Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
AM625: AM625 USB0 can only enumerate once as device
Part Number: AM625
Other Parts Discussed in Thread: TPS65988
Hi, USB Owner;
I encountered a problem. After the system is loaded, set USB0 to peripheral mode. the device can only be enumerated once, the USB port cannot be enumerated again.
steps as follows:
insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/libcomposite.ko
insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/function/usb_f_printer.ko
insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/legacy/g_printer.ko
When the device cannot be enumerated, it needs to be powered off and then loaded to enumerate;
dv1912_usb_host.txt
25:39  [ 2461.258907]  [0:    kworker/0:0: 4780] usb 1-1.2: new high-speed USB device number 9 using xhci-hcd
25:39  [ 2461.376557]  [0:    kworker/0:0: 4780] usb 1-1.2: generic_probe: slot_id = 2, idVendor=0525, idProduct=a4a8
25:39  [ 2461.406625]  [0:    kworker/0:0: 4780] usblp 1-1.2:1.0: usblp0: USB Bidirectional printer dev 9 if 0 alt 0 proto 2 vid 0x0525 pid 0xA4A8
25:39  [ 2461.419147]  [0:    kworker/0:0: 4780] usb_notify: call_device_notify device
25:39  [ 2461.426358]  [0:    kworker/0:0: 4780] usb_notify: send_otg_notify event=device_connect(20) enable=1
25:39  [ 2461.435615]  [0:    kworker/0:0: 4780] usb_notify: extra_notifier_callback event=device_connect(20)
25:39  [ 2461.445244]  [0:    kworker/0:0: 4780] usb_notify: extra_notify_state+ event=device_connect(20), enable=on
25:39  [ 2461.454999]  [0:    kworker/0:0: 4780] usb_notify: extra_notify_state- event=device_connect(20), cable=none
25:39  [ 2461.464895]  [0:    kworker/0:0: 4780] usb_notify: check_gamepad_device : product=Printer Gadget
25:39  [ 2461.473815]  [0:    kworker/0:0: 4780] usb_notify: check_lanhub_device : product=Printer Gadget
25:39  [ 2461.482693]  [0:    kworker/0:0: 4780] usb_notify: call_battery_notify : VID : 0x525, PID : 0xa4a8, on=1, count=1
25:39  [ 2461.493516]  [0:    kworker/0:0: 4780] usb_notify: send_otg_notify event=smtd_ext_current(18) enable=1
25:39  [ 2461.502946]  [0:    kworker/0:0: 4780] usb_notify: extra_notifier_callback event=smtd_ext_current(18)
25:39  [ 2461.512318]  [0:    kworker/0:0: 4780] usb_notify: extra_notify_state+ event=smtd_ext_current(18), enable=on
25:39  [ 2461.522237]  [0:    kworker/0:0: 4780] usb_notify: No smart dock!!!!!!
25:39  [ 2461.528860]  [0:    kworker/0:0: 4780] usb_notify: extra_notify_state- event=smtd_ext_current(18), cable=none
25:39  [ 2461.539305]  [0:    kworker/0:0: 4780] usb_notify: check_device_speed : attached highspeed device
25:44
25:45  dv1912:/ #
25:45  dv1912:/ #
25:45  dv1912:/ #
25:45  dv1912:/ #
25:45  dv1912:/ #
25:45  dv1912:/ #
25:45  dv1912:/ #
26:09  dv1912:/ # [ 2490.989459]  [0:    kworker/0:0: 4780] usb 1-1.2: USB disconnect, device number 9
26:09  [ 2491.000492]  [0:    kworker/0:0: 4780] usblp0: removed
26:09  [ 2491.008565]  [0:    kworker/0:0: 4780] usb 1-1.2: generic_disconnect: slot_id = 2, idVendor=0525, idProduct=a4a8
26:09  [ 2491.019360]  [0:    kworker/0:0: 4780] usb_notify: call_battery_notify : VID : 0x525, PID : 0xa4a8, on=0, count=0
26:09  [ 2491.029749]  [0:    kworker/0:0: 4780] usb_notify: send_otg_notify event=smtd_ext_current(18) enable=0
26:09  [ 2491.039149]  [0:    kworker/0:0: 4780] usb_notify: extra_notifier_callback event=smtd_ext_current(18)
26:09  [ 2491.048513]  [0:    kworker/0:0: 4780] usb_notify: extra_notify_state+ event=smtd_ext_current(18), enable=off
26:09  [ 2491.058544]  [0:    kworker/0:0: 4780] usb_notify: No smart dock!!!!!!
26:09  [ 2491.065218]  [0:    kworker/0:0: 4780] usb_notify: extra_notify_state- event=smtd_ext_current(18), cable=none
26:14
26:14  dv1912:/ #
26:15  dv1912:/ #
am625_usb_device.txt
20:24:38
20:24:38 _____                    _____           _         _
20:24:38|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
20:24:38|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
20:24:38|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
20:24:38              |___|                    |___|
20:24:38
20:24:38Arago Project http://arago-project.org am62xx-evm ttyS2
20:24:38
20:24:38Arago 2021.09 am62xx-evm ttyS2
20:24:38
20:24:40am62xx-evm login:
20:24:42am62xx-evm login: root
20:24:43root@am62xx-evm:~#
20:24:57root@am62xx-evm:~# [   33.862246] tlv71033: disabling
20:25:34
20:25:34root@am62xx-evm:~#
20:25:35root@am62xx-evm:~#
20:25:38root@am62xx-evm:~# insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/libcomposite.ko
20:25:38insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/function/usb_f_printer.ko
20:25:38insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/legacy/g_printer.koroot@am62xx-evm:~# insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/function/usb_f_printer.ko
20:25:39root@am62xx-evm:~# insmod /lib/modules/5.10.109-g9e58028f94/kernel/drivers/usb/gadget/legacy/g_printer.ko
20:25:39[   75.463975] printer gadget: printer ready
20:25:39root@am62xx-evm:~# [   75.823567] printer gadget: Using interface 0
20:25:39[   75.832122] printer gadget: Using interface 0
20:25:40
20:25:40root@am62xx-evm:~#
20:25:41root@am62xx-evm:~#
20:26:05root@am62xx-evm:~#
20:26:32root@am62xx-evm:~# [  128.546087] Initializing XFRM netlink socket
