Hi Experts,
Seeking your assistance on this query:
I have few issue when I boot-up my TDA4 starter kit board which I just bought two weeks ago.
Our team have bought few boards but only this will fail starting.
It usually stuck when plug-in. Sometime the reset button will work, or need to press several times. Even that works, it still very unstable. It really bothered me.
Issues:
1. The system hang during the ATF boot up sequence(system_hang_after_reset.txt). By press the reset button, the boot-up sequence still failed.
2. The system hang during the linux kernel initialization(kernel_panic_after_reset.txt)
Attached are the error logs.
I'm looking forward to your prompt reply.
Archie A.
U-Boot SPL 2021.01-g44a87e3ab8 (Apr 18 2022 - 22:20:44 +0000) Model: Texas Instruments J721E SK R5 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 U-Boot SPL 2021.01-g44a87e3ab8 (Apr 18 2022 - 22:20:44 +0000) Model: Texas Instruments J721E SK R5 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.5(release):08.01.00.006-dirty NOTICE: BL31: Built : 21:21:02, Apr 18 2022 U-Boot SPL 2021.01-g44a87e3ab8 (Apr 18 2022 - 21:22:46 +0000) Model: Texas Instruments J721E SK A72 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 U-Boot 2021.01-g44a87e3ab8 (Apr 18 2022 - 21:22:46 +0000) SoC: J721E SR1.1 Model: Texas Instruments J721E SK A72 Board: J721EX-EAIK rev A1 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4fb0000: 1 In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 8 ms (58.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 8 ms (0 Bytes/s) Already setup. k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work 572788 bytes read in 34 ms (16.1 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 572788 bytes: Success! 297932 bytes read in 23 ms (12.4 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 297932 bytes: Success! Failed to load '/lib/firmware/j7-main-r5f1_0-fw' Failed to load '/lib/firmware/j7-main-r5f1_1-fw' 1461044 bytes read in 71 ms (19.6 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1461044 bytes: Success! 1461012 bytes read in 71 ms (19.6 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1461012 bytes: Success! 13242432 bytes read in 557 ms (22.7 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 13242432 bytes: Success! 19276288 bytes read in 803 ms (22.9 MiB/s) 100968 bytes read in 13 ms (7.4 MiB/s) 10670 bytes read in 9 ms (1.1 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee4000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Archit2 [ 0.000000] Machine model: Texas Instruments J721E SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 560 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff] [ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff] [ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fcffffff] [ 0.000000] node 0: [mem 0x00000000fd000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff] [ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65472 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboott [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB) [ 0.000000] Memory: 2302848K/4194304K available (10880K kernel code, 1288K rwdata, 4352K rodata, 1856K init, 755K bss, 1891456K rese) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008a00b0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a00c0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008419] Console: colour dummy device 80x25 [ 0.012980] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023650] pid_max: default: 32768 minimum: 301 [ 0.028398] LSM: Security Framework initializing [ 0.033146] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.040716] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.049713] rcu: Hierarchical SRCU implementation. [ 0.054782] Platform MSI: msi-controller@1820000 domain created [ 0.061044] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070348] EFI services will not be available. [ 0.075117] smp: Bringing up secondary CPUs ... [ 0.080395] Detected PIPT I-cache on CPU1 [ 0.080418] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.080429] GICv3: CPU1: using allocated LPI pending table @0x00000008a00d0000 [ 0.080463] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.080516] smp: Brought up 1 node, 2 CPUs [ 0.109863] SMP: Total of 2 processors activated. [ 0.114668] CPU features: detected: 32-bit EL0 Support [ 0.119922] CPU features: detected: CRC32 instructions [ 0.133776] CPU: All CPU(s) started at EL2 [ 0.137970] alternatives: patching kernel code [ 0.143001] devtmpfs: initialized [ 0.151927] KASLR disabled due to lack of seed [ 0.156596] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.166559] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.173708] pinctrl core: initialized pinctrl subsystem [ 0.179282] DMI not present or invalid. [ 0.183517] NET: Registered protocol family 16 [ 0.188297] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.195630] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.203600] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.211889] thermal_sys: Registered thermal governor 'step_wise' [ 0.211892] thermal_sys: Registered thermal governor 'power_allocator' [ 0.218325] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.231956] ASID allocator initialised with 65536 entries [ 0.254655] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.261507] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.268268] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.275987] cryptd: max_cpu_qlen set to 1000 [ 0.281952] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.290755] vsys_3v3: supplied by vusb-main5v0 [ 0.295765] iommu: Default domain type: Translated [ 0.300882] SCSI subsystem initialized [ 0.304977] mc: Linux media interface: v0.10 [ 0.309346] videodev: Linux video capture interface: v2.00 [ 0.314973] pps_core: LinuxPPS API ver. 1 registered [ 0.320045] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.329382] PTP clock support registered [ 0.333400] EDAC MC: Ver: 3.0.0 [ 0.337163] FPGA manager framework [ 0.340673] Advanced Linux Sound Architecture Driver Initialized. [ 0.347282] clocksource: Switched to clocksource arch_sys_counter [ 0.353718] VFS: Disk quotas dquot_6.6.0 [ 0.357763] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.367548] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.373843] NET: Registered protocol family 2 [ 0.378442] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear) [ 0.387064] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.395833] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.404032] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.411840] TCP: Hash tables configured (established 32768 bind 32768) [ 0.418587] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.425479] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.432863] NET: Registered protocol family 1 [ 0.437576] RPC: Registered named UNIX socket transport module. [ 0.443633] RPC: Registered udp transport module. [ 0.448447] RPC: Registered tcp transport module. [ 0.453250] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.459834] PCI: CLS 0 bytes, default 64 [ 0.464184] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.474534] Initialise system trusted keyrings [ 0.479155] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.487563] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.493785] NFS: Registering the id_resolver key type [ 0.499001] Key type id_resolver registered [ 0.503272] Key type id_legacy registered [ 0.507390] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.514239] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.521882] 9p: Installing v9fs 9p2000 file system support [ 0.546534] Key type asymmetric registered [ 0.550721] Asymmetric key parser 'x509' registered [ 0.555718] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.563278] io scheduler mq-deadline registered [ 0.567904] io scheduler kyber registered [ 0.573167] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.579338] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.587901] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.594164] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.602028] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.610191] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.619555] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq [ 0.629224] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq [ 0.637117] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.650329] brd: module loaded [ 0.656434] loop: module loaded [ 0.659962] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys' [ 0.667886] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.100-g7a7a3af903 #1 [ 0.675174] Hardware name: Texas Instruments J721E SK (DT) [ 0.680774] Call trace: [ 0.683278] dump_backtrace+0x0/0x1a0 [ 0.687014] show_stack+0x18/0x68 [ 0.690397] dump_stack+0xd0/0x12c [ 0.693867] sysfs_warn_dup+0x60/0x80 [ 0.697602] sysfs_create_dir_ns+0xe0/0xf8 [ 0.701783] kobject_add_internal+0x98/0x288 [ 0.706140] kobject_add+0x94/0x100 [ 0.709701] device_add+0xe0/0x740 [ 0.713171] platform_device_add+0x100/0x238 [ 0.717528] platform_device_register_full+0xcc/0x150 [ 0.722689] dma_buf_phys_init+0x6c/0x9c [ 0.726690] do_one_initcall+0x54/0x1b8 [ 0.730605] kernel_init_freeable+0x220/0x2a0 [ 0.735052] kernel_init+0x14/0x114 [ 0.738608] ret_from_fork+0x10/0x34 [ 0.742274] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same d. [ 0.755455] megasas: 07.714.04.00-rc1 [ 0.760870] tun: Universal TUN/TAP device driver, 1.6 [ 0.766296] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.772702] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.778773] sky2: driver version 1.30 [ 0.783020] VFIO - User Level meta-driver version: 0.3 [ 0.788685] i2c /dev entries driver [ 0.792927] sdhci: Secure Digital Host Controller Interface driver [ 0.799249] sdhci: Copyright(c) Pierre Ossman [ 0.803881] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.810208] ledtrig-cpu: registered to indicate activity on CPUs [ 0.816511] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.823632] optee: probing for conduit method. [ 0.828185] optee: revision 3.12 (3d47a131) [ 0.828445] optee: initialized driver [ 0.837788] NET: Registered protocol family 17 [ 0.842399] 9pnet: Installing 9P2000 support [ 0.846796] Key type dns_resolver registered [ 0.851288] Loading compiled-in X.509 certificates [ 0.860570] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.866911] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.875066] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') [ 0.905027] random: fast init done [ 0.929921] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.936032] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.942099] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.971439] i2c i2c-3: Added multiplexed i2c bus 4 [ 0.976416] i2c i2c-3: Added multiplexed i2c bus 5 [ 0.981315] pca954x 3-0071: registered 2 multiplexed busses for I2C switch pca9543 [ 0.989073] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 0.995166] omap_i2c 2010000.i2c: bus 6 rev0.12 at 100 kHz [ 1.023440] i2c i2c-7: Added multiplexed i2c bus 8 [ 1.028418] i2c i2c-7: Added multiplexed i2c bus 9 [ 1.033317] pca954x 7-0070: registered 2 multiplexed busses for I2C switch pca9543 [ 1.041076] omap_i2c 2030000.i2c: bus 7 rev0.12 at 400 kHz [ 1.047528] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.057495] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.066304] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.076153] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.099144] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.106839] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.115118] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.123396] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.132304] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 1.139992] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 1.148272] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 1.156549] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.165769] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.175655] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.182416] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.191441] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.201586] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.208349] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.216314] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [ 1.225745] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 27, base_baud = 3000000) is a 8250 [ 1.234491] printk: console [ttyS2] enabled [ 1.234491] printk: console [ttyS2] enabled [ 1.242929] printk: bootconsole [ns16550a0] disabled [ 1.242929] printk: bootconsole [ns16550a0] disabled [ 1.253427] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 28, base_baud = 3000000) is a 8250 [ 1.262387] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 29, base_baud = 3000000) is a 8250 [ 1.311291] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.320297] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.328597] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirk0 [ 1.342645] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 1.457339] vdd_mmc1: supplied by vsys_3v3 [ 1.462198] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 1.469087] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 1.475936] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 1.482793] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 1.489605] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 1.499820] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.507315] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.515395] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.523481] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.534231] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 2.540496] pci_bus 0000:00: root bus resource [bus 00-ff] [ 2.545968] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 2.555427] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 2.562311] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.568306] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.577938] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.587591] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xe8 may corrupt adjacent RW1C bits [ 2.597312] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.607044] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits [ 2.616767] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits [ 2.626512] pci 0000:00:00.0: supports D1 [ 2.630509] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.636241] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits [ 2.648096] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.656085] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.665811] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.675533] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 2.687251] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.693861] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.699038] pcieport 0000:00:00.0: PME: Signaling with IRQ 492 [ 2.705367] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.712856] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.720936] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.729019] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.739731] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00 [ 3.745991] pci_bus 0001:00: root bus resource [bus 00-ff] [ 3.751463] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 3.761094] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 3.767972] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400 [ 3.774029] pci 0001:00:00.0: supports D1 [ 3.778027] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 3.785800] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.795761] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01 [ 3.802367] pci 0001:00:00.0: PCI bridge to [bus 01] [ 3.807526] pcieport 0001:00:00.0: PME: Signaling with IRQ 494 [ 3.814176] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 3.824682] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 3.840107] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 3.845082] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 3.851684] Creating 8 MTD partitions on "47040000.spi.0": [ 3.857160] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 3.863141] 0x000000080000-0x000000280000 : "ospi.tispl" [ 3.868870] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 3.874687] 0x000000680000-0x0000006c0000 : "ospi.env" [ 3.880189] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 3.885936] 0x0000007c0000-0x000000800000 : "ospi.env.backup" [ 3.892069] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 3.897884] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 3.947310] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 3.956159] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 3.964453] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirk0 [ 3.978084] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 3.985070] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 3.992281] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 3.998620] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 4.009237] mmc0: CQHCI version 5.10 [ 4.011940] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 4.020097] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 4.028329] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 4.035669] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 4.042984] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 4.050303] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 4.068991] ALSA device list: [ 4.071964] No soundcards found. [ 5.081946] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 5.089718] Waiting for root device PARTUUID=3482acd4-02... [ 5.148006] mmc0: new ultra high speed DDR50 SDHC card at address aaaa [ 5.154862] mmcblk0: mmc0:aaaa SL32G 29.7 GiB [ 5.164765] mmcblk0: p1 p2 [ 5.303458] EXT4-fs (mmcblk0p2): recovery complete [ 5.309280] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 5.317389] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 5.331269] devtmpfs: mounted [ 5.334627] Freeing unused kernel memory: 1856K [ 5.339183] Run /sbin/init as init process [ 5.498325] systemd[1]: System time before build time, advancing clock. [ 5.554398] NET: Registered protocol family 10 [ 5.559358] Segment Routing with IPv6 [ 5.584028] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPT) [ 5.605783] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 5.646022] systemd[1]: Set hostname to <tda4vm-sk>. [ 5.845822] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updat. [ 5.916076] random: systemd: uninitialized urandom read (16 bytes read) [ 5.922813] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewal. [ 5.935137] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 5.945026] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 5.967356] random: systemd: uninitialized urandom read (16 bytes read) [ 5.974633] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 5.995357] random: systemd: uninitialized urandom read (16 bytes read) [ 6.002504] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 6.023463] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password �…ts to Console Directory Watch. [ 6.047396] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R�…uests to Wall Directory Watch. [ 6.071388] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 6.087341] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 6.107331] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 6.123339] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 6.146394] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 6.167365] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 6.191566] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 6.211470] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 6.249939] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 6.258283] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 6.279557] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 6.295626] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 6.319521] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 6.339450] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 6.362403] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 6.382451] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 6.405730] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 6.428490] systemd[1]: Mounting Temporary Directory (/tmp)... Mounting Temporary Directory (/tmp)... [ 6.446014] systemd[1]: Starting Create list of static device nodes for the current kernel... Starting Create list of st�…odes for the current kernel... [ 6.474221] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 6.505019] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 6.519484] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 6.532169] systemd[1]: Starting Journal Service... Starting Journal Service... [ 6.551979] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 6.562251] cryptodev: loading out-of-tree module taints kernel. [ 6.570944] systemd[1]: Starting Remount Root and Kernel File Systems... [ 6.577809] cryptodev: driver 1.10 loaded. Starting Remount Root and Kernel File Systems... [ 6.596908] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 6.605587] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ 6.633979] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 6.655725] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Create list of sta�… nodes for the current kernel. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star�…progress communication helper. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 6.889720] systemd-journald[163]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting udev Wait for Complete Device Initialization... Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. [ 7.356998] CAN device driver interface [ 7.548307] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 7.617984] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode [ 7.660558] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc [ 7.693545] PVR_K: 216: Read BVNC 22.104.208.318 from HW device registers [ 7.695475] remoteproc remoteproc0: 4d80800000.dsp is available [ 7.706560] img_dec 4300000.video-decoder: decoder registered as /dev/video0 [ 7.713880] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0 [ 7.721101] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes [ 7.737412] remoteproc remoteproc0: attaching to 4d80800000.dsp [ 7.747550] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 7.841211] PVR_K: 216: RGX Device registered with BVNC 22.104.208.318 [ 7.863686] img_enc 4200000.video-encoder: encoder registered as /dev/video1 [ 7.878147] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode [ 7.917098] platform 41000000.r5f: configured R5F for IPC-only mode [ 7.923853] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 1 [ 7.936612] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 7.952205] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 7.965610] virtio_rpmsg_bus virtio0: rpmsg host is online [ 7.971157] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 7.978667] remoteproc remoteproc1: 41000000.r5f is available [ 7.984461] remoteproc remoteproc1: attaching to 41000000.r5f [ 7.992065] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 7.998811] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 8.008703] virtio_rpmsg_bus virtio1: rpmsg host is online [ 8.014019] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 8.020820] remoteproc1#vdev0buffer: registered virtio1 (type 7) [ 8.027004] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 8.039394] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 8.054224] remoteproc remoteproc1: remote processor 41000000.r5f is now attached [ 8.060712] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached [ 8.067317] platform 5c00000.r5f: configured R5F for IPC-only mode [ 8.087597] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 8.111789] remoteproc remoteproc2: 5c00000.r5f is available [ 8.127349] remoteproc remoteproc2: attaching to 5c00000.r5f [ 8.133192] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 8.147344] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 8.157118] virtio_rpmsg_bus virtio2: rpmsg host is online [ 8.162977] remoteproc2#vdev0buffer: registered virtio2 (type 7) [ 8.169507] remoteproc remoteproc2: remote processor 5c00000.r5f is now attached [ 8.176975] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ 8.185181] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 8.200725] platform 5d00000.r5f: configured R5F for IPC-only mode [ 8.269095] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode [ 8.315831] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 8.348722] remoteproc remoteproc3: 4d81800000.dsp is available [ 8.363624] remoteproc remoteproc4: 5d00000.r5f is available [ 8.400223] remoteproc remoteproc3: attaching to 4d81800000.dsp [ 8.426670] remoteproc remoteproc4: attaching to 5d00000.r5f [ 8.436201] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode [ 8.456617] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 8.470248] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 8.516236] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 8.553719] virtio_rpmsg_bus virtio3: rpmsg host is online [ 8.559337] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 8.597471] virtio_rpmsg_bus virtio4: rpmsg host is online [ 8.612362] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 8.627835] remoteproc3#vdev0buffer: registered virtio3 (type 7) [ 8.669737] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 8.707096] remoteproc remoteproc3: remote processor 4d81800000.dsp is now attached [ 8.747328] remoteproc remoteproc4: remote processor 5d00000.r5f is now attached [ 8.777036] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ 8.810204] platform 5e00000.r5f: configured R5F for remoteproc mode [ 8.837388] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 8.851473] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 8.875419] remoteproc remoteproc5: 64800000.dsp is available [ 8.889624] remoteproc remoteproc6: 5e00000.r5f is available [ 8.914934] remoteproc remoteproc5: attaching to 64800000.dsp [ 8.928929] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2 [ 8.939481] remoteproc remoteproc5: unsupported resource 65538 [ 8.945370] remoteproc remoteproc6: powering up 5e00000.r5f [ 8.950972] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2 [ 8.960074] remoteproc remoteproc6: request_firmware failed: -2 [ 8.966756] platform 5f00000.r5f: configured R5F for remoteproc mode [ 8.983456] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 8.991572] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 9.011988] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ 9.027513] remoteproc remoteproc7: 5f00000.r5f is available [ 9.052341] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2 [ 9.064113] remoteproc remoteproc7: powering up 5f00000.r5f [ 9.075317] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2 [ 9.084357] remoteproc remoteproc7: request_firmware failed: -2 [ 9.103830] virtio_rpmsg_bus virtio5: rpmsg host is online [ 9.109403] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 9.116601] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ 9.125567] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe [ 9.138187] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 9.148761] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 9.160403] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 9.170145] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 9.171622] remoteproc5#vdev0buffer: registered virtio5 (type 7) [ 9.179481] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ 9.191920] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe [ 9.199810] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 9.207500] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 9.216631] remoteproc remoteproc5: remote processor 64800000.dsp is now attached [ 9.220783] BUG: Bad page map in process mount.sh pte:200008fa780fc3 pmd:8a5150003 [ 9.224119] Unable to handle kernel paging request at virtual address ffdf000820354700 [ 9.231759] page:(____ptrval____) refcount:0 mapcount:-129 mapping:0000000000000000 index:0x1 pfn:0x8fa78 [ 9.239642] Mem abort info: [ 9.239643] ESR = 0x96000004 [ 9.239646] EC = 0x25: DABT (current EL), IL = 32 bits [ 9.239648] SET = 0, FnV = 0 [ 9.249192] flags: 0x8000000000000002(referenced) [ 9.251965] EA = 0, S1PTW = 0 [ 9.251966] Data abort info: [ 9.251968] ISV = 0, ISS = 0x00000004 [ 9.251970] CM = 0, WnR = 0 [ 9.255012] raw: 8000000000000002 ffffffe001fec408 ffffffe001fede88 0000000000000000 [ 9.260300] [ffdf000820354700] address between user and kernel address ranges [ 9.260303] Internal error: Oops: 96000004 [#1] PREEMPT SMP [ 9.260306] Modules linked in: ti_k3_r5_remoteproc cdns_mhdp8546 pruss vxe_enc vxd_dec j721e_csi2rx sa2ul pvrsrvkm(O) videobuf2_dma_6 [ 9.260349] CPU: 0 PID: 187 Comm: systemd-udevd Tainted: G O 5.10.100-g7a7a3af903 #1 [ 9.260351] Hardware name: Texas Instruments J721E SK (DT) [ 9.260355] pstate: 20000085 (nzCv daIf -PAN -UAO -TCO BTYPE=--) [ 9.260363] pc : update_curr+0x34/0x1a8 [ 9.260367] lr : task_tick_fair+0x6c/0x680 [ 9.260369] sp : ffff80001138fd00 [ 9.260370] x29: ffff80001138fd00 x28: ffff8000100e9b28 [ 9.260374] x27: ffff00087fa68300 x26: 0000000000000004 [ 9.260377] x25: ffff80001124d000 x24: ffff800011153000 [ 9.260381] x23: ffff800010fe1a60 x22: ffff000820354600 [ 9.260384] x21: ffff00087fa6b040 x20: ffff000824b93600 [ 9.260387] x19: ffdf0008203546c0 x18: 0000000000000010 [ 9.260390] x17: 0000000000000000 x16: 0000000000000000 [ 9.260393] x15: 00009ef9c3a71d96 x14: 00000000000000c0 [ 9.260397] x13: 0000000000000318 x12: 0000000000000001 [ 9.260400] x11: 000000000000031b x10: 0000000000000007 [ 9.260403] x9 : 0000000000000000 x8 : 000000000000031b [ 9.260406] x7 : ffff00087fa6bb80 x6 : ffff00087fa6b040 [ 9.260410] x5 : 000000000000b999 x4 : 0000000000000000 [ 9.260413] x3 : ffff800010088ab8 x2 : 0000000000000000 [ 9.260416] x1 : ffff000820354600 x0 : 0000000222ac6d49 [ 9.260420] Call trace: [ 9.260423] update_curr+0x34/0x1a8 [ 9.260425] task_tick_fair+0x6c/0x680 [ 9.260432] scheduler_tick+0xb8/0x158 [ 9.260436] update_process_times+0x8c/0xa0 [ 9.260439] tick_sched_handle.isra.0+0x34/0x50 [ 9.260442] tick_sched_timer+0x4c/0xa8 [ 9.260444] __hrtimer_run_queues+0x114/0x1b8 [ 9.260446] hrtimer_interrupt+0xe8/0x248 [ 9.260451] arch_timer_handler_phys+0x34/0x48 [ 9.260455] handle_percpu_devid_irq+0x84/0x148 [ 9.260459] generic_handle_irq+0x30/0x48 [ 9.260461] __handle_domain_irq+0x64/0xc0 [ 9.260465] gic_handle_irq+0x58/0x128 [ 9.260469] el1_irq+0xcc/0x180 [ 9.260472] console_unlock+0x268/0x428 [ 9.260475] vprintk_emit+0x134/0x268 [ 9.260480] dev_vprintk_emit+0x14c/0x17c [ 9.260482] dev_printk_emit+0x5c/0x80 [ 9.260485] __dev_printk+0x5c/0x7c [ 9.260488] _dev_info+0x64/0x88 [ 9.260492] rproc_boot+0x480/0x670 [ 9.260494] rproc_add+0x88/0x158 [ 9.260503] k3_dsp_rproc_probe+0x710/0x850 [ti_k3_dsp_remoteproc] [ 9.260508] platform_drv_probe+0x54/0xa8 [ 9.260510] really_probe+0xec/0x3e0 [ 9.260513] driver_probe_device+0x58/0xb8 [ 9.260515] device_driver_attach+0x74/0x80 [ 9.260518] __driver_attach+0x58/0xe0 [ 9.260520] bus_for_each_dev+0x70/0xc0 [ 9.260522] driver_attach+0x24/0x30 [ 9.260524] bus_add_driver+0x14c/0x1f0 [ 9.260527] driver_register+0x64/0x120 [ 9.260529] __platform_driver_register+0x48/0x58 [ 9.260533] k3_dsp_rproc_driver_init+0x20/0x10000 [ti_k3_dsp_remoteproc] [ 9.260536] do_one_initcall+0x54/0x1b8 [ 9.260539] do_init_module+0x54/0x208 [ 9.260542] load_module+0x1f28/0x24c8 [ 9.260545] __do_sys_finit_module+0xb8/0xf8 [ 9.260548] __arm64_sys_finit_module+0x20/0x30 [ 9.260552] el0_svc_common.constprop.0+0x78/0x1c8 [ 9.260554] do_el0_svc+0x24/0x90 [ 9.260557] el0_svc+0x14/0x20 [ 9.260559] el0_sync_handler+0xb0/0xb8 [ 9.260561] el0_sync+0x180/0x1c0 [ 9.260565] Code: 7100041f 54000969 f944e2a0 b40002f3 (f9402275) [ 9.260572] ---[ end trace 309d337a7213834f ]--- [ 9.260574] Kernel panic - not syncing: Oops: Fatal exception in interrupt [ 9.260577] SMP: stopping secondary CPUs [ 10.329580] SMP: failed to stop secondary CPUs 0-1 [ 10.329584] Kernel Offset: disabled [ 10.329587] CPU features: 0x0040022,20006008 [ 10.329588] Memory Limit: none [ 10.730999] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:34:29 +0000) Model: Texas Instruments J721E SK R5 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.5(release):08.01.00.006-dirty NOTICE: BL31: Built : 21:03:57, Mar 23 2022 U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000) Model: Texas Instruments J721E SK A72 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 ERROR: Unhandled External Abort received on 0x80000000 from EL2 ERROR: exception reason=0 syndrome=0xbf000000 Unhandled Exception from EL2 x0 = 0x00000000ffffffff x1 = 0x0000000080177938 x2 = 0x0000000000000020 x3 = 0x0000000000000000 x4 = 0x0000000000000020 x5 = 0x00000000fffff807 x6 = 0x0000000000000000 x7 = 0x0000000000000000 x8 = 0x0000000080177df8 x9 = 0x0000000000000008 x10 = 0x000000000a200023 x11 = 0x0000000000000002 x12 = 0x0000000000000002 x13 = 0x00000000807ff980 x14 = 0x00000000807ff980 x15 = 0x0000000080081344 x16 = 0x000000008009ce0c x17 = 0x0000000000000000 x18 = 0x0000000080177e90 x19 = 0x00000000ffffffff x20 = 0x0000000000000000 x21 = 0x0000000000008000 x22 = 0x00000000800bf4d0 x23 = 0x00000000800b764e x24 = 0x00000000800b7636 x25 = 0x00000000deadbeef x26 = 0x0000000000000005 x27 = 0x0000000000000000 x28 = 0x0000000000000000 x29 = 0x0000000080177940 x30 = 0x0000000080089b14 scr_el3 = 0x000000000000073d sctlr_el3 = 0x0000000030cd183f cptr_el3 = 0x0000000000000000 tcr_el3 = 0x0000000080803520 daif = 0x00000000000002c0 mair_el3 = 0x00000000004404ff spsr_el3 = 0x00000000800003c9 elr_el3 = 0x0000000080089b3c ttbr0_el3 = 0x0000000070010c00 esr_el3 = 0x00000000bf000000 far_el3 = 0x0000000000000000 spsr_el1 = 0x0000000000000000 elr_el1 = 0x0000000000000000 spsr_abt = 0x0000000000000000 spsr_und = 0x0000000000000000 spsr_irq = 0x0000000000000000 spsr_fiq = 0x0000000000000000 sctlr_el1 = 0x0000000030d00801 actlr_el1 = 0x0000000000000000 cpacr_el1 = 0x0000000000000000 csselr_el1 = 0x0000000000000000 sp_el1 = 0x0000000000000000 esr_el1 = 0x0000000000000000 ttbr0_el1 = 0x0000000000000000 ttbr1_el1 = 0x0000000000000000 mair_el1 = 0x0000000000000000 amair_el1 = 0x0000000000000000 tcr_el1 = 0x0000000000800080 tpidr_el1 = 0x0000000000000000 tpidr_el0 = 0x0000000000000000 tpidrro_el0 = 0x0000000000000000 par_el1 = 0x0000000000000000 mpidr_el1 = 0x0000000080000000 afsr0_el1 = 0x0000000000000000 afsr1_el1 = 0x0000000000000000 contextidr_el1 = 0x0000000000000000 vbar_el1 = 0x0000000000000000 cntp_ctl_el0 = 0x0000000000000000 cntp_cval_el0 = 0x0000000000000000 cntv_ctl_el0 = 0x0000000000000000 cntv_cval_el0 = 0x0000000000000000 cntkctl_el1 = 0x0000000000000000 sp_el0 = 0x000000007000a3d0 isr_el1 = 0x0000000000000000 dacr32_el2 = 0x0000000000000000 ifsr32_el2 = 0x0000000000000000 cpuectlr_el1 = 0x0000001b00000040 cpumerrsr_el1 = 0x0000000000000000 l2merrsr_el1 = 0x0000000000000000 U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:34:29 +0000) Model: Texas Instruments J721E SK R5 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 spl_load_image_fat: error reading image tispl.bin, err - -6 spl_load_image_ext: ext4fs mount err - 0 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:34:29 +0000) Model: Texas Instruments J721E SK R5 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.5(release):08.01.00.006-dirty NOTICE: BL31: Built : 21:03:57, Mar 23 2022 U-Boot SPL 2021.01-g44a87e3ab8 (Mar 23 2022 - 21:04:54 +0000) Model: Texas Instruments J721E SK A72 Board: J721EX-EAIK rev A1 SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam') Trying to boot from MMC2 ERROR: Unhandled External Abort received on 0x80000000 from EL2 ERROR: exception reason=0 syndrome=0xbf000000 Unhandled Exception from EL2 x0 = 0x0000000000000000 x1 = 0x0000000000000000 x2 = 0x0000000000000000 x3 = 0x0000000000000038 x4 = 0x000000000000000a x5 = 0x0000000000000021 x6 = 0x0000000000020000 x7 = 0x0000000000100000 x8 = 0x0000000080177768 x9 = 0x0000000000000008 x10 = 0x00000000ffdfffd0 x11 = 0x0000000000000010 x12 = 0x0000000000000af8 x13 = 0x00000000801778bc x14 = 0x00000000808fdab8 x15 = 0x00000000808fdab8 x16 = 0x000000008009ce0c x17 = 0x0000000000000000 x18 = 0x0400000003000000 x19 = 0x000000007ff77768 x20 = 0x00000000801772eb x21 = 0x00000000ffdfffc8 x22 = 0x00000000801777a0 x23 = 0x00000000801777a0 x24 = 0x00000000801772c8 x25 = 0x00000000808c583c x26 = 0x0000000000000008 x27 = 0x00000000ffffffff x28 = 0x00000000801776dc x29 = 0x0000000080177140 x30 = 0x00000000808b21ec scr_el3 = 0x000000000000073d sctlr_el3 = 0x0000000030cd183f cptr_el3 = 0x0000000000000000 tcr_el3 = 0x0000000080803520 daif = 0x00000000000002c0 mair_el3 = 0x00000000004404ff spsr_el3 = 0x00000000a00003c9 elr_el3 = 0x00000000808b20b4 ttbr0_el3 = 0x0000000070010c00 esr_el3 = 0x00000000bf000000 far_el3 = 0x0000000000000000 spsr_el1 = 0x0000000000000000 elr_el1 = 0x0000000000000000 spsr_abt = 0x0000000000000000 spsr_und = 0x0000000000000000 spsr_irq = 0x0000000000000000 spsr_fiq = 0x0000000000000000 sctlr_el1 = 0x0000000030d00801 actlr_el1 = 0x0000000000000000 cpacr_el1 = 0x0000000000000000 csselr_el1 = 0x0000000000000000 sp_el1 = 0x0000000000000000 esr_el1 = 0x0000000000000000 ttbr0_el1 = 0x0000000000000000 ttbr1_el1 = 0x0000000000000000 mair_el1 = 0x0000000000000000 amair_el1 = 0x0000000000000000 tcr_el1 = 0x0000000000800080 tpidr_el1 = 0x0000000000000000 tpidr_el0 = 0x0000000000000000 tpidrro_el0 = 0x0000000000000000 par_el1 = 0x0000000000000000 mpidr_el1 = 0x0000000080000000 afsr0_el1 = 0x0000000000000000 afsr1_el1 = 0x0000000000000000 contextidr_el1 = 0x0000000000000000 vbar_el1 = 0x0000000000000000 cntp_ctl_el0 = 0x0000000000000000 cntp_cval_el0 = 0x0000000000000000 cntv_ctl_el0 = 0x0000000000000000 cntv_cval_el0 = 0x0000000000000000 cntkctl_el1 = 0x0000000000000000 sp_el0 = 0x000000007000a3d0 isr_el1 = 0x0000000000000000 dacr32_el2 = 0x0000000000000000 ifsr32_el2 = 0x0000000000000000 cpuectlr_el1 = 0x0000001b00000040 cpumerrsr_el1 = 0x0000000000000000 l2merrsr_el1 = 0x0000000000000000
Hi Archie,
Some common issues for the board not being able to boot up properly are:
Does the board still fail to boot when switching out power supply and SD card from a known working setup?
Takuma
Hello Takuma,
Cx responded.
I have switched them with other board's it still the same.
My SD card and power supply works well on other board so I think it may not the problem.
For your assistance.
73,
Archie A.
Hi Archie,
So far, it sounds like a defective board. I will have the hardware team look at this thread as well, but it sounds very similar to the following thread: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1123065/sk-tda4vm-the-evm-board-often-crashes-when-running-or-no-loading
Takuma
Since both the power supply and SD card are working with several other SKs, the Starter Kit looks to be defective. You can go to: https://www.ti.com/productreturns/docs/createReturn.tsp
to get the return process started. You will use this E2E thread as confirmation issue with Starter Kit board.
