SK-AM68: Bootloader unable to boot into u-boot when building with Yocto
Part Number: SK-AM68
Other Parts Discussed in Thread: AM68, AM69
I had a previous issue here https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1223446/sk-am68-bootloader-only-works-with-hs-version-and-gpu-crashing-when-running-glmark2-with-yocto,
In which tiboot3-j721s2-gp-evm.bin will not boot up the device but tiboot3-j721s2-hs-fs-evm.bin would. I have been told it would not work with the `gp` bootloader however I have not seen any definitive documentation regarding this. The SDK from 08/06 mentions uboot CAN be built for hs, but mentions no need to do so.
Now, 4 months later I have pulled the latest kirkstone branch and I am unable to boot with either bootloader, the board acts effectively dead with no output to the terminal on ttyUSB2.
So the details are the same, here is my local.conf:
IMAGE_INSTALL:append = " vim glmark2"
MACHINE_ESSENTIAL_EXTRA_RRECOMMENDS += "kernel-modules"
DISTRO_FEATURES:remove = "x11 vulkan"
DISTRO_FEATURES:append = " wayland egl gles2"
DISTRO_FEATURES:append = " pam opencv openmp"
PACKAGECONFIG:append:pn-glmark2 = " drm-gles2 wayland-gles2"
PACKAGECONFIG:append:pn-libsdl2 = " kmsdrm"
PACKAGECONFIG:append:pn-weston = " egl wayland"
PACKAGECONFIG:append:pn-cairo = " egl glesv2"
KERNEL_DEVICETREE_PREFIX:append = " k3-am68 ti/k3-am68"
KERNEL_DEVICETREE:append = " ti/k3-am68-sk-base-board.dtb"
MACHINE ??= "j721s2-evm"
And my bblayers.conf:
# POKY_BBLAYERS_CONF_VERSION is increased each time build/conf/bblayers.conf
# changes incompatibly
POKY_BBLAYERS_CONF_VERSION = "2"
BBPATH = "${TOPDIR}"
BBFILES ?= ""
BBLAYERS ?= " \
  /home/rich/Yocto/poky-kirkstone/meta \
  /home/rich/Yocto/poky-kirkstone/meta-poky \
  /home/rich/Yocto/poky-kirkstone/meta-yocto-bsp \
  /home/rich/Yocto/poky-kirkstone/meta-arm/meta-arm-toolchain \
  /home/rich/Yocto/poky-kirkstone/meta-arm/meta-arm \
  /home/rich/Yocto/poky-kirkstone/meta-ti/meta-ti-bsp \
  /home/rich/Yocto/poky-kirkstone/meta-openembedded/meta-oe \
  /home/rich/Yocto/poky-kirkstone/meta-openembedded/meta-python \
  /home/rich/Yocto/poky-kirkstone/meta-openembedded/meta-networking \
  /home/rich/Yocto/poky-kirkstone/meta-freescale-distro \
I build the image e.g. `bitbake core-image-weston`  and now I get a new folder now in build/deploy-ti/images/j721s2-evm. Flash it onto my SD card, place it into the starter kit and use picocom to read TTYUSB2, and I get no output.
Details of the boot partition on the SD card (defaults to gp bootloader, but neither will work):
rich@rich-Precision-3660:/media/rich/boot$ ls -lh
total 24M
drwxr-xr-x 3 rich rich  2.0K Apr  5  2011 EFI
-rw-r--r-- 1 rich rich   21M Apr  5  2011 Image
-rw-r--r-- 1 rich rich  463K Apr  5  2011 tiboot3.bin
-rw-r--r-- 1 rich rich  463K Apr  5  2011 tiboot3-j721s2-gp-evm.bin
-rw-r--r-- 1 rich rich  466K Apr  5  2011 tiboot3-j721s2-hs-fs-evm.bin
-rw-r--r-- 1 rich rich 1004K Apr  5  2011 tispl.bin
-rw-r--r-- 1 rich rich  1.3M Apr  5  2011 u-boot.img
rich@rich-Precision-3660:/media/rich/boot$ ls EFI
BOOT
rich@rich-Precision-3660:/media/rich/boot$ ls EFI/BOOT
bootaa64.efi  grub.cfg
Regarding the SDK documentation here: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-am68/09_00_00_06/exports/docs/devices/J7_Family/linux/Release_Specific_Yocto_layer_Configuration.html
The default config hasn't even been setup correctly, so you will get an error.
ERROR: Layer 'meta-arago-extras' depends on layer 'openembedded-layer', but this layer is not enabled in your configuration
I have been told from customer support previously that SDK9 will feature the following updates:
For SDK 9.0 – Make uboot would build HS-FS, GP and HS-SW with the correct names and GP being default.
For SDK 9.0 – Add documentation around which uboot image to use for which Board.
For SDK 9.0 - WIC image to have only relevant Uboot images.
It isn't made clear at all what bootloader is needed from https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-am68/09_00_00_06/exports/docs/linux/Foundational_Components/U-Boot/UG-General-Info.html#build-u-boot as there isn't a specific table documenting what the AM68 is. However https://www.ti.com/product/AM68 the product page describes it as a "General Purpose SoC" so I would assume it is a GP device. But again the GP bootloader has never worked for me. There are so many acronyms that are poorly explained across the SDK, for example K3 you won't find defined as Keystone 3 as there is no glossary. I also found that the default image had no output on DisplayPort.
I have the exact same issues with booting on the AM69-SK.
Regardless, could someone explain which bootloader is needed and additionally why it is not working? Thank you
  • Hi Richard,
    The AM68 and AM69 are both high security devices (I understand your confusion regarding the "GP SoC" phrase), so they require the "hs-fs" bootloaders as opposed to the "gp" bootloaders.
    After you've flashed your SD card, if you remove/rename the "tiboot3.bin" file and rename the "tiboot3-j721s2-hs-fs-evm.bin" file to "tiboot3.bin", the board should boot. The process is the same for the AM69 as well.
    Jared
  • Hi Jared,
    Thanks for the reply but that is exactly what I have done and the board fails to boot,
    Richard
  • Hi Richard,
    I tried replicating your issue using the J721s2 9.0 SDK by following the steps for building the SDK with Yocto (I used processor-sdk-linux-09_00_00_07.txt).
    I was able to build the weston image with the following command: MACHINE=j721s2-evm bitbake -k core-image-weston
    After etching the SD card and changing the tiboot3-j721s2-hs-fs-evm.bin file name, the AM68 boot without issue.
    I assume your setup environment is different, however are you able to use the SDK (and its respective local.conf and bblayers.conf files)? You can install the SDK using the binary you can find here.
    Jared
  • Hi Jared, so I tried again on the SD card, but made sure I ran sudo sync and sudo umount before ejecting the SD card and it booted so perhaps the write just didn't take effect before.
    But with the SDK, I haven't been able to get it to work as I mentioned the bitbake layers are not setup correctly on SDK9 with "ERROR: Layer 'meta-arago-extras' depends on layer 'openembedded-layer', but this layer is not enabled in your configuration"
    Richard
  • Hi Richard,
    I'm happy to hear that the SD card is now successfully booting.
    I'm unsure what is happening with the openembedded-layer error, since I don't see that issue on my side. Are you running on Ubuntu 22.04 and following these instructions after installing the SDK?
    The commands I execute are:
    # run the binary to install the SDK
    # cd into the root of the SDK directory
    $ rm -rf yocto-build
    $ git clone https://git.ti.com/git/arago-project/oe-layersetup.git yocto-build
    $ cd yocto-build
    $ ./oe-layertool-setup.sh -f configs/processor-sdk-linux/processor-sdk-linux-09_00_00_07.txt
    $ cd build
    $ . conf/setenv
    $ MACHINE=j721s2-evm bitbake -k core-image-weston
    Jared
  • Thanks, I can take a look. Although seeing as I have Yocto running without the SDK I will most likely use that as I am not fond of the SDK's documentation,
    Richard
  • Hi Jared,
    So I tried building the core-image-weston via the SDK, and the image can be built but the kernel fails to start Weston.
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 6.1.33-g8f7f371be2 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Fri Jul 14 00:39:55 UTC 2023
    [    0.000000] Machine model: Texas Instruments AM68 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000bc7e00000, size 896 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000bffffefff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a9bfffff]
    [    0.000000]   node   0: [mem 0x00000000a9c00000-0x00000000ffffefff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x0000000bffffefff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000bffffefff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-v3a
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4128766
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) systemd.hostname=am68-sk root=PARTUUID=d211bf20-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] Memory: 15268600K/16777208K available (12480K kernel code, 1294K rwdata, 4040K rodata, 2176K init, 498K bss, 591104K reserved, 917504K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008393] Console: colour dummy device 80x25
    [    0.012961] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023633] pid_max: default: 32768 minimum: 301
    [    0.028373] LSM: Security Framework initializing
    [    0.033175] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.040953] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.050018] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.057427] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.063690] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.070009] rcu: Hierarchical SRCU implementation.
    [    0.074906] rcu: 	Max phase no-delay instances is 1000.
    [    0.080420] Platform MSI: msi-controller@1820000 domain created
    [    0.086615] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.096299] EFI services will not be available.
    [    0.101045] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.114110] Detected PIPT I-cache on CPU1
    [    0.114172] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.114186] GICv3: CPU1: using allocated LPI pending table @0x0000000880050000
    [    0.114220] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.114274] smp: Brought up 1 node, 2 CPUs
    [    0.143623] SMP: Total of 2 processors activated.
    [    0.148427] CPU features: detected: 32-bit EL0 Support
    [    0.153682] CPU features: detected: CRC32 instructions
    [    0.158967] CPU: All CPU(s) started at EL2
    [    0.163148] alternatives: applying system-wide alternatives
    [    0.169765] devtmpfs: initialized
    [    0.179563] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.189552] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.207740] pinctrl core: initialized pinctrl subsystem
    [    0.213438] DMI not present or invalid.
    [    0.217690] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.224554] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
    [    0.232223] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.240562] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.248788] audit: initializing netlink subsys (disabled)
    [    0.254439] audit: type=2000 audit(0.164:1): state=initialized audit_enabled=0 res=1
    [    0.254679] thermal_sys: Registered thermal governor 'step_wise'
    [    0.262365] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.268590] cpuidle: using governor menu
    [    0.279349] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.286316] ASID allocator initialised with 65536 entries
    [    0.300699] platform hdmi-connector: Fixed dependency cycle(s) with /dvi-bridge
    [    0.308215] platform 4a00000.dss: Fixed dependency cycle(s) with /dvi-bridge
    [    0.315624] KASLR disabled due to lack of seed
    [    0.323225] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.330169] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.336572] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.343506] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.349906] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.356840] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.363241] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.370174] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.377574] k3-chipinfo 43000014.chipid: Family:J721S2 rev:SR1.0 JTAGID[0x0bb7502f] Detected
    [    0.387029] iommu: Default domain type: Translated
    [    0.392016] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.398549] SCSI subsystem initialized
    [    0.402570] usbcore: registered new interface driver usbfs
    [    0.408197] usbcore: registered new interface driver hub
    [    0.413636] usbcore: registered new device driver usb
    [    0.419076] pps_core: LinuxPPS API ver. 1 registered
    [    0.424150] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.433491] PTP clock support registered
    [    0.437574] EDAC MC: Ver: 3.0.0
    [    0.441381] FPGA manager framework
    [    0.444895] Advanced Linux Sound Architecture Driver Initialized.
    [    0.451578] clocksource: Switched to clocksource arch_sys_counter
    [    0.457934] VFS: Disk quotas dquot_6.6.0
    [    0.461971] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.471991] NET: Registered PF_INET protocol family
    [    0.477355] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.490209] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
    [    0.499122] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.507064] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.515759] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.524340] TCP: Hash tables configured (established 131072 bind 65536)
    [    0.531232] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.538359] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.546015] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.552129] RPC: Registered named UNIX socket transport module.
    [    0.558197] RPC: Registered udp transport module.
    [    0.563001] RPC: Registered tcp transport module.
    [    0.567803] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.574386] NET: Registered PF_XDP protocol family
    [    0.579301] PCI: CLS 0 bytes, default 64
    [    0.583741] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.592936] Initialise system trusted keyrings
    [    0.597619] workingset: timestamp_bits=46 max_order=22 bucket_order=0
    [    0.606756] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.613069] NFS: Registering the id_resolver key type
    [    0.618251] Key type id_resolver registered
    [    0.622523] Key type id_legacy registered
    [    0.626647] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.633496] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.641149] 9p: Installing v9fs 9p2000 file system support
    [    0.665746] Key type asymmetric registered
    [    0.669931] Asymmetric key parser 'x509' registered
    [    0.674939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.682590] io scheduler mq-deadline registered
    [    0.687222] io scheduler kyber registered
    [    0.693291] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
    [    0.699295] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
    [    0.705282] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
    [    0.711313] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
    [    0.717155] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    0.727345] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.737599] loop: module loaded
    [    0.741688] megasas: 07.719.03.00-rc1
    [    0.747618] tun: Universal TUN/TAP device driver, 1.6
    [    0.753155] thunder_xcv, ver 1.0
    [    0.756475] thunder_bgx, ver 1.0
    [    0.759781] nicpf, ver 1.0
    [    0.762785] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
    [    0.770167] hns3: Copyright (c) 2017 Huawei Corporation.
    [    0.775619] hclge is initializing
    [    0.779007] e1000: Intel(R) PRO/1000 Network Driver
    [    0.783988] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    0.789873] e1000e: Intel(R) PRO/1000 Network Driver
    [    0.794943] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    0.801010] igb: Intel(R) Gigabit Ethernet Network Driver
    [    0.806524] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    0.812226] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.818628] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.824748] sky2: driver version 1.30
    [    0.828910] VFIO - User Level meta-driver version: 0.3
    [    0.834598] usbcore: registered new interface driver usb-storage
    [    0.841236] i2c_dev: i2c /dev entries driver
    [    0.846546] sdhci: Secure Digital Host Controller Interface driver
    [    0.852871] sdhci: Copyright(c) Pierre Ossman
    [    0.857607] Synopsys Designware Multimedia Card Interface Driver
    [    0.864013] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.870301] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.876543] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.883295] usbcore: registered new interface driver usbhid
    [    0.888990] usbhid: USB HID core driver
    [    0.893700] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.898265] optee: revision 3.20 (8e74d476)
    [    0.914715] optee: dynamic shared memory is enabled
    [    0.924203] optee: initialized driver
    [    0.929125] Initializing XFRM netlink socket
    [    0.933516] NET: Registered PF_PACKET protocol family
    [    0.938753] 9pnet: Installing 9P2000 support
    [    0.943153] Key type dns_resolver registered
    [    0.947751] registered taskstats version 1
    [    0.951956] Loading compiled-in X.509 certificates
    [    0.961821] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.6--v09.00.06 (Kool Koala)')
    [    0.991030] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.997361] pca953x 1-0020: supply vcc not found, using dummy regulator
    [    1.004220] pca953x 1-0020: using no AI
    [    1.032612] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.039028] pca953x 2-0021: supply vcc not found, using dummy regulator
    [    1.045860] pca953x 2-0021: using no AI
    [    1.072133] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.078203] omap_i2c 2040000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.084018] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 125 domain created
    [    1.092561] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 148 domain created
    [    1.101900] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 227 domain created
    [    1.110548] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 265 created
    [    1.121223] ti-udma 311a0000.dma-controller: Number of rings: 48
    [    1.127989] ti-udma 311a0000.dma-controller: Channels: 24 (bchan: 0, tchan: 8, rchan: 16)
    [    1.137243] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:272
    [    1.147135] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.153894] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.162733] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:259
    [    1.172897] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.179656] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.187656] printk: console [ttyS2] disabled
    [    1.192053] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 216, base_baud = 3000000) is a 8250
    [    1.200909] printk: console [ttyS2] enabled
    [    1.209356] printk: bootconsole [ns16550a0] disabled
    [    1.220961] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.267588] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.276221] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.284501] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.297358] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.304568] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.310860] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.321326] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
    [    1.335211] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.342036] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.348837] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.355635] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.363555] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.373560] ti-udma 31150000.dma-controller: Channels: 60 (tchan: 30, rchan: 30, gp-rflow: 16)
    [    1.385748] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.390762] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
    [    1.397367] Creating 7 MTD partitions on "47040000.spi.0":
    [    1.402838] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.408986] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.414856] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.420768] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.426398] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.432652] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.438521] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.448712] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    1.491583] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.500201] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.508479] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.521336] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.528544] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.534815] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
    [    1.544847] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.552746] debugfs: Directory 'pd:39' with parent 'pm_genpd' already present!
    [    1.553235] mmc1: CQHCI version 5.10
    [    1.560060] debugfs: Directory 'pd:38' with parent 'pm_genpd' already present!
    [    1.571849] debugfs: Directory 'pd:154' with parent 'pm_genpd' already present!
    [    1.584013] ALSA device list:
    [    1.586975]   No soundcards found.
    [    1.602192] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    1.609796] Waiting for root device PARTUUID=d211bf20-02...
    [    1.657819] mmc1: new ultra high speed SDR104 SDHC card at address 5048
    [    1.664867] mmcblk1: mmc1:5048 SD32G 29.7 GiB
    [    1.671115]  mmcblk1: p1 p2
    [    1.746651] EXT4-fs (mmcblk1p2): recovery complete
    [    1.752448] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    1.760999] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    1.767823] devtmpfs: mounted
    [    1.771624] Freeing unused kernel memory: 2176K
    [    1.776249] Run /sbin/init as init process
    [    1.890760] systemd[1]: System time before build time, advancing clock.
    [    1.918162] NET: Registered PF_INET6 protocol family
    [    1.923832] Segment Routing with IPv6
    [    1.927502] In-situ OAM (IOAM) with IPv6
    [    1.946399] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    1.977960] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.04!
    [    2.055771] systemd[1]: Hostname set to <am68-sk>.
    [    2.128949] systemd-sysv-generator[136]: SysV service '/etc/init.d/inetd.busybox' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.154290] systemd-sysv-generator[136]: SysV service '/etc/init.d/dropbear' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.178584] systemd-sysv-generator[136]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    2.310903] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    2.356522] systemd[1]: Queued start job for default target Graphical Interface.
    [    2.390029] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    2.412684] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    2.436559] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    2.460438] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    2.483831] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    2.507746] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    2.531793] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    2.551651] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    2.571639] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    2.591639] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    2.650236] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    2.671742] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    2.692075] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    2.714681] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    2.735846] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    2.760004] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    2.779877] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    2.799918] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    2.819965] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    2.843975] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    2.863830] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    2.883866] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    2.927936] systemd[1]: Mounting Huge Pages File System...
    [    2.950049] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.974083] systemd[1]: Mounting Kernel Debug File System...
    [    2.995906] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.031903] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.054407] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.078319] systemd[1]: Starting Load Kernel Module configfs...
    [    3.098346] systemd[1]: Starting Load Kernel Module drm...
    [    3.140083] systemd[1]: Starting Load Kernel Module fuse...
    [    3.163138] systemd[1]: Starting Start psplash boot splash screen...
    [    3.187208] systemd[1]: Starting RPC Bind...
    [    3.207783] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
    [    3.240124] systemd[1]: Starting Journal Service...
    [    3.261425] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
    [    3.273484] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network …ts from Kernel command line...
    [    3.321537] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems EXT4-fs (mmcblk1p2): re-mounted. Quota mode: none.
    [0m...
    [    3.354384] systemd[1]: Starting Apply Kernel Variables...
    [    3.374415] systemd[1]: Starting Coldplug All udev Devices...
    [    3.400581] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    3.420160] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Reached target Preparation for Network.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    3.777675] systemd-journald[151]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /media/ram...
             Mounting /var/volatile...
    [    3.917843] audit: type=1334 audit(1651167747.024:2): prog-id=5 op=LOAD
    [    3.924945] audit: type=1334 audit(1651167747.032:3): prog-id=6 op=LOAD
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Mounted /var/volatile.
             Starting Network Configuration...
             Starting Load/Save Random Seed...
    [  OK  ] Started Network Configuration.
    [  OK  ] Found device /dev/ttyS2.
    [    4.300812] pvrsrvkm: loading out-of-tree module taints kernel.
    [    4.364781] PVR_K:  174: Device: 4e20000000.gpu
    [    4.369669] PVR_K:  174: Read BVNC 36.53.104.796 from HW device registers
    [    4.387920] PVR_K:  174: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    4.404920] [drm] Initialized pvr 23.1.6404501 20170530 for 4e20000000.gpu on minor 0
    [    4.506405] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    4.535553] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Found device /dev/disk/by-uuid/1CF5-6846.
             Mounting /boot...
    [    4.653983] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [  OK  ] Mounted /boot.
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Name Resolution...
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started Network Name Resolution[    5.059606] random: crng init done
    [    5.068329] systemd-journald[151]: Oldest entry in /run/log/journal/8a4f4bfcfe744f4098fbe4ac2f97d6ea/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    [  OK  ] Started Network Time Synchronizatio[    5.089228] systemd-journald[151]: /run/log/journal/8a4f4bfcfe744f4098fbe4ac2f97d6ea/system.journal: Journal header limits reached or header out-of-date, rotating.
    n.
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
             Starting Weston socket...
    [  OK  ] Listening on Weston socket.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Kernel Logging Service.
    [  OK  ] Started System Logging Service.
             Starting D-Bus System Message Bus...
             Starting Telephony service...
    [    5.483341] audit: type=1334 audit(1697618425.702:4): prog-id=7 op=LOAD
    [    5.490291] audit: type=1334 audit(1697618425.710:5): prog-id=8 op=LOAD
             Starting User Login Management...
             Starting Permit User Sessions...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Started Getty on tty1.
    [    5.600782] Bluetooth: Core ver 2.22
    [    5.605442] NET: Registered PF_BLUETOOTH protocol family
    [    5.612562] Bluetooth: HCI device and connection manager initialized
    [    5.624125] Bluetooth: HCI socket layer initialized
    [    5.624135] Bluetooth: L2CAP socket layer initialized
    [    5.624151] Bluetooth: SCO socket layer initialized
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
             Starting Weston, a Wayland…ositor, as a system service...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
    [    5.761817] audit: type=1334 audit(1697618425.982:6): prog-id=9 op=LOAD
    [    5.768821] audit: type=1334 audit(1697618425.990:7): prog-id=10 op=LOAD
             Starting User Database Manager...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started User Login Management.
    [  OK  ] Started Telephony service.
    [  OK  ] Started User Database Manager.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Created slice User Slice of UID 1000.
             Starting User Runtime Directory /run/user/1000...
    [  OK  ] Finished User Runtime Directory /run/user/1000.
             Starting User Manager for UID 1000...[    6.005881] audit: type=1006 audit(1697618426.226:8): pid=237 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [    6.018443] audit: type=1300 audit(1697618426.226:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd65709e8 a2=4 a3=ffff931b8020 items=0 ppid=1 pid=237 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [    6.048143] audit: type=1327 audit(1697618426.226:8): proctitle="(systemd)"
    [  OK  ] Started User Manager for UID 1000.
    [  OK  ] Started Session c1 of User weston.
    [    6.312023] audit: type=1006 audit(1697618426.534:9): pid=231 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1
    [    6.324774] audit: type=1300 audit(1697618426.534:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffd65709e8 a2=4 a3=ffff931b8020 items=0 ppid=1 pid=231 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null)
    [    6.351707] audit: type=1327 audit(1697618426.534:9): proctitle="(weston)"
    [FAILED] Failed to start Weston, a …mpositor, as a system service.
    See 'systemctl status weston.service' for details.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am68-sk -
    Arago 2023.04 am68-sk -
    am68-sk login: [    7.624578] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [    7.633362] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    am68-sk login: root
    [   30.553045] audit: type=1006 audit(1697618500.256:10): pid=249 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   30.566198] audit: type=1300 audit(1697618500.256:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd65709e8 a2=1 a3=ffff931b8020 items=0 ppid=1 pid=249 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
    [   30.593151] audit: type=1327 audit(1697618500.256:10): proctitle="(systemd)"
    [   30.601005] audit: type=1334 audit(1697618500.268:11): prog-id=11 op=LOAD
    [   30.609026] audit: type=1300 audit(1697618500.268:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffdddf06a0 a2=78 a3=0 items=0 ppid=1 pid=249 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   30.634918] audit: type=1327 audit(1697618500.268:11): proctitle="(systemd)"
    [   30.642369] audit: type=1334 audit(1697618500.296:12): prog-id=11 op=UNLOAD
    [   30.649723] audit: type=1334 audit(1697618500.296:13): prog-id=12 op=LOAD
    [   30.656850] audit: type=1300 audit(1697618500.296:13): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffdddf0740 a2=78 a3=0 items=0 ppid=1 pid=249 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/lib/systemd/systemd" key=(null)
    [   30.682531] audit: type=1327 audit(1697618500.296:13): proctitle="(systemd)"
    Is the image core-image-weston support?
    Richard
  • Hi Richard,
    This is a question on a topic that is fairly removed from the initial thread question. Can you open up a new thread for your question?
    Jared
  • No worries, I will make many threads for my many SDK problems,
    Cheers,
    Rich
