 10.624408] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
[ 10.637119] remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[ OK ] Started Simple Network Man…ement [ 10.649313] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 10.654408] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[ 10.656949] remoteproc0#vdev0buffer: registered virtio0 (type 7)
[ 10.670293] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[ 10.685110] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[ 10.818774] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[ 11.124995] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 11.145856] CAN device driver interface
[ 11.211517] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[ 11.335297] remoteproc remoteproc1: 4d81800000.dsp is available
[ 11.341278] platform 41000000.r5f: configured R5F for IPC-only mode
[ 11.348265] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[ 11.350725] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[ 11.355505] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
NOTICE: This file system contains the following GPLv3 packages:
autoconf
bash-dev
bash
bc
binutils
cifs-utils
coreutils-stdbuf
coreutils
cpio
cpp-symlinks
cpp
dosfsto[ 11.509284] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
ols
elfutils
g++-symlinks
g++
gawk
gcc-symlinks
[ 11.519185] remoteproc remoteproc1: powering up 4d81800000.dsp
gdb
gdbserver
gettext
glmark2
gstreamer1.0-libav-dev
gstreamer1.0-libav
gzip
less
libasm1
libbfd
libdw1
[ 11.537022] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 187480
libelf1
libgdbm-compat4
libgdbm-dev
libgdbm6
libgettextlib
libgettextsrc
libgmp-dev
libgmp10
libgmpxx4
libidn2[ 11.554379] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
-0
libidn2-dev
libmpc3
libmpfr6
libreadline-dev
libreadline8
libunistring-dev
libunistring2
m4-dev
m4
make
[ 11.577385] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
nettle-dev
nettle
parted
python3-rfc3987
python3-strict[ 11.577573] remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
-rfc3339
tar
which
zeromq
If you do not wish to distribute GPLv3 components please remove
the above packages prior to [ 11.605349] virtio_rpmsg_bus virtio1: rpmsg host is online
distribution. This can be done using
the opkg remove command. [ 11.621016] remoteproc1#vdev0buffer: registered virtio1 (type 7)
i.e.:
opkg remove <package>
Where <package> is the name p[ 11.627656] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
rinted in the list above
NOTE: If the package is a dependency[ 11.645044] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
of another package you
will be notified of the dependent[ 11.657079] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ 11.798778] remoteproc remoteproc3: 64800000.dsp is available
[ 11.801631] remoteproc remoteproc2: 41000000.r5f is available
[ 11.919767] remoteproc remoteproc2: attaching to 41000000.r5f
[ 12.022145] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 12.073974] remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[ 12.098375] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 12.112874] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[ 12.125495] remoteproc2#vdev0buffer: registered virtio2 (type 7)
[ 12.224447] remoteproc remoteproc3: powering up 64800000.dsp
[ 12.230134] remoteproc remoteproc3: Booting fw image j7-c71_0-fw, size 10489872
[ 12.245055] remoteproc remoteproc3: unsupported resource 65538
[ 12.254007] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
[ 12.269743] remoteproc3#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[ 12.283376] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 12.293096] remoteproc3#vdev0buffer: registered virtio3 (type 7)
[ 12.294447] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[ 12.304979] remoteproc remoteproc3: remote processor 64800000.dsp is now up
[ 12.309052] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[ 12.329750] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
[ 12.335666] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ 12.487691] platform 5c00000.r5f: configured R5F for remoteproc mode
[ 12.503010] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[ 12.523381] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[ 12.559865] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[ 12.678420] remoteproc remoteproc4: 5c00000.r5f is available
[ 12.769012] platform 5d00000.r5f: configured R5F for remoteproc mode
[ 12.778367] remoteproc remoteproc4: powering up 5c00000.r5f
[ 12.783971] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 527528
[ 12.802510] remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[ 12.814960] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 12.820574] remoteproc4#vdev0buffer: registered virtio4 (type 7)
[ 12.832988] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[ 12.858433] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[ 12.876815] remoteproc remoteproc5: 5d00000.r5f is available
[ 12.898332] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 12.932328] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[ 12.969665] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[ 12.983789] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[ 13.071806] remoteproc remoteproc5: powering up 5d00000.r5f
[ 13.077457] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 7870940
[ 13.151380] remoteproc remoteproc6: 5e00000.r5f is available
[ 13.243641] remoteproc remoteproc6: powering up 5e00000.r5f
[ 13.249258] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 78708
[ 13.266240] remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[ 13.274914] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 13.284400] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[ 13.289025] remoteproc6#vdev0buffer: registered virtio5 (type 7)
[ 13.297045] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
[ 13.297957] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[ 13.321348] platform 5f00000.r5f: configured R5F for remoteproc mode
[ 13.375619] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[ 13.542178] remoteproc remoteproc7: 5f00000.r5f is available
[ 13.666326] remoteproc remoteproc7: powering up 5f00000.r5f
[ 13.671996] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 78708
[ 13.687984] remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[ 13.701335] virtio_rpmsg_bus virtio6: rpmsg host is online
[ 13.706863] remoteproc7#vdev0buffer: registered virtio6 (type 7)
[ 13.716462] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[ 13.717037] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[ 13.727920] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[ 13.805857] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
[ 13.848697] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
[ 13.856143] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 2
[ 13.873024] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1) 13/Jul/2021 SHA:4cb38131
[ 13.957264] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[ 13.969005] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00
[ 13.985036] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ 14.777378] usbcore: registered new interface driver usbfs
[ 14.789064] usbcore: registered new interface driver hub
[ 14.800082] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[ 14.801066] usbcore: registered new device driver usb
[ 14.897101] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[ 14.905029] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 14.978310] remoteproc remoteproc8: b034000.pru is available
[ 15.063519] remoteproc remoteproc9: b004000.rtu is available
[ 15.241434] remoteproc remoteproc10: b00a000.txpru is available
[ 15.340245] remoteproc remoteproc11: b038000.pru is available
[ 15.354865] PVR_K: 1002: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[ 15.429546] remoteproc remoteproc12: b006000.rtu is available
[ 15.500523] remoteproc remoteproc13: b00c000.txpru is available
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [ 15.569936] remoteproc remoteproc14: b134000.pru is available
[ 15.685768] remoteproc remoteproc15: b104000.rtu is available
[ 15.771375] remoteproc remoteproc16: b10a000.txpru is available
[ 15.873374] remoteproc remoteproc17: b138000.pru is available
[ 15.967535] remoteproc remoteproc18: b106000.rtu is available
[ 16.000580] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 16.005273] remoteproc remoteproc19: b10c000.txpru is available
[ 16.033033] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 16.145972] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[ 16.212177] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 16.225052] xhci-hcd xhci-hcd.2.auto: irq 620, io mem 0x06410000
[ 16.248454] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 16.335494] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 16.386104] usb usb1: Product: xHCI Host Controller
[ 16.413169] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[ 16.469218] usb usb1: SerialNumber: xhci-hcd.2.auto
[ 16.496549] hub 1-0:1.0: USB hub found
[ 16.512999] hub 1-0:1.0: 1 port detected
[ 16.517144] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 16.528991] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 16.544984] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 16.556986] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 16.573013] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 16.584970] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 16.592250] usb usb2: Product: xHCI Host Controller
[ 16.597208] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[ 16.608972] usb usb2: SerialNumber: xhci-hcd.2.auto
[ 16.617150] hub 2-0:1.0: USB hub found
[ 16.620916] hub 2-0:1.0: 1 port detected
[ 16.856984] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 17.013246] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 17.024969] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 17.036975] usb 1-1: SerialNumber: B3020861CDF1
[ 17.042009] hub 1-1:1.0: USB hub found
[ 17.049022] hub 1-1:1.0: 4 ports detected
Thank you very much!
