I am using Yocto with the meta-ti-bsp layer to create a simple image with graphical support for the SK-AM68.
Using Yocto (kirkstone) my local.conf file:
IMAGE_INSTALL:append = " vim glmark2" MACHINE_ESSENTIAL_EXTRA_RRECOMMENDS += "kernel-modules" DISTRO_FEATURES:remove = "x11 vulkan" DISTRO_FEATURES:append = " wayland egl gles2" DISTRO_FEATURES:append = " pam opencv openmp" PACKAGECONFIG:append:pn-glmark2 = " drm-gles2 wayland-gles2" PACKAGECONFIG:append:pn-libsdl2 = " kmsdrm" PACKAGECONFIG:append:pn-weston = " egl wayland" PACKAGECONFIG:append:pn-cairo = " egl glesv2" KERNEL_DEVICETREE_PREFIX:append = " k3-am68 ti/k3-am68" KERNEL_DEVICETREE:append = " ti/k3-am68-sk-base-board.dtb" MACHINE ??= "j721s2-evm"
and my bblayers file:
POKY_BBLAYERS_CONF_VERSION = "2" BBPATH = "${TOPDIR}" BBFILES ?= "" BBLAYERS ?= " \ /home/rich/Yocto/poky-kirkstone/meta \ /home/rich/Yocto/poky-kirkstone/meta-poky \ /home/rich/Yocto/poky-kirkstone/meta-yocto-bsp \ /home/rich/Yocto/poky-kirkstone/meta-arm/meta-arm-toolchain \ /home/rich/Yocto/poky-kirkstone/meta-arm/meta-arm \ /home/rich/Yocto/poky-kirkstone/meta-ti/meta-ti-bsp \ /home/rich/Yocto/poky-kirkstone/meta-openembedded/meta-oe \ "
I can do `bitbake core-image-weston` to generate an image and use balena-etcher to flash it to the SD card.
Now the first problem I have (also present with the SDK), is that the board does not boot up into the uboot shell with *tiboot3-j721s2-gp-evm.bin* but only boots with *tiboot3-j721s2-hs-fs-evm.bin*.
Now when using the tiboot3-j721s2-hs-fs-evm.bin file, I can boot the kernel and load the `/boot/k3-am68-sk-base-board` device tree blob and the `k3-am68-sk-som-ddr_mem_carveout` device tree overlay.
setenv dorprocboot 1; mmc dev 1; run init_mmc; ext4load mmc 1:2 ${loadaddr} /boot/Image; ext4load mmc 1:2 ${fdtaddr} /boot/k3-am68-sk-base-board.dtb; setenv name_overlays k3-am68-sk-som-ddr_mem_carveout.dtbo $name_overlays; run get_overlay_mmc; setenv bootargs console=ttyS2,115200n8 root=/dev/mmcblk1p2 rootfstype=ext4 rootwait; booti ${loadaddr} - ${fdtaddr}
And I get the kernel boot log
Starting kernel ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.168-g2c23e6c538 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Thu Feb 23 19:09:34 UTC 2023 [ 0.000000] Machine model: Texas Instruments AM68 SK [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x0000000bffffefff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a9bfffff] [ 0.000000] node 0: [mem 0x00000000a9c00000-0x00000000ffffefff] [ 0.000000] node 0: [mem 0x0000000880000000-0x0000000bffffefff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff] [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] cma: Reserved 512 MiB at 0x00000000dfc00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s51288 r8192 d30632 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128766 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk1p2 rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000dbc00000-0x00000000dfc00000] (64MB) [ 0.000000] Memory: 15663700K/16777208K available (11328K kernel code, 1162K rwdata, 4260K rodata, 1856K init, 431K bss, 589220K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000181] Console: colour dummy device 80x25 [ 0.000213] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.000220] pid_max: default: 32768 minimum: 301 [ 0.000266] LSM: Security Framework initializing [ 0.000364] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.000448] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.001350] rcu: Hierarchical SRCU implementation. [ 0.001518] Platform MSI: msi-controller@1820000 domain created [ 0.001648] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.001691] EFI services will not be available. [ 0.001794] smp: Bringing up secondary CPUs ... [ 0.010229] Detected PIPT I-cache on CPU1 [ 0.010255] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.010267] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000 [ 0.010308] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.010362] smp: Brought up 1 node, 2 CPUs [ 0.010370] SMP: Total of 2 processors activated. [ 0.010376] CPU features: detected: 32-bit EL0 Support [ 0.010380] CPU features: detected: CRC32 instructions [ 0.019786] CPU: All CPU(s) started at EL2 [ 0.019812] alternatives: patching kernel code [ 0.020357] devtmpfs: initialized [ 0.024298] KASLR disabled due to lack of seed [ 0.024408] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.024418] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.030843] pinctrl core: initialized pinctrl subsystem [ 0.031154] DMI not present or invalid. [ 0.031483] NET: Registered protocol family 16 [ 0.032270] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.032652] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.033187] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.033406] thermal_sys: Registered thermal governor 'step_wise' [ 0.033409] thermal_sys: Registered thermal governor 'power_allocator' [ 0.033918] cpuidle: using governor menu [ 0.034001] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.034031] ASID allocator initialised with 65536 entries [ 0.048627] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.048635] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.048638] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.048641] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.049282] cryptd: max_cpu_qlen set to 1000 [ 0.050971] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected [ 0.051247] vsys_3v3: supplied by vusb-main5v0 [ 0.051959] iommu: Default domain type: Translated [ 0.052145] SCSI subsystem initialized [ 0.052398] mc: Linux media interface: v0.10 [ 0.052411] videodev: Linux video capture interface: v2.00 [ 0.052444] pps_core: LinuxPPS API ver. 1 registered [ 0.052448] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.052453] PTP clock support registered [ 0.052469] EDAC MC: Ver: 3.0.0 [ 0.053039] FPGA manager framework [ 0.053074] Advanced Linux Sound Architecture Driver Initialized. [ 0.053448] clocksource: Switched to clocksource arch_sys_counter [ 0.053540] VFS: Disk quotas dquot_6.6.0 [ 0.053568] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.056027] NET: Registered protocol family 2 [ 0.056849] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.060275] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 0.060394] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.060808] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) [ 0.061256] TCP: Hash tables configured (established 131072 bind 65536) [ 0.061394] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.061768] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.062017] NET: Registered protocol family 1 [ 0.062338] RPC: Registered named UNIX socket transport module. [ 0.062344] RPC: Registered udp transport module. [ 0.062347] RPC: Registered tcp transport module. [ 0.062350] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.062355] NET: Registered protocol family 44 [ 0.062369] PCI: CLS 0 bytes, default 64 [ 0.062719] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.064881] Initialise system trusted keyrings [ 0.064976] workingset: timestamp_bits=46 max_order=22 bucket_order=0 [ 0.066555] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.066837] NFS: Registering the id_resolver key type [ 0.066861] Key type id_resolver registered [ 0.066864] Key type id_legacy registered [ 0.066896] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.066901] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.066988] 9p: Installing v9fs 9p2000 file system support [ 0.086993] Key type asymmetric registered [ 0.086999] Asymmetric key parser 'x509' registered [ 0.087023] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.087028] io scheduler mq-deadline registered [ 0.087032] io scheduler kyber registered [ 0.088382] pinctrl-single 4301c000.pinctrl: 101 pins, size 404 [ 0.088529] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.092901] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.099273] brd: module loaded [ 0.102701] loop: module loaded [ 0.103334] megasas: 07.714.04.00-rc1 [ 0.105253] tun: Universal TUN/TAP device driver, 1.6 [ 0.105560] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.105564] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.105598] sky2: driver version 1.30 [ 0.106180] VFIO - User Level meta-driver version: 0.3 [ 0.106712] i2c /dev entries driver [ 0.107488] sdhci: Secure Digital Host Controller Interface driver [ 0.107492] sdhci: Copyright(c) Pierre Ossman [ 0.107679] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.108222] ledtrig-cpu: registered to indicate activity on CPUs [ 0.108412] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.109160] optee: probing for conduit method. [ 0.109180] optee: revision 3.20 (8e74d476) [ 0.125616] optee: dynamic shared memory is enabled [ 0.125842] optee: initialized driver [ 0.127108] NET: Registered protocol family 17 [ 0.127191] 9pnet: Installing 9P2000 support [ 0.127231] Key type dns_resolver registered [ 0.127383] Loading compiled-in X.509 certificates [ 0.135201] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3-v08.06.03 (Chill Capybara') [ 0.158846] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz [ 0.159283] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 400 kHz [ 0.159938] pca953x 2-0020: supply vcc not found, using dummy regulator [ 0.159999] pca953x 2-0020: using no AI [ 0.182601] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz [ 0.183348] pca953x 3-0021: supply vcc not found, using dummy regulator [ 0.183405] pca953x 3-0021: using no AI [ 0.206016] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 0.206510] omap_i2c 2040000.i2c: bus 4 rev0.12 at 400 kHz [ 0.207259] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created [ 0.207356] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created [ 0.207438] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created [ 0.207592] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created [ 0.211885] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 0.211906] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 0.211917] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 0.211928] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.213844] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00 [ 1.213852] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.213857] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff]) [ 1.213861] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff] [ 1.213894] pci 0000:00:00.0: [104c:b013] type 01 class 0x060400 [ 1.213994] pci 0000:00:00.0: supports D1 [ 1.213997] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 1.215516] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.216943] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 1.216958] pci 0000:00:00.0: PCI bridge to [bus 01] [ 1.217216] pcieport 0000:00:00.0: PME: Signaling with IRQ 56 [ 1.218351] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272 [ 1.218358] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.218362] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.219797] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259 [ 1.219803] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.219807] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.220016] omap8250 40a00000.serial: failed to get alias [ 1.220559] printk: console [ttyS2] disabled [ 1.220595] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 28, base_baud = 3000000) is a 8250 [ 2.750311] printk: console [ttyS2] enabled [ 2.761374] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.805452] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.814054] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.822354] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 2.835155] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.842359] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.848644] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 2.859011] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0 [ 2.971668] vdd_mmc1: supplied by vsys_3v3 [ 2.977717] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100 [ 2.984542] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100 [ 2.991342] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100 [ 2.998136] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100 [ 3.005258] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 3.015190] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16) [ 3.029196] spi-nor spi11.0: s28hs512t (65536 Kbytes) [ 3.037061] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 3.081452] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 3.090041] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 3.098337] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 3.111145] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 3.118350] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 3.124590] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 3.134646] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 3.143080] mmc1: CQHCI version 5.10 [ 3.146143] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present! [ 3.153978] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present! [ 3.161756] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present! [ 3.169683] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present! [ 3.182231] ALSA device list: [ 3.185189] No soundcards found. [ 3.194061] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 3.202664] Waiting for root device /dev/mmcblk1p2... [ 3.252963] mmc1: new ultra high speed DDR50 SDHC card at address 5048 [ 3.259869] mmcblk1: mmc1:5048 SD32G 29.7 GiB [ 3.265954] mmcblk1: p1 p2 [ 3.277983] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem [ 3.285288] EXT4-fs (mmcblk1p2): write access will be enabled during recovery [ 3.301199] EXT4-fs (mmcblk1p2): recovery complete [ 3.307495] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.315612] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 3.323137] devtmpfs: mounted [ 3.326800] Freeing unused kernel memory: 1856K [ 3.331435] Run /sbin/init as init process INIT: version 3.01 booting Framebuffer /dev/fb0 not detected Boot splashscreen disabled [ 3.568097] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. Starting udev [ 3.656478] udevd[183]: starting version 3.2.10 [ 3.678427] random: udevd: uninitialized urandom read (16 bytes read) [ 3.685607] random: udevd: uninitialized urandom read (16 bytes read) [ 3.692672] random: udevd: uninitialized urandom read (16 bytes read) [ 3.715251] udevd[184]: starting eudev-3.2.10 [ 3.785742] random: crng init done [ 3.789171] random: 3 urandom warning(s) missed due to ratelimiting [ 3.802019] CAN device driver interface [ 3.904333] pvrsrvkm: loading out-of-tree module taints kernel. [ 3.925403] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a6000000 [ 3.936634] PVR_K: 198: Device: 4e20000000.gpu [ 3.941575] vdec 4210000.video-codec: Direct firmware load for wave521c_codec_fw.bin failed with error -2 [ 3.951782] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode [ 3.952256] vdec 4210000.video-codec: request_firmware, fail: -2 [ 3.965064] PVR_K: 198: Read BVNC 36.53.104.796 from HW device registers [ 3.965344] vdec 4210000.video-codec: wave5_vpu_load_firmware, fail: -2 [ 3.971906] PVR_K: 198: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 3.980891] remoteproc remoteproc0: 64800000.dsp is available [ 3.992862] [drm] Initialized pvr 23.1.6404501 20170530 for 4e20000000.gpu on minor 0 [ 3.994827] remoteproc remoteproc0: Direct firmware load for j721s2-c71_0-fw failed with error -2 [ 4.010610] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a7000000 [ 4.011261] vdec: probe of 4210000.video-codec failed with error -2 [ 4.025482] remoteproc remoteproc0: powering up 64800000.dsp [ 4.026056] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode [ 4.031195] remoteproc remoteproc0: Direct firmware load for j721s2-c71_0-fw failed with error -2 [ 4.052245] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 4.053489] remoteproc remoteproc0: request_firmware failed: -2 [ 4.071000] remoteproc remoteproc1: 65800000.dsp is available [ 4.077022] remoteproc remoteproc1: Direct firmware load for j721s2-c71_1-fw failed with error -2 [ 4.077208] platform 41000000.r5f: configured R5F for IPC-only mode [ 4.085933] remoteproc remoteproc1: powering up 65800000.dsp [ 4.097936] remoteproc remoteproc1: Direct firmware load for j721s2-c71_1-fw failed with error -2 [ 4.106882] remoteproc remoteproc1: request_firmware failed: -2 [ 4.113104] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 4.122433] remoteproc remoteproc2: 41000000.r5f is available [ 4.128315] remoteproc remoteproc2: attaching to 41000000.r5f [ 4.134325] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 4.141111] remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000 [ 4.150870] virtio_rpmsg_bus virtio0: rpmsg host is online [ 4.157206] remoteproc2#vdev0buffer: registered virtio0 (type 7) [ 4.164304] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 4.173532] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 4.185052] remoteproc remoteproc2: remote processor 41000000.r5f is now attached [ 4.201651] platform 5c00000.r5f: configured R5F for remoteproc mode [ 4.211761] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000 [ 4.221589] remoteproc remoteproc3: 5c00000.r5f is available [ 4.228254] remoteproc remoteproc3: Direct firmware load for j721s2-main-r5f0_0-fw failed with error -2 [ 4.238522] remoteproc remoteproc3: powering up 5c00000.r5f [ 4.245372] platform 5d00000.r5f: configured R5F for remoteproc mode [ 4.251812] remoteproc remoteproc3: Direct firmware load for j721s2-main-r5f0_0-fw failed with error -2 [ 4.261522] remoteproc remoteproc3: request_firmware failed: -2 [ 4.267962] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000 [ 4.276929] remoteproc remoteproc4: 5d00000.r5f is available [ 4.282896] remoteproc remoteproc4: Direct firmware load for j721s2-main-r5f0_1-fw failed with error -2 [ 4.288339] platform 5e00000.r5f: configured R5F for remoteproc mode [ 4.292380] remoteproc remoteproc4: powering up 5d00000.r5f [ 4.300332] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000 [ 4.312311] remoteproc remoteproc4: Direct firmware load for j721s2-main-r5f0_1-fw failed with error -2 [ 4.312988] remoteproc remoteproc5: 5e00000.r5f is available [ 4.327382] remoteproc remoteproc4: request_firmware failed: -2 [ 4.327503] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2 [ 4.342828] remoteproc remoteproc5: powering up 5e00000.r5f [ 4.348497] remoteproc remoteproc5: Direct firmware load for j721s2-main-r5f1_0-fw failed with error -2 [ 4.357898] platform 5f00000.r5f: configured R5F for remoteproc mode [ 4.364282] remoteproc remoteproc5: request_firmware failed: -2 [ 4.370519] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000 [ 4.380176] remoteproc remoteproc6: 5f00000.r5f is available [ 4.386081] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -2 [ 4.398120] remoteproc remoteproc6: powering up 5f00000.r5f [ 4.399799] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22 [ 4.403994] remoteproc remoteproc6: Direct firmware load for j721s2-main-r5f1_1-fw failed with error -2 [ 4.414837] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22 [ 4.420010] remoteproc remoteproc6: request_firmware failed: -2 [ 4.435469] usbcore: registered new interface driver usbfs [ 4.441034] usbcore: registered new interface driver hub [ 4.446389] usbcore: registered new device driver usb [ 4.473610] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 4.479126] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 4.486894] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010 [ 4.496322] xhci-hcd xhci-hcd.0.auto: irq 467, io mem 0x06010000 [ 4.502436] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 4.507927] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 4.515587] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 4.522191] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 4.530457] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.537672] usb usb1: Product: xHCI Host Controller [ 4.542558] usb usb1: Manufacturer: Linux 5.10.168-g2c23e6c538 xhci-hcd [ 4.549168] usb usb1: SerialNumber: xhci-hcd.0.auto [ 4.554353] hub 1-0:1.0: USB hub found [ 4.558135] hub 1-0:1.0: 1 port detected [ 4.562241] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 4.570385] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 4.578654] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.585882] usb usb2: Product: xHCI Host Controller [ 4.590759] usb usb2: Manufacturer: Linux 5.10.168-g2c23e6c538 xhci-hcd [ 4.597379] usb usb2: SerialNumber: xhci-hcd.0.auto [ 4.602533] hub 2-0:1.0: USB hub found [ 4.606312] hub 2-0:1.0: 1 port detected [ 4.644449] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) hwclock: can't open '/dev/misc/rtc': No such file or directory Fri Mar 9 12:34:56 UTC 2018 hwclock: can't open '/dev/misc/rtc': No such file or directory [ 4.817503] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 4.846037] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1 ALSA: Restoring mixer settings... [ 4.909373] Console: switching to colour frame buffer device 240x67 [ 4.932268] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device INIT: Entering runlevel: 5 [ 4.950194] m_can_platform 40528000.can: m_can device registered (irq=19, version=32) [ 4.961004] m_can_platform 40568000.can: m_can device registered (irq=21, version=32) Configuring network interfaces... [ 4.971843] m_can_platform 2761000.can: m_can device registered (irq=36, version=32) [ 4.982241] m_can_platform 2771000.can: m_can device registered (irq=38, version=32) [ 5.033010] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 5.042487] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode udhcpc: started, v1.35.0 udhcpc: broadcasting discover [ 5.245756] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00 [ 5.253934] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1 [ 5.261054] usb 1-1: SerialNumber: 990608499906 [ 5.266502] hub 1-1:1.0: USB hub found [ 5.270296] hub 1-1:1.0: 4 ports detected [ 5.373497] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd [ 5.397693] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00 [ 5.405856] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 5.413635] hub 2-1:1.0: USB hub found [ 5.417404] hub 2-1:1.0: 4 ports detected [ 5.561458] usb 1-1.3: new low-speed USB device number 3 using xhci-hcd [ 5.671911] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08 [ 5.680247] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [ 5.687546] usb 1-1.3: Product: Dell KB216 Wired Keyboard [ 5.708973] input: Dell KB216 Wired Keyboard as /devices/platform/bus@100000/4104000.cdns-usb/6000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2113.0001/input/input0 [ 5.781468] usb 1-1.4: new low-speed USB device number 4 using xhci-hcd [ 5.781895] hid-generic 0003:413C:2113.0001: input: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-xhci-hcd.0.auto-1.3/input0 [ 5.804892] input: Dell KB216 Wired Keyboard System Control as /devices/platform/bus@100000/4104000.cdns-usb/6000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:413C:2113.0002/input/input1 [ 5.881573] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/bus@100000/4104000.cdns-usb/6000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:413C:2113.0002/input/input2 [ 5.889114] usb 1-1.4: New USB device found, idVendor=413c, idProduct=301a, bcdDevice= 1.00 [ 5.899087] hid-generic 0003:413C:2113.0002: input: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-xhci-hcd.0.auto-1.3/input1 [ 5.907413] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.919496] usbcore: registered new interface driver usbhid [ 5.926896] usb 1-1.4: Product: Dell MS116 USB Optical Mouse [ 5.932440] usbhid: USB HID core driver [ 5.937963] usb 1-1.4: Manufacturer: PixArt [ 5.952865] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/bus@100000/4104000.cdns-usb/6000000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.4/1-1.4:1.0/0003:413C:301A.0003/input/input3 [ 5.969833] hid-generic 0003:413C:301A.0003: input: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-xhci-hcd.0.auto-1.4/input0 udhcpc: broadcasting discover udhcpc: broadcasting discover udhcpc: no lease, forking to background done. Starting system message bus: dbus. Starting Dropbear SSH server: [ 14.471557] NET: Registered protocol family 10 [ 14.477671] Segment Routing with IPv6 dropbear. Starting rpcbind daemon...done. Starting advanced power management daemon: No APM support in kernel (failed.) Starting bluetooth: bluetoothd. hwclock: can't open '/dev/misc/rtc': No such file or directory Starting syslogd/klogd: done * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon [ 14.680529] Bluetooth: Core ver 2.22 [ 14.685309] NET: Registered protocol family 31 [ 14.689975] Bluetooth: HCI device and connection manager initialized [ 14.696381] Bluetooth: HCI socket layer initialized [ 14.701291] Bluetooth: L2CAP socket layer initialized ...done. [ 14.706523] Bluetooth: SCO socket layer initialized Starting Telephony daemon Starting Linux NFC daemon [ 14.882765] nfc: nfc_init: NFC Core ver 0.1 [ 14.887320] NET: Registered protocol family 39 [ 14.953136] PVR_K: 391: RGX Firmware image 'rgx.fw.36.53.104.796' loaded [ 14.970001] PVR_K: 391: Shader binary image 'rgx.sh.36.53.104.796' loaded Poky (Yocto Project Reference Distro) 4.0.9 j721s2-evm /dev/ttyS2
I can run glmark2-es2-wayland on an external 1920x1080 screen and everything appears smooth for a couple of seconds.
And then I get a crash log:
[ 165.097256] PVR_K: 210: ------------[ PVR DBG: START (High) ]------------ [ 165.104603] PVR_K: 210: OS kernel info: Linux 5.10.168-g2c23e6c538 #1 SMP PREEMPT Thu Feb 23 19:09:34 UTC 2023 aarch64 [ 165.115550] PVR_K: 210: DDK info: Rogue_DDK_Linux_WS rogueddk 23.1@6404501 (release) j721s2_linux [ 165.124784] PVR_K: 210: Time now: 165124775us [ 165.129378] PVR_K: 210: Services State: OK [ 165.133580] PVR_K: 210: Server Errors: 0 [ 165.137661] PVR_K: 210: Connections Device ID:0(128) P391-V391-T391-weston, P474-V474-T474-glmark2-es2-way [ 165.147437] PVR_K: 210: ------[ Driver Info ]------ [ 165.152417] PVR_K: 210: Comparison of UM/KM components: MATCHING [ 165.158501] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.164837] PVR_K: 210: KM Arch: 64 Bit [ 165.168756] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.175097] PVR_K: 210: UM Connected Clients: 64 Bit [ 165.180134] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.186470] PVR_K: 210: UM info: 23.1 @ 6404501 (release) build options: 0x80000810 [ 165.194280] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.200616] PVR_K: 210: KM info: 23.1 @ 6404501 (release) build options: 0x00000810 [ 165.208425] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.214760] PVR_K: 210: Window system: lws-generic [ 165.219624] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.225961] PVR_K: 210: ------[ Server Thread Summary ]------ [ 165.231776] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.238112] PVR_K: 210: pvr_defer_free : Running [ 165.242975] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.249310] PVR_K: 210: Number of deferred cleanup items: QUEUED: 00000 CONNECTION : 00000 MMU : 00000 OSMEM : 00000 PMR : 00000 [ 165.261366] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.267702] PVR_K: 210: Number of deferred cleanup items dropped after retry limit reached : 0 [ 165.276725] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.283061] PVR_K: 210: pvr_device_wdg : Running [ 165.287924] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 165.294259] PVR_K: 210: ------[ RGX Device ID:0 Start ]------ [ 165.300088] PVR_K: 210: ------[ RGX Info ]------ [ 165.304784] PVR_K: 210: Device Node (Info): 000000003e4e53e6 (00000000a3280625) [ 165.312171] PVR_K: 210: DevmemHistoryRecordStats - None [ 165.317819] PVR_K: 210: RGX BVNC: 36.53.104.796 (rogue) [ 165.323119] PVR_K: 210: RGX Device State: Active [ 165.327819] PVR_K: 210: RGX Power State: ON [ 165.332080] PVR_K: 210: FW info: 23.1 @ 6404501 (release) build options: 0x80000810 [ 165.339894] PVR_K: 210: TRP: HW support - Yes; SW disabled [ 165.345461] PVR_K: 210: WGP: HW support - Yes; SW disabled [ 165.351026] PVR_K: 210: BIF0 - OK [ 165.354423] PVR_K: 210: BIF1 - OK [ 165.357819] PVR_K: 210: FWCORE - OK [ 165.361391] PVR_K: 210: RGX FW State: OK (HWRState 0x000000c1: HWR OK; FW fault; Restart requested;) [ 165.370594] PVR_K: 210: RGX FW Power State: RGXFWIF_POW_ON (APM disabled: 0 ok, 0 denied, 0 non-idle, 0 retry, 0 other, 0 total. Latency: 100 ms) [ 165.383707] PVR_K: 210: RGX DVFS: 0 frequency changes. Current frequency: 799.999 MHz (sampled at 165282033300 ns). FW frequency: 800.000 MHz. [ 165.396555] PVR_K: 210: RGX FW OS 0 - State: active; Freelists: Ok; Priority: 0; Isolation group: 0; MTS on; [ 165.406457] PVR_K: 210: FW Fault 80: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.415578] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e0ce3cc, OSTimer = 165.281747530 [ 165.425141] PVR_K: 210: FW Fault 81: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.434257] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e0ce485, OSTimer = 165.281806730 [ 165.443817] PVR_K: 210: FW Fault 82: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.452931] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e0ce5ad, OSTimer = 165.281901450 [ 165.462493] PVR_K: 210: FW Fault 83: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.471609] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e0ce665, OSTimer = 165.281960330 [ 165.481169] PVR_K: 210: FW Fault 84: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.490284] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e0ce854, OSTimer = 165.282118740 [ 165.499845] PVR_K: 210: FW Fault 85: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.508964] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e0ce93e, OSTimer = 165.282193620 [ 165.518518] PVR_K: 210: FW Fault 86: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.527637] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e0ce9f9, OSTimer = 165.282253460 [ 165.537190] PVR_K: 210: FW Fault 87: "Unknown Client CCB command" (firmware/rgxfw_client_ccb.c:655) [ 165.546310] PVR_K: 210: Data = 0x600b50b0, CRTimer = 0x00001e11ada3, OSTimer = 165.382168340 [ 165.555871] PVR_K: 210: Number of HWR: GP(0/0+0), 2D(0/0+0), TA(1/1+0), 3D(1/1+0), CDM(0/0+0), RAY(0/0+0), TA2(0/0+0), FALSE(0,0,0,0,0,0,0) [ 165.568460] PVR_K: 210: DM 0 (GP) [ 165.571859] PVR_K: 210: DM 1 (HWRflags 0x00000000: working;) [ 165.577599] PVR_K: 210: DM 2 (HWRflags 0x00000000: working;) [ 165.583337] PVR_K: 210: Recovery 1: Core = 0, PID = 474 / glmark2-es2-way, frame = 29, HWRTData = 0x600B5AC0, EventStatus = 0x00000010, Innocent Lockup [ 165.597138] PVR_K: 210: CRTimer = 0x00001E040425, OSTimer = 165.095653750, CyclesElapsed = 33792 [ 165.607226] PVR_K: 210: PreResetTimeInCycles = 49152, HWResetTimeInCycles = 31744, FreelistReconTimeInCycles = 5756160, TotalRecoveryTimeInCycles = 5837056 [ 165.622417] PVR_K: 210: BIF0 - FAULT: [ 165.626512] PVR_K: 210: * MMU status (0x0000000000002021): PC = 2, Page Size = 0 (Page Directory). [ 165.636060] PVR_K: 210: * Request (0x00101fe00b827800): USCS (-), Reading from 0xE00B827800. [ 165.645102] PVR_K: 210: PCE for index 896 = 0x0889ae91 and is valid [ 165.651791] PVR_K: 210: PD index (92) out of bounds (0) [ 165.657439] PVR_K: 210: DM 3 (HWRflags 0x00000000: working;) [ 165.663182] PVR_K: 210: Recovery 1: Core = 0, PID = 474 / glmark2-es2-way, frame = 28, HWRTData = 0x600B5380, EventStatus = 0x00000010, Innocent Lockup [ 165.676983] PVR_K: 210: CRTimer = 0x00001E04046C, OSTimer = 165.095676470, CyclesElapsed = 115712 [ 165.687139] PVR_K: 210: PreResetTimeInCycles = 30976, HWResetTimeInCycles = 31744, FreelistReconTimeInCycles = 5756160, TotalRecoveryTimeInCycles = 5818880 [ 165.702325] PVR_K: 210: BIF0 - FAULT: [ 165.706413] PVR_K: 210: * MMU status (0x0000000000002021): PC = 2, Page Size = 0 (Page Directory). [ 165.715966] PVR_K: 210: * Request (0x00101fe00b827800): USCS (-), Reading from 0xE00B827800. [ 165.725002] PVR_K: 210: PCE for index 896 = 0x0889ae91 and is valid [ 165.731691] PVR_K: 210: PD index (92) out of bounds (0) [ 165.737339] PVR_K: 210: DM 4 (HWRflags 0x00000000: working;) [ 165.743080] PVR_K: 210: DM 5 (HWRflags 0x00000000: working;) [ 165.748816] PVR_K: 210: DM 6 (HWRflags 0x00000000: working;) [ 165.754551] PVR_K: 210: RGX Kernel CCB WO:0x9 RO:0x9 [ 165.759597] PVR_K: 210: RGX Firmware CCB WO:0x6 RO:0x5 [ 165.764809] PVR_K: 210: RGX Kernel CCB commands executed = 42633 [ 165.770887] PVR_K: 210: RGX SLR: Forced UFO updates requested = 0 [ 165.777061] PVR_K: 210: RGX Errors: WGP:0, TRP:0 [ 165.781756] PVR_K: 210: Thread0: FW IRQ count = 73815 [ 165.786882] PVR_K: 210: Last sampled IRQ count in LISR = 73815 [ 165.792797] PVR_K: 210: FW System config flags = 0x00020000 (Ctx switch options: Medium CSW profile;) [ 165.802085] PVR_K: 210: FW OS config flags = 0x0000000F (Ctx switch: TDM; GEOM; 3D; CDM;) [ 165.810340] PVR_K: 210: ------[ RGX registers ]------ [ 165.815468] PVR_K: 210: RGX Register Base Address (Linear): 0x0000000062668a9f [ 165.822953] PVR_K: 210: RGX Register Base Address (Physical): 0x4E20000000 [ 165.829915] PVR_K: 210: CORE_ID__PBVNC : 0x002400350068031C [ 165.836863] PVR_K: 210: DESIGNER_REV_FIELD1 : 0x00000000 [ 165.843123] PVR_K: 210: DESIGNER_REV_FIELD2 : 0x00000000 [ 165.849377] PVR_K: 210: CHANGESET_NUMBER : 0x0000000000000000 [ 165.856323] PVR_K: 210: MULTICORE_SYSTEM : 0x00000001 [ 165.862584] PVR_K: 210: MULTICORE_GPU : 0x00000078 [ 165.868840] PVR_K: 210: CLK_CTRL : 0x002AAA002A22AAAA [ 165.875795] PVR_K: 210: CLK_STATUS : 0x0000000000600000 [ 165.882743] PVR_K: 210: CLK_CTRL2 : 0x0000000000000000 [ 165.889690] PVR_K: 210: CLK_STATUS2 : 0x0000000000000000 [ 165.896642] PVR_K: 210: EVENT_STATUS : 0x00000000 [ 165.902896] PVR_K: 210: TIMER : 0x000000001E2A7097 [ 165.909849] PVR_K: 210: BIF_FAULT_BANK0_MMU_STATUS : 0x00000000 [ 165.916105] PVR_K: 210: BIF_FAULT_BANK0_REQ_STATUS : 0x0000000000000000 [ 165.923052] PVR_K: 210: BIF_FAULT_BANK1_MMU_STATUS : 0x00000000 [ 165.929311] PVR_K: 210: BIF_FAULT_BANK1_REQ_STATUS : 0x0000000000000000 [ 165.936259] PVR_K: 210: BIF_MMU_STATUS : 0x00000000 [ 165.942519] PVR_K: 210: BIF_MMU_ENTRY : 0x00000000 [ 165.948774] PVR_K: 210: BIF_MMU_ENTRY_STATUS : 0x0000000000000000 [ 165.955722] PVR_K: 210: BIF_STATUS_MMU : 0x00000000 [ 165.961981] PVR_K: 210: BIF_READS_EXT_STATUS : 0x00000000 [ 165.968234] PVR_K: 210: BIF_READS_INT_STATUS : 0x00000000 [ 165.974488] PVR_K: 210: BIFPM_STATUS_MMU : 0x00000000 [ 165.980746] PVR_K: 210: BIFPM_READS_EXT_STATUS : 0x00000000 [ 165.987001] PVR_K: 210: BIFPM_READS_INT_STATUS : 0x00000000 [ 165.993261] PVR_K: 210: BIF_CAT_BASE_INDEX : 0x0000000000000202 [ 166.000210] PVR_K: 210: BIF_CAT_BASE0 : 0x000000088428D000 [ 166.007157] PVR_K: 210: BIF_CAT_BASE1 : 0x0000000884BCF000 [ 166.014111] PVR_K: 210: BIF_CAT_BASE2 : 0x0000000889AE2000 [ 166.021059] PVR_K: 210: BIF_CAT_BASE3 : 0x0000000000000000 [ 166.028011] PVR_K: 210: BIF_CAT_BASE4 : 0x0000000000000000 [ 166.034957] PVR_K: 210: BIF_CAT_BASE5 : 0x0000000000000000 [ 166.041910] PVR_K: 210: BIF_CAT_BASE6 : 0x0000000000000000 [ 166.048866] PVR_K: 210: BIF_CAT_BASE7 : 0x0000000000000000 [ 166.055814] PVR_K: 210: BIF_CTRL_INVAL : 0x00000000 [ 166.062077] PVR_K: 210: BIF_CTRL : 0x00000000 [ 166.068332] PVR_K: 210: BIF_PM_CAT_BASE_VCE0 : 0x0000000000000000 [ 166.075285] PVR_K: 210: BIF_PM_CAT_BASE_TE0 : 0x0000000000000000 [ 166.082233] PVR_K: 210: BIF_PM_CAT_BASE_ALIST0 : 0x0000000000000000 [ 166.089180] PVR_K: 210: BIF_PM_CAT_BASE_VCE1 : 0x0000000000000000 [ 166.096132] PVR_K: 210: BIF_PM_CAT_BASE_TE1 : 0x0000000000000000 [ 166.103080] PVR_K: 210: BIF_PM_CAT_BASE_ALIST1 : 0x0000000000000000 [ 166.110031] PVR_K: 210: MULTICORE_GEOMETRY_CTRL_COMMON: 0x00000000 [ 166.116285] PVR_K: 210: MULTICORE_FRAGMENT_CTRL_COMMON: 0x00000101 [ 166.122540] PVR_K: 210: MULTICORE_COMPUTE_CTRL_COMMON : 0x00000101 [ 166.128799] PVR_K: 210: PERF_TA_PHASE : 0x00000001 [ 166.135055] PVR_K: 210: PERF_TA_CYCLE : 0x000091A1 [ 166.141307] PVR_K: 210: PERF_3D_PHASE : 0x00000001 [ 166.147568] PVR_K: 210: PERF_3D_CYCLE : 0x00037C00 [ 166.153822] PVR_K: 210: PERF_TA_OR_3D_CYCLE : 0x00037C00 [ 166.160080] PVR_K: 210: PERF_TA_AND_3D_CYCLE : 0x000091A1 [ 166.166333] PVR_K: 210: PERF_COMPUTE_PHASE : 0x00000000 [ 166.172586] PVR_K: 210: PERF_COMPUTE_CYCLE : 0x00000000 [ 166.178846] PVR_K: 210: PM_PARTIAL_RENDER_ENABLE : 0x00000000 [ 166.185101] PVR_K: 210: ISP_RENDER : 0x00000000 [ 166.191356] PVR_K: 210: TLA_STATUS : 0x0000000000000000 [ 166.198309] PVR_K: 210: MCU_FENCE : 0x0000000000000000 [ 166.205257] PVR_K: 210: VDM_CONTEXT_STORE_STATUS : 0x00000001 [ 166.211516] PVR_K: 210: VDM_CONTEXT_STORE_TASK0 : 0x0000000000000000 [ 166.218464] PVR_K: 210: VDM_CONTEXT_STORE_TASK1 : 0x0000000000000000 [ 166.225417] PVR_K: 210: VDM_CONTEXT_STORE_TASK2 : 0x0000000000000000 [ 166.232366] PVR_K: 210: VDM_CONTEXT_RESUME_TASK0 : 0x0000000000000000 [ 166.239312] PVR_K: 210: VDM_CONTEXT_RESUME_TASK1 : 0x0000000000000000 [ 166.246267] PVR_K: 210: VDM_CONTEXT_RESUME_TASK2 : 0x0000000000000000 [ 166.253214] PVR_K: 210: ISP_CTL : 0x00000000 [ 166.259473] PVR_K: 210: ISP_STATUS : 0x00000000 [ 166.265727] PVR_K: 210: MTS_INTCTX : 0x00000000 [ 166.271981] PVR_K: 210: MTS_BGCTX : 0x00000000 [ 166.278240] PVR_K: 210: MTS_BGCTX_COUNTED_SCHEDULE : 0x00000000 [ 166.284493] PVR_K: 210: MTS_SCHEDULE : 0x00000000 [ 166.290747] PVR_K: 210: MTS_GPU_INT_STATUS : 0x00000000 [ 166.297006] PVR_K: 210: CDM_CONTEXT_STORE_STATUS : 0x00000000 [ 166.303259] PVR_K: 210: CDM_CONTEXT_PDS0 : 0x0000000000000000 [ 166.310215] PVR_K: 210: CDM_CONTEXT_PDS1 : 0x0000000000000000 [ 166.317163] PVR_K: 210: CDM_TERMINATE_PDS : 0x0000000000000000 [ 166.324111] PVR_K: 210: CDM_TERMINATE_PDS1 : 0x0000000000000000 [ 166.331064] PVR_K: 210: CDM_CONTEXT_LOAD_PDS0 : 0x0000000000000000 [ 166.338012] PVR_K: 210: CDM_CONTEXT_LOAD_PDS1 : 0x0000000000000000 [ 166.344964] PVR_K: 210: SIDEKICK_IDLE : 0x0000007F [ 166.351218] PVR_K: 210: SLC_IDLE : 0x000000FF [ 166.357471] PVR_K: 210: SLC_STATUS0 : 0x00000000 [ 166.363729] PVR_K: 210: SLC_STATUS1 : 0x0000000000000000 [ 166.370678] PVR_K: 210: SLC_STATUS2 : 0x0000000000000000 [ 166.377631] PVR_K: 210: SLC_CTRL_BYPASS : 0x00003D1F00000000 [ 166.384578] PVR_K: 210: SLC_CTRL_MISC : 0x0000000000200003 [ 166.391530] PVR_K: 210: SAFETY_EVENT_STATUS__ROGUEXE : 0x00000000 [ 166.397783] PVR_K: 210: MTS_SAFETY_EVENT_ENABLE__ROGUEXE: 0x000000FF [ 166.404208] PVR_K: 210: FWCORE_WDT_CTRL : 0x00001F01 [ 166.410522] PVR_K: 210: SCRATCH0 : 0x00000000 [ 166.416807] PVR_K: 210: SCRATCH1 : 0x00000000 [ 166.423062] PVR_K: 210: SCRATCH2 : 0x00000000 [ 166.429348] PVR_K: 210: SCRATCH3 : 0x00000000 [ 166.435650] PVR_K: 210: SCRATCH4 : 0x00000000 [ 166.441946] PVR_K: 210: SCRATCH5 : 0x00000000 [ 166.448227] PVR_K: 210: SCRATCH6 : 0x00000000 [ 166.454484] PVR_K: 210: SCRATCH7 : 0x00000000 [ 166.460762] PVR_K: 210: SCRATCH8 : 0x00000000 [ 166.467041] PVR_K: 210: SCRATCH9 : 0x00000000 [ 166.473321] PVR_K: 210: SCRATCH10 : 0x00000000 [ 166.479604] PVR_K: 210: SCRATCH11 : 0x00000000 [ 166.485862] PVR_K: 210: SCRATCH12 : 0x00000000 [ 166.492146] PVR_K: 210: SCRATCH13 : 0x00000000 [ 166.498423] PVR_K: 210: SCRATCH14 : 0x00000000 [ 166.504701] PVR_K: 210: SCRATCH15 : 0x00000000 [ 166.510966] PVR_K: 210: FWCORE_MEM_CAT_BASE0 : 0x000000088428D000 [ 166.517935] PVR_K: 210: FWCORE_MEM_CAT_BASE1 : 0x0000000000000000 [ 166.524910] PVR_K: 210: FWCORE_MEM_CAT_BASE2 : 0x0000000889AE2000 [ 166.531878] PVR_K: 210: FWCORE_MEM_CAT_BASE3 : 0x0000000000000000 [ 166.538849] PVR_K: 210: FWCORE_MEM_CAT_BASE4 : 0x0000000000000000 [ 166.545825] PVR_K: 210: FWCORE_MEM_CAT_BASE5 : 0x0000000000000000 [ 166.552799] PVR_K: 210: FWCORE_MEM_CAT_BASE6 : 0x0000000000000000 [ 166.559780] PVR_K: 210: FWCORE_MEM_CAT_BASE7 : 0x0000000000000000 [ 166.566730] PVR_K: 210: FWCORE_ADDR_REMAP_CONFIG4 : 0x120000E1C0002000 [ 166.573698] PVR_K: 210: FWCORE_ADDR_REMAP_CONFIG5 : 0x220000E1C001E000 [ 166.580672] PVR_K: 210: FWCORE_ADDR_REMAP_CONFIG6 : 0x220000E1C0000000 [ 166.587644] PVR_K: 210: FWCORE_ADDR_REMAP_CONFIG12 : 0x120000E1C0000000 [ 166.594621] PVR_K: 210: FWCORE_ADDR_REMAP_CONFIG13 : 0x220000E1C0000000 [ 166.601589] PVR_K: 210: FWCORE_ADDR_REMAP_CONFIG14 : 0x0000000000000000 [ 166.608563] PVR_K: 210: FWCORE_MEM_FAULT_MMU_STATUS : 0x00000000 [ 166.614819] PVR_K: 210: FWCORE_MEM_FAULT_REQ_STATUS : 0x0000000000000000 [ 166.621798] PVR_K: 210: FWCORE_MEM_MMU_STATUS : 0x00000000 [ 166.628080] PVR_K: 210: FWCORE_MEM_READS_EXT_STATUS : 0x00000000 [ 166.634355] PVR_K: 210: FWCORE_MEM_READS_INT_STATUS : 0x00000000 [ 166.640631] PVR_K: 210: ---- [ RISC-V internal state ] ---- [ 166.646294] PVR_K: 210: pc : 0x40004004 [ 166.652568] PVR_K: 210: ra : 0x4001B28A [ 166.658855] PVR_K: 210: sp : 0x50001010 [ 166.665136] PVR_K: 210: mepc : 0x40004004 [ 166.671394] PVR_K: 210: mcause : 0x8000000B [ 166.677675] PVR_K: 210: mdseac : 0x00000000 [ 166.683960] PVR_K: 210: mstatus : 0x00001888 [ 166.690239] PVR_K: 210: mie : 0x40000888 [ 166.696525] PVR_K: 210: mip : 0x00000000 [ 166.702782] PVR_K: 210: mscratch : 0x00000000 [ 166.709065] PVR_K: 210: mbvnc0 : 0x00010001 [ 166.715345] PVR_K: 210: mbvnc1 : 0x0032000B [ 166.721621] PVR_K: 210: micect : 0x10000000 [ 166.727912] PVR_K: 210: mdcect : 0x10000000 [ 166.734170] PVR_K: 210: mdcrfct : 0x10000000 [ 166.740448] PVR_K: 210: ------[ RGX FW Trace Info ]------ [ 166.745952] PVR_K: 210: Debug log type: none [ 166.750302] PVR_K: 210: RGX FW thread 0: Trace buffer not yet allocated [ 166.757010] PVR_K: 210: ------[ Full CCB Status ]------ [ 166.762349] PVR_K: 210: FWCtx 0x60032A00 (TQ_3D-P391-T391-weston) [ 166.768538] PVR_K: 210: `--<Empty> [ 166.772194] PVR_K: 210: FWCtx 0x600B7100 (TQ_3D-P474-T474-glmark2-es2-w) [ 166.778990] PVR_K: 210: `--<Empty> [ 166.782646] PVR_K: 210: FWCtx 0x60032040 (TA-P391-T391-weston) [ 166.788574] PVR_K: 210: |--Waiting FENCE @ 13248 Int=42425 Ext=1520 [ 166.795114] PVR_K: 210: | |--Addr:0xd00300b9 Val=0x00000519 [ 166.801127] PVR_K: 210: | `--Addr:0xd0030159 Val=0x00000519 [ 166.807125] PVR_K: 210: |--Waiting TA @ 13280 Int=42425 Ext=1520 [ 166.813405] PVR_K: 210: `--Waiting UPDATE @ 13360 Int=42425 Ext=1520 [ 166.820023] PVR_K: 210: |--Addr:0xd0064004 Val=0x000002df [ 166.826043] PVR_K: 210: `--Addr:0xd00301a9 Val=0x00000519 [ 166.832041] PVR_K: 210: FWCtx 0x600320F0 (3D-P391-T391-weston) [ 166.837953] PVR_K: 210: |--Waiting FENCE_PR @ 800 Int=42425 Ext=1520 [ 166.844562] PVR_K: 210: | `--Addr:0xd0064004 Val=0x000002df [ 166.850572] PVR_K: 210: |--Waiting 3D @ 824 Int=42425 Ext=1520 [ 166.856654] PVR_K: 210: `--Waiting UPDATE @ 1160 Int=42425 Ext=1520 [ 166.863175] PVR_K: 210: |--Addr:0xd0064004 Val=0x000002e0 [ 166.869171] PVR_K: 210: |--Addr:0xd00302e1 Val=0x00000519 [ 166.875172] PVR_K: 210: `--Addr:0xd0030199 Val=0x00000519 [ 166.881168] PVR_K: 210: FWCtx 0x600B5000 (TA-P474-T474-glmark2-es2-way) [ 166.887857] PVR_K: 210: |--Waiting FENCE @ 11152 Int=42424 Ext=40903 [ 166.894461] PVR_K: 210: | `--Addr:0xd00303a1 Val=0x00000519 [ 166.900455] PVR_K: 210: |--Waiting TA @ 11176 Int=42424 Ext=40903 [ 166.906796] PVR_K: 210: `--Waiting UPDATE @ 11256 Int=42424 Ext=40903 [ 166.913489] PVR_K: 210: |--Addr:0xd00b6030 Val=0x00000029 [ 166.919481] PVR_K: 210: `--Addr:0xd00303e9 Val=0x00000519 [ 166.925483] PVR_K: 210: FWCtx 0x600B50B0 (3D-P474-T474-glmark2-es2-way) [ 166.932172] PVR_K: 210: |--Waiting UPDATE @ 32360 Int=42422 Ext=40901 [ 166.938858] PVR_K: 210: | |--Addr:0xd00b6004 Val=0x0000002a [ 166.944857] PVR_K: 210: | |--Addr:0xd00303a1 Val=0x00000519 [ 166.950850] PVR_K: 210: | `--Addr:0xd0030201 Val=0x00000519 [ 166.956845] PVR_K: 210: |--Waiting FENCE_PR @ 32400 Int=42423 Ext=40902 [ 166.963710] PVR_K: 210: | `--Addr:0xd00b6008 Val=0x00000029 [ 166.969704] PVR_K: 210: |--Waiting 3D @ 32424 Int=42423 Ext=40902 [ 166.976051] PVR_K: 210: |--Waiting UPDATE @ 32760 Int=42423 Ext=40902 [ 166.982738] PVR_K: 210: | |--Addr:0xd00b6008 Val=0x0000002a [ 166.988733] PVR_K: 210: | |--Addr:0xd0030309 Val=0x00000519 [ 166.994733] PVR_K: 210: | `--Addr:0xd0030249 Val=0x00000519 [ 167.000728] PVR_K: 210: |--Waiting FENCE_PR @ 32800 Int=42424 Ext=40903 [ 167.007589] PVR_K: 210: | `--Addr:0xd00b6030 Val=0x00000029 [ 167.013588] PVR_K: 210: |--Waiting 3D @ 32824 Int=42424 Ext=40903 [ 167.019930] PVR_K: 210: `--Waiting UPDATE @ 33160 Int=42424 Ext=40903 [ 167.026622] PVR_K: 210: |--Addr:0xd00b6030 Val=0x0000002a [ 167.032615] PVR_K: 210: |--Addr:0xd0030159 Val=0x00000519 [ 167.038610] PVR_K: 210: `--Addr:0xd0030269 Val=0x00000519 [ 167.044611] PVR_K: 210: ------[ RGX Device ID:0 End ]------ [ 167.050266] PVR_K: 210: ------[ Device ID: 128 - Phys Heaps ]------ [ 167.056603] PVR_K:(Warn): 357: Device experienced error 14 [106] [ 167.062939] PVR_K: 210: 0x000000004cca0ef1 -> PdMs: SYSMEM, Type: UMA, Usage Flags: 0x00000004 (, GPU_LOCAL), Refs: 11, Free Size: 16336625664B, Total Size: 16578400256B [ 167.078165] PVR_K: 210: ------[ System Summary Device ID:0 ]------ [ 167.084439] PVR_K: 210: Device System Power State: ON [ 167.089596] PVR_K: 210: MaxHWTOut: 500000us, WtTryCt: 10000, WDGTOut(on,off): (10000ms,3600000ms) [ 167.098568] PVR_K: 210: ------[ AppHint Settings ]------ [ 167.103958] PVR_K: 210: Build Vars [ 167.107615] PVR_K: 210: EnableTrustedDeviceAceConfig: N [ 167.113274] PVR_K: 210: CleanupThreadPriority: 0x00000005 [ 167.119096] PVR_K: 210: WatchdogThreadPriority: 0x00000000 [ 167.125011] PVR_K: 210: HWPerfClientBufferSize: 0x000c0000 [ 167.130919] PVR_K: 210: DevmemHistoryBufSizeLog2: 0x0000000b [ 167.137000] PVR_K: 210: DevmemHistoryMaxEntries: 0x00002710 [ 167.142999] PVR_K: 210: Module Params [ 167.146964] PVR_K: 210: none [ 167.150271] PVR_K: 210: Debug Info Params [ 167.154555] PVR_K: 210: none [ 167.157864] PVR_K: 210: Debug Info Params Device ID: 0 [ 167.163278] PVR_K: 210: none [ 167.166590] PVR_K: 210: ------[ HTB Log state: Off ]------ [ 167.172154] PVR_K: 210: ------[ Active Sync Checkpoints ]------ [ 167.178170] PVR_K: 210: (SyncCP Counts: InUse:12 Max:41) [ 167.183575] sw: RM_SWTimeline-weston-391 @0 cur=0 [ 167.188271] sw: RM_SWTimeline-glmark2-es2-wayla @0 cur=0 [ 167.193599] ------[ Native Fence Sync: timelines ]------ [ 167.198900] foreign_sync: @0 ctx=1 refs=1 [ 167.202914] rogue-ta3d: @1470 ctx=5 refs=3 [ 167.206997] @1468: (++) refs=1 fwaddr=0xd0030121 enqueue=2 status=Signalled 1468-update fence [ 167.215586] @1469: (++) refs=1 fwaddr=0xd00302e1 enqueue=2 status=Signalled 1469-update fence [ 167.224199] V3-weston-391: @1470 ctx=7 refs=3 [ 167.228541] @1468: (++) refs=1 fwaddr=0xd0030301 enqueue=1 status=Signalled 1468-es3_DoKickTA_1519 [ 167.237563] @1469: (++) refs=1 fwaddr=0xd00301a9 enqueue=1 status=Signalled 1469-es3_DoKickTA_1520 [ 167.246613] P3-weston-391: @1470 ctx=8 refs=3 [ 167.250955] @1468: (++) refs=1 fwaddr=0xd00300d1 enqueue=1 status=Signalled 1468-es3_DoKick3D_1519 [ 167.259977] @1469: (++) refs=1 fwaddr=0xd0030199 enqueue=1 status=Signalled 1469-es3_DoKick3D_1520 [ 167.269025] rogue-tq3d: @0 ctx=11 refs=1 [ 167.272954] QE-weston-391: @51 ctx=12 refs=1 [ 167.277220] rogue-ta3d: @100 ctx=67057 refs=3 [ 167.281561] @98: (++) refs=1 fwaddr=0xd0030359 enqueue=1 status=Signalled 98-update fence [ 167.289802] @99: (++) refs=1 fwaddr=0xd0030059 enqueue=1 status=Signalled 99-update fence [ 167.298070] rogue-tq3d: @0 ctx=67066 refs=1 [ 167.302247] QE--wayland-glmark2-es2-way-474: @1 ctx=67067 refs=1 [ 167.308278] V3--wayland-glmark2-es2-way-474: @100 ctx=67068 refs=3 [ 167.314440] @98: (++) refs=1 fwaddr=0xd00301c9 enqueue=1 status=Signalled 98-es3_DoKickTA_40919 [ 167.323202] @99: (++) refs=2 fwaddr=0xd0030361 enqueue=1 status=Signalled 99-es3_DoKickTA_40920 [ 167.331990] P3--wayland-glmark2-es2-way-474: @100 ctx=67069 refs=3 [ 167.338153] @98: (++) refs=1 fwaddr=0xd0030279 enqueue=1 status=Signalled 98-es3_DoKick3D_40919 [ 167.346915] @99: (++) refs=2 fwaddr=0xd0030171 enqueue=1 status=Signalled 99-es3_DoKick3D_40920 [ 167.355710] PVR_K: 210: ------------[ PVR DBG: END ]------------ [ 167.361914] ------------[ cut here ]------------ [ 167.366575] WARNING: CPU: 0 PID: 210 at /home/rich/Yocto/poky-kirkstone/build/tmp/work/j721s2_evm-poky-linux/ti-img-rogue-driver/23.1.6404501-r0b/git/binary_j721s2_linux_lws-generic_release/target_aarch64/kbuild/services/server/common/pvr_notifier.c:651 PVRSRVDebugRequest+0x574/0x6a0 [pvrsrvkm] [ 167.392583] Modules linked in: nfc bluetooth ecdh_generic ecc rfkill ipv6 usbhid xhci_plat_hcd xhci_hcd cdns3 udc_core roles rpmsg_char usbcore usb_common cdns_csi2rx v4l2_fwnode crct10dif_ce phy_can_transceiver ti_k3_r5_remoteproc ti_k3_dsp_remoteproc wave5 virtio_rpmsg_bus ti_sn65dsi86 pvrsrvkm(O) sa2ul cdns_mhdp8546 sha512_generic cdns_dsi authenc j721e_csi2rx v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common cdns_dphy cdns3_ti m_can_platform m_can can_dev optee_rng rng_core [ 167.437728] CPU: 0 PID: 210 Comm: pvr_device_wdg Tainted: G O 5.10.168-g2c23e6c538 #1 [ 167.446836] Hardware name: Texas Instruments AM68 SK (DT) [ 167.452219] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--) [ 167.458244] pc : PVRSRVDebugRequest+0x574/0x6a0 [pvrsrvkm] [ 167.463741] lr : PVRSRVDebugRequest+0x574/0x6a0 [pvrsrvkm] [ 167.469208] sp : ffff8000120f3c80 [ 167.472509] x29: ffff8000120f3c80 x28: 0000000000000000 [ 167.477805] x27: ffff0008038cb9a0 x26: ffff0008024efe08 [ 167.483100] x25: ffff000802621c08 x24: ffff000802621d20 [ 167.488397] x23: ffff0008024eff20 x22: ffff000802621d20 [ 167.493693] x21: 0000000000000002 x20: 0000000000000000 [ 167.498990] x19: 0000000000000000 x18: ffffffffffffffff [ 167.504285] x17: ffff800013183064 x16: ffff800013183030 [ 167.509580] x15: ffff8000920f38c7 x14: 0000000000000006 [ 167.514876] x13: ffff800011140788 x12: 0000000000000945 [ 167.520173] x11: 0000000000000317 x10: ffff800011140788 [ 167.525468] x9 : ffff800011140788 x8 : 00000000ffffefff [ 167.530763] x7 : ffff800011198788 x6 : ffff800011198788 [ 167.536057] x5 : 0000000000000000 x4 : ffff000b7dfc5ab8 [ 167.541352] x3 : 0000000000000000 x2 : 0000000000000000 [ 167.546649] x1 : 0000000000000000 x0 : ffff000802780000 [ 167.551944] Call trace: [ 167.554409] PVRSRVDebugRequest+0x574/0x6a0 [pvrsrvkm] [ 167.559559] DevicesWatchdogThread_ForEachVaCb+0x124/0x174 [pvrsrvkm] [ 167.566009] List_PVRSRV_DEVICE_NODE_ForEach_va+0x70/0xac [pvrsrvkm] [ 167.572372] DevicesWatchdogThread+0x9c/0x204 [pvrsrvkm] [ 167.577694] OSThreadRun+0x24/0x60 [pvrsrvkm] [ 167.582043] kthread+0x154/0x160 [ 167.585259] ret_from_fork+0x10/0x38 [ 167.588819] ---[ end trace 9672ec048e6973e5 ]--- [ 169.925470] PVR_K:(Error): 474: CheckForStalledCCB (force): CCCB has not progressed (ROFF=13968 DOFF=13968 WOFF=14112) for "TA-P391-T391-weston" [2395] [ 169.939198] PVR_K:(Error): 474: CheckForStalledCCB (force): CCCB has not progressed (ROFF=2800 DOFF=2800 WOFF=3200) for "3D-P391-T391-weston" [2395] [ 169.952660] PVR_K:(Error): 474: CheckForStalledCCB (force): CCCB has not progressed (ROFF=32096 DOFF=32096 WOFF=32232) for "TA-P474-T474-glmark2-es2-way" [2395] [ 169.967154] PVR_K:(Error): 474: CheckForStalledCCB (force): CCCB has not progressed (ROFF=29200 DOFF=29200 WOFF=29600) for "3D-P474-T474-glmark2-es2-way" [2395] [ 169.981650] PVR_K: 474: Possible stalled client RGX contexts detected: TA 3D [ 169.988862] PVR_K: 474: Trying to identify stalled context...(force) [1] [ 169.995641] PVR_K: 474: Fence found on context 0x600b5000 'TA-P474-T474-glmark2-es2-way' @ 32096 has 1 UFOs [ 170.005453] PVR_K: 474: 1/1 FWAddr 0xd00302a9 requires 0x519 (currently 0xac1) [ 170.012923] PVR_K: 474: 0 sync checkpoints owned by pvr_sync_file in stalled context [ 170.020737] PVR_K: 474: Forced update command issued for FWCtx 0x600B5000 [ 170.235184] PVR_K: 474: No further stalled client contexts exist
Could anyone please advise me on how to fix this GPU crash? For what it's worth, I have created a similar image for the AM572x and can run glmark2-es2-wayland with no issues.
Richard
Hello Richard,
It looks like you are using the latest driver available, 23.1 for the GPU. Let me check with our development team on the issue you are facing.
Erick
It seems this is currently a known issue, and the team is working to fix it. Please keep a look-out for updates, the team will push a fix when it is available.
Erick
team will
Hi Erick, just want to add I am getting the issue on the SK-AM69 also,
Richard
Richard,
Thanks for the data point. The team here is able to replicate it as well and is looking for a fix. I'll update this thread as soon as they find something.
Erick
Hello all,
It looks like the fix has been pushed, can you please let me know if this issue is still replicating on the latest releases?
Erick
Hi Erick,
I am trying to load the kirkstone-wip branch (linux kernel 6.1) and having issues. What is the intended way to boot into the starter kit?
The default tiboot3.bin gp bootloader doesn't work, the HS version will boot. And then booting up with the boot/dtb/ti/k3-am68-sk-base-board dtb will boot but without hdmi or usb support. I would like to attach the kernel boot log but I am told "You don't have permission to access "">e2e.ti.com/.../configure on this server."
If I rollback to an older commit of kirkstone (linux kernel 5.10) I can boot just fine. And then if I manually update the ti-img-rogue-driver SRCREV to the newest version `93c66ec66136654849809132b86d3b880ee96ed6` then I get a kernel panic.
Richard
Richard,
Can you please copy and paste the whole boot log using the "Insert -> Code" tool for the E2E post, that will be fine as well. Or just dump the whole log as a post and I can edit it.
Let me check with our dev team on the state of booting the SK board on the latest kirkstone-wip.
Erick
Richard,
At the moment, there are various updates going into kirkstone-wip that are causing conflicts for you, although the GPU driver is updated, there are other updates (such as the bootloader changes) that will cause us issues at the moment. Please wait until the release is stable. You can fall back to the latest stable release for now.
Erick
Hi Erick,
I am able to insert a code log again, so here is the kernel log from my 6.1 kirkstone-wip branch boot:
Starting kernel ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 6.1.26-g5618571dbf (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Tue May 16 04:31:55 UTC 2023 [ 0.000000] Machine model: Texas Instruments AM68 SK [ 0.000000] efi: UEFI not found. [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x0000000bffffefff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffefff] [ 0.000000] node 0: [mem 0x0000000880000000-0x0000000bffffefff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff] [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] cma: Reserved 32 MiB at 0x00000000fde00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 19 pages/cpu s38248 r8192 d31384 u77824 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Spectre-v3a [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128766 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk1p2 rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 2. [ 0.000000] software IO TLB: mapped [mem 0x00000000f9e00000-0x00000000fde00000] (64MB) [ 0.000000] Memory: 16313688K/16777208K available (12032K kernel code, 1242K rwdata, 3860K rodata, 2112K init, 483K bss, 430752K reserved, 32768K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000154] Console: colour dummy device 80x25 [ 0.000182] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.000188] pid_max: default: 32768 minimum: 301 [ 0.000213] LSM: Security Framework initializing [ 0.000294] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.000330] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.001161] cblist_init_generic: Setting adjustable number of callback queues. [ 0.001167] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.001218] cblist_init_generic: Setting shift to 1 and lim to 1. [ 0.001303] rcu: Hierarchical SRCU implementation. [ 0.001306] rcu: Max phase no-delay instances is 1000. [ 0.001457] Platform MSI: msi-controller@1820000 domain created [ 0.001524] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.001750] EFI services will not be available. [ 0.001857] smp: Bringing up secondary CPUs ... [ 0.010294] Detected PIPT I-cache on CPU1 [ 0.010355] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.010369] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000 [ 0.010403] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.010457] smp: Brought up 1 node, 2 CPUs [ 0.010462] SMP: Total of 2 processors activated. [ 0.010465] CPU features: detected: 32-bit EL0 Support [ 0.010467] CPU features: detected: CRC32 instructions [ 0.010507] CPU: All CPU(s) started at EL2 [ 0.010509] alternatives: applying system-wide alternatives [ 0.011419] devtmpfs: initialized [ 0.016484] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.016498] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.016992] pinctrl core: initialized pinctrl subsystem [ 0.017272] DMI not present or invalid. [ 0.017584] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.018298] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.018671] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.019039] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.019077] audit: initializing netlink subsys (disabled) [ 0.019167] audit: type=2000 audit(0.016:1): state=initialized audit_enabled=0 res=1 [ 0.019354] thermal_sys: Registered thermal governor 'step_wise' [ 0.019357] thermal_sys: Registered thermal governor 'power_allocator' [ 0.019379] cpuidle: using governor menu [ 0.019443] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.019473] ASID allocator initialised with 65536 entries [ 0.024251] KASLR disabled due to lack of seed [ 0.027263] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.027267] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.027271] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.027272] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.027275] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.027277] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.027280] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.027281] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.028135] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected [ 0.028767] iommu: Default domain type: Translated [ 0.028772] iommu: DMA domain TLB invalidation policy: strict mode [ 0.028898] SCSI subsystem initialized [ 0.029070] usbcore: registered new interface driver usbfs [ 0.029085] usbcore: registered new interface driver hub [ 0.029096] usbcore: registered new device driver usb [ 0.029274] pps_core: LinuxPPS API ver. 1 registered [ 0.029277] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.029286] PTP clock support registered [ 0.029339] EDAC MC: Ver: 3.0.0 [ 0.029742] FPGA manager framework [ 0.029777] Advanced Linux Sound Architecture Driver Initialized. [ 0.030192] clocksource: Switched to clocksource arch_sys_counter [ 0.030307] VFS: Disk quotas dquot_6.6.0 [ 0.030326] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.033132] NET: Registered PF_INET protocol family [ 0.033491] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.038750] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 0.038817] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.038829] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.039240] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.040247] TCP: Hash tables configured (established 131072 bind 65536) [ 0.040352] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.040515] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.040771] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.041094] RPC: Registered named UNIX socket transport module. [ 0.041100] RPC: Registered udp transport module. [ 0.041102] RPC: Registered tcp transport module. [ 0.041103] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.041110] PCI: CLS 0 bytes, default 64 [ 0.041475] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.042134] Initialise system trusted keyrings [ 0.042282] workingset: timestamp_bits=46 max_order=22 bucket_order=0 [ 0.044768] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.045106] NFS: Registering the id_resolver key type [ 0.045124] Key type id_resolver registered [ 0.045126] Key type id_legacy registered [ 0.045158] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.045162] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.045261] 9p: Installing v9fs 9p2000 file system support [ 0.064456] Key type asymmetric registered [ 0.064461] Asymmetric key parser 'x509' registered [ 0.064495] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.064499] io scheduler mq-deadline registered [ 0.064502] io scheduler kyber registered [ 0.065807] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.065954] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.068900] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.072298] loop: module loaded [ 0.072822] megasas: 07.719.03.00-rc1 [ 0.074417] tun: Universal TUN/TAP device driver, 1.6 [ 0.074676] thunder_xcv, ver 1.0 [ 0.074692] thunder_bgx, ver 1.0 [ 0.074704] nicpf, ver 1.0 [ 0.074858] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version [ 0.074861] hns3: Copyright (c) 2017 Huawei Corporation. [ 0.074889] hclge is initializing [ 0.074900] e1000: Intel(R) PRO/1000 Network Driver [ 0.074902] e1000: Copyright (c) 1999-2006 Intel Corporation. [ 0.074917] e1000e: Intel(R) PRO/1000 Network Driver [ 0.074919] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 0.074932] igb: Intel(R) Gigabit Ethernet Network Driver [ 0.074935] igb: Copyright (c) 2007-2014 Intel Corporation. [ 0.074948] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.074951] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.075000] sky2: driver version 1.30 [ 0.075246] VFIO - User Level meta-driver version: 0.3 [ 0.075558] usbcore: registered new interface driver usb-storage [ 0.075867] i2c_dev: i2c /dev entries driver [ 0.076452] sdhci: Secure Digital Host Controller Interface driver [ 0.076455] sdhci: Copyright(c) Pierre Ossman [ 0.076629] Synopsys Designware Multimedia Card Interface Driver [ 0.076784] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.077114] ledtrig-cpu: registered to indicate activity on CPUs [ 0.077195] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.077302] usbcore: registered new interface driver usbhid [ 0.077305] usbhid: USB HID core driver [ 0.077849] optee: probing for conduit method. [ 0.077867] optee: revision 3.20 (8e74d476) [ 0.094296] optee: dynamic shared memory is enabled [ 0.094523] optee: initialized driver [ 0.095423] NET: Registered PF_PACKET protocol family [ 0.095491] 9pnet: Installing 9P2000 support [ 0.095523] Key type dns_resolver registered [ 0.095717] registered taskstats version 1 [ 0.095731] Loading compiled-in X.509 certificates [ 0.099555] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3--1-g2249f (Chill Capybara') [ 0.108516] pca953x 0-0021: supply vcc not found, using dummy regulator [ 0.108580] pca953x 0-0021: using no AI [ 0.122781] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz [ 0.122927] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created [ 0.123019] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created [ 0.123102] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created [ 0.123258] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created [ 0.124000] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272 [ 0.124007] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 0.124010] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 0.125385] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259 [ 0.125391] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 0.125394] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 0.125865] printk: console [ttyS2] disabled [ 0.125897] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 165, base_baud = 3000000) is a 8250 [ 1.414583] printk: console [ttyS2] enabled [ 1.419392] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.462199] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.470810] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.479087] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.491922] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.499131] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.508497] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 1.518476] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16) [ 1.528698] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.574195] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.582782] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.591062] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 1.603900] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.611109] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.618105] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.626296] mmc1: CQHCI version 5.10 [ 1.629265] ALSA device list: [ 1.632863] No soundcards found. [ 1.670841] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 1.678458] Waiting for root device /dev/mmcblk1p2... [ 1.731356] mmc1: new ultra high speed SDR104 SDHC card at address 5048 [ 1.738339] mmcblk1: mmc1:5048 SD32G 29.7 GiB [ 1.744652] mmcblk1: p1 p2 [ 1.766362] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none. [ 1.774909] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 1.782336] devtmpfs: mounted [ 1.786066] Freeing unused kernel memory: 2112K [ 1.790705] Run /sbin/init as init process INIT: version 3.01 booting Framebuffer /dev/fb0 not detected Boot splashscreen disabled Starting udev [ 2.028758] udevd[137]: starting version 3.2.10 [ 3.018190] random: crng init done [ 3.038970] udevd[138]: starting eudev-3.2.10 [ 3.167692] ------------[ cut here ]------------ [ 3.172332] wiz bus@100000:wiz@5060000: Unable to create SERDES platform device [ 3.193792] WARNING: CPU: 0 PID: 142 at drivers/phy/ti/phy-j721e-wiz.c:1572 wiz_probe+0xb3c/0x1090 [phy_j721e_wiz] [ 3.204150] Modules linked in: drm phy_j721e_wiz(+) drm_panel_orientation_quirks phy_can_transceiver optee_rng rng_core [ 3.214924] CPU: 0 PID: 142 Comm: udevd Not tainted 6.1.26-g5618571dbf #1 [ 3.221696] Hardware name: Texas Instruments AM68 SK (DT) [ 3.227077] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 3.234022] pc : wiz_probe+0xb3c/0x1090 [phy_j721e_wiz] [ 3.239240] lr : wiz_probe+0xb3c/0x1090 [phy_j721e_wiz] [ 3.244456] sp : ffff80000a8a3840 [ 3.247757] x29: ffff80000a8a3840 x28: ffff000b7dfe2448 x27: ffff000801974ae4 [ 3.254877] x26: 0000000000000004 x25: 0000000000000000 x24: ffff000801974908 [ 3.261996] x23: ffff000800c51810 x22: ffff0008019748e8 x21: 0000000000000004 [ 3.269115] x20: ffff000800c51810 x19: ffff000801974880 x18: fffffc00200e1ac0 [ 3.276233] x17: 0000000000000000 x16: 0000000000000010 x15: 0000496be36b4175 [ 3.283354] x14: 00000000000000da x13: 00000000000000da x12: 0000000000000000 [ 3.290473] x11: 000000000000000d x10: 0000000000000990 x9 : ffff80000a8a36f0 [ 3.297594] x8 : ffff0008016fddf0 x7 : ffff000800250c00 x6 : 0000000000000000 [ 3.304712] x5 : 00000000410fd080 x4 : 0000000000c0000e x3 : 0000000000100000 [ 3.311832] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008016fd400 [ 3.318952] Call trace: [ 3.321386] wiz_probe+0xb3c/0x1090 [phy_j721e_wiz] [ 3.326256] platform_probe+0x68/0xe0 [ 3.329915] really_probe+0xbc/0x2dc [ 3.333478] __driver_probe_device+0x78/0xe0 [ 3.337735] driver_probe_device+0xd8/0x160 [ 3.341904] __driver_attach+0x94/0x19c [ 3.345727] bus_for_each_dev+0x70/0xd0 [ 3.349549] driver_attach+0x24/0x30 [ 3.353111] bus_add_driver+0x154/0x20c [ 3.356934] driver_register+0x78/0x130 [ 3.360756] __platform_driver_register+0x28/0x34 [ 3.365447] wiz_driver_init+0x20/0x1000 [phy_j721e_wiz] [ 3.370747] do_one_initcall+0x50/0x1d0 [ 3.374570] do_init_module+0x48/0x1d0 [ 3.378309] load_module+0x18e8/0x1c70 [ 3.382045] __do_sys_finit_module+0xa8/0x100 [ 3.386388] __arm64_sys_finit_module+0x20/0x30 [ 3.390905] invoke_syscall+0x48/0x114 [ 3.394643] el0_svc_common.constprop.0+0x44/0xfc [ 3.399332] do_el0_svc+0x30/0xd0 [ 3.402635] el0_svc+0x2c/0x84 [ 3.405678] el0t_64_sync_handler+0xbc/0x140 [ 3.409933] el0t_64_sync+0x18c/0x190 [ 3.413582] ---[ end trace 0000000000000000 ]--- [ 3.418487] wiz: probe of bus@100000:wiz@5060000 failed with error -12 [ 3.455193] mc: Linux media interface: v0.10 [ 3.467649] pvrsrvkm: loading out-of-tree module taints kernel. [ 3.477312] videodev: Linux video capture interface: v2.00 [ 3.487663] PVR_K: 147: Device: 4e20000000.gpu [ 3.493177] PVR_K: 147: Read BVNC 36.53.104.796 from HW device registers [ 3.493395] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 3.500417] PVR_K: 147: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 3.516305] [drm] Initialized pvr 23.1.6404501 20170530 for 4e20000000.gpu on minor 0 [ 3.532582] vdec 4210000.video-codec: Direct firmware load for wave521c_codec_fw.bin failed with error -2 [ 3.542244] vdec 4210000.video-codec: request_firmware, fail: -2 [ 3.548253] vdec 4210000.video-codec: wave5_vpu_load_firmware, fail: -2 [ 3.555253] vdec: probe of 4210000.video-codec failed with error -2 [ 3.578812] EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none. hwclock: can't open '/dev/misc/rtc': No such file or directory Fri Mar 9 12:34:56 UTC 2018 hwclock: can't open '/dev/misc/rtc': No such file or directory ALSA: Restoring mixer settings... Configuring packages on first boot.... (This may take several minutes. Please do not power off the machine.) Running postinst /etc/rpm-postinsts/100-sysvinit-inittab... update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing) INIT: Entering runlevel: 5up links for run-postin Configuring network interfaces... [ 4.105989] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 4.115474] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode udhcpc: started, v1.35.0 udhcpc: broadcasting discover [ 7.199254] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx udhcpc: broadcasting discover udhcpc: broadcasting select for 192.168.2.134, server 192.168.2.17 udhcpc: lease of 192.168.2.134 obtained from 192.168.2.17, lease time 28800 /etc/udhcpc.d/50default: Adding DNS 192.168.2.17 /etc/udhcpc.d/50default: Adding DNS 10.1.2.17 done. Starting system message bus: dbus. Starting Dropbear SSH server: Generating 2048 bit rsa key, this may take a while... Internal warning: debug scope 'drm-backend' has not been destroyed. Public key portion is: ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCliIQPTQ1mXwt3mN3mL9ixwSwB86sMI8Tg1iqIw27Fu1eTljx2cR7i2hcHXa47yML2nJe7GgaqWD64vcMl7H4PzxQvdlVAda23DLTxCuxOIWYgLwxjwyZ/c+BUDjtkoxPlZrlCiO9mShytRJTYVu/mNeJPfGKi2ktUz2qVhfA1Lae0VZYE3zYEeBO5lVrtV+clfT4W9f/GFcp/XdTjmYyZ9/GkwDJheQaC7cy8xyqz/rAGSVpErnfM7LzXvYbXHtV[ 7.999928] NET: Registered PF_INET6 protocol family gnQMn7tclSuZqiDq8DyhnoUw405c7z14bxWCVN6++XbtoR9K14E4HoVymUybnv6T[ 8.011431] Segment Routing with IPv6 6Z20ZK8uzQfUs4oQBx+0j root@j721s2-evm Fingerprint: sha1!! 54:b[ 8.019171] In-situ OAM (IOAM) with IPv6 1:6c:3b:bb:98:b4:8b:23:62:bc:2c:69:74:ee:26:83:a8:97:eb dropbear. Starting rpcbind daemon...done. Starting advanced power management daemon: No APM support in kernel (failed.) Starting bluetooth: bluetoothd. hwclock: can't open '/dev/misc/rtc': No such file or directory [ 8.152435] Bluetooth: Core ver 2.22 [ 8.156117] NET: Registered PF_BLUETOOTH protocol family [ 8.161430] Bluetooth: HCI device and connection manager initialized [ 8.167787] Bluetooth: HCI socket layer initialized [ 8.172664] Bluetooth: L2CAP socket layer initialized [ 8.177721] Bluetooth: SCO socket layer initialized Starting syslogd/klogd: done * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon ...done. Starting Telephony daemon Starting Linux NFC daemon [ 8.755390] nfc: nfc_init: NFC Core ver 0.1 [ 8.760085] NET: Registered PF_NFC protocol family Poky (Yocto Project Reference Distro) 4.0.10 j721s2-evm /dev/ttyS2 j721s2-evm login:
And the log with the older linux kernel but with using the updated ti-img-rouge-driver
Starting kernel ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Reserved shared memory is enabled I/TC: Dynamic shared memory is enabled I/TC: Normal World virtualization support is disabled I/TC: Asynchronous notifications are disabled [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.168-g2c23e6c538 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Thu Feb 23 19:09:34 UTC 2023 [ 0.000000] Machine model: Texas Instruments AM68 SK [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x0000000bffffefff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a9bfffff] [ 0.000000] node 0: [mem 0x00000000a9c00000-0x00000000ffffefff] [ 0.000000] node 0: [mem 0x0000000880000000-0x0000000bffffefff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff] [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1 pages in unavailable ranges [ 0.000000] cma: Reserved 512 MiB at 0x00000000dfc00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s51288 r8192 d30632 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128766 [ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk1p2 rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000dbc00000-0x00000000dfc00000] (64MB) [ 0.000000] Memory: 15663700K/16777208K available (11328K kernel code, 1162K rwdata, 4260K rodata, 1856K init, 431K bss, 589220K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000168] Console: colour dummy device 80x25 [ 0.000198] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.000205] pid_max: default: 32768 minimum: 301 [ 0.000251] LSM: Security Framework initializing [ 0.000345] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.000424] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.001310] rcu: Hierarchical SRCU implementation. [ 0.001465] Platform MSI: msi-controller@1820000 domain created [ 0.001592] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.001633] EFI services will not be available. [ 0.001733] smp: Bringing up secondary CPUs ... [ 0.010166] Detected PIPT I-cache on CPU1 [ 0.010190] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.010202] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000 [ 0.010240] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.010293] smp: Brought up 1 node, 2 CPUs [ 0.010300] SMP: Total of 2 processors activated. [ 0.010305] CPU features: detected: 32-bit EL0 Support [ 0.010309] CPU features: detected: CRC32 instructions [ 0.019665] CPU: All CPU(s) started at EL2 [ 0.019688] alternatives: patching kernel code [ 0.020216] devtmpfs: initialized [ 0.024131] KASLR disabled due to lack of seed [ 0.024234] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.024243] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.030354] pinctrl core: initialized pinctrl subsystem [ 0.030662] DMI not present or invalid. [ 0.030984] NET: Registered protocol family 16 [ 0.031735] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.032131] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.032646] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.032863] thermal_sys: Registered thermal governor 'step_wise' [ 0.032865] thermal_sys: Registered thermal governor 'power_allocator' [ 0.033351] cpuidle: using governor menu [ 0.033440] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.033470] ASID allocator initialised with 65536 entries [ 0.048083] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.048091] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.048095] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.048098] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.048728] cryptd: max_cpu_qlen set to 1000 [ 0.050306] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected [ 0.050602] vsys_3v3: supplied by vusb-main5v0 [ 0.051244] iommu: Default domain type: Translated [ 0.051388] SCSI subsystem initialized [ 0.051626] mc: Linux media interface: v0.10 [ 0.051638] videodev: Linux video capture interface: v2.00 [ 0.051664] pps_core: LinuxPPS API ver. 1 registered [ 0.051667] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.051673] PTP clock support registered [ 0.051693] EDAC MC: Ver: 3.0.0 [ 0.052310] FPGA manager framework [ 0.052351] Advanced Linux Sound Architecture Driver Initialized. [ 0.052708] clocksource: Switched to clocksource arch_sys_counter [ 0.052804] VFS: Disk quotas dquot_6.6.0 [ 0.052830] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.055232] NET: Registered protocol family 2 [ 0.056034] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.059390] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 0.059486] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.059894] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) [ 0.060336] TCP: Hash tables configured (established 131072 bind 65536) [ 0.060469] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.060629] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.060959] NET: Registered protocol family 1 [ 0.061282] RPC: Registered named UNIX socket transport module. [ 0.061286] RPC: Registered udp transport module. [ 0.061289] RPC: Registered tcp transport module. [ 0.061292] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.061297] NET: Registered protocol family 44 [ 0.061310] PCI: CLS 0 bytes, default 64 [ 0.061638] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.063681] Initialise system trusted keyrings [ 0.063768] workingset: timestamp_bits=46 max_order=22 bucket_order=0 [ 0.065391] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.065653] NFS: Registering the id_resolver key type [ 0.065667] Key type id_resolver registered [ 0.065671] Key type id_legacy registered [ 0.065702] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.065707] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.065792] 9p: Installing v9fs 9p2000 file system support [ 0.085653] Key type asymmetric registered [ 0.085659] Asymmetric key parser 'x509' registered [ 0.085684] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.085688] io scheduler mq-deadline registered [ 0.085692] io scheduler kyber registered [ 0.087002] pinctrl-single 4301c000.pinctrl: 101 pins, size 404 [ 0.087163] pinctrl-single 11c000.pinctrl: 72 pins, size 288 [ 0.091475] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.097606] brd: module loaded [ 0.100957] loop: module loaded [ 0.101562] megasas: 07.714.04.00-rc1 [ 0.103474] tun: Universal TUN/TAP device driver, 1.6 [ 0.103746] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.103750] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.103782] sky2: driver version 1.30 [ 0.104354] VFIO - User Level meta-driver version: 0.3 [ 0.104913] i2c /dev entries driver [ 0.105694] sdhci: Secure Digital Host Controller Interface driver [ 0.105698] sdhci: Copyright(c) Pierre Ossman [ 0.105880] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.106407] ledtrig-cpu: registered to indicate activity on CPUs [ 0.106593] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.107331] optee: probing for conduit method. [ 0.107352] optee: revision 3.20 (8e74d476) [ 0.123793] optee: dynamic shared memory is enabled [ 0.124012] optee: initialized driver [ 0.125265] NET: Registered protocol family 17 [ 0.125343] 9pnet: Installing 9P2000 support [ 0.125385] Key type dns_resolver registered [ 0.125544] Loading compiled-in X.509 certificates [ 0.133330] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.3-v08.06.03 (Chill Capybara') [ 0.156784] omap_i2c 42120000.i2c: bus 0 rev0.12 at 100 kHz [ 0.157231] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 400 kHz [ 0.157889] pca953x 2-0020: supply vcc not found, using dummy regulator [ 0.157948] pca953x 2-0020: using no AI [ 0.181864] omap_i2c 40b10000.i2c: bus 2 rev0.12 at 100 kHz [ 0.182596] pca953x 3-0021: supply vcc not found, using dummy regulator [ 0.182644] pca953x 3-0021: using no AI [ 0.205270] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 0.205734] omap_i2c 2040000.i2c: bus 4 rev0.12 at 400 kHz [ 0.206479] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created [ 0.206570] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created [ 0.206652] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created [ 0.206810] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created [ 0.210900] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 0.210920] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 0.210932] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 0.210943] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.212874] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00 [ 1.212881] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.212895] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff]) [ 1.212898] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff] [ 1.212938] pci 0000:00:00.0: [104c:b013] type 01 class 0x060400 [ 1.213037] pci 0000:00:00.0: supports D1 [ 1.213041] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 1.214482] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.215768] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 1.215782] pci 0000:00:00.0: PCI bridge to [bus 01] [ 1.216029] pcieport 0000:00:00.0: PME: Signaling with IRQ 56 [ 1.217056] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272 [ 1.217062] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.217066] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.218376] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259 [ 1.218383] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.218386] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64 [ 1.218595] omap8250 40a00000.serial: failed to get alias [ 1.219129] printk: console [ttyS2] disabled [ 1.219163] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 28, base_baud = 3000000) is a 8250 [ 2.748861] printk: console [ttyS2] enabled [ 2.759953] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 2.804710] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.813286] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 2.821588] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 2.834394] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 2.841600] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.847889] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 2.858219] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:200000000, add_val:4 pps:0 [ 2.970912] vdd_mmc1: supplied by vsys_3v3 [ 2.976971] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100 [ 2.983797] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100 [ 2.990602] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100 [ 2.997414] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100 [ 3.004555] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 3.014478] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16) [ 3.028457] spi-nor spi11.0: s28hs512t (65536 Kbytes) [ 3.036324] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 3.080711] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 3.089292] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 3.097588] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000 [ 3.110394] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 3.117600] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 3.123849] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0 [ 3.133907] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 3.142311] mmc1: CQHCI version 5.10 [ 3.146508] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present! [ 3.153804] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present! [ 3.161547] debugfs: Directory 'pd:276' with parent 'pm_genpd' already present! [ 3.169432] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present! [ 3.182031] ALSA device list: [ 3.184998] No soundcards found. [ 3.189271] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 3.197082] Waiting for root device /dev/mmcblk1p2... [ 3.244667] mmc1: new ultra high speed DDR50 SDHC card at address 5048 [ 3.251542] mmcblk1: mmc1:5048 SD32G 29.7 GiB [ 3.257609] mmcblk1: p1 p2 [ 3.270329] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.278444] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 3.286020] devtmpfs: mounted [ 3.289684] Freeing unused kernel memory: 1856K [ 3.294310] Run /sbin/init as init process INIT: version 3.01 booting Framebuffer /dev/fb0 not detected Boot splashscreen disabled Starting udev [ 3.605087] udevd[181]: starting version 3.2.10 [ 3.627053] random: udevd: uninitialized urandom read (16 bytes read) [ 3.634135] random: udevd: uninitialized urandom read (16 bytes read) [ 3.641203] random: udevd: uninitialized urandom read (16 bytes read) [ 3.664181] udevd[182]: starting eudev-3.2.10 [ 3.734034] random: crng init done [ 3.740754] random: 3 urandom warning(s) missed due to ratelimiting [ 3.795527] CAN device driver interface [ 3.812650] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a6000000 [ 3.836102] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode [ 3.846384] remoteproc remoteproc0: 64800000.dsp is available [ 3.859186] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a7000000 [ 3.868576] remoteproc remoteproc0: Direct firmware load for j721s2-c71_0-fw failed with error -2 [ 3.878353] vdec 4210000.video-codec: Direct firmware load for wave521c_codec_fw.bin failed with error -2 [ 3.887955] remoteproc remoteproc0: powering up 64800000.dsp [ 3.893693] remoteproc remoteproc0: Direct firmware load for j721s2-c71_0-fw failed with error -2 [ 3.904676] vdec 4210000.video-codec: request_firmware, fail: -2 [ 3.904957] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode [ 3.914260] remoteproc remoteproc0: request_firmware failed: -2 [ 3.923625] vdec 4210000.video-codec: wave5_vpu_load_firmware, fail: -2 [ 3.932046] pvrsrvkm: loading out-of-tree module taints kernel. [ 3.948484] vdec: probe of 4210000.video-codec failed with error -2 [ 3.966021] remoteproc remoteproc1: 65800000.dsp is available [ 3.987439] PVR_K: 188: Device: 4e20000000.gpu [ 4.002101] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 4.018331] SError Interrupt on CPU0, code 0xbf000000 -- SError [ 4.018334] CPU: 0 PID: 188 Comm: udevd Tainted: G O 5.10.168-g2c23e6c538 #1 [ 4.018336] Hardware name: Texas Instruments AM68 SK (DT) [ 4.018337] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--) [ 4.018338] pc : _RGXReadBVNCFromReg.isra.0+0x20/0x140 [pvrsrvkm] [ 4.018339] lr : RGXBvncInitialiseConfiguration+0x284/0x974 [pvrsrvkm] [ 4.018340] sp : ffff800012aab750 [ 4.018341] x29: ffff800012aab750 x28: 0000000000000100 [ 4.018345] x27: 0000000000000000 x26: ffff800012aab7b8 [ 4.018347] x25: ffff000801cfc000 x24: ffff000803d1d1a0 [ 4.018350] x23: 0000000000000000 x22: ffff800008d1f000 [ 4.018352] x21: ffff000803d1d008 x20: ffff800008ccb0f8 [ 4.018354] x19: 0000000000000000 x18: ffff800008c81b94 [ 4.018356] x17: 000000ffc0000000 x16: ffff800008c81f00 [ 4.018358] x15: ffff800008c81b80 x14: ffff800008c7fc00 [ 4.018361] x13: ffff800008c8a7c0 x12: 0000000000000000 [ 4.018363] x11: ffff000803d1d008 x10: 0000000000000020 [ 4.018365] x9 : 0000000000000000 x8 : 0000000000000024 [ 4.018367] x7 : 0000000000000000 x6 : ffff800013680000 [ 4.018370] x5 : ffff800012aab7c0 x4 : ffff800012aab7bc [ 4.018372] x3 : ffff800012aab7b8 x2 : ffff800012aab7b4 [ 4.018374] x1 : 0000000000000000 x0 : ffff000803d1d008 [ 4.018376] Kernel panic - not syncing: Asynchronous SError Interrupt [ 4.018378] CPU: 0 PID: 188 Comm: udevd Tainted: G O 5.10.168-g2c23e6c538 #1 [ 4.018379] Hardware name: Texas Instruments AM68 SK (DT) [ 4.018380] Call trace: [ 4.018381] dump_backtrace+0x0/0x1b0 [ 4.018382] show_stack+0x18/0x40 [ 4.018383] dump_stack+0xe8/0x124 [ 4.018384] panic+0x198/0x360 [ 4.018384] add_taint+0x0/0xc0 [ 4.018385] arm64_serror_panic+0x78/0x84 [ 4.018386] do_serror+0x64/0x6c [ 4.018387] el1_error+0x90/0x110 [ 4.018387] _RGXReadBVNCFromReg.isra.0+0x20/0x140 [pvrsrvkm] [ 4.018389] RGXRegisterDevice+0x3bc/0xc00 [pvrsrvkm] [ 4.018390] PVRSRVCommonDeviceCreate+0x230/0x710 [pvrsrvkm] [ 4.018391] pvr_drm_load+0x90/0x1b0 [pvrsrvkm] [ 4.018392] pvr_probe+0x5c/0xb0 [pvrsrvkm] [ 4.018393] platform_drv_probe+0x54/0xac [ 4.018394] really_probe+0xec/0x4e0 [ 4.018395] driver_probe_device+0x58/0xbc [ 4.018395] device_driver_attach+0xc0/0xd0 [ 4.018396] __driver_attach+0x68/0x130 [ 4.018397] bus_for_each_dev+0x70/0xd0 [ 4.018398] driver_attach+0x24/0x30 [ 4.018399] bus_add_driver+0x108/0x1fc [ 4.018400] driver_register+0x78/0x130 [ 4.018401] __platform_driver_register+0x48/0x54 [ 4.018402] pvr_init+0x50/0x1000 [pvrsrvkm] [ 4.018403] do_one_initcall+0x50/0x1b0 [ 4.018404] do_init_module+0x44/0x234 [ 4.018405] load_module+0x2034/0x2740 [ 4.018406] __do_sys_finit_module+0xa4/0xf0 [ 4.018407] __arm64_sys_finit_module+0x20/0x30 [ 4.018408] el0_svc_common.constprop.0+0x78/0x1c4 [ 4.018409] do_el0_svc+0x28/0xac [ 4.018410] el0_svc+0x14/0x20 [ 4.018411] el0_sync_handler+0xa4/0x130 [ 4.018412] el0_sync+0x180/0x1c0 [ 4.018429] SMP: stopping secondary CPUs [ 4.018430] Kernel Offset: disabled [ 4.018431] CPU features: 0x28040022,20006008 [ 4.018432] Memory Limit: none
I appreciate that it's not necessarily a straight forward fix so thank you for taking the time to look at this, I will keep an eye out for future updates.
Richard
Richard,
Team is still looking into this. As I mentioned before they are preparing for a release, so it will be churning a lot in the upcoming month or two. Please use an older release until the official release is available as it is not expected to work until then.
Erick
Hi Erick,
Thanks for the update. Do you have any idea of when we can expect to get an official release?
Thanks again,
Richard
Richard,
You can expect tentatively at the end of next month. I'd expect stabilization before then, so keep an eye out for updates.
Erick
