TDA4VM: How to generate initial xml files for a new sensor?
Part Number: TDA4VM
Hi, TI experts,
I have brought up a new sensor (OV0X3C10) in TDA4 board with sdk 7.03, but I have trouble in preparing the initial xml files (initial ISP parameters).
When I use the 0233 or 0820 xmls to generate .h files, it fails to get image output, even though no error is found in logs.
So, I used the imaging/tools/default_DCC_profile_gen to generate default xmls. In this way, it successfully gets image output.
However, the YUV output is gray image with no color, while the raw image has correct CFA pattern and correct color.
So, when bringing up a new sensor in TDA4 board, I want to know how to get proper initial xml files with color YUV image output? And what causes the gray output of YUV? How to change the gray output to color output?
Looking forward to your reply,
best regards,
Jianxiong Hua
