Part Number: CCSTUDIO
Other Parts Discussed in Thread: TDA4VH
Hello everyone,
I am trying to use CCS(Code Composer Studio) debug on J784S4 TDA4VH as per below link guide. When loadJSFile("/home/user/ti-processor-sdk-rtos-j784s4-evm-08_06_00_14/pdk_j784s4_08_06_00_31/packages/ti/drv/sciclient/tools/ccsLoadDmsc/j784s4/launch.js"), CCS is always stuck as the below screen and can't move forward.
Meanwhile the XDS110 JTAG connector indicator changes from green to red.
CCS scripting Console log and Console log are attached as below. Could you help me? Thanks a lot
js:> loadJSFile("/home/huwenzhi/workspace/tda4VH_J784S4/ti-processor-sdk-rtos-j784s4-evm-08_06_00_14/pdk_j784s4_08_06_00_31/packages/ti/drv/sciclient/tools/ccsLoadDmsc/j784s4/launch.js")
Connecting to Cortex_M4F_0!
Fill R5F ATCM memory...
Writing While(1) for R5F
Loading DMSC Firmware ... /home/huwenzhi/workspace/tda4VH_J784S4/ti-processor-sdk-rtos-j784s4-evm-08_06_00_14/pdk_j784s4_08_06_00_31/packages/ti/drv/sciclient/soc/sysfw/binaries/ti-fs-firmware-j784s4-gp.bin
DMSC Firmware Load Done...
DMSC Firmware run starting now...
J784S4 Running the DDR configuration... Wait till it completes!
CORTEX_M4F_0: GEL Output: Configuring ATCM for the R5Fs CORTEX_M4F_0: GEL Output: ATCM Configured. CORTEX_M4F_0: GEL Output: This GEL is currently only supported for use from the Cortex-M3 inside the DMSC. CORTEX_M4F_0: GEL Output: Do not run this GEL from any other CPU on the SoC. CORTEX_M4F_0: GEL Output: This script sets the first address translation region to [0x8000_0000, 0x0000_0000]. CORTEX_M4F_0: GEL Output: It also sets the second address translation region to [0x6000_0000, 0x4000_0000]. CORTEX_M4F_0: GEL Output: This is consistent with the SoC DV assumptions. CORTEX_M4F_0: GEL Output: R5F Halt bits set. CORTEX_M4F_0: GEL Output: Debugging disabled. CORTEX_M4F_0: GEL Output: Powering up LPSC_WKUPMCU2MAIN CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Checking LPSC_WKUPMCU2MAIN CORTEX_M4F_0: GEL Output: Power Domain: On CORTEX_M4F_0: GEL Output: Module State: Enable CORTEX_M4F_0: GEL Output: Programming all PLLs. CORTEX_M4F_0: GEL Output: Programming Main PLL 0 (Main PLL) CORTEX_M4F_0: GEL Output: Main PLL 0 (Main PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 1 (Peripheral 0 PLL) CORTEX_M4F_0: GEL Output: Main PLL 1 (Peripheral 0 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 2 (Peripheral 1 PLL) CORTEX_M4F_0: GEL Output: Main PLL 2 (Peripheral 1 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 3 (CPSW5X PLL) CORTEX_M4F_0: GEL Output: Main PLL 3 (CPSW5X PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 4 (Audio 0 PLL) CORTEX_M4F_0: GEL Output: Main PLL 4 (Audio 0 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 5 (Video PLL) CORTEX_M4F_0: GEL Output: Main PLL 5 (Video PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 6 (GPU PLL) CORTEX_M4F_0: GEL Output: Main PLL 6 (GPU PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 7 (MSMC PLL) CORTEX_M4F_0: GEL Output: Main PLL 7 (MSMC PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 8 (ARM0 PLL) CORTEX_M4F_0: GEL Output: Main PLL 8 (ARM0 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 9 (ARM1 PLL) CORTEX_M4F_0: GEL Output: Main PLL 9 (ARM1 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 12 (DDR0 PLL) CORTEX_M4F_0: GEL Output: Main PLL 12 (DDR0 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 14 (Main Domain Pulsar) PLL) CORTEX_M4F_0: GEL Output: Main PLL 14 (Main Domain Pulsar PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 16 (DSS0 PLL) CORTEX_M4F_0: GEL Output: Main PLL 16 (DSS0 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 17 (DSS1 PLL) CORTEX_M4F_0: GEL Output: Main PLL 17 (DSS1 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 19 (DSS3 PLL) CORTEX_M4F_0: GEL Output: Main PLL 19 (DSS3 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 25 (Vision PLL) CORTEX_M4F_0: GEL Output: Main PLL 25 (Vision PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 26 (DDR1 PLL) CORTEX_M4F_0: GEL Output: Main PLL 26 (DDR1 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 27 (DDR2 PLL) CORTEX_M4F_0: GEL Output: Main PLL 27 (DDR2 PLL) Set. CORTEX_M4F_0: GEL Output: Programming Main PLL 28 (DDR3 PLL) CORTEX_M4F_0: GEL Output: Main PLL 28 (DDR3 PLL) Set. CORTEX_M4F_0: GEL Output: Programming MCU PLL 0 (MCU PLL) CORTEX_M4F_0: GEL Output: MCU PLL 0 (MCU PLL) Set. CORTEX_M4F_0: GEL Output: Programming MCU PLL 1 (MCU Peripheral PLL) CORTEX_M4F_0: GEL Output: MCU PLL 1 (MCU PLL) Set. CORTEX_M4F_0: GEL Output: Programming MCU PLL 2 (MCU CPSW PLL) CORTEX_M4F_0: GEL Output: MCU PLL 2 (MCU PLL) Set. CORTEX_M4F_0: GEL Output: All PLLs programmed. CORTEX_M4F_0: GEL Output: Powering up all PSC power domains in progress... CORTEX_M4F_0: GEL Output: Powering up LPSC_WKUP_ALWAYSON CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_DMSC CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_DEBUG2DMSC CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_WKUP_GPIO CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_WKUPMCU2MAIN CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN2WKUPMCU CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_TEST CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_DEBUG CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_MCAN_0 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_MCAN_1 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_OSPI_0 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_OSPI_1 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_HYPERBUS CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_I3C_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_ADC_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_ADC_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_WKUP_SPARE_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_R5_0 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_R5_1 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MCU_PULSAR_PBIST_0 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_ALWAYSON CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_TEST CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_PBIST CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_AUDIO CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_ATL CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_MLB CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_MOTOR CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_MISCIO CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_GPMC CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_VPFE CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_VPE CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_SPARE_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_SPARE_1 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_DEBUG CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_CFG_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_DATA_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_CFG_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_DATA_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_CFG_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_DATA_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_SPARE_2 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_CC_TOP_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MMC4B_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MMC4B_1 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MMC8B_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_SAUL CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PER_I3C CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_CFG_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_EMIF_DATA_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MSMC_L1_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DRU_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_ANA_PBIST_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MSMC_L1_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DRU_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_ANA_PBIST_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MSMC_L1_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DRU_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_ANA_PBIST_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MSMC_L1_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DRU_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_ANA_PBIST_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_SERDES_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_SERDES_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_SERDES_4 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_SERDES_5 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_4 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_5 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_6 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_7 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_8 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_9 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_10 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_11 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_12 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_MAIN_MCANSS_13 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DSS_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DSS CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_TX_DPHY_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DSI CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_EDP_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSITX_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSIRX_PHY_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSIRX_PHY_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSIRX_PHY_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSIRX_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSIRX_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSIRX_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_CSITX_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_TX_DPHY_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_9GSS CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PCIe_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PCIe_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PCIe_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PCIe_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DMTIMER_0 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_DMTIMER_1 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_DMTIMER_2 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_DMTIMER_3 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powered up all Main Timers. CORTEX_M4F_0: GEL Output: Powering up LPSC_USB_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_USB_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_USB_2 CORTEX_M4F_0: GEL Output: No change needed. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_0_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_1_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_2_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_C71X_3_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER_0_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER_1_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER0_CORE2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER0_CORE3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER1_CORE2 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_A72_CLUSTER1_CORE3 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_GPUCOM CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_GPUPBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_GPUCORE CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_0_R5_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_0_R5_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_0_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_1_R5_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_1_R5_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_1_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_2_R5_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_2_R5_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_PULSAR_2_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_ENCODE_0 CORTEX_M4F_0: GEL Output: ERROR: module state NOT changed! CORTEX_M4F_0: GEL Output: Powering up LPSC_ENCODE_PBIST CORTEX_M4F_0: GEL Output: ERROR: module state NOT changed! CORTEX_M4F_0: GEL Output: Powering up LPSC_ENCODE_1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_ENCODE_1_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DECODE_0 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DECODE_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DMPAC CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_SDE CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_DMPAC_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_VPAC CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_VPAC_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_VPAC1 CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up LPSC_VPAC1_PBIST CORTEX_M4F_0: GEL Output: Power domain and module state changed successfully. CORTEX_M4F_0: GEL Output: Powering up PD_SPARE4 CORTEX_M4F_0: GEL Output: ERROR: module state NOT changed! CORTEX_M4F_0: GEL Output: Powering up PD_SPARE5 CORTEX_M4F_0: GEL Output: ERROR: module state NOT changed! CORTEX_M4F_0: GEL Output: Powering up PD_SPARE6 CORTEX_M4F_0: GEL Output: ERROR: module state NOT changed! CORTEX_M4F_0: GEL Output: Powering up all PSC power domains done! CORTEX_M4F_0: GEL Output: MCU R5F Cluster set to split mode. CORTEX_M4F_0: GEL Output: Main R5F Cluster 0 set to split mode. CORTEX_M4F_0: GEL Output: Main R5F Cluster 1 set to split mode. CORTEX_M4F_0: GEL Output: Main R5F Cluster 2 set to split mode. CORTEX_M4F_0: GEL Output: --->>> ================================================== <<<--- CORTEX_M4F_0: GEL Output: --->>> Set DDR Interelave Configuration: Enable DDR0 only <<<--- CORTEX_M4F_0: GEL Output: --->>> ==================================================== <<<--- CORTEX_M4F_0: GEL Output: Setting DDR0 PLL to produce a clock at 1066MHz. CORTEX_M4F_0: GEL Output: Programming Main PLL 12 (DDR0 PLL) CORTEX_M4F_0: GEL Output: Main PLL 12 (DDR0 PLL) Set. CORTEX_M4F_0: GEL Output: --->>> DDR controller programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PI programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PHY Data Slice 0 programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PHY Data Slice 1 programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PHY Data Slice 2 programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PHY Data Slice 3 programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PHY Address Slice 0 programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> Set PHY registers for F1 freq... <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PHY programming completed... <<<--- CORTEX_M4F_0: GEL Output: --->>> NO Set PHY registers for F2 freq... FI and F2 are set to the same<<<--- CORTEX_M4F_0: GEL Output: --->>> Non-CS Interleave CTL_273 0x000001FF.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Manual modification by Rajesh... Before <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_139 0x000E0A09.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_140 0x07000401.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_148 0x08080000.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_227 0x15110000.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_277 0x01180101.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_377 0x00010000.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_430 0x00000105.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Manual modification by Rajesh... <<<--- CORTEX_M4F_0: GEL Output: --->>> Manual modification by Rajesh... After <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_139 0x000E0A09.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_140 0x07000400.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_148 0x08080000.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_227 0x15130000.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_277 0x01140101.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_377 0x00010000.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Read Back Manual modification CTL_430 0x00000105.. <<<--- CORTEX_M4F_0: GEL Output: --->>> Disable all trainig for pre-silicon simulation <<<--- CORTEX_M4F_0: GEL Output: --->>> Adjust the latencies for pre-silicon simulation <<<--- CORTEX_M4F_0: GEL Output: --->>> DDR PI initialization started... <<<--- CORTEX_M4F_0: GEL Output: --->>> Waiting for first frequency change request ... <<<---
