PROCESSOR-SDK-AM62X: Not able to detect sdcard in the kernel ,we cant see the sd card(mmc1) messages in the bootup logs thatswhy our AM62X device is not bootup through SDCARD
Part Number: PROCESSOR-SDK-AM62X
Other Parts Discussed in Thread: AM625
please find Boot up logs :
U-Boot SPL 2021.01-g74fc69c889 (May 30 2022 - 16:40:44 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
Trying to boot from MMC2
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.6(release):08.03.00.003-dirty
NOTICE:  BL31: Built : 16:35:46, May 30 2022
I/TC:
I/TC: OP-TEE version: 3.18.0-rc1-22-g42be8d89 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Thu Jul 14 05:46:35 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html
I/TC: Primary CPU initializing
E/TC:0 0 k3_sec_proxy_verify_thread:108 Queue is busy
E/TC:0 0 k3_sec_proxy_recv:196 Thread SEC_PROXY_RESPONSE_THREAD verification failed. ret = -65523
E/TC:0 0 ti_sci_get_response:101 Message receive failed (-65523)
E/TC:0 0 ti_sci_do_xfer:149 Failed to get response (-65523)
E/TC:0 0 ti_sci_init:378 Unable to communicate with control firmware (-65523)
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x0005b2e8 failed
E/TC:0 0 tee_otp_get_hw_unique_key:86 Could not get HUK
E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x0005b308 failed
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2021.01-00002-g77bcc61275-dirty (Jul 15 2022 - 12:00:58 +0530)
U-Boot 2021.01-00002-g77bcc61275-dirty (Jul 15 2022 - 12:00:58 +0530)
SoC:   AM62X SR1.0
Model: Texas Instruments AM625 SK
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed 1
DRAM:  2 GiB
MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   eth0: ethernet@8000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
1490 bytes read in 2 ms (727.5 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
Running uenvcmd ...
1 bytes read in 2 ms (0 Bytes/s)
Already setup.
18448896 bytes read in 764 ms (23 MiB/s)
44493 bytes read in 5 ms (8.5 MiB/s)
   Loading Device Tree to 000000008fef2000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.109-g9e58028f94 (test@test-ThinkCentre-neo-50t-Gen-3) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, 2
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9db00000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009cafffff]
[    0.000000]   node   0: [mem 0x000000009cb00000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] cma: Reserved 144 MiB at 0x00000000f4000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s49880 r8192 d32040 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=7f00581c-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1836756K/2097152K available (10816K kernel code, 1120K rwdata, 4176K rodata, 1792K init, 433K bss, 112940K reserved, 147456K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
[    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000004] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008470] Console: colour dummy device 80x25
[    0.013061] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023743] pid_max: default: 32768 minimum: 301
[    0.028551] LSM: Security Framework initializing
[    0.033338] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.040919] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.050625] rcu: Hierarchical SRCU implementation.
[    0.055802] Platform MSI: msi-controller@1820000 domain created
[    0.062078] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.071320] EFI services will not be available.
[    0.076191] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.100023] Detected VIPT I-cache on CPU1
[    0.100060] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.100076] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
[    0.100141] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.119369] Detected VIPT I-cache on CPU2
[    0.119396] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.119408] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000
[    0.119446] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.138631] Detected VIPT I-cache on CPU3
[    0.138653] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.138664] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000
[    0.138699] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.138787] smp: Brought up 1 node, 4 CPUs
[    0.218498] SMP: Total of 4 processors activated.
[    0.223310] CPU features: detected: 32-bit EL0 Support
[    0.228579] CPU features: detected: CRC32 instructions
[    0.241383] CPU: All CPU(s) started at EL2
[    0.245591] alternatives: patching kernel code
[    0.251309] devtmpfs: initialized
[    0.260451] KASLR disabled due to lack of seed
[    0.265218] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.275196] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.286734] pinctrl core: initialized pinctrl subsystem
[    0.292735] DMI not present or invalid.
[    0.297192] NET: Registered protocol family 16
[    0.303447] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.310799] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.318873] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.327601] thermal_sys: Registered thermal governor 'step_wise'
[    0.327606] thermal_sys: Registered thermal governor 'power_allocator'
[    0.334151] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.347871] ASID allocator initialised with 65536 entries
[    0.374971] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.381855] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.388716] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.395569] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.403437] cryptd: max_cpu_qlen set to 1000
[    0.410535] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.419573] vcc_5v0: supplied by vmain_pd
[    0.424135] vcc_3v3_sys: supplied by vmain_pd
[    0.429060] vcc_1v8: supplied by vcc_3v3_sys
[    0.434286] iommu: Default domain type: Translated
[    0.439622] SCSI subsystem initialized
[    0.443823] mc: Linux media interface: v0.10
[    0.448210] videodev: Linux video capture interface: v2.00
[    0.453886] pps_core: LinuxPPS API ver. 1 registered
[    0.458961] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.468315] PTP clock support registered
[    0.472353] EDAC MC: Ver: 3.0.0
[    0.476139] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    0.483244] FPGA manager framework
[    0.486803] Advanced Linux Sound Architecture Driver Initialized.
[    0.493929] clocksource: Switched to clocksource arch_sys_counter
[    0.500390] VFS: Disk quotas dquot_6.6.0
[    0.504457] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.516975] NET: Registered protocol family 2
[    0.521701] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.530418] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.539219] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.547435] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.555173] TCP: Hash tables configured (established 16384 bind 16384)
[    0.562078] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.568977] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.576439] NET: Registered protocol family 1
[    0.581345] RPC: Registered named UNIX socket transport module.
[    0.587419] RPC: Registered udp transport module.
[    0.592257] RPC: Registered tcp transport module.
[    0.597067] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.603668] PCI: CLS 0 bytes, default 64
[    0.608536] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.620427] Initialise system trusted keyrings
[    0.625178] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.635461] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.642007] NFS: Registering the id_resolver key type
[    0.647209] Key type id_resolver registered
[    0.651485] Key type id_legacy registered
[    0.655640] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.662495] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.670254] 9p: Installing v9fs 9p2000 file system support
[    0.711858] Key type asymmetric registered
[    0.716055] Asymmetric key parser 'x509' registered
[    0.721083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.728650] io scheduler mq-deadline registered
[    0.733282] io scheduler kyber registered
[    0.739197] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.745536] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.758098] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.777521] brd: module loaded
[    0.787918] loop: module loaded
[    0.791856] megasas: 07.714.04.00-rc1
[    0.799027] tun: Universal TUN/TAP device driver, 1.6
[    0.804693] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.811110] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.817213] sky2: driver version 1.30
[    0.821768] VFIO - User Level meta-driver version: 0.3
[    0.827949] i2c /dev entries driver
[    0.832324] sdhci: Secure Digital Host Controller Interface driver
[    0.838652] sdhci: Copyright(c) Pierre Ossman
[    0.843373] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.850147] ledtrig-cpu: registered to indicate activity on CPUs
[    0.856629] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.864307] optee: probing for conduit method.
[    0.868908] optee: revision 3.17 (42be8d89)
[    0.869199] optee: dynamic shared memory is enabled
[    0.878711] optee: initialized driver
[    0.884361] NET: Registered protocol family 17
[    0.889079] 9pnet: Installing 9P2000 support
[    0.893510] Key type dns_resolver registered
[    0.898097] Loading compiled-in X.509 certificates
[    0.912481] ti-sci 44043000.system-controller: ti,ctx-memory-region is required for suspend but not provided.
[    0.922658] ti-sci 44043000.system-controller: ti_sci_init_suspend failed, mem suspend will be non-functional.
[    0.932901] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.3.2--v08.03.02 (Jolly Jellyfi')
[    1.440838] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    1.496403] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.507455] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.513751] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.522179] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.531514] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.540554] ti-bcdma 485c0100.dma-controller: Number of rings: 82
[    1.548688] ti-bcdma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.559912] ti-pktdma 485c0000.dma-controller: Number of rings: 150
[    1.570080] ti-pktdma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.580675] printk: console [ttyS2] disabled
[    1.585125] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250
[    1.593895] printk: console [ttyS2] enabled
[    1.602338] printk: bootconsole [ns16550a0] disabled
[    1.651979] random: fast init done
[    1.658946] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    1.663963] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.670916] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.676310] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.683033] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.689411] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.695857] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.702094] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    1.708883] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.715307] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.793985] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.804510] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.812611] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.820788] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000002
[    1.834598] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.841374] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    1.847654] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.854782] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.866852] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.890415] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    1.895602] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:10 UTC (10)
[    1.905146] pinctrl-single f4000.pinctrl: pin PIN145 already requested by fa00000.mmc; cannot claim for leds
[    1.915003] pinctrl-single f4000.pinctrl: pin-145 (leds) status -22
[    1.921288] pinctrl-single f4000.pinctrl: could not request pin 145 (PIN145) from group usr-led-pins-default  on device pinctrl-single
[    1.933367] leds-gpio leds: Error applying setting, reverse things back
[    1.940007] leds-gpio: probe of leds failed with error -22
[    1.973453] davinci-mcasp 2b10000.mcasp: IRQ common not found
[    1.984119] mmc0: CQHCI version 5.10
[    2.026512] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    2.093613] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.101741] pca953x 1-0022: supply vcc not found, using dummy regulator
[    2.108478] pca953x 1-0022: using AI
[    2.117154] mmc0: Command Queue Engine enabled
[    2.121624] mmc0: new HS200 MMC card at address 0001
[    2.127242] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    2.131971] mmcblk0boot0: mmc0:0001 G1M15L partition 1 31.5 MiB
[    2.137961] pca953x 1-0022: failed writing register
[    2.138146] mmcblk0boot1: mmc0:0001 G1M15L partition 2 31.5 MiB
[    2.143041] pca953x: probe of 1-0022 failed with error -121
[    2.148923] mmcblk0rpmb: mmc0:0001 G1M15L partition 3 4.00 MiB, chardev (237:0)
[    2.164376]  mmcblk0: p1
[    2.169624] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.179030] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.260018] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.269336] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    2.269896] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.486856] ALSA device list:
[    2.489843]   No soundcards found.
[    2.523051] reg-fixed-voltage regulator-6: Failed to register regulator: -517
[    2.617055] Waiting for root device PARTUUID=7f00581c-02...
[   33.869944] tlv71033: disabling
