TDA4VM: TDA4VM_EVH ospi cannot recognize _a72
Part Number: TDA4VM
Hi team,
TI-processor-SDK-Linux-j784s4-EVM-08_06_00_12.git does not recognize the ospi and does not get the DMA after power on. The prebuild img in the SDK is also the same issue:
[    1.322721] printk: console [ttyS2] enabled
[    1.331157] printk: bootconsole [ns16550a0] disabled
[    1.342342] cadence-qspi 47040000.spi: error -ENODEV: No Rx DMA available
[    1.349631] spi-nor: probe of spi0.0 failed with error -22
[    1.355480] cadence-qspi 47050000.spi: error -ENODEV: No Rx DMA available
[    1.362509] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    1.369373] spi-nor: probe of spi1.0 failed with error -2
Please see the kernel boot log here: https://e2echina.ti.com/cfs-file/__key/communityserver-discussions-components-files/120/ospi_5F00_ti_5F00_demo.log
Could you help check this case? Thanks.
Cherry
  • Hi Cherry,
    Can you confirm that you are using the TI J784s4 EVM?
    - Keerthy
  • Cheery,
    There is an existing Internal issue that is being worked upon. There is an untested workaround that should help.
    Please try the below change in the Linux driver:
    diff --git a/drivers/spi/spi-cadence-quadspi.c b/drivers/spi/spi-cadence-quadspi.c
    index 3f64275a3140..2138bd28bd6d 100644
    --- a/drivers/spi/spi-cadence-quadspi.c
    +++ b/drivers/spi/spi-cadence-quadspi.c
    @@ -2219,6 +2219,8 @@ static int cqspi_request_mmap_dma(struct cqspi_st *cqspi)
            if (IS_ERR(cqspi->rx_chan)) {
                    int ret = PTR_ERR(cqspi->rx_chan);
                    cqspi->rx_chan = NULL;
    +               if (ret == -ENODEV)
    +                       ret = -EPROBE_DEFER;
                    return dev_err_probe(&cqspi->pdev->dev, ret, "No Rx DMA available\n");
            init_completion(&c
    Let us know if you are unblocked while the issue is being fixed internally.
    Keerthy
  • Hi Keerthy,
    Thanks for your support.
    Yes.
    patch:
    line 206: 20230524_14:34:21:500:[ 0.000000] GICv3: 960 SPIs implemented
    line 207: 20230524_14:34:21:500:[ 0.000000] GICv3: 0 Extended SPIs implemented
    line 433: 20230524_14:34:22:796:[ 1.477158] cadence-qspi 47040000.spi: error (____ptrval____): No Rx DMA available
    line 435: 20230524_14:34:22:850:[ 1.494626] spi-nor: probe of spi0.0 failed with error -22
    line 436: 20230524_14:34:22:850:[ 1.500467] cadence-qspi 47050000.spi: error (____ptrval____): No Rx DMA available
    line 438: 20230524_14:34:22:850:[ 1.517669] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    line 439: 20230524_14:34:22:851:[ 1.524533] spi-nor: probe of spi1.0 failed with error -2
    It seems no improvements:
    20230524_14:35:12:506:root@j784s4-evm:~# ls /dev/mt* -al
    20230524_14:35:12:534:ls: cannot access '/dev/mt*': No such file or directory
    Thanks and regards,
    Cherry
  • Cherry,
    Thanks for the feedback. This confirms that the above workaround is not helping. We will wait for the fix in the next SDK version from the internal team.
    Keerthy
