.Hi ,
i am working on my customer board , Audio is not enabling in the kernel .
we are using same audio chipset which is used by TI AM62X for our customer board .
i am getting in the boot up logs as
"davinci-mcasp 2b00000.mcasp: IRQ common not found "
[ 1.593944] davinci-mcasp 2b00000.mcasp: IRQ common not found
please find attached Device tree nodes .
&main_i2c1 { pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <100000>; tlv320aic3106: audio-codec@1b { #sound-dai-cells = <0>; compatible = "ti,tlv320aic3106"; reg = <0x1b>; /* Regulators */ AVDD-supply = <&vcc_3v3_sys>; IOVDD-supply = <&vcc_3v3_sys>; DRVDD-supply = <&vcc_3v3_sys>; DVDD-supply = <&vcc_1v8>; }; &mcasp0 { status = "okay"; //added below properties #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&main_mcasp0_pins_default>; op-mode = <0>; /* MCASP_IIS_MODE */ tdm-slots = <2>; serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ 0 1 2 0 0 0 0 0 0 0 0 0 0 0 0 0 >; tx-num-evt = <32>; rx-num-evt = <32>; }; sound { compatible = "simple-audio-card"; simple-audio-card,name = "AM62x-SKEVM"; simple-audio-card,widgets = "Headphone", "Headphone Jack"; simple-audio-card,routing = "Headphone Jack", "HPLOUT", "Headphone Jack", "HPROUT"; simple-audio-card,format = "dsp_b"; simple-audio-card,bitclock-master = <&sound_master>; simple-audio-card,frame-master = <&sound_master>; simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp0>; }; sound_master: simple-audio-card,codec { sound-dai = <&tlv320aic3106>; clocks = <&tlv320_mclk>; }; }; tlv320_mclk: clk-0 { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <12288000>; } //added below node for mcasp0 pinmux main_mcasp0_pins_default: main-mcasp0-pins-default { pinctrl-single,pins = < AM62X_IOPAD(0x019c, PIN_OUTPUT, 0) /* (B18) AM62X_MCASP0_AXR1\G */ AM62X_IOPAD(0x0198, PIN_INPUT, 0) /* (A19) AM62X_MCASP0_AXR2\G */ AM62X_IOPAD(0x01a4, PIN_INPUT, 0) /* (B20) AM62X_MCASP0_ACLKX\G */ AM62X_IOPAD(0x01a8, PIN_INPUT, 0) /* (D20) AM62X_MCASP0_AFSX\G */ /*AM62X_IOPAD(0x01a0, PIN_OUTPUT, 2) (E18) AM62X_AUD_EXT_REF0\G AM62X_IOPAD(0x0194, PIN_OUTPUT, 5) (B19) AM62X_ECAP1_IN_APWM_OUT\G */ >; };
please let me know whether i need to add /configure any thing in thee device tree file ?
Thanks ,
Naresh
Hello Naresh,
Which Kernel version are you using? Also, what happens when you try to use aplay to play a wave file?
Krunal
Hey Krunal ,
its customer board , kernel version : 5.4 .
we didnt tried yet aplay command to test audio .
we are seeing error messages for mcasp as :
davinci-mcasp 2b10000.mcasp: IRQ common not found
root@am62xx-evm:/home# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: AM62xSKEVM [AM62x-SKEVM], device 0: davinci-mcasp.0-tlv320aic3x-hifi tlv320aic3x-hifi-0 [davinci-mcasp.0-tlv320aic3x-hifi tlv320aic3x-hifi-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
root@am62xx-evm:/home# aplay -c 2 -r 44100 -d 10 file_example_WAV_2MG.wav
Playing raw data 'file_example_WAV_2MG.wav' : Unsigned 8 bit, Rate 44100 Hz, Stereo
[ 2378.060551] ti-bcdma 485c0100.dma-controller: chan2 teardown timeout!
Naresh
Hi Krunal ,
i am observing this .
root@am62xx-evm:~# cat /proc/asound/cards
0 [AM62xSKEVM ]: AM62x-SKEVM - AM62x-SKEVM
AM62x-SKEVM
When you ran the above command " aplay -c 2 -r 44100 -d 10 file_example_WAV_2MG.wav", do you see any activity on your output clocks? Is it possible to collect the BCLK and FSYNC clock while running the aplay command?
Krunal
Hi Krunal ,
>> please let me know how to check (i didnt see anything ) .
>> may i know how to collect BLCK and FSYNC clock
Naresh
Hello Naresh,
You need to physically probe the pins and measure the clocks.
Krunal
Hi Bhargav ,
My Audio interface is MCASP0.
MCASP0_ACLK -> BCLK
MCASP0_AFSX -> WCLK
MCASP0_AXR2 -> DIN
MCASP0_AXR1 -> DOUT
Naresh
Hi Bhargav,
in dmesh i am getting :
[ 1071.180615] ti-bcdma 485c0100.dma-controller: chan2 teardown timeout!
[ 1179.212614] ti-bcdma 485c0100.dma-controller: chan2 teardown timeout!
while testing audio i am getting below :
root@am62xx-evm:/home# aplay -c 2 -r 48000 -d 20 -v file_example_WAV_2MG.wav
Playing raw data 'file_example_WAV_2MG.wav' : Unsigned 8 bit, Rate 48000 Hz, Stereo
Plug PCM: Linear conversion PCM (S16_LE)
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : U8
subformat : STD
channels : 2
rate : 48000
exact rate : 48000 (48000/1)
msbits : 8
buffer_size : 24000
period_size : 6000
period_time : 125000
tstamp_mode : NONE
tstamp_type : MONOTONIC
period_step : 1
avail_min : 6000
period_event : 0
start_threshold : 24000
stop_threshold : 24000
silence_threshold: 0
silence_size : 0
boundary : 6755399441055744000
Slave: Hardware PCM card 0 'AM62x-SKEVM' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
access : MMAP_INTERLEAVED
format : S16_LE
subformat : STD
channels : 2
rate : 48000
msbits : 16
buffer_size : 24000
period_size : 6000
tstamp_mode : NONE
period_step : 1
avail_min : 6000
period_event : 0
silence_size : 0
appl_ptr : 0
hw_ptr : 0
I believe the chan2 teardown timeout warning is expected but I will internally check with our dev team and get back to you. Also, are you able to hear anything on the output side? Have you probed the clock to make sure your FSYNC and BCLK are correct.
Krunal
Hi Bhargav ,
Also, are you able to hear anything on the output side? - not yet
could you reply on previous to previous post ?
Thanks ,
Naresh
Hi Naresh,
Let me review the above post and get back to you.
Krunal
Hi Krunal ,
could you please share amixer settings or alsa mixer setting to playback the audio clip ?
Naresh
Naresh,
Are you sure about the kernel version?
Kernel v5.4 doesn't support AM62x.
Hi ,
we used TI SDK - Platform AM62x – BSP bsp_08_03_00_19
song is playing , but Noise is not coming .
Do we need to set amixer settings ? please let me know what changes are required to get the sound ?
root@am62xx-evm:/home# aplay Test_WAV_1MG.wav
Playing WAVE 'Test_WAV_1MG.wav' : [ 417.638574] line = 1389 fun =sound/soc/codecs/tlv320aic3x.c file
Signed 16 bit Little Endian, Rate 8000 Hz, Stereo
[ 588.230254] line = 1054 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_hw_params
[ 588.239951] line = 1203 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_prepare
[ 588.251979] line = 1445 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_set_bias_level
[ 588.259469] line = 1389 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_set_power
X 588.331194] line = 1445 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_set_bias_level
[ 588.341808] line = 1445 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_set_bias_level
[ 588.349922] line = 1224 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_mute
HI Krunal ,
please find Dmesg logs :dmesg | grep aic
[ 2.192001] line = 1784 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_i2c_probe
[ 2.192370] line = 1715 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_configure_ocmv
[ 3.417068] line = 1622 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_probe
[ 3.421025] line = 1535 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_init
[ 3.428372] line = 1511 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_mono_init
[ 3.442918] line = 1009 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_add_widgets
[ 3.454241] line = 1241 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_set_dai_sysclk
[ 3.477933] line = 1258 fun =sound/soc/codecs/tlv320aic3x.c file =aic3x_set_dai_fmt
[ 6.634242] Error: Driver 'tlv320aic3x-codec' is already registered, aborting...
[ 6.785079] Error: Driver 'tlv320aic3x-codec' is already registered, aborting...
[ 9.745364] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.745397] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.759210] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.768170] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.777036] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.785900] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.794756] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.803646] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.812514] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
[ 9.812540] line = 174 fun =sound/soc/codecs/tlv320aic3x.c file =snd_soc_dapm_put_volsw_aic3x
root@am62xx-evm:~#
Naresh
Hi Krunal ,
Now getting some noise while playing .
please find my Device amixer controls :
oot@am62xx-evm:~# amixer Simple mixer control 'PCM',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 127 Mono: Front Left: Playback 100 [79%] [-13.50dB] Front Right: Playback 100 [79%] [-13.50dB] Simple mixer control 'Line',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 9 Mono: Front Left: Playback 9 [100%] [9.00dB] [on] Front Right: Playback 9 [100%] [9.00dB] [on] Simple mixer control 'Line DAC',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 118 Mono: Front Left: Playback 100 [85%] [-9.00dB] Front Right: Playback 100 [85%] [-9.00dB] Simple mixer control 'Line Line2 Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 71 [60%] [-23.50dB] Front Right: 71 [60%] [-23.50dB] Simple mixer control 'Line PGA Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 71 [60%] [-23.50dB] Front Right: 71 [60%] [-23.50dB] Simple mixer control 'Mono',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 9 Mono: Playback 9 [100%] [9.00dB] [on] Simple mixer control 'Mono DAC',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 118 Mono: Front Left: Playback 100 [85%] [-9.00dB] Front Right: Playback 100 [85%] [-9.00dB] Simple mixer control 'Mono Line2 Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 100 [85%] [-9.00dB] Front Right: 100 [85%] [-9.00dB] Simple mixer control 'Mono Mixer DACL1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Mono Mixer DACR1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Mono Mixer Line2L Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Mono Mixer Line2R Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Mono Mixer PGAL Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Mono Mixer PGAR Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Mono PGA Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 100 [85%] [-9.00dB] Front Right: 100 [85%] [-9.00dB] Simple mixer control 'ADC HPF Cut-off',0 Capabilities: enum Items: 'Disabled' '0.0045xFs' '0.0125xFs' '0.025xFs' Item0: 'Disabled' Item1: 'Disabled' Simple mixer control 'AGC',0 Capabilities: pswitch Playback channels: Front Left - Front Right Mono: Front Left: Playback [on] Front Right: Playback [on] Simple mixer control 'De-emphasis',0 Capabilities: pswitch Playback channels: Front Left - Front Right Mono: Front Left: Playback [on] Front Right: Playback [on] Simple mixer control 'HP',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 9 Mono: Front Left: Playback 9 [100%] [9.00dB] [on] Front Right: Playback 9 [100%] [9.00dB] [on] Simple mixer control 'HP DAC',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 118 Mono: Front Left: Playback 100 [85%] [-9.00dB] Front Right: Playback 100 [85%] [-9.00dB] Simple mixer control 'HP Line2 Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 100 [85%] [-9.00dB] Front Right: 100 [85%] [-9.00dB] Simple mixer control 'HP PGA Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 100 [85%] [-9.00dB] Front Right: 100 [85%] [-9.00dB] Simple mixer control 'HPCOM',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 9 Mono: Front Left: Playback 9 [100%] [9.00dB] [on] Front Right: Playback 9 [100%] [9.00dB] [on] Simple mixer control 'HPCOM DAC',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 118 Mono: Front Left: Playback 100 [85%] [-9.00dB] Front Right: Playback 100 [85%] [-9.00dB] Simple mixer control 'HPCOM Line2 Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 100 [85%] [-9.00dB] Front Right: 100 [85%] [-9.00dB] Simple mixer control 'HPCOM PGA Bypass',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 118 Front Left: 100 [85%] [-9.00dB] Front Right: 100 [85%] [-9.00dB] Simple mixer control 'Left AGC Attack time',0 Capabilities: enum Items: '8ms' '11ms' '16ms' '20ms' Item0: '8ms' Simple mixer control 'Left AGC Decay time',0 Capabilities: enum Items: '100ms' '200ms' '400ms' '500ms' Item0: '100ms' Simple mixer control 'Left AGC Target level',0 Capabilities: enum Items: '-5.5dB' '-8dB' '-10dB' '-12dB' '-14dB' '-17dB' '-20dB' '-24dB' Item0: '-5.5dB' Simple mixer control 'Left DAC Mux',0 Capabilities: enum Items: 'DAC_L1' 'DAC_L3' 'DAC_L2' Item0: 'DAC_L1' Simple mixer control 'Left HP Mixer DACL1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left HP Mixer DACR1',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 118 Mono: Playback 100 [85%] [-9.00dB] [off] Simple mixer control 'Left HP Mixer Line2L Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left HP Mixer Line2R Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Left HP Mixer PGAL Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left HP Mixer PGAR Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [on] Simple mixer control 'Left HPCOM Mixer DACL1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left HPCOM Mixer DACR1',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 118 Mono: Playback 100 [85%] [-9.00dB] [off] Simple mixer control 'Left HPCOM Mixer Line2L Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left HPCOM Mixer Line2R Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Left HPCOM Mixer PGAL Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left HPCOM Mixer PGAR Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Left HPCOM Mux',0 Capabilities: enum Items: 'differential of HPLOUT' 'constant VCM' 'single-ended' Item0: 'differential of HPLOUT' Simple mixer control 'Left Line Mixer DACL1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left Line Mixer DACR1',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 118 Mono: Playback 100 [85%] [-9.00dB] [off] Simple mixer control 'Left Line Mixer Line2L Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Line Mixer Line2R Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Left Line Mixer PGAL Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Line Mixer PGAR Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Left Line1L Mux',0 Capabilities: enum Items: 'single-ended' 'differential' Item0: 'single-ended' Simple mixer control 'Left Line1R Mux',0 Capabilities: enum Items: 'single-ended' 'differential' Item0: 'single-ended' Simple mixer control 'Left Line2L Mux',0 Capabilities: enum Items: 'single-ended' 'differential' Item0: 'single-ended' Simple mixer control 'Left PGA Mixer Line1L',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Left PGA Mixer Line1R',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left PGA Mixer Line2L',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left PGA Mixer Mic3L',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left PGA Mixer Mic3R',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Output Driver Power-On time',0 Capabilities: enum Items: '0us' '10us' '100us' '1ms' '10ms' '50ms' '100ms' '200ms' '400ms' '800ms' '2s' '4s' Item0: '0us' Simple mixer control 'Output Driver Ramp-up step',0 Capabilities: enum Items: '0ms' '1ms' '2ms' '4ms' Item0: '0ms' Simple mixer control 'PGA',0 Capabilities: cvolume cswitch Capture channels: Front Left - Front Right Limits: Capture 0 - 119 Front Left: Capture 100 [84%] [50.00dB] [on] Front Right: Capture 100 [84%] [50.00dB] [on] Simple mixer control 'Right AGC Attack time',0 Capabilities: enum Items: '8ms' '11ms' '16ms' '20ms' Item0: '8ms' Simple mixer control 'Right AGC Decay time',0 Capabilities: enum Items: '100ms' '200ms' '400ms' '500ms' Item0: '100ms' Simple mixer control 'Right AGC Target level',0 Capabilities: enum Items: '-5.5dB' '-8dB' '-10dB' '-12dB' '-14dB' '-17dB' '-20dB' '-24dB' Item0: '-5.5dB' Simple mixer control 'Right DAC Mux',0 Capabilities: enum Items: 'DAC_R1' 'DAC_R3' 'DAC_R2' Item0: 'DAC_R1' Simple mixer control 'Right HP Mixer DACL1',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 118 Mono: Playback 100 [85%] [-9.00dB] [off] Simple mixer control 'Right HP Mixer DACR1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right HP Mixer Line2L Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Right HP Mixer Line2R Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right HP Mixer PGAL Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Right HP Mixer PGAR Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right HPCOM Mixer DACL1',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 118 Mono: Playback 100 [85%] [-9.00dB] [off] Simple mixer control 'Right HPCOM Mixer DACR1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right HPCOM Mixer Line2L Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Right HPCOM Mixer Line2R Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right HPCOM Mixer PGAL Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Right HPCOM Mixer PGAR Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right HPCOM Mux',0 Capabilities: enum Items: 'differential of HPROUT' 'constant VCM' 'single-ended' 'differential of HPLCOM' 'external feedback' Item0: 'differential of HPROUT' Simple mixer control 'Right Line Mixer DACL1',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 118 Mono: Playback 100 [85%] [-9.00dB] [off] Simple mixer control 'Right Line Mixer DACR1',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right Line Mixer Line2L Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Right Line Mixer Line2R Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Line Mixer PGAL Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 118 Mono: 100 [85%] [-9.00dB] Playback [off] Simple mixer control 'Right Line Mixer PGAR Bypass',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Line1L Mux',0 Capabilities: enum Items: 'single-ended' 'differential' Item0: 'single-ended' Simple mixer control 'Right Line1R Mux',0 Capabilities: enum Items: 'single-ended' 'differential' Item0: 'single-ended' Simple mixer control 'Right Line2R Mux',0 Capabilities: enum Items: 'single-ended' 'differential' Item0: 'single-ended' Simple mixer control 'Right PGA Mixer Line1L',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right PGA Mixer Line1R',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right PGA Mixer Line2R',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right PGA Mixer Mic3L',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on] Simple mixer control 'Right PGA Mixer Mic3R',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] root@am62xx-evm:~# CTRL-A Z for hel
root@am62xx-evm:~# amixer scontrols Simple mixer control 'PCM',0 Simple mixer control 'Line',0 Simple mixer control 'Line DAC',0 Simple mixer control 'Line Line2 Bypass',0 Simple mixer control 'Line PGA Bypass',0 Simple mixer control 'Mono',0 Simple mixer control 'Mono DAC',0 Simple mixer control 'Mono Line2 Bypass',0 Simple mixer control 'Mono Mixer DACL1',0 Simple mixer control 'Mono Mixer DACR1',0 Simple mixer control 'Mono Mixer Line2L Bypass',0 Simple mixer control 'Mono Mixer Line2R Bypass',0 Simple mixer control 'Mono Mixer PGAL Bypass',0 Simple mixer control 'Mono Mixer PGAR Bypass',0 Simple mixer control 'Mono PGA Bypass',0 Simple mixer control 'ADC HPF Cut-off',0 Simple mixer control 'AGC',0 Simple mixer control 'De-emphasis',0 Simple mixer control 'HP',0 Simple mixer control 'HP DAC',0 Simple mixer control 'HP Line2 Bypass',0 Simple mixer control 'HP PGA Bypass',0 Simple mixer control 'HPCOM',0 Simple mixer control 'HPCOM DAC',0 Simple mixer control 'HPCOM Line2 Bypass',0 Simple mixer control 'HPCOM PGA Bypass',0 Simple mixer control 'Left AGC Attack time',0 Simple mixer control 'Left AGC Decay time',0 Simple mixer control 'Left AGC Target level',0 Simple mixer control 'Left DAC Mux',0 Simple mixer control 'Left HP Mixer DACL1',0 Simple mixer control 'Left HP Mixer DACR1',0 Simple mixer control 'Left HP Mixer Line2L Bypass',0 Simple mixer control 'Left HP Mixer Line2R Bypass',0 Simple mixer control 'Left HP Mixer PGAL Bypass',0 Simple mixer control 'Left HP Mixer PGAR Bypass',0 Simple mixer control 'Left HPCOM Mixer DACL1',0 Simple mixer control 'Left HPCOM Mixer DACR1',0 Simple mixer control 'Left HPCOM Mixer Line2L Bypass',0 Simple mixer control 'Left HPCOM Mixer Line2R Bypass',0 Simple mixer control 'Left HPCOM Mixer PGAL Bypass',0 Simple mixer control 'Left HPCOM Mixer PGAR Bypass',0 Simple mixer control 'Left HPCOM Mux',0 Simple mixer control 'Left Line Mixer DACL1',0 Simple mixer control 'Left Line Mixer DACR1',0 Simple mixer control 'Left Line Mixer Line2L Bypass',0 Simple mixer control 'Left Line Mixer Line2R Bypass',0 Simple mixer control 'Left Line Mixer PGAL Bypass',0 Simple mixer control 'Left Line Mixer PGAR Bypass',0 Simple mixer control 'Left Line1L Mux',0 Simple mixer control 'Left Line1R Mux',0 Simple mixer control 'Left Line2L Mux',0 Simple mixer control 'Left PGA Mixer Line1L',0 Simple mixer control 'Left PGA Mixer Line1R',0 Simple mixer control 'Left PGA Mixer Line2L',0 Simple mixer control 'Left PGA Mixer Mic3L',0 Simple mixer control 'Left PGA Mixer Mic3R',0 Simple mixer control 'Output Driver Power-On time',0 Simple mixer control 'Output Driver Ramp-up step',0 Simple mixer control 'PGA',0 Simple mixer control 'Right AGC Attack time',0 Simple mixer control 'Right AGC Decay time',0 Simple mixer control 'Right AGC Target level',0 Simple mixer control 'Right DAC Mux',0 Simple mixer control 'Right HP Mixer DACL1',0 Simple mixer control 'Right HP Mixer DACR1',0 Simple mixer control 'Right HP Mixer Line2L Bypass',0 Simple mixer control 'Right HP Mixer Line2R Bypass',0 Simple mixer control 'Right HP Mixer PGAL Bypass',0 Simple mixer control 'Right HP Mixer PGAR Bypass',0 Simple mixer control 'Right HPCOM Mixer DACL1',0 Simple mixer control 'Right HPCOM Mixer DACR1',0 Simple mixer control 'Right HPCOM Mixer Line2L Bypass',0 Simple mixer control 'Right HPCOM Mixer Line2R Bypass',0 Simple mixer control 'Right HPCOM Mixer PGAL Bypass',0 Simple mixer control 'Right HPCOM Mixer PGAR Bypass',0 Simple mixer control 'Right HPCOM Mux',0 Simple mixer control 'Right Line Mixer DACL1',0 Simple mixer control 'Right Line Mixer DACR1',0 Simple mixer control 'Right Line Mixer Line2L Bypass',0 Simple mixer control 'Right Line Mixer Line2R Bypass',0 Simple mixer control 'Right Line Mixer PGAL Bypass',0 Simple mixer control 'Right Line Mixer PGAR Bypass',0 Simple mixer control 'Right Line1L Mux',0 Simple mixer control 'Right Line1R Mux',0 Simple mixer control 'Right Line2R Mux',0 Simple mixer control 'Right PGA Mixer Line1L',0 Simple mixer control 'Right PGA Mixer Line1R',0 Simple mixer control 'Right PGA Mixer Line2R',0 Simple mixer control 'Right PGA Mixer Mic3L',0 Simple mixer control 'Right PGA Mixer Mic3R',0
Naresh.
Have you tried running the above on the AM62x-SK EVM?
Krunal
