SK-TDA4VM: EdgeAI Apps can't run sample OD networks by compiled using Edge TIDL Tools
Part Number: SK-TDA4VM
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1086904/sk-tda4vm-i-can-t-compile-any-sample-model-on-edgeai-tidl-tools
I had model compile issue like above link , now I compiled sample models using EdgeAI TIDL Tools.
and copy the compiled models to SK-TDA4VM's model zoo directory like below:
od-ort-ssd-lite_mobilenetv2_fpn
├── param.yaml
├── artifacts
│   ├── allowedNode.txt
│   ├── boxeslabels_tidl_io_1.bin
│   ├── boxeslabels_tidl_net.bin
│   ├── boxeslabels_tidl_net.bin.layer_info.txt
│   ├── boxeslabels_tidl_net.bin.svg
│   ├── boxeslabels_tidl_net.bin_netLog.txt
│   ├── onnxrtMetaData.txt
│   └── runtimes_visualization.svg
└── model
    ├── ssd-lite_mobilenetv2_fpn.onnx
    └── ssd-lite_mobilenetv2_fpn.prototxt
After copied model files, I tested CL/SS/OD models using CPP based EdgeAI Apps.
The CL/SS networks are works. but OD networks are not working.
(OD networks is work using EdgeAI TIDL Tools on PC)
Log when running OD network on CPP-based EdgeAI Apps.
root@j7-evm:/opt/edge_ai_apps/apps_cpp# ./bin/Release/app_edgeai ../configs/object_detection.yaml
 Number of subgraphs:1 , 107 nodes delegated out of 107 nodes
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=5) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
   664.341727 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
   664.341809 s:  VX_ZONE_INIT:Enabled
   664.341815 s:  VX_ZONE_ERROR:Enabled
   664.341820 s:  VX_ZONE_WARNING:Enabled
   664.342515 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
   664.342834 s:  VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
[01:49:16.000.000439]:DEBUG:[OutputInfo:0438] CONSTRUCTOR
[01:49:16.000.000452]:DEBUG:[GstWrapperBuffer:0094] CONSTRUCTOR
[01:49:16.000.000472]:DEBUG:[OutputInfo:0438] CONSTRUCTOR
[01:49:16.000.000484]:DEBUG:[GstWrapperBuffer:0094] CONSTRUCTOR
[01:49:16.000.000504]:DEBUG:[OutputInfo:0438] CONSTRUCTOR
[01:49:16.000.000534]:DEBUG:[MosaicInfo:0649] CONSTRUCTOR
[01:49:16.000.000549]:DEBUG:[FlowInfo:1011] CONSTRUCTOR
libtidl_onnxrt_EP loaded 0x34d2a460
Final number of subgraphs created are : 1, - Offloaded Nodes - 494, Total Nodes - 494
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
IPC: Init ... !!!
   566.016988 s: GTC Frequency = 200 MHz
   566.017090 s:  VX_ZONE_INIT:Enabled
   566.017097 s:  VX_ZONE_ERROR:Enabled
   566.017103 s:  VX_ZONE_WARNING:Enabled
   566.017880 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
   566.018154 s:  VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
[01:49:31.15198.198457]:DEBUG:[DlTensor:0062] DEFAULT CONSTRUCTOR
[01:49:31.15198.198526]:DEBUG:[DlTensor:0080] COPY CONSTRUCTOR
[01:49:31.15198.198549]:DEBUG:[~DlTensor:0136] DESTRUCTOR
[01:49:31.15198.198577]:DEBUG:[DlTensor:0062] DEFAULT CONSTRUCTOR
[01:49:31.15198.198589]:DEBUG:[DlTensor:0080] COPY CONSTRUCTOR
[01:49:31.15198.198600]:DEBUG:[DlTensor:0080] COPY CONSTRUCTOR
[01:49:31.15198.198610]:DEBUG:[~DlTensor:0136] DESTRUCTOR
[01:49:31.15198.198628]:DEBUG:[ORTInferer:0158] CONSTRUCTOR
[01:49:31.15198.198890]:DEBUG:[DlTensor:0080] COPY CONSTRUCTOR
[01:49:31.15198.198915]:DEBUG:[DlTensor:0080] COPY CONSTRUCTOR
[01:49:31.15198.198927]:DEBUG:[DlTensor:0080] COPY CONSTRUCTOR
[01:49:31.15199.199143]:DEBUG:[InferencePipe:0107] CONSTRUCTOR
[01:49:31.15199.199168]:DEBUG:[SubFlowInfo:0913] CONSTRUCTOR
[01:49:31.15232.232934]:DEBUG:[GstPipe:0134] CONSTRUCTOR
[01:49:31.15232.232985]:INFO:[GstPipe:0136] SRC_CMDS:
[01:49:31.15232.232997]:INFO:[GstPipe:0139]  multifilesrc location=/opt/edge_ai_apps/data/images/%04d.jpg loop=1 index=0 stop-index=-1 caps=image/jpeg,framerate=1/1 ! jpegdec  ! videoscale ! video/x-raw, width=1280, height=720 ! tiovxcolorconvert ! video/x-raw, format=NV12 ! tiovxmultiscaler name=multiscaler_split_20 multiscaler_split_20. ! queue ! video/x-raw, width=1280, height=720 ! tiovxcolorconvert out-pool-size=4 target=1 ! video/x-raw, format=RGB ! appsink drop=true max-buffers=2 name=flow0_sensor0 multiscaler_split_20. ! queue ! video/x-raw, width=512, height=512 ! tiovxdlpreproc data-type=3 channel-order=0 mean-0=0.000000 mean-1=0.000000 mean-2=0.000000 scale-0=1.000000 scale-1=1.000000 scale-2=1.000000 tensor-format=rgb out-pool-size=4 ! application/x-tensor-tiovx ! appsink drop=true max-buffers=2 name=flow0_pre_proc0
[01:49:31.15233.233014]:INFO:[GstPipe:0141] SINK_CMD: appsrc format=GST_FORMAT_TIME is-live=true block=true do-timestamp=true name=flow0_post_proc0 ! tiovxcolorconvert ! video/x-raw,format=NV12 ! queue ! mosaic0.sink_0
appsrc format=GST_FORMAT_TIME block=true num-buffers=1 name=background0 ! tiovxcolorconvert ! video/x-raw,format=NV12 ! queue ! mosaic0.background
tiovxmosaic name=mosaic0
  sink_0::startx=320  sink_0::starty=180  sink_0::width=1280  sink_0::height=720
 ! video/x-raw, format=NV12, width=1920, height=1080 ! kmssink sync=false driver-name=tidss
[01:49:31.15319.319066]:DEBUG:[GstWrapperBuffer:0094] CONSTRUCTOR
[01:49:31.15319.319210]:DEBUG:[GstWrapperBuffer:0094] CONSTRUCTOR
[01:49:31.15319.319221]:INFO:[inferenceThread:0227] Starting inference thread.
MEM: ERROR: Alloc failed with status = 12 !!!
   665.294935 s:  VX_ZONE_ERROR:[tivxMemBufferAlloc:80] Shared mem ptr allocation failed
Segmentation fault (core dumped)
Is there additional work to run OD models?
I attached compiled OD models.
Download: https://drive.google.com/file/d/1-cuvAOlSoC0TaRyt8KKmNsWTP7hxzxGL/view?usp=sharing
And modified 'object_detection.yaml'
title: "Object Detection Demo"
log_level: 2
inputs:
    input0:
        source: /dev/video1
        format: jpeg
        width: 1280
        height: 720
        framerate: 30
    input1:
        source: /opt/edge_ai_apps/data/videos/video_0000_h264.mp4
        format: h264
        width: 1280
        height: 720
        framerate: 25
        loop: False
    input2:
        source: /opt/edge_ai_apps/data/images/%04d.jpg
        width: 1280
        height: 720
        index: 0
        framerate: 1
        loop: True
models:
    model0:
        model_path: /opt/model_zoo/TVM-OD-5020-yolov3-mobv1-gluon-mxnet-416x416
        viz_threshold: 0.6
    model1:
        model_path: /opt/model_zoo/TFL-OD-2020-ssdLite-mobDet-DSP-coco-320x320
        viz_threshold: 0.6
    model2:
        model_path: /opt/model_zoo/ONR-OD-8050-ssd-lite-regNetX-800mf-fpn-bgr-coco-512x512
        viz_threshold: 0.6
    model3:
        model_path: /opt/model_zoo/test/od-ort-ssd-lite_mobilenetv2_fpn
        viz_threshold: 0.3
    model4:
        model_path: /opt/model_zoo/test/od-tfl-ssd_mobilenet_v2_300_float
        viz_threshold: 0.3
outputs:
    output0:
        sink: kmssink
        width: 1920
        height: 1080
    output1:
        sink: /opt/edge_ai_apps/data/output/videos/output_video.mkv
        width: 1920
        height: 1080
    output2:
        sink: /opt/edge_ai_apps/data/output/images/output_image_%04d.jpg
        width: 1920
        height: 1080
flows:
    flow0:
        input: input2
        models: [model3]
        outputs: [output0]
        mosaic:
            mosaic0:
                width:  1280
                height: 720
                pos_x:  320
                pos_y:  180
Lee
  • Hi Lee,
    We will get this checked, did you try running the pyhon edge_ai_apps? Is it similar in behavior?
    Thanks for sharing the precompiled models as well. We mostly rely on a params.yaml file which informs the edge_ai_apps some information to setup the pipeline.
    This params.yaml file is kept in every model available in ModelZoo. Not sure if the import tool is generating these params.yaml file.
    Shyam
  • Hi, Shyam
    I checked python based EdgeAI Apps. The result was similar.
    In python based apps test, i modify model's params.yaml files. (If I didn't modify params.yaml, returns error)
    I added input_dataset, preprocess(reverse_channels) information that copied default sample model's param.yaml fiies.
    Here is ONNX OD model's running log.
    root@j7-evm:/opt/edge_ai_apps/apps_python# ./app_edgeai.py -n -v ../configs/object_detection.yaml
    libtidl_onnxrt_EP loaded 0x22976d30
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       196.995324 s: GTC Frequency = 200 MHz
       197.000692 s:  VX_ZONE_INIT:Enabled
       197.000721 s:  VX_ZONE_ERROR:Enabled
       197.000726 s:  VX_ZONE_WARNING:Enabled
       197.003385 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       197.005921 s:  VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
    [GST SRC STR]
    [FLOW 0]
    filesrc location=/opt/edge_ai_apps/data/videos/video_0000_h264.mp4 ! qtdemux ! h264parse ! v4l2h264dec ! video/x-raw, format=NV12  ! tiovxmultiscaler name=split_01
    split_01. ! queue ! video/x-raw, width=512, height=512 ! tiovxdlpreproc data-type=10 channel-order=0 mean-0=0.000000 mean-1=0.000000 mean-2=0.000000 scale-0=1.000000 scale-1=1.000000 scale-2=1.000000 tensor-format=bgr out-pool-size=4 ! application/x-tensor-tiovx ! appsink name=pre_0 max-buffers=2 drop=true
    split_01. ! queue ! video/x-raw, width=1280, height=720 ! tiovxcolorconvert target=1 out-pool-size=4 ! video/x-raw, format=RGB ! appsink name=sen_0 max-buffers=2 drop=true
    [GST SINK STR]
    appsrc format=GST_FORMAT_TIME is-live=true block=true do-timestamp=true name=post_0 ! tiovxcolorconvert ! video/x-raw,format=NV12, width=1280, height=720 ! queue ! mosaic_0.sink_0
    appsrc format=GST_FORMAT_TIME block=true num-buffers=1 name=background_0 ! tiovxcolorconvert ! video/x-raw,format=NV12, width=1920, height=1080 ! queue ! mosaic_0.background
    tiovxmosaic name=mosaic_0
    ! video/x-raw,format=NV12, width=1920, height=1080 ! kmssink sync=fals[  191.241171] unclassified data detected!
    e driver-name=tidss
    [  191.266497] unclassified data detected!
    Exception in thread Thread-1:
    Traceback (most recent call last):
      File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner
        self.run()
      File "/usr/lib/python3.8/threading.py", line 870, in run
        self._target(*self._args, **self._kwargs)
      File "/opt/edge_ai_apps/apps_python/infer_pipe.py", line 90, in pipeline
        result = self.run_time(input_img)
      File "/opt/edge_ai_apps/apps_python/run_times.py", line 119, in __call__
        return self.interpreter.run(None, {self.input_name:input_img})
      File "/usr/lib/python3.8/site-packages/onnxruntime/capi/onnxruntime_inference_collection.py", line 188, in run
        return self._sess.run(output_names, input_feed, run_options)
    onnxruntime.capi.onnxruntime_pybind11_state.InvalidArgument: [ONNXRuntimeError] : 2 : INVALID_ARGUMENT : Unexpected input data type. Actual: (tensor(float)) , expected: (tensor(uint8))
    Lee
  • Update this thread.
    I tried to anther way OD sample model compile using EdgeAI Benchmark.
    The model compile result using EdgeAI Benchmark are successful.
    And it create a model's "param.yaml" file similar to the sample model's "param.yaml" file.
    Also The compiled model works on SK-TDA4VM(EdgeAI Apps).
    I don't know that why EdgeAI TIDL Tools compiled model not working.
    I used same sample model files. but result is different.
    Lee
  • Hi Manu, Kumar,
    Can you please suggest what Lee should be using to run the models properly on EdgeAI SDK?
    EdgeAI Benchmark or EdgeAI TIDL Tools.
    Shyam
  • edgeai-tidl-tools provide the foundational compilation and inference tools. The compilation and inference tools that edgeai-benchmark uses come from edgeai-tidl-tools. edgeai-tidl-tools only provide a few basic compilation scripts as examples.
    However, edgeai-benchkmark has 120+ models integrated and those compiled models are frequently tested to make sure that they work in the edgeai-SDK (SK-TDA4VM).
    When it comes to running the models in the SDK, edgeai-benchmark will be more reliable. However to understand the basics of how to do the model compilation, the scripts and examples in edgeai-tidl-tools will be easier.
