PROCESSOR-SDK-J7200: udhcpd server daemon running failed in CPSW5G since BOOTP packet seems be Not reached to CPSW5G
Part Number: PROCESSOR-SDK-J7200
Other Parts Discussed in Thread: DRA821U, DRA829, TDA4VM, DRA821, TDA4VH
Hi TI
This is an issue reported in SDK 8.2, which is still being reproduced in SDK 8.4.
A customer has been reported that they still can not see ip4 related packet and can not get ip from udhcpd.
Please check if the issue is reproducible. and let us know how to fix the problem.
The following is observed during the test.
Jack
  • Hi Jack,
    Can you explain the test setup and share if you have any scripts to run the tests.
    How is the setup different from EVM? This will help us to reproduce the issue as closely as possible.
    Tanmay
  • Hi Tanmay
    We're still under waiting for test script and test setup configuration from the customer engineer.
    It has been delayed due to email server security issue. Attachment has been blocked. Sorry for delay.
    Jack
  • HI Tanmay
    I test whether ip is assigned to the pc by connecting the pc with ethernet in TI EVB (dhcpd).
    But, The port of CPSW5G is not assigned an IP address.
    I share the test procedure and configuration .
    Environment configuration
    1. EVB(TI): udhcp running => Attach the configuration and uchcpd configuration files, recipe, and service files. (Based on TI SDK8.04)
    udhcpd.zip
       1)  UUnzip udhcpd,copy(/sources/meta-arago/meta-arago-distro/recipes-tisdk)
       2)  Add udhcpd to roots image( yocto-build/sources/meta-arago/meta-arago-distro/recipes-core/images/tisdk-default-image.bb )
       3) Build 및 download
       4)  =>. /usr/sbin/udhcpd -f /etc/udhcpd_tgu.conf &
    2. PC
       1) interface   eth1(line9 in udhcpd_tgu.conf)    => CPSW5G (Fix to eth0 when using CPSW2G)
       2) PC configuration(dhcp)
       3) Assign IP address
             *. Ipconfig /renew(in PC side)
       4) Check packet
             *. EVB(TI) – tcpdump -I eth1 -n &
             *. PC – Wireshark
    3. normal packet using CPSW2G
    eth0_normal.zip
  • First of all, I recommend you to go over the below link to get familiar with our solution.
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/08_04_00_06/exports/docs/psdk_rtos/docs/user_guide/developer_notes_ethfw.html
    Please review the User guide to make sure you have the correct setup on EVM, especially the ethernet cable is connected to the right port on EVM for your testing.
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/08_04_00_06/exports/docs/ethfw/docs/user_guide/index.html
  • What does the above answer have to do with not being able to get an IP from eth1 (CPSW5G) through DHCP in EVM?
    In eth0, it is normal to get an IP assigned by DHCP.
    How do I connect the EVM and PC through eth1 (CPSW5G) and get the IP assigned to the PC by DHCP from the EVM?
    Bootp packet is not seen when looking at the packet with tcpdump in evm. Please support.
  • Subject changed to "udhcpd server daemon running failed in CPSW5G since BOOTP packet seems be Not reached to CPSW5G"
    @Hi Stanley
    They have tried to run udhcpd server program in CPSW5G after verified the running on CPSW2G.
    Could you please teach him to debug in CPSW5G to find out the problrmatic area? He's still unable to dig out the root cause in CPSW5G FW side.
    BTW,
    If you're able to reproduce the DHCP IP assignemnt issue on CPSW5G using udhcpd, Can you help to fix the problem?
    As my understanding, The client PC is unable to get IP address from the DRA821U' udhcpd server side.
    It works from CPSW2G port. But failed at CPSW5G ports. They want to run udhcpd server via CPSW5G from their custom board which does not include CPSW2G port.
  • Hi All,
    The packets sent by the DHCP Client is broadcast packet is not reaching the A72. By default, the ethfw does not transfer the broadcast and multicast packets to all the cores. This would result in the DHCP server not receiving any request.
    The solution to this would be to enable intercore ethernet support. This would ensure that the multicast and broadcast packets are forwarded to the A72 core. But the implementation of the intercore ethernet is through creation of another interface on linux called tap interface.
    To tie the eth1 and tap interface together, you can create a bridge interface with this two interfaces and run the dhcp server on this interface. This isn't tested on TI side, but this should work.
    To create a tap interface : Please see this. Make sure that the flag "ETHFW_INTERCORE_ETH_SUPPORT" is "yes" and "ETHFW_PROXY_ARP_SUPPORT" flag is "no". These flags can be changed in [RTOS-SDK-INSTALL-DIR]/ethfw/ethfw_build_flags.mak
    After the changes, you will have to do a rebuild for ethfw and update the binary in the linux filesystem.
    To create bridge : Run these commands from linux user space. After this bind the DHCP server to this br0. The bridge interface can also be configured from systemd-network service. The interface br0 will be the interface to use after this.
    ip link add name br0 type bridge
    ip link set dev br0 up
    ip link set dev tap0 master br0
    ip link set dev eth1 master br0
    Can you try this and let me know the results.
    Tanmay
  • Hi Tanmay.
    Thanks for your kind support.
    As they followed with your suggestion,, the ip address is assigned with the bootp packet returend, But Ping is failed.
    The below is the test result. Please check the problem.
    1) Download ethfw with two flags set below in Ethfw to linux filesystem.
    ETHFW_INTERCORE_ETH_SUPPORT=yes
    ETHFW_PROXY_ARP_SUPPORT=no
    2) Create tab interface:  Create br0 after porting the source to RootFS with "<RTOS>/ethfw/apps/tap" code
    3) br0 gateway ip assignment and interface check
    4) Run Udhcpd and check ip allocation (confirm pc receives 192.168.5.11)
    A. EVM
    B. PC
    5) Packet check
    A. Check the interface status of the window after IP allocation: Rx does not work
    B.  Wireshark: only arp packets observed
    C, Tcpdump (EVM): Replying to arp packets
    6) Ping progress (PC -> EVM): No ping
    Jack
  • Hi Jack,
    Can you do the following experiment and share the result :
    • Start with a new boot.
    • run the command `ethtool -t eth1`
    • Run a ping test from PC to EVM for around 10 seconds
    • run the command `ethtool -t eth1` again
    After this please share the output of ethfw logs captured at MAIN UART 2.
    Tanmay
  • Hi Tanmay
    Please find the test result what Customer tried.
    Can you please check the below?
    * Run the command 'ethtool -t eth1'
    The log before and after pinging from pc to EVM for 10 seconds is the same as below.
    * After this please share the output of ethfw logs captured at MAIN UART 2.
    The followings is the log from Ethfw.
    root@j7200-evm:/etc/systemd/system# cat /sys/kernel/debug/remoteproc/remoteproc*/trace0
    Sciclient_boardCfgRm init Passed
    DM Built On: Jun 16 2022 04:04:08
    Sciserver Version: v2022.01.1.0-REL.CORESDK.08.02.01.03-1-g59713
    RM_PM_HAL Version: REL.CORESDK.08.02.01.03-1-g59713
    Starting Sciserver..... PASSED
    IPC_echo_test (core : mcu1_0) .....
    mcu1_0 <--> mcu2_1, Ping- 10000, pong - 10000 completed
                CPSW Ethernet Firmware
    ETHFW: Shared multicasts (software fanout):
      01:00:5e:00:00:01
      01:00:5e:00:00:fb
      01:00:5e:00:00:fc
      33:33:00:00:00:01
      33:33:ff:1d:92:c2
      01:80:c2:00:00:00
      01:80:c2:00:00:03
    ETHFW: Reserved multicasts:
      01:80:c2:00:00:0e
      01:1b:19:00:00:00
    EnetMcm: CPSW_5G on MAIN NAVSS
    PHY 16 is alive
    PHY 17 is alive
    PHY 18 is alive
    PHY 19 is alive
    EnetPhy_bindDriver: PHY 16: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 17: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 18: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 19: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    ETHFW Version   : 0.02.00
    ETHFW Build Date: Feb  2, 2022
    ETHFW Build Time: 05:31:12
    ETHFW Commit SHA: bd5a13f4
    Starting lwIP, local interface IP is dhcp-enabled
    Host MAC address: 70:ff:76:1d:92:c3
    [LWIPIF_LWIP] Enet LLD netif initialized successfully
    [LWIPIF_LWIP_IC] Interface started successfully
    [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
    Added interface 'br4', IP is 0.0.0.0
    CpswProxyServer: Virtual port configuration:
      mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
      mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
      mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
      mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
    CpswProxyServer: initialization completed (core: mcu2_0)
    CpswMacPort_checkSgmiiStatus: MAC 2: SGMII link parter config port: link up: 1-Gbps Full-Duplex
    Cpsw_handleLinkUp: Port 2: Link up: 1-Gbps Full-Duplex
    REMOTE_SERVICE: Init ... !!!
    REMOTE_SERVICE: Init ... Done !!!
    Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:5
    Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:85, FlowIdxOffset:1
    Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6,mode:disable
    Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:84, FlowIdxOffset:0
    Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:7, Policer Entry:2
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0
    CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a570e8,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c000000
    Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c020000
    Function:CpswProxyServer_clientNotifyHandlerCb,HostId:0,Handle:38acb7e6,CoreKey:a2a570e8,NotifyId:RPMSG_KDRV_TP_ETHSWITCH_CLIENTNOTIFY_DUMPSTATS,NotifyLen
         0: Vlanid: 012c, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff RAW:[0 212c1ff1 ff0001ff]
         1: Vlanid: 0000, UTagged: 13, Mult: 13, UMult: 13, Member: 13 RAW:[0 20000130 13013013]
         2: Vlanid: 0001, UTagged: d, Mult: d, UMult: 0, Member: d RAW:[0 200100d0 0d00000d]
         3: Address: ffffffffffff, Member:01f Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[7c 1000ffff ffffffff]
         4: Address: 70ff761d92c3, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c3]
         5: EtherType: 0806 RAW:[1 20000000 00000806]
         6: Address: 70ff761d92c2, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c2]
         7: Address: 70ff761d92c1, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[0 100070ff 761d92c1]
         8: Address: 333300000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10003333 00000001]
         9: Address: 01005e000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000100 5e000001]
        10: Address: 3333ff1d92c1, Member:00d Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[34 10003333 ff1d92c1]
        11: Address: 0180c2000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000000]
        12: Address: 0180c2000003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000003]
        13: Address: 3333000000fb, Member:00d Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[34 10003333 000000fb]
        14: Address: 333300010003, Member:00d Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[34 10003333 00010003]
    497 Free Entries
        0: POLICER_DST_MAC,ALE Index: 3
        0: POLICER_ETHERTYPE,ALE Index: 5
        0: POLICER_THREAD,THREAD ID:4
        0: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        1: POLICER_PORT, PORT_NUM: 1 ISTRUNK:0
        1: POLICER_THREAD,THREAD ID:1
        1: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
        2: POLICER_DST_MAC,ALE Index: 7
        2: POLICER_THREAD,THREAD ID:0
        2: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
        3: POLICER_DST_MAC,ALE Index: 10
        3: POLICER_THREAD,THREAD ID:0
        3: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        4: POLICER_DST_MAC,ALE Index: 13
        4: POLICER_THREAD,THREAD ID:0
        4: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        5: POLICER_DST_MAC,ALE Index: 14
        5: POLICER_THREAD,THREAD ID:0
        5: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
    58 Free Entries
    Port 0 Statistics
    External Port 0 Statistics
    External Port 1 Statistics
    External Port 2 Statistics
    External Port 3 Statistics
    Added interface 'br4', IP is 192.168.5.12
    EthFw: TimeSync PTP enabled
    Rx Flow for Software Inter-VLAN Routing is up
        15: Address: 0180c200000e, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c200000e]
        16: Address: 011b19000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 1000011b 19000000]
        23: Address: 88366cfad915, Port: 000 Se=0 Bl=0 TOUCH=1 AGE=1 TRUNK=0 RAW:[0 d0018836 6cfad915]
        40: Address: 0a1f96f71101, Port: 000 Se=0 Bl=0 TOUCH=1 AGE=1 TRUNK=0 RAW:[0 d12c0a1f 96f71101]
    493 Free Entries
        6: POLICER_DST_MAC,ALE Index: 15
        6: POLICER_THREAD,THREAD ID:5
        6: POLICER_PIR_IDL_INC_VAL: 279180
        6: POLICER_CIR_IDL_INC_VAL: 279180
        6: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
        7: POLICER_DST_MAC,ALE Index: 16
        7: POLICER_THREAD,THREAD ID:5
        7: POLICER_PIR_IDL_INC_VAL: 279180
        7: POLICER_CIR_IDL_INC_VAL: 279180
        7: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
    56 Free Entries
    Port 0 Statistics
    IPC_echo_test (core : mcu2_1) .....
    mcu2_1 <--> mcu1_0, Ping- 10000, pong - 10000 completed
    Thanks.
    Jack
  • Hi Jack,
    The command "cat /sys/kernel/debug/remoteproc/remoteproc*/trace0" does not print the statistics which i actually wanted to see. Do you have any other way to get CPSW statistics? like running debug gels from CCS.
    If No, then let me know and I will provide you with a script to print relevant statistics.
    Tanmay
  • Hi Tanmay.
    Please provide us with the script to print out. We don't have the relevant stuff.
  • Hi Jack,
    First can you try by running this command after the bridge is setup : "bridge vlan add dev br0 vid 1 pvid untagged self"
    Also for the script, please let me know the MAC_PORT to which the ethernet cable is connected.
    Tanmay
  • Hi Tanmay
    Please find the answers from Customer side. below.
    “bridge vlan add dev br0 vid 1 pvid untagged self “
    --> We are currently testing SDK 8.05 on the EVM board, so we will share the results after setting the binary related to tap tomorrow.
    --> Testing with 2 ports below.
    Thanks.
    Jack
  • Hi
    As shown above, the phenomenon during the test is the same.
  • Hi Jack,
    As you are using EVM and default SDK, you should be able to get ethfw log on MAIN_UART2. When you connect a micro-usb connection to MAIN UART, you would see 4 interfaces coming up on the host device. For Linux, it would be /dev/ttyUSB0 to /dev/ttyUSB3. For windows, it would be 4 com ports. One gives you the comand-line (/dev/ttyUSB0 or 1st COM port). The 3rd instance, /dev/ttyUSB2 or 3rd COM port, will be ehfw logs.
    So you should have easy access to ethfw logs.
    The issue with writing the script is that the logging function in ethfw is clearing the stat registers so I am not able to read the registers.
    Can you please try to get the ethfw logs over uart. Getting stats after this would be easy. You have to follow the following steps :
    Sorry for the confusion caused.
    Tanmay
  • Hi Tanmay
    As customer followed up your suggestion, they are unable to get any logs from MAIN_UART2 as below.
    When testing with the Default evb binary, no logs are taken on the other three ports except the linux log port (MAIN_UART).
    Please check if the default pre-built binary able to produce the ethfw logs.
    Thanks.
    Jack
  • Hi Jack,
    Can you just confirm that you tried COM5. You should get the logs on COM5.
    Tanmay
  • Hi Tanmay
    Yes, COM5 does not show any logs.
    Is it possible to see any log with default binary too?
    Let me check once again this week by my EVM as I am on the biz trip.
    Regard
    Jack
  • Hi Tanmay
    I have the default SDK bianry only. It does not show any EthFW logs via 4x MAIN UARTs and 2x MCU UART ports. I can see only Linux Logs from the first MAIN UART port.
    Please let us know if we're able to see EthFW log from UART port with PSDK fedault binary.
    If I have to enable Log output feature, Also let us know how to enable it.
    Thanks.
    Jack
  • Hi Jack,
    Extremely sorry for the delay.
    You can see this to enable the logs from ethfw :
    In some cases, it might be possible that you do not have a ethfw UART available on board, in those cases a patch needs to be applied to ethfw to enable periodic dump of stats to the IPC buffer which can be viewed from Linux. The patch is available in the following attachment and is tested on SDK 8.6.
    Attachment : CPSW_Periodic_stat_dump.zip
    To apply the patch and build ethfw :
    1. Extract the patch from the attachment.
    2. Go to "[PSDK-RTOS-INSTALL-DIR]/ethfw" and create a git repository there if not one already. Run
      1. git init - to create an empty git repository
      2. git add . - to add all the files to the git repo
      3. git commit -m "Initial Commit" - to do the first commit
    3. Apply the patch "0001-Adds-support-for-periodic-CPSW-stat-collection.patch"
      1. run "git am [Path_to_0001-Adds-support-for-periodic-CPSW-stat-collection.patch]" to apply the patch
    4. Modify the code based on "readme.txt" given in the attachment for your setup and requirements
    5. To build ethfw, go to "[PSDK-RTOS-INSTALL-DIR]/ethfw" and run the following command
      1. make ethfw_all BUILD_SOC_LIST=<SOC_NAME>
        1. <SOC_NAME>=J721E for DRA829 and TDA4VM
        2. <SOC_NAME>=J7200 for DRA821
        3. <SOC_NAME>=J784S4 for TDA4VH
    To read the stats:
    1. The printed stats can be read using the command
      1. cat /sys/kernel/debug/remoteproc/remoteproc*/trace0
    Can you take the stats now and check if any increments are seen on the "txGoodFrames" of the external Port statistics.
    Tanmay
  • Hi Tanmay
    Here's an attachment what the customer obtained after applied your patch.
    root@j7200-evm:~# cat /sys/kernel/debug/remoteproc/remoteproc*/trace0
    DM Built On: Feb  1 2023 16:37:10
    Sciserver Version: v2022.01.1.0-REL.CORESDK.08.06.00.09-14-ge559a+
    RM_PM_HAL Version: REL.CORESDK.08.06.00.09-7-g4da19
    Warning: Using 6 MAC address(es) from static pool
      01:00:5e:00:00:01
      01:00:5e:00:00:fb
      01:00:5e:00:00:fc
      33:33:00:00:00:01
      33:33:ff:1d:92:c2
      01:80:c2:00:00:00
      01:80:c2:00:00:03
      01:80:c2:00:00:0e
      01:1b:19:00:00:00
    Mdio_open: MDIO manual mode enabled
    PHY 16 is alive
    PHY 17 is alive
    PHY 18 is alive
    PHY 19 is alive
    ETHFW Build Date: Apr 24, 2023
    ETHFW Build Time: 14:27:58
    ETHFW Commit SHA:
     NETWORK TASK
     ====== Iteration 1 =====
     Port 0 Statistics
      txGoodFrames            = 4
      txBcastFrames           = 4
      txOctets                = 256
      octetsFrames64          = 4
      netOctets               = 256
      txPri[0]                = 4
      txPriBcnt[0]            = 256
      rxGoodFrames            = 25
      rxBcastFrames           = 4
      rxMcastFrames           = 21
      aleDrop                 = 21
      rxOctets                = 2381
      octetsFrames64          = 8
      octetsFrames65to127     = 13
      octetsFrames128to255    = 4
      netOctets               = 2381
      portMaskDrop            = 21
      aleUnknownBcast         = 1
      aleUnknownBcastBcnt     = 64
    Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:85, FlowIdxOffset:1
    Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6,mode:disable
    Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:84, FlowIdxOffset:0
    Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:6, Policer Entry:1
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0
     ====== Iteration 2 =====
     Port 0 Statistics
      rxGoodFrames            = 7
      rxBcastFrames           = 3
      rxMcastFrames           = 4
      aleDrop                 = 5
      rxOctets                = 1400
      txGoodFrames            = 29
      txBcastFrames           = 29
      txOctets                = 3064
      octetsFrames64          = 15
      octetsFrames65to127     = 16
      octetsFrames256to511    = 5
      netOctets               = 4464
      portMaskDrop            = 5
      txPri[0]                = 29
      txPriBcnt[0]            = 3064
      rxGoodFrames            = 76
      rxBcastFrames           = 29
      rxMcastFrames           = 47
      aleDrop                 = 47
      rxOctets                = 8353
      txGoodFrames            = 2
      txBcastFrames           = 2
      txOctets                = 691
      octetsFrames64          = 23
      octetsFrames65to127     = 37
      octetsFrames128to255    = 14
      octetsFrames256to511    = 4
      netOctets               = 9044
      portMaskDrop            = 47
      aleUnknownBcast         = 1
      txPri[0]                = 1
      txPri[2]                = 1
      txPriBcnt[0]            = 337
      txPriBcnt[2]            = 354
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bcb0a0,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
     ====== Iteration 3 =====
     Port 0 Statistics
      rxGoodFrames            = 54
      rxBcastFrames           = 8
      rxMcastFrames           = 46
      aleDrop                 = 34
      rxOctets                = 8368
      txGoodFrames            = 53
      txBcastFrames           = 41
      txMcastFrames           = 12
      txOctets                = 5552
      octetsFrames64          = 20
      octetsFrames65to127     = 63
      octetsFrames128to255    = 13
      octetsFrames256to511    = 11
      netOctets               = 13920
      portMaskDrop            = 34
      aleUnknownMcast         = 1
      aleUnknownMcastBcnt     = 94
      alePolicyMatch          = 18
      txPri[0]                = 53
      txPriBcnt[0]            = 5552
      rxGoodFrames            = 129
      rxBcastFrames           = 41
      rxMcastFrames           = 88
      aleDrop                 = 76
      rxOctets                = 14193
      txGoodFrames            = 20
      txBcastFrames           = 6
      txMcastFrames           = 14
      txOctets                = 4198
      octetsFrames64          = 28
      octetsFrames65to127     = 83
      octetsFrames128to255    = 29
      octetsFrames256to511    = 9
      netOctets               = 18391
      portMaskDrop            = 76
      aleUnknownBcast         = 1
      alePolicyMatch          = 12
      txPri[0]                = 9
      txPri[2]                = 11
      txPriBcnt[0]            = 1794
      txPriBcnt[2]            = 2404
     ====== Iteration 4 =====
     Port 0 Statistics
      rxGoodFrames            = 63
      rxBcastFrames           = 13
      rxMcastFrames           = 50
      aleDrop                 = 39
      rxOctets                = 10500
      txGoodFrames            = 64
      txBcastFrames           = 48
      txMcastFrames           = 16
      txOctets                = 7032
      octetsFrames64          = 25
      octetsFrames65to127     = 70
      octetsFrames256to511    = 18
      netOctets               = 17532
      portMaskDrop            = 39
      aleUnknownMcast         = 1
      aleUnknownBcast         = 1
      aleUnknownBcastBcnt     = 346
      alePolicyMatch          = 19
      txPri[0]                = 64
      txPriBcnt[0]            = 7032
      rxGoodFrames            = 146
      rxBcastFrames           = 48
      rxMcastFrames           = 98
      aleDrop                 = 82
      rxOctets                = 16361
      txGoodFrames            = 24
      txBcastFrames           = 9
      txMcastFrames           = 15
      txOctets                = 5434
      octetsFrames64          = 33
      octetsFrames65to127     = 91
      octetsFrames128to255    = 32
      octetsFrames256to511    = 14
      netOctets               = 21795
      portMaskDrop            = 82
      aleUnknownMcast         = 1
      aleUnknownMcastBcnt     = 86
      aleUnknownBcast         = 1
      alePolicyMatch          = 16
      txPri[0]                = 10
      txPri[2]                = 14
      txPriBcnt[0]            = 2131
      txPriBcnt[2]            = 3303
     ====== Iteration 5 =====
     Port 0 Statistics
      rxGoodFrames            = 65
      rxBcastFrames           = 13
      rxMcastFrames           = 52
      aleDrop                 = 41
      rxOctets                = 10648
      txGoodFrames            = 86
      txBcastFrames           = 62
      txMcastFrames           = 24
      txOctets                = 9152
      octetsFrames64          = 32
      octetsFrames65to127     = 86
      octetsFrames256to511    = 19
      netOctets               = 19800
      portMaskDrop            = 41
      aleUnknownMcast         = 2
      aleUnknownMcastBcnt     = 168
      aleUnknownBcast         = 1
      alePolicyMatch          = 19
      txPri[0]                = 86
      txPriBcnt[0]            = 9152
      rxGoodFrames            = 176
      rxBcastFrames           = 62
      rxMcastFrames           = 114
      aleDrop                 = 90
      rxOctets                = 19049
      txGoodFrames            = 24
      txBcastFrames           = 9
      txMcastFrames           = 15
      txOctets                = 5434
      octetsFrames64          = 40
      octetsFrames65to127     = 113
      octetsFrames256to511    = 15
      netOctets               = 24483
      portMaskDrop            = 90
      aleUnknownMcast         = 1
      aleUnknownBcast         = 1
      alePolicyMatch          = 24
      txPri[0]                = 10
      txPri[2]                = 14
      txPriBcnt[0]            = 2131
      txPriBcnt[2]            = 3303
     ====== Iteration 6 =====
     Port 0 Statistics
      rxGoodFrames            = 108
      rxBcastFrames           = 23
      rxMcastFrames           = 85
      aleDrop                 = 59
      rxOctets                = 16914
      txGoodFrames            = 92
      txBcastFrames           = 68
      txMcastFrames           = 24
      txOctets                = 9536
      octetsFrames64          = 45
      octetsFrames65to127     = 106
      octetsFrames128to255    = 26
      octetsFrames256to511    = 23
      netOctets               = 26450
      portMaskDrop            = 59
      aleUnknownMcast         = 3
      aleUnknownMcastBcnt     = 282
      aleUnknownBcast         = 1
      alePolicyMatch          = 35
      txPri[0]                = 92
      txPriBcnt[0]            = 9536
      rxGoodFrames            = 182
      rxBcastFrames           = 68
      rxMcastFrames           = 114
      aleDrop                 = 90
      rxOctets                = 19433
      txGoodFrames            = 49
      txBcastFrames           = 18
      txMcastFrames           = 31
      txOctets                = 9563
      octetsFrames64          = 52
      octetsFrames65to127     = 119
      octetsFrames128to255    = 42
      netOctets               = 28996
      portMaskDrop            = 90
      aleUnknownMcast         = 1
      aleUnknownBcast         = 1
      alePolicyMatch          = 24
      txPri[0]                = 26
      txPri[2]                = 23
      txPriBcnt[0]            = 4556
      txPriBcnt[2]            = 5007
     ====== Iteration 7 =====
     Port 0 Statistics
      rxGoodFrames            = 128
      rxBcastFrames           = 27
      rxMcastFrames           = 101
      aleDrop                 = 61
      rxOctets                = 18918
      txGoodFrames            = 108
      txBcastFrames           = 72
      txMcastFrames           = 36
      txOctets                = 10978
      octetsFrames64          = 53
      octetsFrames65to127     = 132
      octetsFrames128to255    = 28
      netOctets               = 29896
      portMaskDrop            = 61
      aleUnknownMcast         = 4
      aleUnknownMcastBcnt     = 489
      aleUnknownBcast         = 1
      alePolicyMatch          = 49
      txPri[0]                = 108
      txPriBcnt[0]            = 10978
      rxGoodFrames            = 206
      rxBcastFrames           = 72
      rxMcastFrames           = 134
      aleDrop                 = 98
      rxOctets                = 21714
      txGoodFrames            = 67
      txBcastFrames           = 22
      txMcastFrames           = 45
      txOctets                = 11419
      octetsFrames64          = 60
      octetsFrames65to127     = 150
      octetsFrames128to255    = 45
      netOctets               = 33133
      portMaskDrop            = 98
      aleUnknownMcast         = 2
      aleUnknownMcastBcnt     = 247
      aleUnknownBcast         = 1
      alePolicyMatch          = 36
      txPri[0]                = 31
      txPri[2]                = 36
      txPriBcnt[0]            = 5019
      txPriBcnt[2]            = 6400
     ====== Iteration 8 =====
     Port 0 Statistics
      rxGoodFrames            = 170
      rxBcastFrames           = 29
      rxMcastFrames           = 141
      aleDrop                 = 85
      rxOctets                = 24402
      txGoodFrames            = 126
      txBcastFrames           = 74
      txMcastFrames           = 52
      txOctets                = 12966
      octetsFrames64          = 55
      octetsFrames65to127     = 178
      octetsFrames256to511    = 31
      netOctets               = 37368
      portMaskDrop            = 85
      aleUnknownMcast         = 6
      aleUnknownMcastBcnt     = 629
      aleUnknownBcast         = 1
      alePolicyMatch          = 65
      txPri[0]                = 126
      txPriBcnt[0]            = 12966
      rxGoodFrames            = 228
      rxBcastFrames           = 74
      rxMcastFrames           = 154
      aleDrop                 = 102
      rxOctets                = 24078
      txGoodFrames            = 85
      txBcastFrames           = 24
      txMcastFrames           = 61
      txOctets                = 13407
      octetsFrames64          = 62
      octetsFrames65to127     = 186
      octetsFrames256to511    = 20
      netOctets               = 37485
      portMaskDrop            = 102
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      alePolicyMatch          = 52
      txPri[0]                = 33
      txPri[2]                = 52
      txPriBcnt[0]            = 5431
      txPriBcnt[2]            = 7976
     ====== Iteration 9 =====
     Port 0 Statistics
      rxGoodFrames            = 205
      rxBcastFrames           = 49
      rxMcastFrames           = 156
      aleDrop                 = 89
      rxOctets                = 29566
      txGoodFrames            = 154
      txBcastFrames           = 90
      txMcastFrames           = 64
      txOctets                = 16212
      octetsFrames64          = 61
      octetsFrames65to127     = 223
      octetsFrames128to255    = 38
      octetsFrames256to511    = 37
      netOctets               = 45778
      portMaskDrop            = 89
      aleUnknownMcast         = 7
      aleUnknownMcastBcnt     = 868
      aleUnknownBcast         = 3
      aleUnknownBcastBcnt     = 1038
      alePolicyMatch          = 77
      txPri[0]                = 154
      txPriBcnt[0]            = 16212
      rxGoodFrames            = 276
      rxBcastFrames           = 90
      rxMcastFrames           = 186
      aleDrop                 = 122
      rxOctets                = 29392
      txGoodFrames            = 116
      txBcastFrames           = 43
      txMcastFrames           = 73
      txOctets                = 17682
      octetsFrames64          = 72
      octetsFrames65to127     = 243
      octetsFrames128to255    = 52
      octetsFrames256to511    = 25
      netOctets               = 47074
      portMaskDrop            = 122
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      alePolicyMatch          = 64
      txPri[0]                = 50
      txPri[2]                = 66
      txPriBcnt[0]            = 7676
      txPriBcnt[2]            = 10006
     ====== Iteration 10 =====
     Port 0 Statistics
      rxGoodFrames            = 278
      rxBcastFrames           = 85
      rxMcastFrames           = 188
      aleDrop                 = 89
      rxOctets                = 38420
      txGoodFrames            = 217
      txBcastFrames           = 121
      txMcastFrames           = 96
      txOctets                = 23016
      octetsFrames64          = 82
      octetsFrames65to127     = 321
      octetsFrames128to255    = 46
      octetsFrames256to511    = 46
      netOctets               = 61436
      portMaskDrop            = 94
      aleUnknownMcast         = 7
      aleUnknownBcast         = 5
      aleUnknownBcastBcnt     = 1730
      alePolicyMatch          = 109
      txPri[0]                = 217
      txPriBcnt[0]            = 23016
      rxGoodFrames            = 397
      rxBcastFrames           = 121
      rxMcastFrames           = 276
      aleDrop                 = 180
      rxOctets                = 42484
      txGoodFrames            = 184
      txBcastFrames           = 79
      txMcastFrames           = 105
      txOctets                = 26216
      octetsFrames64          = 95
      octetsFrames65to127     = 380
      octetsFrames128to255    = 72
      octetsFrames256to511    = 34
      netOctets               = 68700
      portMaskDrop            = 180
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      alePolicyMatch          = 96
      txPri[0]                = 83
      txPri[2]                = 101
      txPriBcnt[0]            = 11888
      txPriBcnt[2]            = 14328
     ====== Iteration 11 =====
     Port 0 Statistics
      rxGoodFrames            = 313
      rxBcastFrames           = 100
      rxMcastFrames           = 200
      aleDrop                 = 89
      rxOctets                = 41236
      txGoodFrames            = 244
      txBcastFrames           = 136
      txMcastFrames           = 108
      txOctets                = 25320
      octetsFrames64          = 108
      octetsFrames65to127     = 357
      netOctets               = 66556
      portMaskDrop            = 102
      aleUnknownMcast         = 7
      aleUnknownBcast         = 5
      alePolicyMatch          = 121
      txPri[0]                = 244
      txPriBcnt[0]            = 25320
      rxGoodFrames            = 452
      rxBcastFrames           = 136
      rxMcastFrames           = 316
      aleDrop                 = 208
      rxOctets                = 49008
      txGoodFrames            = 211
      txBcastFrames           = 94
      txMcastFrames           = 117
      txOctets                = 28520
      octetsFrames64          = 113
      octetsFrames65to127     = 428
      octetsFrames128to255    = 88
      netOctets               = 77528
      portMaskDrop            = 208
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      alePolicyMatch          = 108
      txPri[0]                = 98
      txPri[2]                = 113
      txPriBcnt[0]            = 13040
      txPriBcnt[2]            = 15480
     ====== Iteration 12 =====
     Port 0 Statistics
      rxGoodFrames            = 341
      rxBcastFrames           = 107
      rxMcastFrames           = 214
      aleDrop                 = 91
      rxOctets                = 43552
      txGoodFrames            = 263
      txBcastFrames           = 143
      txMcastFrames           = 120
      txOctets                = 27040
      octetsFrames64          = 129
      octetsFrames65to127     = 383
      netOctets               = 70592
      portMaskDrop            = 111
      aleUnknownMcast         = 7
      aleUnknownBcast         = 5
      alePolicyMatch          = 133
      txPri[0]                = 263
      txPriBcnt[0]            = 27040
      rxGoodFrames            = 488
      rxBcastFrames           = 144
      rxMcastFrames           = 344
      aleDrop                 = 224
      rxOctets                = 52632
      txGoodFrames            = 230
      txBcastFrames           = 101
      txMcastFrames           = 129
      txOctets                = 30240
      octetsFrames64          = 128
      octetsFrames65to127     = 464
      octetsFrames128to255    = 92
      netOctets               = 82872
      portMaskDrop            = 224
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      alePolicyMatch          = 120
      txPri[0]                = 105
      txPri[2]                = 125
      txPriBcnt[0]            = 13488
      txPriBcnt[2]            = 16752
     ====== Iteration 13 =====
     Port 0 Statistics
      rxGoodFrames            = 371
      rxBcastFrames           = 122
      rxMcastFrames           = 222
      aleDrop                 = 91
      rxOctets                = 46460
      txGoodFrames            = 285
      txBcastFrames           = 157
      txMcastFrames           = 128
      txOctets                = 28856
      octetsFrames64          = 151
      octetsFrames65to127     = 411
      octetsFrames256to511    = 48
      netOctets               = 75316
      portMaskDrop            = 118
      aleUnknownMcast         = 7
      aleUnknownBcast         = 5
      alePolicyMatch          = 141
      txPri[0]                = 285
      txPriBcnt[0]            = 28856
      rxGoodFrames            = 517
      rxBcastFrames           = 157
      rxMcastFrames           = 360
      aleDrop                 = 232
      rxOctets                = 54952
      txGoodFrames            = 254
      txBcastFrames           = 117
      txMcastFrames           = 137
      txOctets                = 32764
      octetsFrames64          = 143
      octetsFrames65to127     = 500
      octetsFrames256to511    = 36
      netOctets               = 87716
      portMaskDrop            = 232
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      alePolicyMatch          = 128
      txPri[0]                = 120
      txPri[2]                = 134
      txPriBcnt[0]            = 14930
      txPriBcnt[2]            = 17834
     ====== Iteration 14 =====
     Port 0 Statistics
      rxGoodFrames            = 384
      rxBcastFrames           = 128
      rxMcastFrames           = 224
      aleDrop                 = 93
      rxOctets                = 47594
      txGoodFrames            = 289
      txBcastFrames           = 161
      txMcastFrames           = 128
      txOctets                = 29112
      octetsFrames64          = 165
      octetsFrames65to127     = 413
      octetsFrames256to511    = 49
      netOctets               = 76706
      portMaskDrop            = 125
      aleUnknownMcast         = 8
      aleUnknownMcastBcnt     = 942
      aleUnknownBcast         = 5
      txPri[0]                = 289
      txPriBcnt[0]            = 29112
      rxGoodFrames            = 522
      rxBcastFrames           = 161
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 55369
      txGoodFrames            = 259
      txBcastFrames           = 122
      txMcastFrames           = 137
      txOctets                = 33366
      octetsFrames128to255    = 93
      netOctets               = 88735
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      txPri[0]                = 124
      txPri[2]                = 135
      txPriBcnt[0]            = 15186
      txPriBcnt[2]            = 18180
     ====== Iteration 15 =====
     Port 0 Statistics
      rxGoodFrames            = 396
      rxBcastFrames           = 135
      rxMcastFrames           = 224
      aleDrop                 = 93
      rxOctets                = 48917
      txGoodFrames            = 294
      txBcastFrames           = 166
      txMcastFrames           = 128
      txOctets                = 29432
      octetsFrames64          = 180
      octetsFrames256to511    = 51
      netOctets               = 78349
      portMaskDrop            = 130
      aleUnknownMcast         = 8
      aleUnknownBcast         = 6
      aleUnknownBcastBcnt     = 2076
      txPri[0]                = 294
      txPriBcnt[0]            = 29432
      rxGoodFrames            = 527
      rxBcastFrames           = 166
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 55689
      txGoodFrames            = 266
      txBcastFrames           = 129
      txMcastFrames           = 137
      txOctets                = 34369
      octetsFrames64          = 161
      octetsFrames256to511    = 39
      netOctets               = 90058
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      txPri[0]                = 130
      txPri[2]                = 136
      txPriBcnt[0]            = 15843
      txPriBcnt[2]            = 18526
     ====== Iteration 16 =====
     Port 0 Statistics
      rxGoodFrames            = 411
      rxBcastFrames           = 143
      rxMcastFrames           = 225
      aleDrop                 = 95
      rxOctets                = 50442
      txGoodFrames            = 301
      txBcastFrames           = 173
      txMcastFrames           = 128
      txOctets                = 29880
      octetsFrames64          = 199
      octetsFrames65to127     = 414
      octetsFrames256to511    = 53
      netOctets               = 80322
      portMaskDrop            = 138
      aleUnknownMcast         = 8
      aleUnknownBcast         = 7
      aleUnknownBcastBcnt     = 2422
      txPri[0]                = 301
      txPriBcnt[0]            = 29880
      rxGoodFrames            = 534
      rxBcastFrames           = 173
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 56137
      txGoodFrames            = 273
      txBcastFrames           = 136
      txMcastFrames           = 137
      txOctets                = 35099
      octetsFrames64          = 174
      octetsFrames256to511    = 40
      netOctets               = 91236
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      txPri[0]                = 136
      txPri[2]                = 137
      txPriBcnt[0]            = 16227
      txPriBcnt[2]            = 18872
     ====== Iteration 17 =====
     Port 0 Statistics
      rxGoodFrames            = 423
      rxBcastFrames           = 149
      rxMcastFrames           = 225
      aleDrop                 = 95
      rxOctets                = 51210
      txGoodFrames            = 306
      txBcastFrames           = 178
      txMcastFrames           = 128
      txOctets                = 30200
      octetsFrames64          = 216
      netOctets               = 81410
      portMaskDrop            = 144
      aleUnknownMcast         = 8
      aleUnknownBcast         = 7
      txPri[0]                = 306
      txPriBcnt[0]            = 30200
      rxGoodFrames            = 539
      rxBcastFrames           = 178
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 56457
      txGoodFrames            = 279
      txBcastFrames           = 142
      txMcastFrames           = 137
      txOctets                = 35483
      octetsFrames64          = 185
      netOctets               = 91940
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      txPri[0]                = 142
      txPri[2]                = 137
      txPriBcnt[0]            = 16611
     ====== Iteration 18 =====
     Port 0 Statistics
      rxGoodFrames            = 431
      rxBcastFrames           = 152
      rxMcastFrames           = 227
      aleDrop                 = 97
      rxOctets                = 51742
      txGoodFrames            = 309
      txBcastFrames           = 181
      txMcastFrames           = 128
      txOctets                = 30392
      octetsFrames64          = 225
      octetsFrames65to127     = 416
      netOctets               = 82134
      portMaskDrop            = 149
      aleUnknownMcast         = 8
      aleUnknownBcast         = 7
      txPri[0]                = 309
      txPriBcnt[0]            = 30392
      rxGoodFrames            = 542
      rxBcastFrames           = 181
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 56649
      txGoodFrames            = 282
      txBcastFrames           = 145
      txMcastFrames           = 137
      txOctets                = 35675
      octetsFrames64          = 191
      netOctets               = 92324
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 1
      txPri[0]                = 145
      txPri[2]                = 137
      txPriBcnt[0]            = 16803
     ====== Iteration 19 =====
     Port 0 Statistics
      rxGoodFrames            = 441
      rxBcastFrames           = 157
      rxMcastFrames           = 227
      aleDrop                 = 97
      rxOctets                = 52382
      txGoodFrames            = 314
      txBcastFrames           = 186
      txMcastFrames           = 128
      txOctets                = 30712
      octetsFrames64          = 240
      netOctets               = 83094
      portMaskDrop            = 154
      aleUnknownUcast         = 2
      aleUnknownUcastBcnt     = 128
      aleUnknownMcast         = 8
      aleUnknownBcast         = 7
      txPri[0]                = 314
      txPriBcnt[0]            = 30712
      rxGoodFrames            = 547
      rxBcastFrames           = 186
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 56969
      txGoodFrames            = 287
      txBcastFrames           = 150
      txMcastFrames           = 137
      txOctets                = 35995
      octetsFrames64          = 201
      netOctets               = 92964
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 3
      aleUnknownBcastBcnt     = 192
      txPri[0]                = 150
      txPri[2]                = 137
      txPriBcnt[0]            = 17123
     ====== Iteration 20 =====
     Port 0 Statistics
      rxGoodFrames            = 450
      rxBcastFrames           = 162
      rxMcastFrames           = 227
      aleDrop                 = 97
      rxOctets                = 53240
      txGoodFrames            = 318
      txBcastFrames           = 190
      txMcastFrames           = 128
      txOctets                = 30968
      octetsFrames64          = 252
      octetsFrames256to511    = 54
      netOctets               = 84208
      portMaskDrop            = 158
      aleUnknownUcast         = 3
      aleUnknownUcastBcnt     = 192
      aleUnknownMcast         = 8
      aleUnknownBcast         = 8
      aleUnknownBcastBcnt     = 2768
      txPri[0]                = 318
      txPriBcnt[0]            = 30968
      rxGoodFrames            = 551
      rxBcastFrames           = 190
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 57225
      txGoodFrames            = 292
      txBcastFrames           = 155
      txMcastFrames           = 137
      txOctets                = 36597
      octetsFrames64          = 209
      octetsFrames256to511    = 41
      netOctets               = 93822
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 4
      aleUnknownBcastBcnt     = 256
      txPri[0]                = 154
      txPri[2]                = 138
      txPriBcnt[0]            = 17379
      txPriBcnt[2]            = 19218
     ====== Iteration 21 =====
     Port 0 Statistics
      rxGoodFrames            = 460
      rxBcastFrames           = 168
      rxMcastFrames           = 227
      aleDrop                 = 97
      rxOctets                = 54444
      txGoodFrames            = 322
      txBcastFrames           = 194
      txMcastFrames           = 128
      txOctets                = 31224
      octetsFrames64          = 264
      octetsFrames256to511    = 56
      netOctets               = 85668
      portMaskDrop            = 162
      aleUnknownUcast         = 5
      aleUnknownUcastBcnt     = 320
      aleUnknownMcast         = 8
      aleUnknownBcast         = 10
      aleUnknownBcastBcnt     = 3460
      txPri[0]                = 322
      txPriBcnt[0]            = 31224
      rxGoodFrames            = 555
      rxBcastFrames           = 194
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 57481
      txGoodFrames            = 298
      txBcastFrames           = 161
      txMcastFrames           = 137
      txOctets                = 37545
      octetsFrames64          = 217
      octetsFrames256to511    = 43
      netOctets               = 95026
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 6
      aleUnknownBcastBcnt     = 384
      txPri[0]                = 158
      txPri[2]                = 140
      txPriBcnt[0]            = 17635
      txPriBcnt[2]            = 19910
     ====== Iteration 22 =====
     Port 0 Statistics
      rxGoodFrames            = 470
      rxBcastFrames           = 173
      rxMcastFrames           = 227
      aleDrop                 = 97
      rxOctets                = 55084
      txGoodFrames            = 327
      txBcastFrames           = 199
      txMcastFrames           = 128
      txOctets                = 31544
      octetsFrames64          = 279
      netOctets               = 86628
      portMaskDrop            = 167
      aleUnknownUcast         = 6
      aleUnknownUcastBcnt     = 384
      aleUnknownMcast         = 8
      txPri[0]                = 327
      txPriBcnt[0]            = 31544
      rxGoodFrames            = 560
      rxBcastFrames           = 199
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 57801
      txGoodFrames            = 303
      txBcastFrames           = 166
      txMcastFrames           = 137
      txOctets                = 37865
      octetsFrames64          = 227
      netOctets               = 95666
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 7
      aleUnknownBcastBcnt     = 448
      txPri[0]                = 163
      txPri[2]                = 140
      txPriBcnt[0]            = 17955
     ====== Iteration 23 =====
     Port 0 Statistics
      rxGoodFrames            = 480
      rxBcastFrames           = 178
      rxMcastFrames           = 227
      aleDrop                 = 97
      rxOctets                = 55724
      txGoodFrames            = 332
      txBcastFrames           = 204
      txMcastFrames           = 128
      txOctets                = 31864
      octetsFrames64          = 294
      netOctets               = 87588
      portMaskDrop            = 172
      aleUnknownUcast         = 8
      aleUnknownUcastBcnt     = 512
      aleUnknownMcast         = 8
      txPri[0]                = 332
      txPriBcnt[0]            = 31864
      rxGoodFrames            = 565
      rxBcastFrames           = 204
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 58121
      txGoodFrames            = 308
      txBcastFrames           = 171
      txMcastFrames           = 137
      txOctets                = 38185
      octetsFrames64          = 237
      netOctets               = 96306
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 9
      aleUnknownBcastBcnt     = 576
      txPri[0]                = 168
      txPri[2]                = 140
      txPriBcnt[0]            = 18275
     ====== Iteration 24 =====
     Port 0 Statistics
      rxGoodFrames            = 490
      rxBcastFrames           = 183
      rxMcastFrames           = 227
      aleDrop                 = 97
      rxOctets                = 56364
      txGoodFrames            = 337
      txBcastFrames           = 209
      txMcastFrames           = 128
      txOctets                = 32184
      octetsFrames64          = 309
      netOctets               = 88548
      portMaskDrop            = 177
      aleUnknownUcast         = 9
      aleUnknownUcastBcnt     = 576
      aleUnknownMcast         = 8
      txPri[0]                = 337
      txPriBcnt[0]            = 32184
      rxGoodFrames            = 570
      rxBcastFrames           = 209
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 58441
      txGoodFrames            = 313
      txBcastFrames           = 176
      txMcastFrames           = 137
      txOctets                = 38505
      octetsFrames64          = 247
      netOctets               = 96946
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcastBcnt     = 640
      txPri[0]                = 173
      txPri[2]                = 140
      txPriBcnt[0]            = 18595
     ====== Iteration 25 =====
     Port 0 Statistics
      rxGoodFrames            = 501
      rxBcastFrames           = 189
      rxMcastFrames           = 228
      aleDrop                 = 98
      rxOctets                = 57658
      txGoodFrames            = 341
      txBcastFrames           = 213
      txMcastFrames           = 128
      txOctets                = 32440
      octetsFrames64          = 321
      octetsFrames65to127     = 417
      octetsFrames256to511    = 58
      netOctets               = 90098
      portMaskDrop            = 182
      aleUnknownUcast         = 9
      aleUnknownMcast         = 9
      aleUnknownMcastBcnt     = 1016
      txPri[0]                = 341
      txPriBcnt[0]            = 32440
      rxGoodFrames            = 574
      rxBcastFrames           = 213
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 58697
      txGoodFrames            = 319
      txBcastFrames           = 182
      txMcastFrames           = 137
      txOctets                = 39469
      octetsFrames64          = 255
      octetsFrames256to511    = 45
      netOctets               = 98166
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      txPri[0]                = 178
      txPri[2]                = 141
      txPriBcnt[0]            = 19205
      txPriBcnt[2]            = 20264
     ====== Iteration 26 =====
     Port 0 Statistics
      rxGoodFrames            = 514
      rxBcastFrames           = 196
      rxMcastFrames           = 228
      aleDrop                 = 98
      rxOctets                = 58772
      txGoodFrames            = 347
      txBcastFrames           = 219
      txMcastFrames           = 128
      txOctets                = 32824
      octetsFrames64          = 339
      octetsFrames256to511    = 59
      netOctets               = 91596
      portMaskDrop            = 188
      aleUnknownUcast         = 10
      aleUnknownUcastBcnt     = 640
      aleUnknownMcast         = 9
      aleUnknownBcast         = 11
      aleUnknownBcastBcnt     = 3806
      txPri[0]                = 347
      txPriBcnt[0]            = 32824
      rxGoodFrames            = 580
      rxBcastFrames           = 219
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 59081
      txGoodFrames            = 326
      txBcastFrames           = 189
      txMcastFrames           = 137
      txOctets                = 40199
      octetsFrames64          = 267
      netOctets               = 99280
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcastBcnt     = 704
      txPri[0]                = 184
      txPri[2]                = 142
      txPriBcnt[0]            = 19589
      txPriBcnt[2]            = 20610
     ====== Iteration 27 =====
     Port 0 Statistics
      rxGoodFrames            = 523
      rxBcastFrames           = 201
      rxMcastFrames           = 229
      aleDrop                 = 99
      rxOctets                = 59922
      txGoodFrames            = 350
      txBcastFrames           = 222
      txMcastFrames           = 128
      txOctets                = 33016
      octetsFrames64          = 348
      octetsFrames65to127     = 418
      octetsFrames256to511    = 61
      netOctets               = 92938
      portMaskDrop            = 192
      aleUnknownUcast         = 11
      aleUnknownUcastBcnt     = 704
      aleUnknownMcast         = 9
      aleUnknownBcast         = 13
      aleUnknownBcastBcnt     = 4498
      txPri[0]                = 350
      txPriBcnt[0]            = 33016
      rxGoodFrames            = 583
      rxBcastFrames           = 222
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 59273
      txGoodFrames            = 331
      txBcastFrames           = 194
      txMcastFrames           = 137
      txOctets                = 41083
      octetsFrames64          = 273
      netOctets               = 100356
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      aleUnknownBcast         = 12
      aleUnknownBcastBcnt     = 768
      txPri[0]                = 187
      txPri[2]                = 144
      txPriBcnt[0]            = 19781
      txPriBcnt[2]            = 21302
     ====== Iteration 28 =====
     Port 0 Statistics
      rxGoodFrames            = 534
      rxBcastFrames           = 207
      rxMcastFrames           = 229
      aleDrop                 = 99
      rxOctets                = 60899
      txGoodFrames            = 355
      txBcastFrames           = 227
      txMcastFrames           = 128
      txOctets                = 33336
      octetsFrames64          = 363
      octetsFrames256to511    = 62
      netOctets               = 94235
      portMaskDrop            = 197
      aleUnknownMcast         = 9
      txPri[0]                = 355
      txPriBcnt[0]            = 33336
      rxGoodFrames            = 588
      rxBcastFrames           = 227
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 59593
      txGoodFrames            = 337
      txBcastFrames           = 200
      txMcastFrames           = 137
      txOctets                = 41740
      octetsFrames64          = 283
      netOctets               = 101333
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      txPri[0]                = 193
      txPri[2]                = 144
      txPriBcnt[0]            = 20438
     ====== Iteration 29 =====
     Port 0 Statistics
      rxGoodFrames            = 545
      rxBcastFrames           = 213
      rxMcastFrames           = 229
      aleDrop                 = 100
      rxOctets                = 61876
      txGoodFrames            = 360
      txBcastFrames           = 232
      txMcastFrames           = 128
      txOctets                = 33656
      octetsFrames64          = 378
      octetsFrames256to511    = 63
      netOctets               = 95532
      portMaskDrop            = 203
      aleUnknownMcast         = 9
      txPri[0]                = 360
      txPriBcnt[0]            = 33656
      rxGoodFrames            = 593
      rxBcastFrames           = 232
      rxMcastFrames           = 361
      aleDrop                 = 233
      rxOctets                = 59913
      txGoodFrames            = 342
      txBcastFrames           = 205
      txMcastFrames           = 137
      txOctets                = 42060
      octetsFrames64          = 293
      netOctets               = 101973
      portMaskDrop            = 233
      aleUnknownMcast         = 2
      txPri[0]                = 198
      txPri[2]                = 144
      txPriBcnt[0]            = 20758
    Thanks.
    Jack
  • Hi Jack,
    Is ping from PC to SoC working?
    Can you share the output of "tcpdump -i eth1" when pinging the SoC from PC.
    Tanmay
  • Hi Tanmay
    I am attaching tcpdump data here. Please review it.
    It is sending a reply to ARP msg and does not ping from PC to EVM.
    root@j7200-evm:~# tcpdump -i br0
    [  277.009896] device br0 entered promiscuous mode
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on br0, link-type EN10MB (Ethernet), capture size 262144 bytes
    22:52:45.059085 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:45.059148 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:46.063931 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:46.063988 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:47.162649 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:47.162705 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:48.067979 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:48.068058 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:49.061076 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:49.061146 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:50.061648 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:50.061701 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:51.184549 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:51.184599 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:52.064542 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:52.064614 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:53.063939 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:53.064006 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:54.122503 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:54.122569 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:55.053248 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:55.053313 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:56.054773 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:56.054825 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:57.322533 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:57.322588 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:58.058844 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:58.058903 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:52:59.054079 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:52:59.054137 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:00.063010 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:00.063064 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:01.377169 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:01.377233 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:02.055395 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:02.055461 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:03.060035 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:03.060104 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:04.381618 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:04.381670 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:05.068240 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:05.068306 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:06.065453 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:06.065520 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:07.468041 IP6 j7200-evm > ip6-allrouters: ICMP6, router solicitation, length 16
    22:53:07.893096 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:07.893148 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    22:53:08.559669 ARP, Request who-has j7200-evm tell 192.168.5.12, length 46
    22:53:08.559740 ARP, Reply j7200-evm is-at b6:70:f8:e0:b8:85 (oui Unknown), length 28
    From logs it was observed that Port-2 Tx Broadcast count is increasing, means some broadcast packets sent out of MAC port-2.
    Can you try Ping from EVM to PC.
    Please share the logs using "CPSW_Periodic_stat_dump.zip" along with tcpdump with -xx option on EVM and Wireshark capture at PC.
    Sudheer
  • Hi Sudheer
    Here's attahced log snapshot for EVM to PC use case
    Sometimes PING is working according to them.
    Thanks.
    Jack
  • Hi Tanmay
    Please find the tcpdump below.
    The tcpdump log of br0 is delivered because tab and eth1 are in use by tying br0 to bridge.
    It is sending a reply for Arp, and the ping from PC to EVM is not going.
    Thanks.
    Jack
    When ping is working from EVM to PC, during that time check ping from PC to EVM?
    Also, share the Logs using "CPSW_Periodic_stat_dump.zip" while ping is going on.
    Sudheer
  • Jack's PC is weird, so I'm attaching a log.evm_to_pc.zip
    When ping is working to EVM to PC, pc to EVM is not working.
  • Hi Sudheer
    We want all of this to be transmitted from ethernet firmware to eth1 interface without filtering. ( BROADCAST packet, Unknown Unicast Packet, Unknown Multicast Packet, CPU Unicast packet)
    Is it possible to share about the current progress?
    Regards.
    Dongseuk
    All broadcast packets can be forwarded to eth1 (A72). Please refer to FAQ [How to forward Broadcast to HLOS on A72]
    Default CPU unicast (A72 MAC address as destination MAC) will be forwarded to eth1.
    Unknown Multicast and Unicast can't be possible to direct to eth1.
    Sudheer
  • HI. Sudheer
    fix the two things below, eth1 interface confirmed that ip allocation with dhcp and ping from EVM to EVM to pc works well.
    1.ethfw
    2. linux
    ip maddr add FF:FF:FF:FF:FF:FF dev eth1
    However, if eth0 and eth1 are tested with bridge as br0, it does not work.
    To solve this problem, make the mac address of br0 equal to the mac address of eth1 and it works well during the test.
    Is this the right way to approach it? Is there any other way?
    dongseuk.
    Can you try below and confirm where you are able to get IP and Ping is working?
    Ignore above changes in Ethfw and Linux side.
    Enable Inter-core Virtual Ethernet communication, no need to create bridge interface.
    Try to check whether IP assigned to eth1 and physical switch interface on Ethfw, you can observe from Ethfw debug logs.
    Sudheer
  • HI,
    Cannot get ip from dhcp to eth1 without the above two modifications.
    Also, the use of br0 is essential for our application development.
    As you can see from the top, the defines below are applied.
    The test environment is as shown in the link below, and in the picture in the link, pc1 and pc2 can now be imported as dhcpd
    Ping works with pc1<->linux br0, pc2<->linux br0.
    However, pc1 <->pc2 does not work.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1222969/dra821u-ip-assignment-failed-for-pc-connected-via-cpsw5g/4633431#4633431
    dongseuk
    In above configuration, you mentioned that IP is assigned but ping is not working.
    In above if you configure MAC address of bro same as eth1 then you can able to ping as well.
    If Broadcast packet forwarding to Linux is fine in your environment as per your use case then above fixes working for you fine.
    For this we may need following:
    1. Forwarding of PC1 packets to eth1 interface from bro.
    2. If above is fine, then eth1 should accept the packets with PC1 MAC address as destination address in packet for this we may need to add PC1 MAC address in eth1/A72 List.
    Please refer to Unicast address Addition to A72, In example Port-2 alone configured for policer rules you can add all ports to the policer.
    But, drawback here is, It is static configuration.
    If okay, you can connect CPSW2G to one of CPSW9G port and check your use case.
    Sudheer
  • HI,
     How to configuration below?
    dongseuk
    I am not sure, how to configure it. Ideally it should transmit from br0 to eth1.
    This you can confirm by checking the Internal Host Port Rx packet count while pinging from PC1 to PC2.
    When you run "#ethtool -t eth1" statistics will be printed in ethfw debug UART window.
    May be you check by running tcpdump -i eth1.
    Please refer to FAQ [Unicast address Addition to A72], In example Port-2 alone configured for policer rules you can add all ports to the policer.
    Sudheer
  • Hi Doedla Sudheer Jumar, currently we are using DRA821U EVM not our custom board.
    PLEASE TEST WITH YOUR EVM for our target environments (using br0 with eth0 and eth1)!  And than please provide the solution.
    Already we wait around one year for this issue!
    -- YoungHan Kim
  • Hi Young,
    Can you please try at your end by adding PC#1 MAC address to ALE by referring to FAQ [Unicast address Addition to A72],
    It should work for your Use-case.
    Sudheer
  • Hi Doredla Suhheer Kumar,
    Currently we use SDK 8.06.
    Do you mean to apply apply only "Adding a Unicast MAC Address entry for A72 only for Port-2" patch on origianl SDK 8.06?
    Or does it required other patch?
    Thanks!
    YoungHan Kim
  • HI! Sudheer,
    FAQ [Unicast address Addition to A72] was applied to the above environment (eth0 and eth1 were used as br0).
    However, #PC1 and #PC2 still do not ping.
    It's a test on EVM, so I think you can try it. Please test it and provide the solution.
    dongseuk,
    I have tried and confirmed the forwarding of unicast MAC address frames coming from any of external port to A72 using the latest patch attached in FAQ [Adding a unicast MAC Address entry for A72].
    Earlier patch forward to A72 only when packet receiving from External Port-2.
    Can you please try with latest patch from above FAQ in that instead of default MAC address in patch {00:01:02:03:04:05} use your PC1 MAC address (which is connected to CPSW2G).
    Sudheer
  • HI Sudheer,
    After applying the patch you gave me, eth0 (CPSW2G) is allocated ip from udhcpd, but not ip as eth1 (CPSW5G).
    Should I work on the tap interface above after applying your patch?
    Also, can you tell me the method you checked in order?
    dongseuk
  • Hi Dong,
    Above pointed patch is for only to make successful ping between PC1 & PC2. Rest all to be needed as is. (till you confirmed IP allocation on CPSW2G, CPSW5G and ping between bridge and PC1 as well as ping between Bridge and PC2)
    Make sure that you are using PC1 MAC address instead of Unicast MAC address mentioned in reference patch.
    I have connected PC to one of switch port of CPSW5 and configure the MAC address mentioned reference patch to PC and send some frames using Packeth application from PC to CPSW5G and observed those packets were reaching to A72.
    Basically it is for forwarding of Unicast MAC address frames to A72. (Address we are registering with Ethfw by adding static code).
    Sudheer
  • HI! Sudheer
    I applied the patch you gave me and tested it on TI EVM (SDK8.06) as below. However, there is still no ping between PC1 and PC2.
    1. Apply patch and ethfw and linux side modifications
    2. ETHFW_INTERCORE_ETH_SUPPORT=yes
    3. Create br0
       brctl addbr br0
       brctl addif br0 eth0
       brctl addif br0 eth1
       ifconfig br0 192.168.5.254 netmask 255.255.255.0
    4. Change the Mac address of br0 to the Mac address of eth1
    5. Running udhcpd: Checking ip allocation PC1:192.168.5.11 PC2:192.168.5.12
    6. ping PC1 (CPSW2G:192.168.5.11) to PC2 (CPSW5G:192.168.5. I applied the patch you gave me and tested it on TI EVM (SDK8.06) as below.
    Attached is the wireshark log on the PC side and the tcpdump on the EVM
    Please check
    root@j7200-evm:~# tcpdump -i br0 -n
    [ 1724.766081] device br0 entered promiscuous mode
    23:16:52.734108 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:52.734429 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:16:53.002702 IP 192.168.5.11.63520 > 8.8.8.8.53: 50022+ A? dns.msftncsi.com. (34)
    23:16:53.002799 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:16:53.036305 IP 192.168.5.11.63520 > 8.8.8.8.53: 50022+ A? dns.msftncsi.com. (34)
    23:16:53.728042 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:53.728515 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:16:54.039261 IP 192.168.5.11.63520 > 8.8.8.8.53: 50022+ A? dns.msftncsi.com. (34)
    23:16:54.084889 IP 192.168.5.11.65235 > 8.8.8.8.53: 57906+ A? gms.ahnlab.com. (32)
    23:16:54.734450 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:54.734780 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:16:55.733115 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:55.733536 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:16:56.041411 IP 192.168.5.11.63520 > 8.8.8.8.53: 50022+ A? dns.msftncsi.com. (34)
    23:16:56.041532 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:16:56.721861 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:56.722504 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:16:57.736340 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:57.737229 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:16:58.620763 IP 192.168.5.12.63348 > 8.8.8.8.53: 49695+ A? dns.msftncsi.com. (34)
    23:16:58.620859 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 70
    23:16:58.740436 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:58.741091 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:16:59.024765 IP 192.168.5.12.61418 > 8.8.8.8.53: 28637+ A? go.microsoft.com. (34)
    23:16:59.024848 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 70
    23:16:59.620158 IP 192.168.5.12.63348 > 8.8.8.8.53: 49695+ A? dns.msftncsi.com. (34)
    23:16:59.620250 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 70
    23:16:59.729227 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:16:59.729431 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:00.023593 IP 192.168.5.12.61418 > 8.8.8.8.53: 28637+ A? go.microsoft.com. (34)
    23:17:00.046241 IP 192.168.5.11.63520 > 8.8.8.8.53: 50022+ A? dns.msftncsi.com. (34)
    23:17:00.046319 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:00.621317 IP 192.168.5.12.63348 > 8.8.8.8.53: 49695+ A? dns.msftncsi.com. (34)
    23:17:00.730494 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:00.730784 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:01.034222 IP 192.168.5.12.61418 > 8.8.8.8.53: 28637+ A? go.microsoft.com. (34)
    23:17:01.738869 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:01.739331 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:02.626249 IP 192.168.5.12.63348 > 8.8.8.8.53: 49695+ A? dns.msftncsi.com. (34)
    23:17:02.626344 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 70
    23:17:02.735414 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:02.736009 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:03.036242 IP 192.168.5.12.61418 > 8.8.8.8.53: 28637+ A? go.microsoft.com. (34)
    23:17:03.735865 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:03.736891 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:04.059577 IP 192.168.5.11.49354 > 8.8.8.8.53: 14679+ A? dns.msftncsi.com. (34)
    23:17:04.059665 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:04.061012 IP 192.168.5.11.54930 > 8.8.8.8.53: 12543+ AAAA? dns.msftncsi.com. (34)
    23:17:04.061046 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:04.089085 IP 192.168.5.11.49354 > 8.8.8.8.53: 14679+ A? dns.msftncsi.com. (34)
    23:17:04.089085 IP 192.168.5.11.54930 > 8.8.8.8.53: 12543+ AAAA? dns.msftncsi.com. (34)
    23:17:04.401231 IP 192.168.5.11.137 > 192.168.5.255.137: UDP, length 50
    23:17:04.483781 IP 192.168.5.11.49767 > 192.168.5.254.8013: Flags [S], seq 3259069474, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
    23:17:04.483850 IP 192.168.5.254.8013 > 192.168.5.11.49767: Flags [R.], seq 0, ack 3259069475, win 0, length 0
    23:17:04.728112 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:04.728378 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:04.985154 IP 192.168.5.11.49767 > 192.168.5.254.8013: Flags [S], seq 3259069474, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
    23:17:04.985274 IP 192.168.5.254.8013 > 192.168.5.11.49767: Flags [R.], seq 0, ack 1, win 0, length 0
    23:17:05.090676 IP 192.168.5.11.49354 > 8.8.8.8.53: 14679+ A? dns.msftncsi.com. (34)
    23:17:05.090676 IP 192.168.5.11.54930 > 8.8.8.8.53: 12543+ AAAA? dns.msftncsi.com. (34)
    23:17:05.165840 IP 192.168.5.11.137 > 192.168.5.255.137: UDP, length 50
    23:17:05.498068 IP 192.168.5.11.49767 > 192.168.5.254.8013: Flags [S], seq 3259069474, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
    23:17:05.498161 IP 192.168.5.254.8013 > 192.168.5.11.49767: Flags [R.], seq 0, ack 1, win 0, length 0
    23:17:05.573574 IP 192.168.5.11.49768 > 192.168.5.254.8013: Flags [S], seq 659041508, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
    23:17:05.573618 IP 192.168.5.254.8013 > 192.168.5.11.49768: Flags [R.], seq 0, ack 659041509, win 0, length 0
    23:17:05.724298 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:05.724613 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:05.923441 IP 192.168.5.11.137 > 192.168.5.255.137: UDP, length 50
    23:17:06.075274 IP 192.168.5.11.49768 > 192.168.5.254.8013: Flags [S], seq 659041508, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
    23:17:06.075336 IP 192.168.5.254.8013 > 192.168.5.11.49768: Flags [R.], seq 0, ack 1, win 0, length 0
    23:17:06.576429 IP 192.168.5.11.49768 > 192.168.5.254.8013: Flags [S], seq 659041508, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
    23:17:06.576515 IP 192.168.5.254.8013 > 192.168.5.11.49768: Flags [R.], seq 0, ack 1, win 0, length 0
    23:17:06.626255 IP 192.168.5.12.63348 > 8.8.8.8.53: 49695+ A? dns.msftncsi.com. (34)
    23:17:06.626311 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 70
    23:17:06.735463 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:06.735773 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:07.048161 IP 192.168.5.12.61418 > 8.8.8.8.53: 28637+ A? go.microsoft.com. (34)
    23:17:07.048254 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 70
    23:17:07.093019 IP 192.168.5.11.49354 > 8.8.8.8.53: 14679+ A? dns.msftncsi.com. (34)
    23:17:07.093066 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:07.093179 IP 192.168.5.11.54930 > 8.8.8.8.53: 12543+ AAAA? dns.msftncsi.com. (34)
    23:17:07.221831 ARP, Request who-has 192.168.5.254 (70:ff:76:1d:92:c1) tell 192.168.5.12, length 46
    23:17:07.221851 ARP, Reply 192.168.5.254 is-at 70:ff:76:1d:92:c1, length 28
    23:17:07.725116 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:07.726312 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:08.720838 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:08.721373 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:09.727460 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:09.727694 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:09.801188 ARP, Request who-has 192.168.5.254 (70:ff:76:1d:92:c1) tell 192.168.5.11, length 46
    23:17:09.801206 ARP, Reply 192.168.5.254 is-at 70:ff:76:1d:92:c1, length 28
    23:17:10.643648 ARP, Request who-has 192.168.5.254 tell 192.168.5.12, length 46
    23:17:10.643705 ARP, Reply 192.168.5.254 is-at 70:ff:76:1d:92:c1, length 28
    23:17:10.725714 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:10.726331 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:11.056414 IP 192.168.5.12.52525 > 8.8.8.8.53: 32765+ A? officeclient.microsoft.com. (44)
    23:17:11.056507 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 80
    23:17:11.092954 IP 192.168.5.11.54930 > 8.8.8.8.53: 12543+ AAAA? dns.msftncsi.com. (34)
    23:17:11.093000 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:11.092954 IP 192.168.5.11.49354 > 8.8.8.8.53: 14679+ A? dns.msftncsi.com. (34)
    23:17:11.093033 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:11.729354 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:11.729749 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:12.057715 IP 192.168.5.12.52525 > 8.8.8.8.53: 32765+ A? officeclient.microsoft.com. (44)
    23:17:12.057802 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 80
    23:17:12.723758 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:12.724075 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:13.067624 IP 192.168.5.12.52525 > 8.8.8.8.53: 32765+ A? officeclient.microsoft.com. (44)
    23:17:13.067713 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 80
    23:17:13.735818 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:13.736247 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:14.733333 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:14.733910 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:15.076955 IP 192.168.5.12.52525 > 8.8.8.8.53: 32765+ A? officeclient.microsoft.com. (44)
    23:17:15.077044 IP 192.168.5.254 > 192.168.5.12: ICMP net 8.8.8.8 unreachable, length 80
    23:17:15.097513 IP 192.168.5.11.61064 > 8.8.8.8.53: 9793+ AAAA? dns.msftncsi.com. (34)
    23:17:15.097553 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:15.127080 IP 192.168.5.11.61064 > 8.8.8.8.53: 9793+ AAAA? dns.msftncsi.com. (34)
    23:17:15.127106 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    23:17:15.733128 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:15.733814 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:16.130301 IP 192.168.5.11.61064 > 8.8.8.8.53: 9793+ AAAA? dns.msftncsi.com. (34)
    23:17:16.307947 ARP, Request who-has 192.168.5.12 tell 192.168.5.254, length 28
    23:17:16.308145 ARP, Reply 192.168.5.12 is-at 3c:97:0e:ce:9c:4a, length 46
    23:17:16.729606 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:16.729912 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:17.728353 ARP, Request who-has 192.168.5.11 tell 192.168.5.12, length 46
    23:17:17.728622 ARP, Reply 192.168.5.11 is-at 88:36:6c:fa:d9:15, length 46
    23:17:18.139612 IP 192.168.5.11.61064 > 8.8.8.8.53: 9793+ AAAA? dns.msftncsi.com. (34)
    23:17:18.139697 IP 192.168.5.254 > 192.168.5.11: ICMP net 8.8.8.8 unreachable, length 70
    PC_wiresharklog.zip
    Regard,
    dongseuk
    I hope the Wireshark log attached will be capture at PC1 and PC2 and ping is from PC2 to PC1.
    From log it seems PC1 is sending response for ARP request sent from PC2, but bridge may not be forwarding on eth1 it seems.
    Can you please capture tcpdump on eth1 when pinging from PC2 to PC1.
    Also capture tcpdump on eth0 when pining from PC1 to PC2.
    Sudheer
  • HI! Sudheer
    When I ping between PC1 and PC2, I collect and attach the wireshark log from PC1 and PC2, and the tcpdump log of eth1 (PC2 to PC1) and eth0 (PC1 to PC2).
    Please check.
    PC2_to_PC1.zip
    PC1_to_PC2.zip
    dongseuk
    Can you please share the ALE Table dump (ethtool -t eth1) as well before and after trying the ping from PC1 to PC2 and PC2 to PC1.
    If ethtool is not supported, can you refer to FAQ and provide the statistics and ALE Table.
    Sudheer
  • HI,
    The above command has no value as shown below.
    The ethfw log is as follows
    root@j7200-evm:~# cat /sys/kernel/debug/remoteproc/remoteproc*/trae0
    cat: '/sys/kernel/debug/remoteproc/remoteproc*/trae0': No such file or directory
    Sciclient_boardCfgRm init Passed
    Starting Sciserver..... PASSED
    IPC_echo_test (core : mcu1_0) .....
    mcu1_0 <--> mcu2_1, Ping- 10000, pong - 10000 completed
                CPSW Ethernet Firmware
    ETHFW: Shared multicasts (software fanout):
      01:00:5e:00:00:01
      01:00:5e:00:00:fb
      01:00:5e:00:00:fc
      33:33:00:00:00:01
      33:33:ff:1d:92:c2
      01:80:c2:00:00:00
      01:80:c2:00:00:03
    ETHFW: Reserved multicasts:
      01:80:c2:00:00:0e
      01:1b:19:00:00:00
    EnetMcm: CPSW_5G on MAIN NAVSS
    PHY 16 is alive
    PHY 17 is alive
    PHY 18 is alive
    PHY 19 is alive
    EnetPhy_bindDriver: PHY 16: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 17: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 18: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    EnetPhy_bindDriver: PHY 19: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
    ETHFW Version   : 0.02.00
    ETHFW Build Date: Jun  7, 2023
    ETHFW Build Time: 19:06:49
    ETHFW Commit SHA:
    Starting lwIP, local interface IP is dhcp-enabled
    Host MAC address: 70:ff:76:1d:92:c3
    [LWIPIF_LWIP] Enet LLD netif initialized successfully
    [LWIPIF_LWIP_IC] Interface started successfully
    [LWIPIF_LWIP_IC] NETIF INIT SUCCESS
    Added interface 'br4', IP is 0.0.0.0
    CpswProxyServer: Virtual port configuration:
      mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
      mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
      mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
      mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
    CpswProxyServer: initialization completed (core: mcu2_0)
    CpswMacPort_checkSgmiiStatus: MAC 2: SGMII link parter config port: link up: 1-Gbps Full-Duplex
    Cpsw_handleLinkUp: Port 2: Link up: 1-Gbps Full-Duplex
    REMOTE_SERVICE: Init ... !!!
    REMOTE_SERVICE: Init ... Done !!!
    Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:5
    Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:85, FlowIdxOffset:1
    Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6,mode:disable
    Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:84, FlowIdxOffset:0
    Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:5, Policer Entry:1
    Add static config for mpu1_0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0
    CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bc88a8,CoreKey:38acb7e6, MacAddress:ff:ff:ff:ff:ff:ff, vlanId:0, FlowIdx:84, FlowIdOffset:0
    Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c000000
    Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c020000
    Function:CpswProxyServer_clientNotifyHandlerCb,HostId:0,Handle:38acb7e6,CoreKey:a2bc88a8,NotifyId:RPMSG_KDRV_TP_ETHSWITCH_CLIENTNOTIFY_DUMPSTATS,NotifyLen
         0: Vlanid: 012c, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff RAW:[0 212c1ff1 ff0001ff]
         1: Vlanid: 0000, UTagged: 13, Mult: 13, UMult: 13, Member: 13 RAW:[0 20000130 13013013]
         2: Vlanid: 0001, UTagged: d, Mult: d, UMult: 0, Member: d RAW:[0 200100d0 0d00000d]
         3: Address: 70ff761d92c3, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c3]
         4: Address: 70ff761d92c2, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c2]
         5: Address: 70ff761d92c1, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[0 100070ff 761d92c1]
         6: Address: 000102030405, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[0 10000001 02030405]
         7: Address: 333300000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10003333 00000001]
         8: Address: 01005e000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000100 5e000001]
         9: Address: 3333ff1d92c1, Member:00d Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[34 10003333 ff1d92c1]
        10: Address: 0180c2000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000000]
        11: Address: 0180c2000003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000003]
        12: Address: 3333000000fb, Member:00d Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[34 10003333 000000fb]
        13: Address: 333300010003, Member:00d Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[34 10003333 00010003]
        14: Address: ffffffffffff, Member:00d Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[34 1000ffff ffffffff]
        27: Address: 3c970ece9c4a, Port: 002 Se=0 Bl=0 TOUCH=1 AGE=1 TRUNK=0 RAW:[8 d0013c97 0ece9c4a]
        46: Address: 88366cfad915, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=1 TRUNK=0 RAW:[0 50008836 6cfad915]
        47: Address: 000102040506, Port: 000 Se=0 Bl=0 TOUCH=1 AGE=1 TRUNK=0 RAW:[0 d12c0001 02040506]
    494 Free Entries
        0: POLICER_PORT, PORT_NUM: 1 ISTRUNK:0
        0: POLICER_THREAD,THREAD ID:1
        0: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
        1: POLICER_DST_MAC,ALE Index: 5
        1: POLICER_THREAD,THREAD ID:0
        1: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        2: POLICER_DST_MAC,ALE Index: 6
        2: POLICER_THREAD,THREAD ID:0
        2: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
        3: POLICER_DST_MAC,ALE Index: 9
        3: POLICER_THREAD,THREAD ID:0
        3: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        4: POLICER_DST_MAC,ALE Index: 12
        4: POLICER_THREAD,THREAD ID:0
        4: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        5: POLICER_DST_MAC,ALE Index: 13
        5: POLICER_THREAD,THREAD ID:0
        5: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
        6: POLICER_DST_MAC,ALE Index: 14
        6: POLICER_THREAD,THREAD ID:0
        6: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0
    57 Free Entries
     Port 0 Statistics
     External Port 0 Statistics
     External Port 1 Statistics
     External Port 2 Statistics
     External Port 3 Statistics
        27: Address: 3c970ece9c4a, Port: 002 Se=0 Bl=0 TOUCH=0 AGE=1 TRUNK=0 RAW:[8 50013c97 0ece9c4a]
    495 Free Entries
    57 Free Entries
     Port 0 Statistics
    dongseuk
    From ALE & Policer tables it is identified as no policer rules for PC1 MAC address at CPSW5G side.
    Please find the log at my side below has ALE entry with the unicast address (It has to be "88366cfad915" in your case i.e. PC1 MAC address) and corresponding policer rule to forward packets with destination MAC as above unicast then forward to A72.
    It looks like you are using patch as is, without modifying the MAC address {00:01:02:03:04:05} with your PC1 MAC address.
    Please replace MAC address mentioned in FAQ with PC1 MAC address and test again i.e. replace {00:01:02:03:04:05} with {0x88,0x36,0x6c,0xfa,0xd9,0x15} PC1 MAC address.
    2: Vlanid: 0001, UTagged: 1ed, Mult: 1ed, UMult: 0, Member: 1ed RAW:[0 20011ed1 ed0001ed]
    3: Address: ffffffffffff, Member:1ff Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[7fc 1000ffffffffffff]
    4: Address: 70ff761d92c3, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c3]
    5: EtherType: 0806 RAW:[1 20000000 00000806]
    6: Address: 70ff761d92c1, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[1 100070ff 761d92c1]
    7: Address: 70ff761d92c2, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[0 100070ff 761d92c2]
    8: Address: 000102030405, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 RAW:[0 10000001 02030405]
    9: Address: 333300000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10003333 00000001]
    10: Address: 01005e000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000100 5e000001]
    11: Address: 3333ff1d92c2, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10003333 ff1d92c2]
    12: Address: 0180c2000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000000]
    13: Address: 0180c2000003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[4 10000180 c2000003]
    14: Address: 3333000000fb, Member:1ed Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[7b4 10003333000000fb]
    15: Address: 333300010003, Member:1ed Su=0 FWDSTLVL=0 IGNMBITS=0 RAW:[7b4 1000333300010003]
    1008 Free Entries
    0: POLICER_DST_MAC,ALE Index: 3
    0: POLICER_ETHERTYPE,ALE Index: 5
    0: POLICER_THREAD,THREAD ID:4
    1: POLICER_PORT, PORT_NUM: 1 ISTRUNK:0
    1: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
    2: POLICER_DST_MAC,ALE Index: 7
    2: POLICER_THREAD,THREAD ID:1
    3: POLICER_DST_MAC,ALE Index: 8
    3: POLICER_THREAD,THREAD ID:1
    3: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0
    4: POLICER_DST_MAC,ALE Index: 14
    4: POLICER_THREAD,THREAD ID:1
    5: POLICER_DST_MAC,ALE Index: 15
    5: POLICER_THREAD,THREAD ID:1
    90 Free Entries
    Port 0 Statistics
    rxGoodFrames = 45
    rxBcastFrames = 8
    rxMcastFrames = 37
    aleDrop = 44
    rxOctets = 7154
    octetsFrames65to127 = 25
    octetsFrames128to255 = 12
    octetsFrames256to511 = 8
    netOctets = 7154
    portMaskDrop = 45
    alePolicyMatch = 8
