Part Number: TDA4VM
- I have been working with your library edgeai-torchvision, and your guide on quantization: https://github.com/TexasInstruments/edgeai-torchvision/blob/master/docs/pixel2pixel/Quantization.md#how-to-use--quanttrainmodule
The training flow I'm using is as-
- Taking a trained model that I want to use, loading its weights
- Replacing the relevant layers to TI implementation (
Upsample->xnn.layers.ResizeWith,Concat->xnn.layers.CatBlock) - Wrapping the modified model with
xnn.quantize.QuantTrainModuleclass - Training 50 epochs, with "small" learning rate values
These step were done with many hyper parameters changes- LR changes, adding/removing weights decay:
- Tried with/without freezing BatchNorm and Quantization range as advised in the guide (using
xnn.utils.freeze_bn(model)andxnn.layers.freeze_quant_range(model))
- While training is being done - it can be seem that the training loss value if very much bigger than the one I get without the QAT flow, and seem that nothing of the described experiments improves it (about x5 bigger than without QAT flow)
- When testing the trained model, I use torch.load + load_state_dict (using the weights of each model after the replacement of the relevant layers (concat, upsample) as done before training
- The tested model have severe localization problems, accuracy drops dramatically
