Dear TI experts
After I modified the DPC to the maximum value and compiled the bin, I still can’t see the improvement effect, I hope to get help, During my objective standard test, there are a lot of dead pixels in a pure black environment, and the fixed-position highlight does not exist in a bright environment. The dirt on the lens and module is ruled out. I hope to use dead pixel correction to eliminate these dead pixels, thank you
Hi Li Liu,
Could you please check and confirm that OTF DPC is enabled in the application, ie in viss_params?
Brijesh
Hi Li Liu,
Are you checking the DPC in DCC application? or are you using generated xml files on target and running single/multi camera application?
Brijesh
Hello
After confirming the process, I modified the AWB parameters in the DDC tool to take effect
