Part Number: TDA2SX
Other Parts Discussed in Thread: AM5728
we are using AM5728 in a custom board and board is booted using mSATA. we are getting following error after booting-
after this error system gets hanged and we are not able to use it until we restart.
����r�������
��XL�ꗘ0: exception Emask 0x0 SAct 0xff800 SErr 0x0 action 0x6 frozen
[11702.519808] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.525499] ata1.00: cmd 61/08:58:c0:6a:a3/00:00:06:00:00/40 tag 11 ncq dma 4096 out
[11702.525499] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.540938] ata1.00: status: { DRDY }
[11702.545209] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.550547] ata1.00: cmd 61/08:60:c8:6a:a3/00:00:06:00:00/40 tag 12 ncq dma 4096 out
[11702.550547] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.566714] ata1.00: status: { DRDY }
[11702.570397] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.576509] ata1.00: cmd 61/08:68:d0:6a:a3/00:00:06:00:00/40 tag 13 ncq dma 4096 out
[11702.576509] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.592478] ata1.00: status: { DRDY }
[11702.596164] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.601524] ata1.00: cmd 61/38:70:60:30:04/00:00:00:00:00/40 tag 14 ncq dma 28672 out
[11702.601524] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.617390] ata1.00: status: { DRDY }
[11702.621178] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.627266] ata1.00: cmd 61/01:78:01:08:00/00:00:00:00:00/40 tag 15 ncq dma 512 out
[11702.627266] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.643127] ata1.00: status: { DRDY }
[11702.646923] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.652182] ata1.00: cmd 61/08:80:10:38:02/00:00:00:00:00/40 tag 16 ncq dma 4096 out
[11702.652182] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.668372] ata1.00: status: { DRDY }
[11702.672134] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.678302] ata1.00: cmd 61/10:88:00:38:5e/00:00:03:00:00/40 tag 17 ncq dma 8192 out
[11702.678302] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.693853] ata1.00: status: { DRDY }
[11702.697538] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.703089] ata1.00: cmd 61/08:90:a0:38:5e/00:00:03:00:00/40 tag 18 ncq dma 4096 out
[11702.703089] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.718990] ata1.00: status: { DRDY }
[11702.723727] ata1.00: failed command: WRITE FPDMA QUEUED
[11702.728987] ata1.00: cmd 61/08:98:78:49:5e/00:00:03:00:00/40 tag 19 ncq dma 4096 out
[11702.728987] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[11702.745208] ata1.00: status: { DRDY }
[11702.748897] ata1: hard resetting link
[11703.252276] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[11708.312270] ata1.00: qc timeout (cmd 0xec)
[11708.316652] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[11708.323696] ata1.00: revalidation failed (errno=-5)
[11708.328716] ata1: hard resetting link
[11708.832272] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[11718.872271] ata1.00: qc timeout (cmd 0xec)
[11718.876401] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[11718.883109] ata1.00: revalidation failed (errno=-5)
[11718.889491] ata1: limiting SATA link speed to 1.5 Gbps
[11718.895105] ata1: hard resetting link
[11719.392638] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[11723.142274] omapdrm omapdrm.0: atomic complete timeout (pipe 0)!
[11749.592285] ata1.00: qc timeout (cmd 0xec)
[11749.596417] ata1.00: failed to IDENTIFY (I/O error, err_mask=0x4)
[11749.603394] ata1.00: revalidation failed (errno=-5)
[11749.608365] ata1.00: disabled
[11750.112274] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[11750.118691] ata1: EH complete
[11750.121736] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.132145] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x2a 2a 00 06 a3 6a c0 00 00 08 00
[11750.141180] print_req_error: I/O error, dev sda, sector 111372992
[11750.147471] EXT4-fs warning (device sda2): ext4_end_bio:321: I/O error 10 writing to inode 3473720 (offset 0 size 4096 starting block 13921624)
[11750.161284] Buffer I/O error on device sda2, logical block 13903448
[11750.167782] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.177597] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x2a 2a 00 06 a3 6a c8 00 00 08 00
[11750.186185] print_req_error: I/O error, dev sda, sector 111373000
[11750.192476] EXT4-fs warning (device sda2): ext4_end_bio:321: I/O error 10 writing to inode 1763649 (offset 0 size 4096 starting block 13921625)
[11750.207267] Buffer I/O error on device sda2, logical block 13903449
[11750.213809] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.223574] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x2a 2a 00 06 a3 6a d0 00 00 08 00
[11750.231330] print_req_error: I/O error, dev sda, sector 111373008
[11750.238938] EXT4-fs warning (device sda2): ext4_end_bio:321: I/O error 10 writing to inode 1763650 (offset 0 size 4096 starting block 13921626)
[11750.252644] Buffer I/O error on device sda2, logical block 13903450
[11750.259026] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.262282] JBD2: Detected IO errors while flushing file data on sda2-8
[11750.275274] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x2a 2a 00 00 04 30 60 00 00 38 00
[11750.283819] print_req_error: I/O error, dev sda, sector 274528
[11750.290252] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.291419] Aborting journal on device sda2-8.
[11750.291503] EXT4-fs error (device sda2) in ext4_free_blocks:4942: Journal has aborted
[11750.313195] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x2a 2a 00 00 00 08 01 00 00 01 00
[11750.321440] print_req_error: I/O error, dev sda, sector 2049
[11750.328212] Buffer I/O error on dev sda1, logical block 1, lost async page write
[11750.336328] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.345485] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x2a 2a 00 00 02 68 48 00 00 08 00
[11750.353799] print_req_error: I/O error, dev sda, sector 157768
[11750.359665] print_req_error: I/O error, dev sda, sector 157768
[11750.365599] Buffer I/O error on dev sda2, logical block 1545, lost sync page write
[11750.373254] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.376347] JBD2: Error -5 detected when updating journal superblock for sda2-8.
[11750.389662] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x2a 2a 00 00 02 38 00 00 00 08 00
[11750.397356] print_req_error: I/O error, dev sda, sector 145408
[11750.403799] print_req_error: I/O error, dev sda, sector 145408
[11750.409664] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[11750.417758] EXT4-fs (sda2): I/O error while writing superblock
[11750.426517] EXT4-fs error (device sda2) in ext4_reserve_inode_write:5921: Journal has aborted
[11750.431309] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.431320] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x2a 2a 00 00 02 38 10 00 00 08 00
[11750.431327] print_req_error: I/O error, dev sda, sector 145424
[11750.431334] Buffer I/O error on dev sda2, logical block 2, lost async page write
[11750.431368] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.431379] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x2a 2a 00 03 5e 38 00 00 00 10 00
[11750.431386] Buffer I/O error on dev sda2, logical block 7045120, lost async page write
[11750.431398] Buffer I/O error on dev sda2, logical block 7045121, lost async page write
[11750.431424] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11750.431434] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 00 03 5e 38 a0 00 00 08 00
[11750.431441] Buffer I/O error on dev sda2, logical block 7045140, lost async page write
[11750.431462] Buffer I/O error on dev sda2, logical block 7045679, lost async page write
[11750.539184] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[11750.547402] EXT4-fs (sda2): I/O error while writing superblock
[11750.553431] EXT4-fs error (device sda2) in ext4_orphan_del:2934: Journal has aborted
[11750.561787] Buffer I/O error on dev sda2, logical block 0, lost sync page write
[11750.569606] EXT4-fs (sda2): I/O error while writing superblock
[11750.576402] EXT4-fs error (device sda2) in ext4_reserve_inode_write:5921: Journal has aborted
[11750.585260] EXT4-fs (sda2): I/O error while writing superblock
[11750.591961] EXT4-fs error (device sda2) in ext4_truncate:4568: Journal has aborted
[11750.599974] EXT4-fs (sda2): I/O error while writing superblock
[11750.606182] EXT4-fs (sda2): I/O error while writing superblock
[11750.612048] EXT4-fs error (device sda2): ext4_journal_check_start:61: Detected aborted journal
[11750.621129] EXT4-fs (sda2): Remounting filesystem read-only
[11750.627623] EXT4-fs (sda2): I/O error while writing superblock
[11755.194788] scsi_io_completion_action: 149 callbacks suppressed
[11755.194805] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.209173] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11755.216921] print_req_error: 157 callbacks suppressed
[11755.216926] print_req_error: I/O error, dev sda, sector 44225864
[11755.229039] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.237350] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11755.245791] print_req_error: I/O error, dev sda, sector 44225864
[11755.252323] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.261147] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11755.268958] print_req_error: I/O error, dev sda, sector 44225832
[11755.275743] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.284149] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11755.291903] print_req_error: I/O error, dev sda, sector 44225832
[11755.428618] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.437369] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11755.445471] print_req_error: I/O error, dev sda, sector 44225864
[11755.451845] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.460637] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11755.468298] print_req_error: I/O error, dev sda, sector 44225864
[11755.475149] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.483490] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11755.491560] print_req_error: I/O error, dev sda, sector 44225832
[11755.498002] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.506339] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11755.514187] print_req_error: I/O error, dev sda, sector 44225832
[11755.642440] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.651278] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11755.658889] print_req_error: I/O error, dev sda, sector 44225864
[11755.665302] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11755.673608] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11755.681215] print_req_error: I/O error, dev sda, sector 44225864
[11760.277734] scsi_io_completion_action: 150 callbacks suppressed
[11760.277751] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.292615] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11760.300285] print_req_error: 150 callbacks suppressed
[11760.300290] print_req_error: I/O error, dev sda, sector 44225864
[11760.311787] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.320011] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11760.328159] print_req_error: I/O error, dev sda, sector 44225864
[11760.334554] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.343255] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11760.350903] print_req_error: I/O error, dev sda, sector 44225832
[11760.357903] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.366126] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11760.374259] print_req_error: I/O error, dev sda, sector 44225832
[11760.501974] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.510203] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11760.518344] print_req_error: I/O error, dev sda, sector 44225864
[11760.524713] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.533504] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11760.541169] print_req_error: I/O error, dev sda, sector 44225864
[11760.547556] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.555889] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11760.564210] print_req_error: I/O error, dev sda, sector 44225832
[11760.570561] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.579551] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11760.587195] print_req_error: I/O error, dev sda, sector 44225832
[11760.712118] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.720456] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11760.728574] print_req_error: I/O error, dev sda, sector 44225864
[11760.734997] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11760.743709] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11760.751555] print_req_error: I/O error, dev sda, sector 44225864
[11765.363130] scsi_io_completion_action: 150 callbacks suppressed
[11765.363147] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.377991] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11765.386040] print_req_error: 150 callbacks suppressed
[11765.386045] print_req_error: I/O error, dev sda, sector 44225864
[11765.397576] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.406365] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11765.413973] print_req_error: I/O error, dev sda, sector 44225864
[11765.420850] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.429104] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11765.437267] print_req_error: I/O error, dev sda, sector 44225832
[11765.443726] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.452065] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11765.459764] print_req_error: I/O error, dev sda, sector 44225832
[11765.583601] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.591931] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11765.600031] print_req_error: I/O error, dev sda, sector 44225864
[11765.606399] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.615291] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11765.623084] print_req_error: I/O error, dev sda, sector 44225864
[11765.629438] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.637840] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11765.646238] print_req_error: I/O error, dev sda, sector 44225832
[11765.652620] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.661575] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11765.669426] print_req_error: I/O error, dev sda, sector 44225832
[11765.796620] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.805060] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11765.813336] print_req_error: I/O error, dev sda, sector 44225864
[11765.819706] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11765.828131] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11765.835827] print_req_error: I/O error, dev sda, sector 44225864
[11770.441032] scsi_io_completion_action: 150 callbacks suppressed
[11770.441049] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.456124] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11770.464234] print_req_error: 150 callbacks suppressed
[11770.464239] print_req_error: I/O error, dev sda, sector 44225864
[11770.475770] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.484682] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11770.492378] print_req_error: I/O error, dev sda, sector 44225864
[11770.499246] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.507639] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11770.515793] print_req_error: I/O error, dev sda, sector 44225832
[11770.522307] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.530754] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11770.538448] print_req_error: I/O error, dev sda, sector 44225832
[11770.663020] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.671880] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11770.679630] print_req_error: I/O error, dev sda, sector 44225864
[11770.686253] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.694592] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11770.702340] print_req_error: I/O error, dev sda, sector 44225864
[11770.709143] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.718262] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11770.725989] print_req_error: I/O error, dev sda, sector 44225832
[11770.732386] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.741129] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11770.748870] print_req_error: I/O error, dev sda, sector 44225832
[11770.879977] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.888289] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11770.896606] print_req_error: I/O error, dev sda, sector 44225864
[11770.903053] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11770.911861] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11770.919650] print_req_error: I/O error, dev sda, sector 44225864
[11775.522894] scsi_io_completion_action: 150 callbacks suppressed
[11775.522910] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.537742] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11775.545525] print_req_error: 150 callbacks suppressed
[11775.545531] print_req_error: I/O error, dev sda, sector 44225864
[11775.557653] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.566051] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11775.573785] print_req_error: I/O error, dev sda, sector 44225864
[11775.580234] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.589172] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11775.596868] print_req_error: I/O error, dev sda, sector 44225832
[11775.611675] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.620497] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11775.628287] print_req_error: I/O error, dev sda, sector 44225832
[11775.753668] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.762574] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11775.770360] print_req_error: I/O error, dev sda, sector 44225864
[11775.777375] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.785728] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11775.794111] print_req_error: I/O error, dev sda, sector 44225864
[11775.800462] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.808843] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11775.817024] print_req_error: I/O error, dev sda, sector 44225832
[11775.823454] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.831873] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11775.839811] print_req_error: I/O error, dev sda, sector 44225832
[11775.966776] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.975756] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11775.983451] print_req_error: I/O error, dev sda, sector 44225864
[11775.990018] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11775.998439] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11776.006611] print_req_error: I/O error, dev sda, sector 44225864
[11780.556238] scsi_io_completion_action: 146 callbacks suppressed
[11780.556255] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.571162] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11780.579089] print_req_error: 146 callbacks suppressed
[11780.579094] print_req_error: I/O error, dev sda, sector 44225864
[11780.591185] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.600022] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11780.607809] print_req_error: I/O error, dev sda, sector 44225864
[11780.614765] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.623075] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11780.630893] print_req_error: I/O error, dev sda, sector 44225832
[11780.637270] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.646099] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11780.653933] print_req_error: I/O error, dev sda, sector 44225832
[11780.786425] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.794849] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11780.804240] print_req_error: I/O error, dev sda, sector 44225864
[11780.810769] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.819679] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11780.827375] print_req_error: I/O error, dev sda, sector 44225864
[11780.833822] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.842856] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11780.850549] print_req_error: I/O error, dev sda, sector 44225832
[11780.856946] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11780.865799] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11780.874077] print_req_error: I/O error, dev sda, sector 44225832
[11781.004189] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11781.012597] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11781.020813] print_req_error: I/O error, dev sda, sector 44225864
[11781.027232] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11781.036168] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11781.043862] print_req_error: I/O error, dev sda, sector 44225864
[11785.667230] scsi_io_completion_action: 150 callbacks suppressed
[11785.667247] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.682108] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11785.689804] print_req_error: 150 callbacks suppressed
[11785.689809] print_req_error: I/O error, dev sda, sector 44225864
[11785.701853] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.710363] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11785.718153] print_req_error: I/O error, dev sda, sector 44225864
[11785.724988] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.733343] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11785.741539] print_req_error: I/O error, dev sda, sector 44225832
[11785.747887] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.756812] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11785.764582] print_req_error: I/O error, dev sda, sector 44225832
[11785.895490] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.905514] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11785.913303] print_req_error: I/O error, dev sda, sector 44225864
[11785.920224] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.928535] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11785.936953] print_req_error: I/O error, dev sda, sector 44225864
[11785.946186] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.954500] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11785.962271] print_req_error: I/O error, dev sda, sector 44225832
[11785.969205] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11785.977515] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11785.985841] print_req_error: I/O error, dev sda, sector 44225832
[11786.112524] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11786.120898] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11786.129172] print_req_error: I/O error, dev sda, sector 44225864
[11786.135542] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11786.144348] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11786.152133] print_req_error: I/O error, dev sda, sector 44225864
[11790.759621] scsi_io_completion_action: 150 callbacks suppressed
[11790.759639] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11790.774453] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11790.782265] print_req_error: 150 callbacks suppressed
[11790.782270] print_req_error: I/O error, dev sda, sector 44225864
[11790.799490] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11790.808469] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11790.816315] print_req_error: I/O error, dev sda, sector 44225864
[11790.823191] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11790.831596] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11790.839786] print_req_error: I/O error, dev sda, sector 44225832
[11790.846135] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11790.855010] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11790.862749] print_req_error: I/O error, dev sda, sector 44225832
[11790.988387] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11790.996833] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11791.006205] print_req_error: I/O error, dev sda, sector 44225864
[11791.013083] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11791.021399] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11791.029006] print_req_error: I/O error, dev sda, sector 44225864
[11791.035417] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11791.043734] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11791.051858] print_req_error: I/O error, dev sda, sector 44225832
[11791.058262] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11791.067041] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11791.074649] print_req_error: I/O error, dev sda, sector 44225832
[11791.199697] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11791.207969] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11791.215695] print_req_error: I/O error, dev sda, sector 44225864
[11791.222060] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11791.230682] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11791.238781] print_req_error: I/O error, dev sda, sector 44225864
[11794.661374] systemd-coredump[19305]: Configuration file /etc/systemd/coredump.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[11794.707600] systemd-coredump[19304]: Configuration file /etc/systemd/coredump.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[11795.789690] scsi_io_completion_action: 146 callbacks suppressed
[11795.789706] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11795.804675] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11795.812449] print_req_error: 146 callbacks suppressed
[11795.812455] print_req_error: I/O error, dev sda, sector 44225864
[11795.824612] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11795.833060] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11795.841264] print_req_error: I/O error, dev sda, sector 44225864
[11795.850417] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11795.858891] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11795.866688] print_req_error: I/O error, dev sda, sector 44225832
[11795.873053] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11795.881406] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11795.889559] print_req_error: I/O error, dev sda, sector 44225832
[11796.018018] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11796.026433] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11796.034127] print_req_error: I/O error, dev sda, sector 44225864
[11796.040510] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11796.049338] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11796.056945] print_req_error: I/O error, dev sda, sector 44225864
[11796.063982] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11796.072321] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11796.080465] print_req_error: I/O error, dev sda, sector 44225832
[11796.086848] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11796.095614] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11796.104287] print_req_error: I/O error, dev sda, sector 44225832
[11796.242427] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11796.250754] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11796.258838] print_req_error: I/O error, dev sda, sector 44225864
[11796.267238] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11796.275985] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11796.283594] print_req_error: I/O error, dev sda, sector 44225864
[11800.911849] scsi_io_completion_action: 146 callbacks suppressed
[11800.911865] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11800.926694] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11800.934496] print_req_error: 146 callbacks suppressed
[11800.934501] print_req_error: I/O error, dev sda, sector 44225864
[11800.946547] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11800.954987] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11800.963218] print_req_error: I/O error, dev sda, sector 44225864
[11800.969646] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11800.978584] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11800.986280] print_req_error: I/O error, dev sda, sector 44225832
[11800.992673] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11801.000927] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11801.009093] print_req_error: I/O error, dev sda, sector 44225832
[11801.139085] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11801.147435] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11801.155045] print_req_error: I/O error, dev sda, sector 44225864
[11801.161458] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11801.170285] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11801.177902] print_req_error: I/O error, dev sda, sector 44225864
[11801.184849] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11801.193203] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11801.201298] print_req_error: I/O error, dev sda, sector 44225832
[11801.208777] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11801.217630] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11801.225238] print_req_error: I/O error, dev sda, sector 44225832
[11801.352657] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11801.361487] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11801.369097] print_req_error: I/O error, dev sda, sector 44225864
[11801.376047] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11801.384315] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11801.392395] print_req_error: I/O error, dev sda, sector 44225864
[11805.924972] scsi_io_completion_action: 146 callbacks suppressed
[11805.924989] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11805.939904] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11805.947704] print_req_error: 146 callbacks suppressed
[11805.947709] print_req_error: I/O error, dev sda, sector 44225864
[11805.959778] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11805.968117] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11805.975891] print_req_error: I/O error, dev sda, sector 44225864
[11805.982759] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11805.991530] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11805.999196] print_req_error: I/O error, dev sda, sector 44225832
[11806.006856] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11806.015522] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11806.023774] print_req_error: I/O error, dev sda, sector 44225832
[11806.158100] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11806.166728] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11806.174806] print_req_error: I/O error, dev sda, sector 44225864
[11806.181528] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11806.189856] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11806.197463] print_req_error: I/O error, dev sda, sector 44225864
[11806.204356] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11806.212695] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11806.220779] print_req_error: I/O error, dev sda, sector 44225832
[11806.227178] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11806.235946] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11806.243554] print_req_error: I/O error, dev sda, sector 44225832
[11806.369993] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11806.378765] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11806.386484] print_req_error: I/O error, dev sda, sector 44225864
[11806.392857] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11806.401386] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11806.409266] print_req_error: I/O error, dev sda, sector 44225864
[11810.193496] systemd-coredump[19320]: Configuration file /etc/systemd/coredump.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[11811.053822] scsi_io_completion_action: 150 callbacks suppressed
[11811.053839] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.068822] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11811.076500] print_req_error: 150 callbacks suppressed
[11811.076505] print_req_error: I/O error, dev sda, sector 44225864
[11811.090928] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.099723] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11811.107332] print_req_error: I/O error, dev sda, sector 44225864
[11811.113740] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.121962] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11811.130148] print_req_error: I/O error, dev sda, sector 44225832
[11811.136584] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.145324] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11811.153312] print_req_error: I/O error, dev sda, sector 44225832
[11811.281786] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.290486] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11811.298189] print_req_error: I/O error, dev sda, sector 44225864
[11811.305222] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.313570] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11811.321749] print_req_error: I/O error, dev sda, sector 44225864
[11811.328105] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.336949] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11811.344621] print_req_error: I/O error, dev sda, sector 44225832
[11811.350978] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.359372] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11811.367779] print_req_error: I/O error, dev sda, sector 44225832
[11811.497500] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.505869] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11811.513622] print_req_error: I/O error, dev sda, sector 44225864
[11811.519987] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11811.528632] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11811.536866] print_req_error: I/O error, dev sda, sector 44225864
[11816.142624] scsi_io_completion_action: 150 callbacks suppressed
[11816.142640] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.157079] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11816.165317] print_req_error: 150 callbacks suppressed
[11816.165323] print_req_error: I/O error, dev sda, sector 44225864
[11816.176877] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.185570] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11816.193280] print_req_error: I/O error, dev sda, sector 44225864
[11816.202659] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.211020] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11816.219241] print_req_error: I/O error, dev sda, sector 44225832
[11816.225689] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.234026] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11816.241819] print_req_error: I/O error, dev sda, sector 44225832
[11816.365601] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.374509] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11816.382359] print_req_error: I/O error, dev sda, sector 44225864
[11816.388728] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.397102] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11816.404864] print_req_error: I/O error, dev sda, sector 44225864
[11816.411695] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.420109] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11816.428614] print_req_error: I/O error, dev sda, sector 44225832
[11816.434974] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.443961] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11816.451715] print_req_error: I/O error, dev sda, sector 44225832
[11816.582306] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.590982] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11816.599256] print_req_error: I/O error, dev sda, sector 44225864
[11816.605891] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11816.614289] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11816.622481] print_req_error: I/O error, dev sda, sector 44225864
[11821.221831] scsi_io_completion_action: 150 callbacks suppressed
[11821.221848] sd 0:0:0:0: [sda] tag#13 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.236945] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11821.244639] print_req_error: 150 callbacks suppressed
[11821.244644] print_req_error: I/O error, dev sda, sector 44225864
[11821.256607] sd 0:0:0:0: [sda] tag#14 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.265085] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11821.272802] print_req_error: I/O error, dev sda, sector 44225864
[11821.279943] sd 0:0:0:0: [sda] tag#15 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.288342] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11821.296495] print_req_error: I/O error, dev sda, sector 44225832
[11821.302955] sd 0:0:0:0: [sda] tag#16 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.311372] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11821.319068] print_req_error: I/O error, dev sda, sector 44225832
[11821.451601] sd 0:0:0:0: [sda] tag#17 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.460058] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11821.467842] print_req_error: I/O error, dev sda, sector 44225864
[11821.474212] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.483108] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11821.490887] print_req_error: I/O error, dev sda, sector 44225864
[11821.497237] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.506141] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11821.514701] print_req_error: I/O error, dev sda, sector 44225832
[11821.521059] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.529491] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11821.537676] print_req_error: I/O error, dev sda, sector 44225832
[11821.661942] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.670343] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11821.678522] print_req_error: I/O error, dev sda, sector 44225864
[11821.684965] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11821.693833] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11821.701559] print_req_error: I/O error, dev sda, sector 44225864
[11826.321398] scsi_io_completion_action: 150 callbacks suppressed
[11826.321415] sd 0:0:0:0: [sda] tag#18 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.336672] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11826.344689] print_req_error: 150 callbacks suppressed
[11826.344694] print_req_error: I/O error, dev sda, sector 44225864
[11826.356225] sd 0:0:0:0: [sda] tag#19 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.365217] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11826.373006] print_req_error: I/O error, dev sda, sector 44225864
[11826.379833] sd 0:0:0:0: [sda] tag#20 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.388194] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11826.396473] print_req_error: I/O error, dev sda, sector 44225832
[11826.402820] sd 0:0:0:0: [sda] tag#21 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.411263] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11826.418956] print_req_error: I/O error, dev sda, sector 44225832
[11826.542537] sd 0:0:0:0: [sda] tag#22 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.551330] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11826.559073] print_req_error: I/O error, dev sda, sector 44225864
[11826.565519] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.573873] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11826.581683] print_req_error: I/O error, dev sda, sector 44225864
[11826.588519] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.596930] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11826.605150] print_req_error: I/O error, dev sda, sector 44225832
[11826.612555] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.621422] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11826.629162] print_req_error: I/O error, dev sda, sector 44225832
[11826.753544] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.762459] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11826.770214] print_req_error: I/O error, dev sda, sector 44225864
[11826.778128] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11826.786591] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11826.794991] print_req_error: I/O error, dev sda, sector 44225864
[11831.439704] scsi_io_completion_action: 150 callbacks suppressed
[11831.439720] sd 0:0:0:0: [sda] tag#23 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.454568] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11831.462358] print_req_error: 150 callbacks suppressed
[11831.462363] print_req_error: I/O error, dev sda, sector 44225864
[11831.473981] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.482889] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11831.490622] print_req_error: I/O error, dev sda, sector 44225864
[11831.497051] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.505822] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11831.513578] print_req_error: I/O error, dev sda, sector 44225832
[11831.520516] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.528826] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11831.537143] print_req_error: I/O error, dev sda, sector 44225832
[11831.665444] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.673757] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11831.682083] print_req_error: I/O error, dev sda, sector 44225864
[11831.688457] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.697294] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11831.705035] print_req_error: I/O error, dev sda, sector 44225864
[11831.711430] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.719789] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11831.728115] print_req_error: I/O error, dev sda, sector 44225832
[11831.734460] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.743305] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11831.751028] print_req_error: I/O error, dev sda, sector 44225832
[11831.878111] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.886388] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11831.893995] print_req_error: I/O error, dev sda, sector 44225864
[11831.900400] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11831.909059] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11831.917023] print_req_error: I/O error, dev sda, sector 44225864
[11834.184754] systemd-coredump[19323]: Configuration file /etc/systemd/coredump.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[11836.515686] scsi_io_completion_action: 146 callbacks suppressed
[11836.515703] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.530509] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11836.538269] print_req_error: 146 callbacks suppressed
[11836.538274] print_req_error: I/O error, dev sda, sector 44225864
[11836.552415] sd 0:0:0:0: [sda] tag#25 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.561360] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11836.569085] print_req_error: I/O error, dev sda, sector 44225864
[11836.576036] sd 0:0:0:0: [sda] tag#26 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.584347] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11836.592125] print_req_error: I/O error, dev sda, sector 44225832
[11836.598534] sd 0:0:0:0: [sda] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.607438] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11836.615325] print_req_error: I/O error, dev sda, sector 44225832
[11836.747951] sd 0:0:0:0: [sda] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.756404] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11836.764813] print_req_error: I/O error, dev sda, sector 44225864
[11836.771186] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.780156] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11836.787852] print_req_error: I/O error, dev sda, sector 44225864
[11836.794292] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.803214] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11836.810907] print_req_error: I/O error, dev sda, sector 44225832
[11836.817898] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.826193] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11836.833840] print_req_error: I/O error, dev sda, sector 44225832
[11836.956365] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.964701] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11836.972850] print_req_error: I/O error, dev sda, sector 44225864
[11836.979216] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11836.987553] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11836.995313] print_req_error: I/O error, dev sda, sector 44225864
[11841.597772] scsi_io_completion_action: 150 callbacks suppressed
[11841.597788] sd 0:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.612581] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11841.620848] print_req_error: 150 callbacks suppressed
[11841.620854] print_req_error: I/O error, dev sda, sector 44225864
[11841.637639] sd 0:0:0:0: [sda] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.645951] sd 0:0:0:0: [sda] tag#30 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11841.653745] print_req_error: I/O error, dev sda, sector 44225864
[11841.660112] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.668901] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11841.676675] print_req_error: I/O error, dev sda, sector 44225832
[11841.683514] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.691800] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11841.699952] print_req_error: I/O error, dev sda, sector 44225832
[11841.823147] sd 0:0:0:0: [sda] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.831373] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11841.839087] print_req_error: I/O error, dev sda, sector 44225864
[11841.846040] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.854263] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11841.862453] print_req_error: I/O error, dev sda, sector 44225864
[11841.868894] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.877763] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11841.885475] print_req_error: I/O error, dev sda, sector 44225832
[11841.892628] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11841.900851] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11841.908490] print_req_error: I/O error, dev sda, sector 44225832
[11842.035625] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11842.043937] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11842.052194] print_req_error: I/O error, dev sda, sector 44225864
[11842.058566] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11842.066851] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11842.074548] print_req_error: I/O error, dev sda, sector 44225864
[11846.685161] scsi_io_completion_action: 150 callbacks suppressed
[11846.685179] sd 0:0:0:0: [sda] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.699486] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11846.707768] print_req_error: 150 callbacks suppressed
[11846.707773] print_req_error: I/O error, dev sda, sector 44225864
[11846.719714] sd 0:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.728018] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11846.736254] print_req_error: I/O error, dev sda, sector 44225864
[11846.745620] sd 0:0:0:0: [sda] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.753960] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11846.761627] print_req_error: I/O error, dev sda, sector 44225832
[11846.768523] sd 0:0:0:0: [sda] tag#6 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.776819] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11846.785012] print_req_error: I/O error, dev sda, sector 44225832
[11846.908325] sd 0:0:0:0: [sda] tag#7 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.916550] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11846.924767] print_req_error: I/O error, dev sda, sector 44225864
[11846.931195] sd 0:0:0:0: [sda] tag#8 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.939440] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11846.947597] print_req_error: I/O error, dev sda, sector 44225864
[11846.954028] sd 0:0:0:0: [sda] tag#9 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.962687] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11846.970369] print_req_error: I/O error, dev sda, sector 44225832
[11846.977223] sd 0:0:0:0: [sda] tag#10 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11846.985697] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 02 a2 d5 28 00 00 08 00
[11846.993501] print_req_error: I/O error, dev sda, sector 44225832
[11847.118581] sd 0:0:0:0: [sda] tag#11 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11847.126963] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11847.135340] print_req_error: I/O error, dev sda, sector 44225864
[11847.141709] sd 0:0:0:0: [sda] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=0x00
[11847.150118] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 02 a2 d5 48 00 00 08 00
[11847.157935] print_req_error: I/O error, dev sda, sector 44225864
Please help to resovle the issue.
Vijay
