PROCESSOR-SDK-AM62X: Unable to boot the kernel
Part Number: PROCESSOR-SDK-AM62X
Other Parts Discussed in Thread: AM625
U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:40:44 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.6(release):08.03.00.003-dirty
NOTICE:  BL31: Built : 16:35:46, May 30 2022
U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:39:30 +0000)
U-Boot 2021.01-g74fc69c889 (May 30 2022 - 16:39:30 +0000)
SoC:   AM62X SR1.0
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed 1
DRAM:  2 GiB
MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1490 bytes read in 3 ms (484.4 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 2 ms (0 Bytes/s)
Already setup.
18448896 bytes read in 735 ms (23.9 MiB/s)
44485 bytes read in 5 ms (8.5 MiB/s)
   Loading Device Tree to 000000008fef2000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.109-g9e58028f94 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchai2
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9db00000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009cafffff]
[    0.000000]   node   0: [mem 0x000000009cb00000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] cma: Reserved 144 MiB at 0x00000000f4000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s49880 r8192 d32040 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=7f00581c-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1836756K/2097152K available (10816K kernel code, 1120K rwdata, 4176K rodata, 1792K init, 433K bss, 112940K reserved, 147456K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
[    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008473] Console: colour dummy device 80x25
[    0.013065] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023747] pid_max: default: 32768 minimum: 301
[    0.028556] LSM: Security Framework initializing
[    0.033342] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.040923] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.050634] rcu: Hierarchical SRCU implementation.
[    0.055809] Platform MSI: msi-controller@1820000 domain created
[    0.062085] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.071320] EFI services will not be available.
[    0.076202] smp: Bringing up secondary CPUs ...
[    0.092021] Detected VIPT I-cache on CPU1
[    0.092057] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.092072] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
[    0.092137] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.103341] Detected VIPT I-cache on CPU2
[    0.103367] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.103379] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
[    0.103413] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.114617] Detected VIPT I-cache on CPU3
[    0.114640] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.114650] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
[    0.114684] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.114754] smp: Brought up 1 node, 4 CPUs
[    0.194471] SMP: Total of 4 processors activated.
[    0.199287] CPU features: detected: 32-bit EL0 Support
[    0.204552] CPU features: detected: CRC32 instructions
[    0.217366] CPU: All CPU(s) started at EL2
[    0.221578] alternatives: patching kernel code
[    0.227291] devtmpfs: initialized
[    0.236380] KASLR disabled due to lack of seed
[    0.241144] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.251122] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.262640] pinctrl core: initialized pinctrl subsystem
[    0.268636] DMI not present or invalid.
[    0.273093] NET: Registered protocol family 16
[    0.279332] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.286679] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.294754] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.303480] thermal_sys: Registered thermal governor 'step_wise'
[    0.303487] thermal_sys: Registered thermal governor 'power_allocator'
[    0.310032] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.323755] ASID allocator initialised with 65536 entries
[    0.350888] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.357765] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.364628] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.371480] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.379354] cryptd: max_cpu_qlen set to 1000
[    0.386445] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.395488] vcc_5v0: supplied by vmain_pd
[    0.400001] vcc_3v3_sys: supplied by vmain_pd
[    0.404982] vcc_1v8: supplied by vcc_3v3_sys
[    0.410204] iommu: Default domain type: Translated
[    0.415537] SCSI subsystem initialized
[    0.419729] mc: Linux media interface: v0.10
[    0.424116] videodev: Linux video capture interface: v2.00
[    0.429793] pps_core: LinuxPPS API ver. 1 registered
[    0.434868] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.444221] PTP clock support registered
[    0.448260] EDAC MC: Ver: 3.0.0
[    0.452041] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.459145] FPGA manager framework
[    0.462705] Advanced Linux Sound Architecture Driver Initialized.
[    0.469845] clocksource: Switched to clocksource arch_sys_counter
[    0.476306] VFS: Disk quotas dquot_6.6.0
[    0.480371] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.492895] NET: Registered protocol family 2
[    0.497620] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.506367] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.515142] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.523359] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.531120] TCP: Hash tables configured (established 16384 bind 16384)
[    0.538027] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.544925] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.552388] NET: Registered protocol family 1
[    0.557291] RPC: Registered named UNIX socket transport module.
[    0.563385] RPC: Registered udp transport module.
[    0.568196] RPC: Registered tcp transport module.
[    0.573006] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.579607] PCI: CLS 0 bytes, default 64
[    0.584487] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.596547] Initialise system trusted keyrings
[    0.601320] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.611618] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.618181] NFS: Registering the id_resolver key type
[    0.623389] Key type id_resolver registered
[    0.627670] Key type id_legacy registered
[    0.631832] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.638688] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.646450] 9p: Installing v9fs 9p2000 file system support
[    0.688542] Key type asymmetric registered
[    0.692741] Asymmetric key parser 'x509' registered
[    0.697766] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.705332] io scheduler mq-deadline registered
[    0.709963] io scheduler kyber registered
[    0.715848] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.722211] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.734781] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.754196] brd: module loaded
[    0.764476] loop: module loaded
[    0.768455] megasas: 07.714.04.00-rc1
[    0.775616] tun: Universal TUN/TAP device driver, 1.6
[    0.781318] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.787735] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.793846] sky2: driver version 1.30
[    0.798411] VFIO - User Level meta-driver version: 0.3
[    0.804596] i2c /dev entries driver
[    0.808979] sdhci: Secure Digital Host Controller Interface driver
[    0.815303] sdhci: Copyright(c) Pierre Ossman
[    0.820020] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.826776] ledtrig-cpu: registered to indicate activity on CPUs
[    0.833263] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.840908] optee: probing for conduit method.
[    0.845506] optee: revision 3.12 (3d47a131)
[    0.846014] optee: initialized driver
[    0.855890] NET: Registered protocol family 17
[    0.860626] 9pnet: Installing 9P2000 support
[    0.865058] Key type dns_resolver registered
[    0.869652] Loading compiled-in X.509 certificates
[    0.884018] ti-sci 44043000.system-controller: ti,ctx-memory-region is required for suspend but not provided.
[    0.894189] ti-sci 44043000.system-controller: ti_sci_init_suspend failed, mem suspend will be non-functional.
[    0.904431] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
[    1.412471] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    1.467992] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.479134] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.485423] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.493857] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.503196] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.512234] ti-bcdma 485c0100.dma-controller: Number of rings: 82
[    1.520382] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.531605] ti-pktdma 485c0000.dma-controller: Number of rings: 150
[    1.541741] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.552404] printk: console [ttyS2] disabled
[    1.556855] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[    1.565625] printk: console [ttyS2] enabled
[    1.574068] printk: bootconsole [ns16550a0] disabled
[    1.623712] random: fast init done
[    1.630667] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    1.635680] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.642633] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.648027] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.654762] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.661142] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.667625] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.673819] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    1.680605] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.687033] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.765883] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.776412] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.784510] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.792686] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
[    1.806520] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.813292] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    1.819571] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.826697] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.838748] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.862337] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    1.867522] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:09 UTC (9)
[    1.919088] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    1.971901] mmc0: CQHCI version 5.10
[    2.016666] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    2.061678] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.069732] pca953x 1-0022: supply vcc not found, using dummy regulator
[    2.076470] pca953x 1-0022: using AI
[    2.101973] pca953x 1-0022: failed writing register
[    2.107028] pca953x: probe of 1-0022 failed with error -121
[    2.113738] mmc0: Command Queue Engine enabled
[    2.118222] mmc0: new HS200 MMC card at address 0001
[    2.123867] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    2.126757] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.128727] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
[    2.137883] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.141732] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
[    2.154690] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
[    2.164464]  mmcblk0: p1
[    2.217741] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.232739] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.439530] ALSA device list:
[    2.442539]   No soundcards found.
[    2.498858] Waiting for root device PARTUUID=7f00581c-02...
I am not able to boot completely.Please take a look and give me some suggestions.
Thank you
  • Yes this is boot from sd card
  • Hey Rakshit,
    Thank you for your question. My name is Andrew, and I would be happy to help.  I have relayed your question to the team and hope to have a response for you within the next 1-2 business days.
    Andrew
  • Hey Rakshit,
    Team is still looking into this and will have an update shortly, thank you for your patience.
    Andrew
  • actually Rakshit and me working on it . trying to boot from sd card , but its not booted to linux completely .
    my observations :
    1. not detecting the SD card in the kernel (mmc1 - sd card )
  • please provide your valuable suggestions to resolve the issue . its greatful to us if u would give the solutions for this
  • we are observing that emmc card (mmc0) only detecting in the kernel and no SDCARD(mmc1) in the kernel , which we noticed this from bootup logs mentioned by rakshit above .
    please find only mmc0 logs not able to find mmc1 (sdcard):
    logs:
    please help us how to make detect the SDCARD in the linux kernel ?
  • Hello Rakshit & Naresh,
    Thank you for the additional information. In terms of the SD card that is not being detected, I was wondering if you could clarify the following:
    1. Which SDK version is currently being used?
    2. What tool was used to create the SD card? (balenaEtcher, script, bmap-tools)
    3. Is the image flashed to the SD card default or custom?
    Even if the SD card created was verified at an earlier point, it is possible it has now since become corrupted and could require a new installation after formatting.
    Andrew
  • Hi Andrew ,
    SDK version:08.03.00.19
    Tool : balenetcher
    Image Generation : we used both ways default and custom , but no luck .
    from bootup logs ends with waiting for rootfs  ,please find last 5 lines bootup logs which we got.
    Boot up logs :
     1.945204] davinci-mcasp 2b10000.mcasp: IRQ common not found
    [    1.945562] mmc0: CQHCI version 5.10
    [    1.994457] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.058308] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.066395] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    2.073126] pca953x 1-0022: using AI
    [    2.084362] mmc0: Command Queue Engine enabled
    [    2.088834] mmc0: new HS200 MMC card at address 0001
    [    2.094507] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.098006] pca953x 1-0022: failed writing register
    [    2.099238] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    2.104103] pca953x: probe of 1-0022 failed with error -121
    [    2.110007] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    2.121510] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    2.128955] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.131710]  mmcblk0: p1
    [    2.224609] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.234026] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    2.234641] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.451330] ALSA device list:
    [    2.454329]   No soundcards found.
    [    2.493184] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.587262] Waiting for root device PARTUUID=7f00581c-02...
    thanks ,
    Naresh
  • HI,
    below are the genuine issues , does they solved yet ?
    wiki : https://software-dl.ti.com/processor-sdk-linux-rt/esd/AM62X/08_03_00_19/exports/docs/devices/AM62X/linux/Release_Specific_Release_Notes.html
    Linux kernel known issues ::
    LCPD-28111 am62xx-sk
    wic image flashed sdcard should resize to full image
    LCPD-28110 am62xx-sk uboot and linux cannot boot in UHS speed modes on certain U1 class SD-cards
    due to these issues , our deivce is not boot up through sd card ? can you please confirm ?
  • Hey Naresh,
    Thank you for the additional information, I have copied your attachments over the team and we hope to have an update for you shortly.  I will also reach out directly to the LCPD team about the two errors you inquired about, to see if they are having an effect here.
    Andrew
  • Hey Naresh,
    Thank you for your patience.  I am still awaiting a response from the LCPD team, but I believe we will have an update ready for you shortly.  In the meantime, can you confirm if the following thread you posted is in relation to this one?: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1118376/processor-sdk-am62x-not-able-to-detect-sdcard-in-the-kernel-we-cant-see-the-sd-card-mmc1-messages-in-the-bootup-logs-thatswhy-our-am62x-device-is-not-bootup-through-sdcard
    Andrew
  • Hi Andrew ,
    yes , both threads are same used to raised for same issue
  • Hi Andrew ,
    these are SD power supply nnodes from my k3-am625-sk.dts file
    vdd_mmc1: regulator-3 {
    /* TPS22918DBVR */
    compatible = "regulator-fixed";
    regulator-name = "vdd_mmc1";
    regulator-min-microvolt = <3300000>;
    regulator-max-microvolt = <3300000>;
    regulator-boot-on;
    enable-active-high;
    vin-supply = <&vcc_3v3_sys>;
    gpio = <&exp1 3 GPIO_ACTIVE_HIGH>;
    &sdhci1 {
    /* SD/MMC */
    vmmc-supply = <&vdd_mmc1>;
    vqmmc-supply = <&vdd_sd_dv>;
    pinctrl-names = "default";
    pinctrl-0 = <&main_mmc1_pins_default>;
    ti,driver-strength-ohm = <50>;
    disable-wp;
    vdd_sd_dv: regulator-4 {
    /* Output of TLV71033 */
    compatible = "regulator-gpio";
    regulator-name = "tlv71033";
    pinctrl-0 = <&vdd_sd_dv_pins_default>;
    regulator-min-microvolt = <1800000>;
    regulator-boot-on;
    vin-supply = <&vcc_5v0>;
    gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
    states = <1800000 0x0>,
    <3300000 0x1>;
  • Hey Naresh,
    Thank you for the additional information.  I did get the following response from the LCPD team on this:
    • Which Model of SD card is used, and what is the model/revision of the board?
    • Is it a TI Am62x SK or a custom board the customer built?
    You can rule out LCPD-28111 – it shouldn’t really matter.
    It could be LCPD-28110 if customer is using UHS cards, but we will need the SD cad brand/model to confirm.
    Thank you again for your patience and we hope to resolve this expediently, once we receive the requested information.
    Andrew
  • Hi ,
    its customer board.
    actually with the same sdcard we tried to up the am64x board .
    thank you
  • Hi
    please find SD card we are using  :  sd card- sandisk ultra 16gb
    Naresh
  • Hey Naresh,
    Thank you for the additional information, I have relayed this over to the team and we hope to have an update for you shortly.
    Andrew
  • may i know , where should i make the changes in the kernel so that sdcard will going to detect in the kernel. please help us asap . thanks .
  • HI Andrew,
    yes we followed the same steps .
    please let us know how to enable the sdcard in the kernel .
    its getting delayed .
    Naresh
  • Hi Andrew ,
    could you please confirm below marked field should be ACTIVE HIGH or LOW , by default it is ACTIVE_HIGH .
    will it make any differneces ?
    file : arch/arm64/boot/dts/ti/k3-am625-sk.dts
    vdd_mmc1: fixed-regulator-sd {
    /* TPS22918DBVR */
    regulator-boot-on;
    enable-active-high;
    Naresh
  • Hey Naresh,
    I have reached out to the LCPD team to confirm, but we do not believe this setting to be the cause for the behavior that you are observing.  If you did change  this variable to ACTIVCE_LOW, did you observe any different behavior?
    Andrew
  • no , i didnt tried yet . that pin was sd card load switch , i though to make active low .
    thanks,
    Naresh
  • please help me asap to make detect the sdcard in the kernel.
    what changes/ where we need to change the settings /code so that sdcard will be detect in the kernel.
    thanks,
    Naresh
  • Hey Naresh,
    Thanks for clarifying, I have sent another message to the LCPD team, and will update you tomorrow with their progress.
    Andrew
  • Hey Naresh,
    Thank you for your patience, I have reached out to the LCPD team again, and received the following response:
    "We see in the logs that most of the regulator-requests are failing – we suspect this is because one of the earlier regulators may be missing in the modified device tree for the custom board"
    Could you please confirm a custom (non-default) dtb file is in use here, as well as what changes were made in the device tree? Feel free to attach the whole dtb file as well.
    Andrew
  • Hi Andrew ,
    I commented regualators (vdd_mmc1 & vdd_sd_dv ) regulator nodes from k3-am625-sk.dts from linux  then sdcard is detecting but its not stable , continoulsy logs getting .
    please fins my dts files
    // SPDX-License-Identifier: GPL-2.0
     * AM625 SK: https://www.ti.com/lit/zip/sprr448
     * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/
    /dts-v1/;
    #include <dt-bindings/leds/common.h>
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/net/ti-dp83867.h>
    #include "k3-am625.dtsi"
    	compatible =  "ti,am625-sk", "ti,am625";
    	model = "Texas Instruments AM625 SK its our customised file 7th trial mmc0 status disabled and enabled mmc1 in main.dtsi , disabled in vdd_mmc1 ,vd_sd vd_sd_pins disabled";
    	aliases {
    		serial2 = &main_uart0;
    		mmc0 = &sdhci0;
    		mmc1 = &sdhci1;
    		mmc2 = &sdhci2;
    		spi0 = &ospi0;
    		usb0 = &usb0;
    		usb1 = &usb1;
    		ethernet0 = &cpsw_port1;
    		ethernet1 = &cpsw_port2;
    	chosen {
    		stdout-path = "serial2:115200n8";
    		bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000";
    	memory@80000000 {
    		device_type = "memory";
    		/* 2G RAM */
    		reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
    	reserved-memory {
    		#address-cells = <2>;
    		#size-cells = <2>;
    		ranges;
    		secure_tfa_ddr: tfa@9e780000 {
    			reg = <0x00 0x9e780000 0x00 0x80000>;
    			alignment = <0x1000>;
    			no-map;
    		secure_ddr: optee@9e800000 {
    			reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
    			no-map;
    		wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 {
    			compatible = "shared-dma-pool";
    			reg = <0x00 0x9db00000 0x00 0xc00000>;
    			no-map;
    		mcu_m4fss_dma_memory_region: m4f-dma-memory@9cb00000 {
    			reg = <0x00 0x9cb00000 0x00 0x100000>;
    			no-map;
    		mcu_m4fss_memory_region: m4f-memory@9cc00000 {
    			reg = <0x00 0x9cc00000 0x00 0xf00000>;
    			no-map;
    		lpm_ctx_ddr: lpm-memory@a1000000 {
    			reg = <0x00 0xa1000000 0x00 0x40000>;
    	vmain_pd: regulator-0 {
    		/* TPS65988 PD CONTROLLER OUTPUT*/
    		regulator-name = "vmain_pd";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-always-on;
    		regulator-boot-on;
    	vcc_5v0: regulator-1 {
    		 Output of LM34936
    		regulator-name = "vcc_5v0";
    		vin-supply = <&vmain_pd>;
    		regulator-boot-on;
    	vcc_3v3_sys: regulator-2 {
    		/* output of LM61460-Q1 */
    		regulator-name = "vcc_3v3_sys";
    		regulator-boot-on;
    	vdd_mmc1: regulator-sd {
    		 TPS22918DBVR
    		regulator-boot-on;
    		enable-active-high;
    	vdd_sd_dv: gpio-regulator-TLV71033 {
    		 Output of TLV71033
    		regulator-boot-on;
    			 <3300000 0x1>;
    	wlan_lten: regulator-5 {
    		regulator-name = "wlan_lten";
    		gpios = <&exp1 11 GPIO_ACTIVE_LOW>;
    	wlan_en: regulator-6 {
    		/* OUTPUT of SN74AVC2T244DQMR */
    		regulator-name = "wlan_en";
    		regulator-max-microvolt = <1800000>;
    		enable-active-high;
    		vin-supply = <&wlan_lten>;
    		gpios = <&main_gpio0 71 GPIO_ACTIVE_HIGH>;
    		pinctrl-0 = <&wlan_en_pins_default>;
    	vcc_1v8: regulator-7 {
    		/* output of TPS6282518DMQ */
    		regulator-name = "vcc_1v8";
    		regulator-boot-on;
    	tlv320_mclk: clk-0 {
    		#clock-cells = <0>;
    		compatible = "fixed-clock";
    		clock-frequency = <12288000>;
    	sound {
    		compatible = "simple-audio-card";
    		simple-audio-card,name = "AM62x-SKEVM";
    		simple-audio-card,widgets =
    			"Headphone", "Headphone Jack";
    		simple-audio-card,routing =
    			"Headphone Jack",	"HPLOUT",
    			"Headphone Jack",	"HPROUT";
    		simple-audio-card,format = "dsp_b";
    		simple-audio-card,bitclock-master = <&sound_master>;
    		simple-audio-card,frame-master = <&sound_master>;
    		simple-audio-card,bitclock-inversion;
    		simple-audio-card,cpu {
    			sound-dai = <&mcasp1>;
    		sound_master: simple-audio-card,codec {
    			sound-dai = <&tlv320aic3106>;
    			clocks = <&tlv320_mclk>;
    	leds {
    		compatible = "gpio-leds";
    		pinctrl-0 = <&usr_led_pins_default>;
    		led-0 {
    			label = "am62-sk:green:heartbeat";
    			gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
    			linux,default-trigger = "heartbeat";
    			function = LED_FUNCTION_HEARTBEAT;
    			default-state = "off";
    	hdmi_mstrclk: hdmi-mstrclk {
    		#clock-cells = <0>;
    	hdmi: connector {
    		compatible = "hdmi-connector";
    		label = "hdmi";
    		type = "a";
    		port {
    			hdmi_connector_in: endpoint {
    				remote-endpoint = <&sii9022_out>;
    	extcon_usb0: extcon-usb0 {
    		compatible = "linux,extcon-usb-gpio";
                    id-gpios = <&main_gpio1 50 GPIO_ACTIVE_HIGH>;
                    pinctrl-0 = <&extcon_usb0_gpio_id_pins_default>;
    &mcu_pmx0 {
            wkup_i2c0_pins_default: wkup-i2c0-pins-default {
                    pinctrl-single,pins = <
                            AM62X_IOPAD(0x04C, PIN_INPUT_PULLUP, 0) /* (B9) AM62X_WKUP_I2C0_SCL\G */
                            AM62X_IOPAD(0x050, PIN_INPUT_PULLUP, 0) /* (A9) AM62X_WKUP_I2C0_SDA\G */
            mcu_i2c0_pins_default: mcu-i2c0-pins-default {
                            AM62X_IOPAD(0x044, PIN_INPUT_PULLUP, 0) /* (A8) AM62X_MCU_I2C0_SCL\G */
                            AM62X_IOPAD(0x048, PIN_INPUT_PULLUP, 0) /* (D10) AM62X_MCU_I2C0_SDA\G */
    &main_pmx0 {
    	main_mcan0_pins_default: main_mcan0_pins_default {
                            AM62X_IOPAD(0x038, PIN_INPUT, 0) /* (B3) AM62X_MCU_MCAN0_RX\G */
                           	AM62X_IOPAD(0x034, PIN_OUTPUT, 0) /* (D6) AM62X_MCU_MCAN0_TX\G */
    			AM62X_IOPAD(0x040, PIN_INPUT, 0) /* (D4) AM62X_MCU_MCAN1_RX\G */
    			AM62X_IOPAD(0x03c, PIN_OUTPUT, 0) /* (E5) AM62X_MCU_MCAN1_TX\G */
    			AM62X_IOPAD(0x1dc, PIN_INPUT, 0) /* (E15) AM62X_MCAN0_RX\G */
    			AM62X_IOPAD(0x1d8, PIN_OUTPUT, 0) /* (C15) AM62X_MCAN0_TX\G */
    	main_uart0_pins_default: main-uart0-pins-default {
    			AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */
    			AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */
    	main_i2c0_pins_default: main-i2c0-pins-default {
    			AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */
    			AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */
    	main_i2c1_pins_default: main-i2c1-pins-default {
    			AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */
    			AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */
    	main_i2c2_pins_default: main-i2c2-pins-default {
    			AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */
    			AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */
    	main_mmc0_pins_default: main-mmc0-pins-default {
    			AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */
    			AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */
    			AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */
    			AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */
    			AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */
    			AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */
    			AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */
    			AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */
    			AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */
    			AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */
    	main_mmc1_pins_default: main-mmc1-pins-default {
    			AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */
    			AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */
    			AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */
    			AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */
    			AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */
    			AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */
    			AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */
    	wlan_en_pins_default: wlan-en-pins-default {
    			AM62X_IOPAD(0x124, PIN_OUTPUT, 7) /* (A23) MMC2_SDCD.GPIO0_71 */
    	main_mmc2_pins_default: main-mmc2-pins-default {
    			AM62X_IOPAD(0x120, PIN_INPUT, 0) /* (C24) MMC2_CMD */
    			AM62X_IOPAD(0x118, PIN_INPUT, 0) /* (D25) MMC2_CLK */
    			AM62X_IOPAD(0x114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */
    			AM62X_IOPAD(0x110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */
    			AM62X_IOPAD(0x10c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */
    			AM62X_IOPAD(0x108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */
    			AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */
    	main_wlirq_pins_default: main-wlirq-pins-default {
    			AM62X_IOPAD(0x128, PIN_INPUT, 7) /* (B23) MMC2_SDWP.GPIO0_72 */
    	usr_led_pins_default: usr-led-pins-default {
    			AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */
    	main_mdio1_pins_default: main-mdio1-pins-default {
    			AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */
    			AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */
    	main_rgmii1_pins_default: main-rgmii1-pins-default {
    			AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */
    			AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */
    			AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */
    			AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */
    			AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */
    			AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */
    			AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */
    			AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */
    			AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */
    			AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */
    			AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */
    			AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */
    	main_rgmii2_pins_default: main-rgmii2-pins-default {
    			AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */
    			AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */
    			AM62X_IOPAD(0x18c, PIN_INPUT, 0) /* (AC21) RGMII2_RD2 */
    			AM62X_IOPAD(0x190, PIN_INPUT, 0) /* (AE22) RGMII2_RD3 */
    			AM62X_IOPAD(0x180, PIN_INPUT, 0) /* (AD23) RGMII2_RXC */
    			AM62X_IOPAD(0x17c, PIN_INPUT, 0) /* (AD22) RGMII2_RX_CTL */
    			AM62X_IOPAD(0x16c, PIN_OUTPUT, 0) /* (Y18) RGMII2_TD0 */
    			AM62X_IOPAD(0x170, PIN_OUTPUT, 0) /* (AA18) RGMII2_TD1 */
    			AM62X_IOPAD(0x174, PIN_OUTPUT, 0) /* (AD21) RGMII2_TD2 */
    			AM62X_IOPAD(0x178, PIN_OUTPUT, 0) /* (AC20) RGMII2_TD3 */
    			AM62X_IOPAD(0x168, PIN_OUTPUT, 0) /* (AE21) RGMII2_TXC */
    			AM62X_IOPAD(0x164, PIN_OUTPUT, 0) /* (AA19) RGMII2_TX_CTL */
    	ospi0_pins_default: ospi0-pins-default {
    			AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */
    			AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */
    			AM62X_IOPAD(0x00c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */
    			AM62X_IOPAD(0x010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */
    			AM62X_IOPAD(0x014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */
    			AM62X_IOPAD(0x018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */
    			AM62X_IOPAD(0x01c, PIN_INPUT, 0) /* (J23) OSPI0_D4 */
    			AM62X_IOPAD(0x020, PIN_INPUT, 0) /* (J25) OSPI0_D5 */
    			AM62X_IOPAD(0x024, PIN_INPUT, 0) /* (H25) OSPI0_D6 */
    			AM62X_IOPAD(0x028, PIN_INPUT, 0) /* (J22) OSPI0_D7 */
    			AM62X_IOPAD(0x008, PIN_INPUT, 0) /* (J24) OSPI0_DQS */
    	main_dss0_pins_default: main-dss0-pins-default {
    			AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */
    			AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */
    			AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */
    			AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */
    			AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */
    			AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */
    			AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */
    			AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */
    			AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */
    			AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */
    			AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */
    			AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */
    			AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */
    			AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */
    			AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */
    			AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */
    			AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */
    			AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */
    			AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */
    			AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */
    			AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */
    			AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */
    			AM62X_IOPAD(0x0064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */
    			AM62X_IOPAD(0x0068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */
    			AM62X_IOPAD(0x006c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */
    			AM62X_IOPAD(0x0070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */
    			AM62X_IOPAD(0x0074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */
    			AM62X_IOPAD(0x0078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */
    	vdd_sd_dv_pins_default: vdd-sd-dv-pins-default {
    			AM62X_IOPAD(0x07c, PIN_OUTPUT, 7)  (P25) GPMC0_CLK.GPIO0_31
    	main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-pins-default {
    			AM62X_IOPAD(0x01d4, PIN_INPUT, 7) /* (B15) UART0_RTSn.GPIO1_23 */
    	main_usb1_pins_default: main-usb1-pins-default {
    			AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */
    	extcon_usb0_gpio_id_pins_default: extcon-usb0-gpio-id-pins-default {
                            AM62X_IOPAD(0x254, PIN_INPUT_PULLUP, 7) /* (C20) USB0_DRVVBUS.GPIO1_50 */
    	main_mcasp1_pins_default: main-mcasp1-pins-default {
    			AM62X_IOPAD(0x0090, PIN_INPUT, 2) /* (M24) GPMC0_BE0N_CLE.MCASP1_ACLKX */
    			AM62X_IOPAD(0x0098, PIN_INPUT, 2) /* (U23) GPMC0_WAIT0.MCASP1_AFSX */
    			AM62X_IOPAD(0x008c, PIN_OUTPUT, 2) /* (L25) GPMC0_WEN.MCASP1_AXR0 */
    			AM62X_IOPAD(0x0084, PIN_INPUT, 2) /* (L23) GPMC0_ADVN_ALE.MCASP1_AXR2 */
    &wkup_uart0 {
    	/* WKUP UART0 is used by DM firmware */
    	status = "reserved";
    &mcu_uart0 {
    	status = "disabled";
    &main_uart0 {
    	pinctrl-0 = <&main_uart0_pins_default>;
    &main_uart1 {
    	/* Main UART1 is used by TIFS firmware */
    &main_uart2 {
    &main_uart3 {
    &main_uart4 {
    &main_uart5 {
    &main_uart6 {
    &mcu_i2c0 {
            pinctrl-0 = <&mcu_i2c0_pins_default>;
            clock-frequency = <400000>;
            status = "okay";
    &wkup_i2c0 {
            pinctrl-0 = <&wkup_i2c0_pins_default>;
    	status = "okay";
    &main_i2c0 {
    	pinctrl-0 = <&main_i2c0_pins_default>;
    	eeprom@50 {
                    compatible = "ti,eeprom";
                    reg = <0x50>;
    	typec_pd: usb-pd@3f {
    		compatible = "ti,tps6598x";
    		reg = <0x3f>;
    		connector {
    			ports {
    				#address-cells = <1>;
    				#size-cells = <0>;
    				port@1 {
    					reg = <1>;
    					usb_con_hs: endpoint {
    						remote-endpoint = <&typec_hs>;
    &main_i2c1 {
    	pinctrl-0 = <&main_i2c1_pins_default>;
    	clock-frequency = <100000>;
    	exp1: gpio@22 {
    		compatible = "ti,tca6424";
    		reg = <0x22>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		gpio-line-names = "GPIO_CPSW2_RST", "GPIO_CPSW1_RST",
    				   "PRU_DETECT", "MMC1_SD_EN",
    				   "VPP_LDO_EN", "EXP_PS_3V3_En",
    				   "EXP_PS_5V0_En", "EXP_HAT_DETECT",
    				   "GPIO_AUD_RSTn", "GPIO_eMMC_RSTn",
    				   "UART1_FET_BUF_EN", "WL_LT_EN",
    				   "GPIO_HDMI_RSTn", "CSI_GPIO1",
    				   "CSI_GPIO2", "PRU_3V3_EN",
    				   "HDMI_INTn", "TEST_GPIO2",
    				   "MCASP1_FET_EN", "MCASP1_BUF_BT_EN",
    				   "MCASP1_FET_SEL", "UART1_FET_SEL",
    				   "TSINT#", "IO_EXP_TEST_LED";
    		interrupt-parent = <&main_gpio1>;
    		interrupts = <23 IRQ_TYPE_EDGE_FALLING>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    		pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>;
    	sii9022: sii9022@3b {
    		compatible = "sil,sii9022";
    		reg = <0x3b>;
    		clocks = <&hdmi_mstrclk>;
    		clock-names = "mclk";
    		interrupt-parent = <&exp1>;
    		interrupts = <16 IRQ_TYPE_EDGE_FALLING>;
    		ports {
    			#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    				sii9022_in: endpoint {
    					remote-endpoint = <&dpi1_out>;
    			port@1 {
    				reg = <1>;
    				sii9022_out: endpoint {
    					remote-endpoint = <&hdmi_connector_in>;
    	tlv320aic3106: audio-codec@1b {
    		#sound-dai-cells = <0>;
    		compatible = "ti,tlv320aic3106";
    		reg = <0x1b>;
    		/* Regulators */
    		AVDD-supply = <&vcc_3v3_sys>;
    		IOVDD-supply = <&vcc_3v3_sys>;
    		DRVDD-supply = <&vcc_3v3_sys>;
    		DVDD-supply = <&vcc_1v8>;
    &main_i2c2 {
    &main_i2c3 {
    &sdhci0 {
    	pinctrl-0 = <&main_mmc0_pins_default>;
    	disable-wp;
    &sdhci1 {
    	/* SD/MMC */
    	//vmmc-supply = <&vdd_mmc1>;
    	//vqmmc-supply = <&vdd_sd_dv>;
    	disable-wp;
    	status="okay";
    &sdhci2 {
    	vmmc-supply = <&wlan_en>;
    	pinctrl-0 = <&main_mmc2_pins_default>;
    	bus-width = <4>;
    	non-removable;
    	ti,fails-without-test-cd;
    	cap-power-off-card;
    	keep-power-in-suspend;
    	assigned-clocks = <&k3_clks 157 158>;
    	assigned-clock-parents = <&k3_clks 157 160>;
    	#size-cells = <0>;
    	wlcore: wlcore@2 {
    		compatible = "ti,wl1837";
    		reg = <2>;
    		pinctrl-0 = <&main_wlirq_pins_default>;
    		interrupt-parent = <&main_gpio0>;
    		interrupts = <72 IRQ_TYPE_EDGE_FALLING>;
    &usbss0 {
    	ti,vbus-divider;
    &usb0 {
    	#size-cells = <0>;
    	usb-role-switch;
    	port@1 {
    		reg = <1>;
    		typec_hs: endpoint {
    			remote-endpoint = <&usb_con_hs>;
    &usb1 {
    	dr_mode = "host";
    	pinctrl-0 = <&main_usb1_pins_default>;
    &cpsw3g {
    	pinctrl-0 = <&main_mdio1_pins_default
    		     &main_rgmii1_pins_default
    		     &main_rgmii2_pins_default>;
    &cpsw_port1 {
    	phy-mode = "rgmii-rxid";
    	phy-handle = <&cpsw3g_phy0>;
    &cpsw_port2 {
    	phy-handle = <&cpsw3g_phy1>;
    &cpsw3g_mdio {
    	cpsw3g_phy0: ethernet-phy@0 {
    		reg = <0>;
    		ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
    		ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
    		ti,min-output-impedance;
    	cpsw3g_phy1: ethernet-phy@1 {
    		reg = <1>;
    &dss {
    	pinctrl-0 = <&main_dss0_pins_default>;
    &dss_ports {
    	#size-cells = <0>;
    	/* VP2: DPI Output */
    	port@1 {
    		reg = <1>;
    		dpi1_out: endpoint {
    			remote-endpoint = <&sii9022_in>;
    &mcasp0 {
    &mcasp1 {
    	status = "okay";
    	pinctrl-0 = <&main_mcasp1_pins_default>;
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
    	       1 0 0 0
    	       0 0 0 0
    	       0 0 0 0
    	       0 0 0 0
    	tx-num-evt = <32>;
    	rx-num-evt = <32>;
    &mcasp2 {
    &mailbox0_cluster0 {
    	mbox_m4_0: mbox-m4-0 {
    		ti,mbox-rx = <0 0 0>;
    		ti,mbox-tx = <1 0 0>;
    &ospi0 {
    	pinctrl-0 = <&ospi0_pins_default>;
    	flash@0{
    		compatible = "jedec,spi-nor";
    		reg = <0x0>;
    		spi-tx-bus-width = <8>;
    		spi-rx-bus-width = <8>;
    		spi-max-frequency = <25000000>;
    		cdns,tshsl-ns = <60>;
    		cdns,tsd2d-ns = <60>;
    		cdns,tchsh-ns = <60>;
    		cdns,tslch-ns = <60>;
    		cdns,read-delay = <4>;
    		cdns,phy-mode;
    		partitions {
    			compatible = "fixed-partitions";
    			#size-cells = <1>;
    			partition@0 {
    				label = "ospi.tiboot3";
    				reg = <0x0 0x80000>;
    			partition@80000 {
    				label = "ospi.tispl";
    				reg = <0x80000 0x200000>;
    			partition@280000 {
    				label = "ospi.u-boot";
    				reg = <0x280000 0x400000>;
    			partition@680000 {
    				label = "ospi.env";
    				reg = <0x680000 0x40000>;
    			partition@6c0000 {
    				label = "ospi.env.backup";
    				reg = <0x6c0000 0x40000>;
    			partition@800000 {
    				label = "ospi.rootfs";
    				reg = <0x800000 0x37c0000>;
    			partition@3fc0000 {
    				label = "ospi.phypattern";
    				reg = <0x3fc0000 0x40000>;
    &mcu_m4fss {
    	mboxes = <&mailbox0_cluster0 &mbox_m4_0>;
    	memory-region = <&mcu_m4fss_dma_memory_region>,
    			<&mcu_m4fss_memory_region>;
    &main_mcan0 {
            pinctrl-0 = <&main_mcan0_pins_default>;
    	status = "okay";
    &epwm0 {
    &epwm1 {
    &epwm2 {
    &ecap0 {
    &ecap1 {
    &ecap2 {
    Naresh
  • Hi Andrew ,
    these are bootup logs :
    after mounting the file system  ,its going to rebooting .
    Starting kernel ...
    [    0.000000] Linux version 5.10.109-g9e58028f94 (nagendra@test-OptiPlex-7080) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (2
    [    0.000000] Machine model: Texas Instruments AM625 SK its our customised file 7th trial mmc0 status disabled and enabled mmc1 in main.dtsi , disabled in vdd_mmc1 ,vd_sd vd_sd_pins disabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] Memory: 1836688K/2097152K available (10880K kernel code, 1122K rwdata, 4192K rodata, 1792K init, 431K bss, 113008K reserved, 147456K cma-reserved)
    [    0.013063] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023745] pid_max: default: 32768 minimum: 301
    [    0.028554] LSM: Security Framework initializing
    [    0.050638] rcu: Hierarchical SRCU implementation.
    [    0.055805] Platform MSI: msi-controller@1820000 domain created
    [    0.062081] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.071317] EFI services will not be available.
    [    0.076198] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    I/TC: Secondary CPU 2 initializing
    I/TC: Secondary CPU 2 switching to normal world boot
    I/TC: Secondary CPU 3 initializing
    I/TC: Secondary CPU 3 switching to normal world boot
    [    0.100030] Detected VIPT I-cache on CPU1
    [    0.100069] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.100085] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.100148] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.119382] Detected VIPT I-cache on CPU2
    [    0.119408] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.119420] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
    [    0.119459] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.138646] Detected VIPT I-cache on CPU3
    [    0.138669] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.138681] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
    [    0.138718] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.138790] smp: Brought up 1 node, 4 CPUs
    [    0.218502] SMP: Total of 4 processors activated.
    [    0.223314] CPU features: detected: 32-bit EL0 Support
    [    0.228583] CPU features: detected: CRC32 instructions
    [    0.241515] CPU: All CPU(s) started at EL2
    [    0.245725] alternatives: patching kernel code
    [11:20 am] Rakshit Ashok
    [    0.251452] devtmpfs: initialized
    [    0.260568] KASLR disabled due to lack of seed
    [    0.265332] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.275312] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.286801] pinctrl core: initialized pinctrl subsystem
    [    0.292806] DMI not present or invalid.
    [    0.297268] NET: Registered protocol family 16
    [    0.303525] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.310873] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.318947] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.327682] thermal_sys: Registered thermal governor 'step_wise'
    [    0.327688] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.334239] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.347967] ASID allocator initialised with 65536 entries
    [    0.375613] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.382491] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.389344] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.396196] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.404056] cryptd: max_cpu_qlen set to 1000
    [    0.411213] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.420303] vcc_3v3_sys: supplied by vmain_pd
    [    0.425312] vcc_1v8: supplied by vcc_3v3_sys
    [    0.430502] iommu: Default domain type: Translated
    [    0.435842] SCSI subsystem initialized
    [    0.440077] mc: Linux media interface: v0.10
    [    0.444464] videodev: Linux video capture interface: v2.00
    [    0.450145] pps_core: LinuxPPS API ver. 1 registered
    [    0.455221] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.464570] PTP clock support registered
    [    0.468609] EDAC MC: Ver: 3.0.0
    [    0.472401] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    0.479510] FPGA manager framework
    [    0.483066] Advanced Linux Sound Architecture Driver Initialized.
    [    0.490213] clocksource: Switched to clocksource arch_sys_counter
    [    0.496670] VFS: Disk quotas dquot_6.6.0
    [    0.500733] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.513128] NET: Registered protocol family 2
    [    0.517823] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.526573] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.535345] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.543561] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [    0.551296] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.558192] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.565099] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.572564] NET: Registered protocol family 1
    [    0.577480] RPC: Registered named UNIX socket transport module.
    [    0.583552] RPC: Registered udp transport module.
    [    0.588387] RPC: Registered tcp transport module.
    [    0.593201] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.599797] PCI: CLS 0 bytes, default 64
    [    0.604673] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.616627] Initialise system trusted keyrings
    [    0.621383] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.631691] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.638231] NFS: Registering the id_resolver key type
    [    0.643433] Key type id_resolver registered
    [    0.647711] Key type id_legacy registered
    [    0.651870] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.658725] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.666487] 9p: Installing v9fs 9p2000 file system support
    [    0.708022] Key type asymmetric registered
    [    0.712221] Asymmetric key parser 'x509' registered
    [    0.717247] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.724814] io scheduler mq-deadline registered
    [    0.729445] io scheduler kyber registered
    [    0.735395] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.741729] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.754372] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.773822] brd: module loaded
    [    0.784195] loop: module loaded
    [    0.788147] megasas: 07.714.04.00-rc1
    [    0.795304] tun: Universal TUN/TAP device driver, 1.6
    [    0.800993] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.807410] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.813515] sky2: driver version 1.30
    [    0.818073] VFIO - User Level meta-driver version: 0.3
    [    0.824291] i2c /dev entries driver
    [    0.828681] sdhci: Secure Digital Host Controller Interface driver
    [    0.835006] sdhci: Copyright(c) Pierre Ossman
    [    0.839783] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.846769] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.853276] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.860938] optee: probing for conduit method.
    [    0.865554] optee: revision 3.18 (191f2ed4)
    [    0.865839] optee: dynamic shared memory is enabled
    [    0.875353] optee: initialized driver
    [    0.880981] NET: Registered protocol family 17
    [    0.885700] 9pnet: Installing 9P2000 support
    [    0.890129] Key type dns_resolver registered
    [    0.894701] Loading compiled-in X.509 certificates
    [    0.909337] ti-sci 44043000.system-controller: ti,ctx-memory-region is required for suspend but not provided.
    [    0.919509] ti-sci 44043000.system-controller: ti_sci_init_suspend failed, mem suspend will be non-functional.
    [    0.929751] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
    [    1.476301] davinci-mcasp 2b10000.mcasp: IRQ common not found
    [    1.526584] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.536969] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.549400] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.557204] omap_i2c 20010000.i2c: bus 3 rev0.12 at 100 kHz
    [    1.563488] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.571908] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.581239] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.590294] ti-bcdma 485c0100.dma-controller: Number of rings: 82
    [    1.598477] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.609672] ti-pktdma 485c0000.dma-controller: Number of rings: 150
    [    1.616529] random: fast init done
    [    1.623279] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.633890] printk: console [ttyS2] disabled
    [    1.638341] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250
    [    1.647110] printk: console [ttyS2] enabled
    [    1.655559] printk: bootconsole [ns16550a0] disabled
    [    1.712250] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.717284] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.724236] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.729632] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.736358] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.742778] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.749249] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.755430] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.762191] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.768647] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.846277] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.856811] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.864910] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.873086] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
    [    1.886953] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.893729] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.900010] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.907136] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.919185] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    1.942825] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    1.948022] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:10 UTC (10)
    [    1.999713] davinci-mcasp 2b10000.mcasp: IRQ common not found
    [    2.042068] mmc0: CQHCI version 5.10
    [    2.052521] mmc1: CQHCI version 5.10
    [    2.086745] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.094253] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.117468] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.125166] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    2.131958] pca953x 3-0022: using AI
    [    2.137286] mmc1: new high speed SDHC card at address aaaa
    [    2.143497] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    2.152825]  mmcblk1: p1 p2
    [    2.158373] pca953x 3-0022: failed writing register
    [    2.163466] pca953x: probe of 3-0022 failed with error -121
    [    2.177233] mmc0: Command Queue Engine enabled
    [    2.181756] mmc0: new HS200 MMC card at address 0001
    [    2.182857] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.187436] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.198681] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    2.204805] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    2.205940] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.210972] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    2.227970]  mmcblk0: p1
    [    2.295547] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.304860] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    2.520759] ALSA device list:
    [    2.523752]   No soundcards found.
    [    2.635369] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.643573] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.653172] devtmpfs: mounted
    [    2.657458] Freeing unused kernel memory: 1792K
    [    2.662092] Run /sbin/init as init process
    [    2.973988] systemd[1]: System time before build time, advancing clock.
    [    3.056881] NET: Registered protocol family 10
    [    3.062471] Segment Routing with IPv6
    [    3.104765] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD)
    [    3.126852] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    3.169131] systemd[1]: Set hostname to <am62xx-evm>.
    [    3.484476] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    3.498958] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    3.638883] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.645862] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.658213] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.669755] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    3.690415] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.698358] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    3.722388] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.730029] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.750699] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password �…ts to Console Directory Watch.
    [    3.774542] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R�…uests to Wall Directory Watch.
    [    3.798543] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    3.814377] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.834335] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    3.850346] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    3.914086] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.938454] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.965416] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.986792] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.026493] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.035358] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.058979] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.075155] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.098913] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.118723] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.143096] systemd[1]: Mounting Huge Pages File System...
    [    4.163043] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.192309] systemd[1]: Mounting Kernel Debug File System...
    [    4.217226] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.239148] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st�…odes for the current kernel...
    [    4.266806] systemd[1]: Starting Start psplash boot splash screen...
    [    4.296399] systemd[1]: Starting RPC Bind...
    [    4.310786] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    4.325267] systemd[1]: Starting Journal Service...
    [    4.353937] systemd[1]: Starting Load Kernel Modules...
    [    4.375157] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.377267] cryptodev: loading out-of-tree module taints kernel.
             Starting Remount Root and Kernel File Systems   4.396286] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [0m...
    [    4.396872] cryptodev: driver 1.10 loaded.
    [    4.418663] systemd[1]: Starting udev Coldplug all Devices...
    [    4.444939] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.459110] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Started Create list of sta�… nodes for the current kernel.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star�…progress communication helper.
    [  OK  ] Started Load Kernel Modules.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    4.752233] systemd-journald[184]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create System Users...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create System Users.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
             Starting udev Wait for Complete Device Initialization...
             Starting udev Kernel Device Manager...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Rebuild Dynamic Linker Cache...
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Rebuild Journal Catalog...
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Rebuild Journal Catalog.
    [  OK  ] Started udev Kernel Device Manager.
    [  OK  ] Started Network Time Synchronization.
  • Hey Naresh,
    Thank you for the additional information, I have relayed this over to the LCPD team and we hope to have an update for you shortly.
    Andrew
  • Hey Naresh,
    The team suspects you may have UHS mode enabled, which may be preventing SD card recognition.  We recommend disabling this mode via the following steps:  https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/08_03_00_19/exports/docs/devices/AM62X/linux/Release_Specific_Migration_Guide.html#am62-sd-uhs-speed-modes-enable
    Please let us know if completing these steps rectifies the issue you are observing.
    Andrew
  • @Rakshit , please provide full logs(including uboot logs) to Andrew
  • Hi, please find uart logs with default file system
    U-Boot 2021.01-00002-g77bcc61275-dirty (Aug 01 2022 - 17:45:24 +0530)
    SoC:   AM62X SR1.0
    Model: Texas Instruments AM625 SK
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed 1
    DRAM:  2 GiB
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
    Loading Environment from MMC... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    Failed to load 'boot.scr'
    1490 bytes read in 2 ms (727.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    Running uenvcmd ...
    1 bytes read in 2 ms (0 Bytes/s)
    Already setup.
    18450944 bytes read in 767 ms (22.9 MiB/s)
    44862 bytes read in 5 ms (8.6 MiB/s)
       Loading Device Tree to 000000008fef2000, end 000000008fffffff ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009cafffff]
    [    0.000000]   node   0: [mem 0x000000009cb00000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] cma: Reserved 144 MiB at 0x00000000f4000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 22 pages/cpu s49880 r8192 d32040 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=7f00581c-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 1836752K/2097152K available (10816K kernel code, 1122K rwdata, 4184K rodata, 1792K init, 431K bss, 112944K reserved, 147456K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    1.521304] davinci-mcasp 2b00000.mcasp: invalid tdm slots: 0
    [    1.527242] davinci-mcasp 2b00000.mcasp: IRQ common not found
    [    1.565183] davinci-mcasp 2b10000.mcasp: IRQ common not found
    [    1.603129] davinci-mcasp 2b20000.mcasp: invalid tdm slots: 0
    [    1.609039] davinci-mcasp 2b20000.mcasp: IRQ common not found
    [    1.631392] random: fast init done
    [    1.659081] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.669538] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.681860] at24 2-0050: supply vcc not found, using dummy regulator
    [    1.711329] at24 2-0050: 262144 byte 24AA32AF EEPROM, writable, 1 bytes/write
    [    1.718904] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.726848] omap_i2c 20010000.i2c: bus 3 rev0.12 at 100 kHz
    [    1.733922] omap_i2c 20020000.i2c: bus 4 rev0.12 at 100 kHz
    [    1.740684] omap_i2c 20030000.i2c: bus 5 rev0.12 at 100 kHz
    [    1.746734] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.755082] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.764322] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.773365] ti-bcdma 485c0100.dma-controller: Number of rings: 82
    [    1.781520] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.792709] ti-pktdma 485c0000.dma-controller: Number of rings: 150
    [    1.802808] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.813459] printk: console [ttyS2] disabled
    [    1.817911] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250
    [    1.826682] printk: console [ttyS2] enabled
    [    1.835125] printk: bootconsole [ns16550a0] disabled
    [    1.891759] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.896782] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008476] Console: colour dummy device 80x25
    [    0.013069] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023752] pid_max: default: 32768 minimum: 301
    [    0.028561] LSM: Security Framework initializing
    [    0.033348] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.040929] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.050637] rcu: Hierarchical SRCU implementation.
    [    0.055810] Platform MSI: msi-controller@1820000 domain created
    [    0.062085] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.071325] EFI services will not be available.
    [    0.076200] smp: Bringing up secondary CPUs ...
    [    0.100032] Detected VIPT I-cache on CPU1
    [    0.119377] Detected VIPT I-cache on CPU2
    [    0.119404] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.119417] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
    [    0.119457] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.138633] Detected VIPT I-cache on CPU3
    [    0.138657] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.138667] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
    [    0.138704] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.138777] smp: Brought up 1 node, 4 CPUs
    [    0.218486] SMP: Total of 4 processors activated.
    [    0.223298] CPU features: detected: 32-bit EL0 Support
    [    0.228568] CPU features: detected: CRC32 instructions
    [    0.241377] CPU: All CPU(s) started at EL2
    [    0.245588] alternatives: patching kernel code
    [    0.251313] devtmpfs: initialized
    [    0.260397] KASLR disabled due to lack of seed
    [    0.265167] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.275146] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.286651] pinctrl core: initialized pinctrl subsystem
    [    0.292650] DMI not present or invalid.
    [    0.297099] NET: Registered protocol family 16
    [    0.303353] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.310701] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.318775] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.327508] thermal_sys: Registered thermal governor 'step_wise'
    [    0.327514] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.334066] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.347783] ASID allocator initialised with 65536 entries
    [    0.376394] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.383276] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.390128] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.396980] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.404851] cryptd: max_cpu_qlen set to 1000
    [    0.412001] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.421102] vcc_3v3_sys: supplied by vmain_pd
    [    0.426109] vcc_1v8: supplied by vcc_3v3_sys
    [    0.431339] iommu: Default domain type: Translated
    [    0.436693] SCSI subsystem initialized
    [    0.441017] mc: Linux media interface: v0.10
    [    0.445407] videodev: Linux video capture interface: v2.00
    [    0.451085] pps_core: LinuxPPS API ver. 1 registered
    [    0.456160] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.465509] PTP clock support registered
    [    0.469548] EDAC MC: Ver: 3.0.0
    [    0.473330] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    0.480426] FPGA manager framework
    [    0.483987] Advanced Linux Sound Architecture Driver Initialized.
    [    0.491147] clocksource: Switched to clocksource arch_sys_counter
    [    0.497596] VFS: Disk quotas dquot_6.6.0
    [    0.501669] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.514062] NET: Registered protocol family 2
    [    0.518767] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.527526] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.536299] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.544514] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [    0.552248] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.559152] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.566044] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.573507] NET: Registered protocol family 1
    [    0.578416] RPC: Registered named UNIX socket transport module.
    [    0.584490] RPC: Registered udp transport module.
    [    0.589325] RPC: Registered tcp transport module.
    [    0.594137] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.600733] PCI: CLS 0 bytes, default 64
    [    0.605621] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.617576] Initialise system trusted keyrings
    [    0.622333] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.632635] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.639173] NFS: Registering the id_resolver key type
    [    0.644374] Key type id_resolver registered
    [    0.648651] Key type id_legacy registered
    [    0.652834] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.659688] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.667462] 9p: Installing v9fs 9p2000 file system support
    [    0.708674] Key type asymmetric registered
    [    0.712871] Asymmetric key parser 'x509' registered
    [    0.717899] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.725465] io scheduler mq-deadline registered
    [    0.730096] io scheduler kyber registered
    [    0.736075] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.742391] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.755127] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.774867] brd: module loaded
    [    0.785224] loop: module loaded
    [    0.789213] megasas: 07.714.04.00-rc1
    [    0.796450] tun: Universal TUN/TAP device driver, 1.6
    [    0.802155] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.808572] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.814683] sky2: driver version 1.30
    [    0.819286] VFIO - User Level meta-driver version: 0.3
    [    0.825503] i2c /dev entries driver
    [    0.829933] sdhci: Secure Digital Host Controller Interface driver
    [    0.836259] sdhci: Copyright(c) Pierre Ossman
    [    0.841012] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.847832] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.854314] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.861980] optee: probing for conduit method.
    [    0.866580] optee: revision 3.18 (191f2ed4)
    [    0.866865] optee: dynamic shared memory is enabled
    [    0.876377] optee: initialized driver
    [    0.882148] NET: Registered protocol family 17
    [    0.886866] 9pnet: Installing 9P2000 support
    [    0.891298] Key type dns_resolver registered
    [    0.895871] Loading compiled-in X.509 certificates
    [    0.910833] ti-sci 44043000.system-controller: ti,ctx-memory-region is required for suspend but not provided.
    [    0.921006] ti-sci 44043000.system-controller: ti_sci_init_suspend failed, mem suspend will be non-functional.
    [    0.931244] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
    [    1.903737] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.909133] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.915881] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.922231] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.928707] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.934887] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.941656] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.948146] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    2.027189] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.037724] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    2.045825] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    2.054006] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
    [    2.067844] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    2.074621] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    2.080902] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    2.088029] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    2.100075] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    2.123736] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    2.128933] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:10 UTC (10)
    [    2.180623] davinci-mcasp 2b00000.mcasp: invalid tdm slots: 0
    [    2.186412] davinci-mcasp 2b00000.mcasp: IRQ common not found
    [    2.222993] mmc1: CQHCI version 5.10
    [    2.233445] mmc0: CQHCI version 5.10
    [    2.267714] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.275754] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.279119] davinci-mcasp 2b10000.mcasp: IRQ common not found
    [    2.319799] mmc1: new high speed SDHC card at address aaaa
    [    2.325613] davinci-mcasp 2b20000.mcasp: invalid tdm slots: 0
    [    2.331756] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    2.336234] davinci-mcasp 2b20000.mcasp: IRQ common not found
    [    2.346693]  mmcblk1: p1 p2
    [    2.365571] mmc0: Command Queue Engine enabled
    [    2.370066] mmc0: new HS200 MMC card at address 0001
    [    2.375698] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.380429] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
    [    2.386569] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
    [    2.392668] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
    [    2.397898] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.402800]  mmcblk0: p1
    [    2.407875] pca953x 3-0022: supply vcc not found, using dummy regulator
    [    2.416495] pca953x 3-0022: using AI
    [    2.443288] pca953x 3-0022: failed writing register
    [    2.448346] pca953x: probe of 3-0022 failed with error -121
    [    2.467618] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.476684] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    2.515735] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    2.744611] ALSA device list:
    [    2.747604]   No soundcards found.
    [    2.773756] reg-fixed-voltage regulator-6: Failed to register regulator: -517
    [    4.124454] EXT4-fs (mmcblk1p2): recovery complete
    [    4.130171] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    [    4.138338] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    4.147903] devtmpfs: mounted
    [    4.152155] Freeing unused kernel memory: 1792K
    [    4.156785] Run /sbin/init as init process
    [    4.430027] systemd[1]: System time before build time, advancing clock.
    [    4.514676] NET: Registered protocol family 10
    [    4.520220] Segment Routing with IPv6
    [    4.550099] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD)
    [    4.572217] systemd[1]: Detected architecture arm64.
    [    4.621987] systemd[1]: Set hostname to <am62xx-evm>.
    [    4.634687] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.641373] systemd[1]: Initializing machine ID from random generator.
    [    4.951020] systemd[1]: /lib/systemd/system/startwlansta.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    4.965524] systemd[1]: /lib/systemd/system/startwlanap.service:7: Unknown key name 'After' in section 'Service', ignoring.
    [    5.105678] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.112647] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    5.124997] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    5.136600] systemd[1]: Created slice system-getty.slice.
    [    5.159348] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.167277] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    5.192308] systemd[1]: Created slice User and Session Slice.
    [    5.215623] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    5.239496] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    5.263437] systemd[1]: Reached target Paths.
    [    5.279293] systemd[1]: Reached target Remote File Systems.
    [    5.299264] systemd[1]: Reached target Slices.
    [    5.315271] systemd[1]: Reached target Swap.
    [    5.367299] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    5.391380] systemd[1]: Reached target RPC Port Mapper.
    [    5.418352] systemd[1]: Listening on Process Core Dump Socket.
    [    5.439704] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    5.479500] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    5.488346] systemd[1]: Listening on Journal Socket (/dev/log).
    [    5.511907] systemd[1]: Listening on Journal Socket.
    [    5.528071] systemd[1]: Listening on Network Service Netlink Socket.
    [    5.551813] systemd[1]: Listening on udev Control Socket.
    [    5.571612] systemd[1]: Listening on udev Kernel Socket.
    [    5.595969] systemd[1]: Mounting Huge Pages File System...
    [    5.615746] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.643718] systemd[1]: Mounting Kernel Debug File System...
    [    5.666119] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    5.688018] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    5.715651] systemd[1]: Starting Start psplash boot splash screen...
    [    5.750802] systemd[1]: Starting RPC Bind...
    [    5.767696] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.782240] systemd[1]: Starting Journal Service...
    [    5.810167] systemd[1]: Starting Load Kernel Modules...
    [    5.834644] cryptodev: loading out-of-tree module taints kernel.
    [    5.836288] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems   5.848481] cryptodev: driver 1.10 loaded.
    [0m...
    [    5.865385] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
    [    5.866076] systemd[1]: Starting udev Coldplug all Devices...
    [    5.893907] systemd[1]: Started RPC Bind.
    [    5.908089] systemd[1]: Started Journal Service.
    [  OK  ] Started Create list of sta… nodes for the current kernel.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [    6.193061] systemd-journald[192]: Received client request to flush runtime journal.
             Starting Run pending postinsts...
    [  OK  ] St
  • issue Resolved .
    Andrew
