AM6442: How to enable and configure DMTIMER in linux.
Part Number: AM6442
I'm writing a driver that uses DMTIMER, I couldn't find any node in device tree that configure Timer in k3-am64-main.dtsi file.
Could you please refer me to any doc or link where its shows how to setup timer in device tree and how I can use it in my driver?
I tried to find out some details from below link but haven't found anything related to TIMERS
3.2. Kernel — Processor SDK AM64X Documentation
  • Hello Abdul,
    Apologies in delayed responses due to TI India Holiday.
    Please expect responses within a day.
    Vaibhav
    ARM Based Processors | FAQ AM62x & AM62A | FAQ AM64x
  • I have found the solution for this one. But I think timer-ti-dm driver is available to use. But I want to know how can I access omap_timer  functions pointer in another driver ?
  • Hello Abdul,
    Many thanks for your response.
    Can you share a link with me, from where you got the reference to add timers?
    Also, please look at the recommended approach to add DM Timers.
    • You can open up the SysConfig tool and select device as "AM64x"
    • Once done you can simply head over to "TIMER" section, add a DM Timer.
    • Select the pin you want to enable out of the available options.
    • Head over to the generated files section and make use of the file "devicetree.dtsi"
    • Please have a look at the screenshot below to have a good understanding of the above points.
    Make sure to keep in mind, while you are assigning pins, do not account for resource conflict. Many times the pins you choose might be already in use.
    So please make sure to keep a check on it. On MCU PLUS SDK, SysConfig does this for you, but the device tree source files don't.
    Also, for your follow up question, on omap_timer functions, can you clarify a little bit more?
    Vaibhav
  • Hi Vaibhav,
    Actually, I'm not using ti-linux, rather using Linux from their original website v6.1.22.  So, in that version  main_timers node wasn't there in k3-am64-main.dtsi file. So, I copied from ti-linux. Also enabled the "OMAP_DM_TIMER" in linux, whihc compile omap_timer driver.
    I need to write a driver that uses timers 2-9 for pulse inputs and outputs. How can I access these timers in my driver?
    If I use omap_timer driver than how can I use it to get access all the timer 2-9.
  • Hello Abdul,
    Thanks for your response.
    I have understood your point here. In the dtsi file itself apart from dm timer you have also enabled the omap_dm_timer.
    Can you share me the dtsi file here or over mail?
    I need to look at a couple of thngs.
    Post this, I will try figuring out if we can use the omap_timer driver to access the dm timers numbered 2 till 9.
    Vaibhav
  • Hello Abdul,
    On a side note, I am referring to this website: https://elixir.bootlin.com/linux/v6.1.22/source/arch/arm64/boot/dts/ti/k3-am64-main.dtsi
    Is there another website you are following ?
    Vaibhav
  • Yes I'm using the same website
  • Here is my main dts file where timers nodes are enabled
    &main_timer5 {
    status = "okay";
    compatible = "elpro,el-pulse-in1";
    pintctrl-names = "default";
    pintctrl-0 = <&hsin1_pins_default>;
    &main_timer4 {
    status = "okay";
    compatible = "elpro,el-pulse-in2";
    pintctrl-0 = <&hsin2_pins_default>;
    &main_timer3 {
    status = "okay";
    compatible = "elpro,el-pulse-in3";
    pintctrl-0 = <&hsin3_pins_default>;
    &main_timer2 {
    status = "okay";
    compatible = "elpro,el-pulse-in4";
    pintctrl-0 = <&hsin4_pins_default>;
  • Here is my k3-am64-main.dtsi
    // SPDX-License-Identifier: GPL-2.0
    * Device Tree Source for AM642 SoC Family Main Domain peripherals
    * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/
    #include <dt-bindings/phy/phy-cadence.h>
    #include <dt-bindings/phy/phy-ti.h>
    serdes_refclk: clock-cmnrefclk {
    #clock-cells = <0>;
    compatible = "fixed-clock";
    clock-frequency = <0>;
    &cbass_main {
    oc_sram: sram@70000000 {
    compatible = "mmio-sram";
    reg = <0x00 0x70000000 0x00 0x200000>;
    #address-cells = <1>;
    #size-cells = <1>;
    ranges = <0x0 0x00 0x70000000 0x200000>;
    tfa-sram@1c0000 {
    reg = <0x1c0000 0x20000>;
    dmsc-sram@1e0000 {
    reg = <0x1e0000 0x1c000>;
    sproxy-sram@1fc000 {
    reg = <0x1fc000 0x4000>;
    main_conf: syscon@43000000 {
    compatible = "ti,j721e-system-controller", "syscon", "simple-mfd";
    reg = <0x0 0x43000000 0x0 0x20000>;
    #size-cells = <1>;
    ranges = <0x0 0x0 0x43000000 0x20000>;
    serdes_ln_ctrl: mux-controller {
    compatible = "mmio-mux";
    #mux-control-cells = <1>;
    mux-reg-masks = <0x4080 0x3>; /* SERDES0 lane0 select */
    gic500: interrupt-controller@1800000 {
    compatible = "arm,gic-v3";
    #address-cells = <2>;
    #size-cells = <2>;
    ranges;
    #interrupt-cells = <3>;
    interrupt-controller;
    reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */
    <0x00 0x01840000 0x00 0xC0000>, /* GICR */
    <0x01 0x00000000 0x00 0x2000>, /* GICC */
    <0x01 0x00010000 0x00 0x1000>, /* GICH */
    <0x01 0x00020000 0x00 0x2000>; /* GICV */
    * vcpumntirq:
    * virtual CPU interface maintenance interrupt
    interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>;
    gic_its: msi-controller@1820000 {
    compatible = "arm,gic-v3-its";
    reg = <0x00 0x01820000 0x00 0x10000>;
    socionext,synquacer-pre-its = <0x1000000 0x400000>;
    msi-controller;
    #msi-cells = <1>;
    dmss: bus@48000000 {
    compatible = "simple-mfd";
    #size-cells = <2>;
    dma-ranges;
    ranges = <0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>;
    ti,sci-dev-id = <25>;
    secure_proxy_main: mailbox@4d000000 {
    compatible = "ti,am654-secure-proxy";
    #mbox-cells = <1>;
    reg-names = "target_data", "rt", "scfg";
    reg = <0x00 0x4d000000 0x00 0x80000>,
    <0x00 0x4a600000 0x00 0x80000>,
    <0x00 0x4a400000 0x00 0x80000>;
    interrupt-names = "rx_012";
    interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
    inta_main_dmss: interrupt-controller@48000000 {
    compatible = "ti,sci-inta";
    reg = <0x00 0x48000000 0x00 0x100000>;
    #interrupt-cells = <0>;
    interrupt-parent = <&gic500>;
    msi-controller;
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <28>;
    ti,interrupt-ranges = <4 68 36>;
    ti,unmapped-event-sources = <&main_bcdma>, <&main_pktdma>;
    main_bcdma: dma-controller@485c0100 {
    compatible = "ti,am64-dmss-bcdma";
    reg = <0x00 0x485c0100 0x00 0x100>,
    <0x00 0x4c000000 0x00 0x20000>,
    <0x00 0x4a820000 0x00 0x20000>,
    <0x00 0x4aa40000 0x00 0x20000>,
    <0x00 0x4bc00000 0x00 0x100000>;
    reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt";
    msi-parent = <&inta_main_dmss>;
    #dma-cells = <3>;
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <26>;
    ti,sci-rm-range-bchan = <0x20>; /* BLOCK_COPY_CHAN */
    ti,sci-rm-range-rchan = <0x21>; /* SPLIT_TR_RX_CHAN */
    ti,sci-rm-range-tchan = <0x22>; /* SPLIT_TR_TX_CHAN */
    main_pktdma: dma-controller@485c0000 {
    compatible = "ti,am64-dmss-pktdma";
    reg = <0x00 0x485c0000 0x00 0x100>,
    <0x00 0x4a800000 0x00 0x20000>,
    <0x00 0x4aa00000 0x00 0x40000>,
    <0x00 0x4b800000 0x00 0x400000>;
    reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt";
    #dma-cells = <2>;
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <30>;
    ti,sci-rm-range-tchan = <0x23>, /* UNMAPPED_TX_CHAN */
    <0x24>, /* CPSW_TX_CHAN */
    <0x25>, /* SAUL_TX_0_CHAN */
    <0x26>, /* SAUL_TX_1_CHAN */
    <0x27>, /* ICSSG_0_TX_CHAN */
    <0x28>; /* ICSSG_1_TX_CHAN */
    ti,sci-rm-range-tflow = <0x10>, /* RING_UNMAPPED_TX_CHAN */
    <0x11>, /* RING_CPSW_TX_CHAN */
    <0x12>, /* RING_SAUL_TX_0_CHAN */
    <0x13>, /* RING_SAUL_TX_1_CHAN */
    <0x14>, /* RING_ICSSG_0_TX_CHAN */
    <0x15>; /* RING_ICSSG_1_TX_CHAN */
    ti,sci-rm-range-rchan = <0x29>, /* UNMAPPED_RX_CHAN */
    <0x2b>, /* CPSW_RX_CHAN */
    <0x2d>, /* SAUL_RX_0_CHAN */
    <0x2f>, /* SAUL_RX_1_CHAN */
    <0x31>, /* SAUL_RX_2_CHAN */
    <0x33>, /* SAUL_RX_3_CHAN */
    <0x35>, /* ICSSG_0_RX_CHAN */
    <0x37>; /* ICSSG_1_RX_CHAN */
    ti,sci-rm-range-rflow = <0x2a>, /* FLOW_UNMAPPED_RX_CHAN */
    <0x2c>, /* FLOW_CPSW_RX_CHAN */
    <0x2e>, /* FLOW_SAUL_RX_0/1_CHAN */
    <0x32>, /* FLOW_SAUL_RX_2/3_CHAN */
    <0x36>, /* FLOW_ICSSG_0_RX_CHAN */
    <0x38>; /* FLOW_ICSSG_1_RX_CHAN */
    dmsc: system-controller@44043000 {
    compatible = "ti,k2g-sci";
    ti,host-id = <12>;
    mbox-names = "rx", "tx";
    mboxes = <&secure_proxy_main 12>,
    <&secure_proxy_main 13>;
    reg-names = "debug_messages";
    reg = <0x00 0x44043000 0x00 0xfe0>;
    k3_pds: power-controller {
    compatible = "ti,sci-pm-domain";
    #power-domain-cells = <2>;
    k3_clks: clock-controller {
    compatible = "ti,k2g-sci-clk";
    #clock-cells = <2>;
    k3_reset: reset-controller {
    compatible = "ti,sci-reset";
    #reset-cells = <2>;
    main_pmx0: pinctrl@f4000 {
    compatible = "pinctrl-single";
    reg = <0x00 0xf4000 0x00 0x2d0>;
    #pinctrl-cells = <1>;
    pinctrl-single,register-width = <32>;
    pinctrl-single,function-mask = <0xffffffff>;
    compatible = "syscon", "simple-mfd";
    reg = <0x00 0x43000000 0x00 0x20000>;
    #size-cells = <1>;
    ranges = <0x00 0x00 0x43000000 0x20000>;
    chipid@14 {
    compatible = "ti,am654-chipid";
    reg = <0x00000014 0x4>;
    phy_gmii_sel: phy@4044 {
    compatible = "ti,am654-phy-gmii-sel";
    reg = <0x4044 0x8>;
    #phy-cells = <1>;
    epwm_tbclk: clock@4140 {
    compatible = "ti,am64-epwm-tbclk", "syscon";
    reg = <0x4130 0x4>;
    #clock-cells = <1>;
    main_timer0: timer@2400000 {
    compatible = "ti,am654-timer";
    reg = <0x00 0x2400000 0x00 0x400>;
    interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 36 1>;
    clock-names = "fck";
    assigned-clocks = <&k3_clks 36 1>;
    assigned-clock-parents = <&k3_clks 36 2>;
    power-domains = <&k3_pds 36 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    status = "disabled";
    main_timer1: timer@2410000 {
    reg = <0x00 0x2410000 0x00 0x400>;
    interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 37 1>;
    assigned-clocks = <&k3_clks 37 1>;
    assigned-clock-parents = <&k3_clks 37 2>;
    power-domains = <&k3_pds 37 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer2: timer@2420000 {
    reg = <0x00 0x2420000 0x00 0x400>;
    interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 38 1>;
    assigned-clocks = <&k3_clks 38 1>;
    assigned-clock-parents = <&k3_clks 38 2>;
    power-domains = <&k3_pds 38 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer3: timer@2430000 {
    reg = <0x00 0x2430000 0x00 0x400>;
    interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 39 1>;
    assigned-clocks = <&k3_clks 39 1>;
    assigned-clock-parents = <&k3_clks 39 2>;
    power-domains = <&k3_pds 39 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer4: timer@2440000 {
    reg = <0x00 0x2440000 0x00 0x400>;
    interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 40 1>;
    assigned-clocks = <&k3_clks 40 1>;
    assigned-clock-parents = <&k3_clks 40 2>;
    power-domains = <&k3_pds 40 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer5: timer@2450000 {
    reg = <0x00 0x2450000 0x00 0x400>;
    interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 41 1>;
    assigned-clocks = <&k3_clks 41 1>;
    assigned-clock-parents = <&k3_clks 41 2>;
    power-domains = <&k3_pds 41 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer6: timer@2460000 {
    reg = <0x00 0x2460000 0x00 0x400>;
    interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 42 1>;
    assigned-clocks = <&k3_clks 42 1>;
    assigned-clock-parents = <&k3_clks 42 2>;
    power-domains = <&k3_pds 42 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer7: timer@2470000 {
    reg = <0x00 0x2470000 0x00 0x400>;
    interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 43 1>;
    assigned-clocks = <&k3_clks 43 1>;
    assigned-clock-parents = <&k3_clks 43 2>;
    power-domains = <&k3_pds 43 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer8: timer@2480000 {
    reg = <0x00 0x2480000 0x00 0x400>;
    interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 44 1>;
    assigned-clocks = <&k3_clks 44 1>;
    assigned-clock-parents = <&k3_clks 44 2>;
    power-domains = <&k3_pds 44 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer9: timer@2490000 {
    reg = <0x00 0x2490000 0x00 0x400>;
    interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 45 1>;
    assigned-clocks = <&k3_clks 45 1>;
    assigned-clock-parents = <&k3_clks 45 2>;
    power-domains = <&k3_pds 45 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer10: timer@24a0000 {
    reg = <0x00 0x24a0000 0x00 0x400>;
    interrupts = <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 46 1>;
    assigned-clocks = <&k3_clks 46 1>;
    assigned-clock-parents = <&k3_clks 46 2>;
    power-domains = <&k3_pds 46 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_timer11: timer@24b0000 {
    reg = <0x00 0x24b0000 0x00 0x400>;
    interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 47 1>;
    assigned-clocks = <&k3_clks 47 1>;
    assigned-clock-parents = <&k3_clks 47 2>;
    power-domains = <&k3_pds 47 TI_SCI_PD_EXCLUSIVE>;
    ti,timer-pwm;
    main_esm: esm@420000 {
    compatible = "ti,j721e-esm";
    reg = <0x00 0x420000 0x00 0x1000>;
    ti,esm-pins = <160>, <161>;
    main_uart0: serial@2800000 {
    compatible = "ti,am64-uart", "ti,am654-uart";
    reg = <0x00 0x02800000 0x00 0x100>;
    interrupts = <GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>;
    clock-frequency = <48000000>;
    current-speed = <115200>;
    power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 146 0>;
    clock-names = "fclk";
    main_uart1: serial@2810000 {
    reg = <0x00 0x02810000 0x00 0x100>;
    interrupts = <GIC_SPI 179 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 152 0>;
    main_uart2: serial@2820000 {
    reg = <0x00 0x02820000 0x00 0x100>;
    interrupts = <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 153 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 153 0>;
    main_uart3: serial@2830000 {
    reg = <0x00 0x02830000 0x00 0x100>;
    interrupts = <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 154 0>;
    main_uart4: serial@2840000 {
    reg = <0x00 0x02840000 0x00 0x100>;
    interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 155 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 155 0>;
    main_uart5: serial@2850000 {
    reg = <0x00 0x02850000 0x00 0x100>;
    interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 156 0>;
    main_uart6: serial@2860000 {
    reg = <0x00 0x02860000 0x00 0x100>;
    interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 158 0>;
    main_i2c0: i2c@20000000 {
    compatible = "ti,am64-i2c", "ti,omap4-i2c";
    reg = <0x00 0x20000000 0x00 0x100>;
    interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 102 2>;
    main_i2c1: i2c@20010000 {
    reg = <0x00 0x20010000 0x00 0x100>;
    interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 103 2>;
    status = "okay";
    main_i2c2: i2c@20020000 {
    reg = <0x00 0x20020000 0x00 0x100>;
    interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 104 2>;
    main_i2c3: i2c@20030000 {
    reg = <0x00 0x20030000 0x00 0x100>;
    interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 105 2>;
    main_spi0: spi@20100000 {
    compatible = "ti,am654-mcspi", "ti,omap4-mcspi";
    reg = <0x00 0x20100000 0x00 0x400>;
    interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 141 0>;
    dmas = <&main_pktdma 0xc300 0>, <&main_pktdma 0x4300 0>;
    dma-names = "tx0", "rx0";
    status = "okay";
    main_spi1: spi@20110000 {
    compatible = "ti,am654-mcspi","ti,omap4-mcspi";
    reg = <0x00 0x20110000 0x00 0x400>;
    interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 142 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 142 0>;
    main_spi2: spi@20120000 {
    reg = <0x00 0x20120000 0x00 0x400>;
    interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 143 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 143 0>;
    main_spi3: spi@20130000 {
    reg = <0x00 0x20130000 0x00 0x400>;
    interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 144 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 144 0>;
    main_spi4: spi@20140000 {
    reg = <0x00 0x20140000 0x00 0x400>;
    interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>;
    #size-cells = <0>;
    power-domains = <&k3_pds 145 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 145 0>;
    main_gpio_intr: interrupt-controller@a00000 {
    compatible = "ti,sci-intr";
    reg = <0x00 0x00a00000 0x00 0x800>;
    ti,intr-trigger-type = <1>;
    #interrupt-cells = <1>;
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <3>;
    ti,interrupt-ranges = <0 32 16>;
    main_gpio0: gpio@600000 {
    compatible = "ti,am64-gpio", "ti,keystone-gpio";
    reg = <0x0 0x00600000 0x0 0x100>;
    gpio-controller;
    #gpio-cells = <2>;
    interrupt-parent = <&main_gpio_intr>;
    interrupts = <190>, <191>, <192>,
    <193>, <194>, <195>;
    #interrupt-cells = <2>;
    ti,ngpio = <87>;
    ti,davinci-gpio-unbanked = <0>;
    power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 77 0>;
    clock-names = "gpio";
    main_gpio1: gpio@601000 {
    reg = <0x0 0x00601000 0x0 0x100>;
    gpio-controller;
    #gpio-cells = <2>;
    interrupts = <180>, <181>, <182>,
    <183>, <184>, <185>;
    ti,ngpio = <88>;
    power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 78 0>;
    sdhci0: mmc@fa10000 {
    compatible = "ti,am64-sdhci-8bit";
    reg = <0x00 0xfa10000 0x00 0x260>, <0x00 0xfa18000 0x00 0x134>;
    interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 57 0>, <&k3_clks 57 1>;
    clock-names = "clk_ahb", "clk_xin";
    mmc-ddr-1_8v;
    mmc-hs200-1_8v;
    ti,trm-icp = <0x2>;
    ti,otap-del-sel-legacy = <0x0>;
    ti,otap-del-sel-mmc-hs = <0x0>;
    ti,otap-del-sel-ddr52 = <0x6>;
    ti,otap-del-sel-hs200 = <0x7>;
    sdhci1: mmc@fa00000 {
    compatible = "ti,am64-sdhci-4bit";
    reg = <0x00 0xfa00000 0x00 0x260>, <0x00 0xfa08000 0x00 0x134>;
    interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 58 3>, <&k3_clks 58 4>;
    ti,trm-icp = <0x2>;
    ti,otap-del-sel-sd-hs = <0xf>;
    ti,otap-del-sel-sdr12 = <0xf>;
    ti,otap-del-sel-sdr25 = <0xf>;
    ti,otap-del-sel-sdr50 = <0xc>;
    ti,otap-del-sel-sdr104 = <0x6>;
    ti,otap-del-sel-ddr50 = <0x9>;
    ti,clkbuf-sel = <0x7>;
    cpsw3g: ethernet@8000000 {
    compatible = "ti,am642-cpsw-nuss";
    #size-cells = <2>;
    reg = <0x0 0x8000000 0x0 0x200000>;
    reg-names = "cpsw_nuss";
    ranges = <0x0 0x0 0x0 0x8000000 0x0 0x200000>;
    clocks = <&k3_clks 13 0>;
    assigned-clocks = <&k3_clks 13 1>;
    assigned-clock-parents = <&k3_clks 13 9>;
    power-domains = <&k3_pds 13 TI_SCI_PD_EXCLUSIVE>;
    dmas = <&main_pktdma 0xC500 15>,
    <&main_pktdma 0xC501 15>,
    <&main_pktdma 0xC502 15>,
    <&main_pktdma 0xC503 15>,
    <&main_pktdma 0xC504 15>,
    <&main_pktdma 0xC505 15>,
    <&main_pktdma 0xC506 15>,
    <&main_pktdma 0xC507 15>,
    <&main_pktdma 0x4500 15>;
    dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6",
    "tx7", "rx";
    ethernet-ports {
    #size-cells = <0>;
    cpsw_port1: port@1 {
    reg = <1>;
    ti,mac-only;
    label = "port1";
    phys = <&phy_gmii_sel 1>;
    mac-address = [00 00 00 00 00 00];
    ti,syscon-efuse = <&main_conf 0x200>;
    cpsw_port2: port@2 {
    reg = <2>;
    ti,mac-only;
    label = "port2";
    phys = <&phy_gmii_sel 2>;
    cpsw3g_mdio: mdio@f00 {
    compatible = "ti,cpsw-mdio","ti,davinci_mdio";
    reg = <0x0 0xf00 0x0 0x100>;
    #size-cells = <0>;
    bus_freq = <1000000>;
    cpts@3d000 {
    compatible = "ti,j721e-cpts";
    reg = <0x0 0x3d000 0x0 0x400>;
    clock-names = "cpts";
    interrupts-extended = <&gic500 GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
    interrupt-names = "cpts";
    ti,cpts-ext-ts-inputs = <4>;
    ti,cpts-periodic-outputs = <2>;
    main_cpts0: cpts@39000000 {
    reg = <0x0 0x39000000 0x0 0x400>;
    reg-names = "cpts";
    power-domains = <&k3_pds 84 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 84 0>;
    assigned-clocks = <&k3_clks 84 0>;
    assigned-clock-parents = <&k3_clks 84 8>;
    interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>;
    ti,cpts-periodic-outputs = <6>;
    ti,cpts-ext-ts-inputs = <8>;
    timesync_router: pinctrl@a40000 {
    reg = <0x0 0xa40000 0x0 0x800>;
    pinctrl-single,function-mask = <0x000107ff>;
    usbss0: cdns-usb@f900000{
    compatible = "ti,am64-usb";
    reg = <0x00 0xf900000 0x00 0x100>;
    power-domains = <&k3_pds 161 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 161 9>, <&k3_clks 161 1>;
    clock-names = "ref", "lpm";
    assigned-clocks = <&k3_clks 161 9>; /* USB2_REFCLK */
    assigned-clock-parents = <&k3_clks 161 10>; /* HF0SC0 */
    #size-cells = <2>;
    ranges;
    status = "okay";
    usb0: usb@f400000{
    compatible = "cdns,usb3";
    reg = <0x00 0xf400000 0x00 0x10000>,
    <0x00 0xf410000 0x00 0x10000>,
    <0x00 0xf420000 0x00 0x10000>;
    reg-names = "otg",
    "xhci",
    "dev";
    interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */
    <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>, /* irq.6 */
    <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>; /* otgirq */
    interrupt-names = "host",
    "peripheral",
    "otg";
    maximum-speed = "super-speed";
    dr_mode = "otg";
    tscadc0: tscadc@28001000 {
    compatible = "ti,am654-tscadc", "ti,am3359-tscadc";
    reg = <0x00 0x28001000 0x00 0x1000>;
    interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 0 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 0 0>;
    assigned-clocks = <&k3_clks 0 0>;
    assigned-clock-parents = <&k3_clks 0 3>;
    assigned-clock-rates = <60000000>;
    clock-names = "adc_tsc_fck";
    adc {
    #io-channel-cells = <1>;
    compatible = "ti,am654-adc", "ti,am3359-adc";
    fss: bus@fc00000 {
    compatible = "simple-bus";
    reg = <0x00 0x0fc00000 0x00 0x70000>;
    #size-cells = <2>;
    ranges;
    ospi0: spi@fc40000 {
    compatible = "ti,am654-ospi", "cdns,qspi-nor";
    reg = <0x00 0x0fc40000 0x00 0x100>,
    <0x05 0x00000000 0x01 0x00000000>;
    interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>;
    cdns,fifo-depth = <256>;
    cdns,fifo-width = <4>;
    cdns,trigger-address = <0x0>;
    #address-cells = <0x1>;
    #size-cells = <0x0>;
    clocks = <&k3_clks 75 6>;
    assigned-clocks = <&k3_clks 75 6>;
    assigned-clock-parents = <&k3_clks 75 7>;
    assigned-clock-rates = <166666666>;
    power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>;
    hwspinlock: spinlock@2a000000 {
    compatible = "ti,am64-hwspinlock";
    reg = <0x00 0x2a000000 0x00 0x1000>;
    #hwlock-cells = <1>;
    mailbox0_cluster2: mailbox@29020000 {
    compatible = "ti,am64-mailbox";
    reg = <0x00 0x29020000 0x00 0x200>;
    interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>;
    #mbox-cells = <1>;
    ti,mbox-num-users = <4>;
    ti,mbox-num-fifos = <16>;
    mailbox0_cluster3: mailbox@29030000 {
    reg = <0x00 0x29030000 0x00 0x200>;
    interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>;
    #mbox-cells = <1>;
    mailbox0_cluster4: mailbox@29040000 {
    reg = <0x00 0x29040000 0x00 0x200>;
    interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>;
    #mbox-cells = <1>;
    mailbox0_cluster5: mailbox@29050000 {
    reg = <0x00 0x29050000 0x00 0x200>;
    interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>;
    #mbox-cells = <1>;
    mailbox0_cluster6: mailbox@29060000 {
    reg = <0x00 0x29060000 0x00 0x200>;
    interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>;
    #mbox-cells = <1>;
    mailbox0_cluster7: mailbox@29070000 {
    reg = <0x00 0x29070000 0x00 0x200>;
    interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>;
    #mbox-cells = <1>;
    main_r5fss0: r5fss@78000000 {
    compatible = "ti,am64-r5fss";
    ti,cluster-mode = <0>;
    #size-cells = <1>;
    ranges = <0x78000000 0x00 0x78000000 0x10000>,
    <0x78100000 0x00 0x78100000 0x10000>,
    <0x78200000 0x00 0x78200000 0x08000>,
    <0x78300000 0x00 0x78300000 0x08000>;
    power-domains = <&k3_pds 119 TI_SCI_PD_EXCLUSIVE>;
    main_r5fss0_core0: r5f@78000000 {
    compatible = "ti,am64-r5f";
    reg = <0x78000000 0x00010000>,
    <0x78100000 0x00010000>;
    reg-names = "atcm", "btcm";
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <121>;
    ti,sci-proc-ids = <0x01 0xff>;
    resets = <&k3_reset 121 1>;
    firmware-name = "am64-main-r5f0_0-fw";
    ti,atcm-enable = <1>;
    ti,btcm-enable = <1>;
    ti,loczrama = <1>;
    main_r5fss0_core1: r5f@78200000 {
    reg = <0x78200000 0x00008000>,
    <0x78300000 0x00008000>;
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <122>;
    ti,sci-proc-ids = <0x02 0xff>;
    resets = <&k3_reset 122 1>;
    firmware-name = "am64-main-r5f0_1-fw";
    ti,loczrama = <1>;
    main_r5fss1: r5fss@78400000 {
    #size-cells = <1>;
    ranges = <0x78400000 0x00 0x78400000 0x10000>,
    <0x78500000 0x00 0x78500000 0x10000>,
    <0x78600000 0x00 0x78600000 0x08000>,
    <0x78700000 0x00 0x78700000 0x08000>;
    power-domains = <&k3_pds 120 TI_SCI_PD_EXCLUSIVE>;
    main_r5fss1_core0: r5f@78400000 {
    reg = <0x78400000 0x00010000>,
    <0x78500000 0x00010000>;
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <123>;
    ti,sci-proc-ids = <0x06 0xff>;
    resets = <&k3_reset 123 1>;
    firmware-name = "am64-main-r5f1_0-fw";
    ti,loczrama = <1>;
    main_r5fss1_core1: r5f@78600000 {
    reg = <0x78600000 0x00008000>,
    <0x78700000 0x00008000>;
    ti,sci = <&dmsc>;
    ti,sci-dev-id = <124>;
    ti,sci-proc-ids = <0x07 0xff>;
    resets = <&k3_reset 124 1>;
    firmware-name = "am64-main-r5f1_1-fw";
    ti,loczrama = <1>;
    serdes_wiz0: wiz@f000000 {
    compatible = "ti,am64-wiz-10g";
    #size-cells = <1>;
    power-domains = <&k3_pds 162 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 162 0>, <&k3_clks 162 1>, <&serdes_refclk>;
    clock-names = "fck", "core_ref_clk", "ext_ref_clk";
    num-lanes = <1>;
    #reset-cells = <1>;
    #clock-cells = <1>;
    ranges = <0x0f000000 0x0 0x0f000000 0x00010000>;
    assigned-clocks = <&k3_clks 162 1>;
    assigned-clock-parents = <&k3_clks 162 5>;
    serdes0: serdes@f000000 {
    compatible = "ti,j721e-serdes-10g";
    reg = <0x0f000000 0x00010000>;
    reg-names = "torrent_phy";
    resets = <&serdes_wiz0 0>;
    reset-names = "torrent_reset";
    clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>,
    <&serdes_wiz0 TI_WIZ_PHY_EN_REFCLK>;
    clock-names = "refclk", "phy_en_refclk";
    assigned-clocks = <&serdes_wiz0 TI_WIZ_PLL0_REFCLK>,
    <&serdes_wiz0 TI_WIZ_PLL1_REFCLK>,
    <&serdes_wiz0 TI_WIZ_REFCLK_DIG>;
    assigned-clock-parents = <&k3_clks 162 1>,
    <&k3_clks 162 1>,
    <&k3_clks 162 1>;
    #size-cells = <0>;
    #clock-cells = <1>;
    pcie0_rc: pcie@f102000 {
    compatible = "ti,am64-pcie-host", "ti,j721e-pcie-host";
    reg = <0x00 0x0f102000 0x00 0x1000>,
    <0x00 0x0f100000 0x00 0x400>,
    <0x00 0x0d000000 0x00 0x00800000>,
    <0x00 0x68000000 0x00 0x00001000>;
    reg-names = "intd_cfg", "user_cfg", "reg", "cfg";
    interrupt-names = "link_state";
    interrupts = <GIC_SPI 203 IRQ_TYPE_EDGE_RISING>;
    device_type = "pci";
    ti,syscon-pcie-ctrl = <&main_conf 0x4070>;
    max-link-speed = <2>;
    num-lanes = <1>;
    power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 114 0>, <&serdes0 CDNS_TORRENT_REFCLK_DRIVER>;
    clock-names = "fck", "pcie_refclk";
    #address-cells = <3>;
    #size-cells = <2>;
    bus-range = <0x0 0xff>;
    cdns,no-bar-match-nbits = <64>;
    vendor-id = <0x104c>;
    device-id = <0xb010>;
    msi-map = <0x0 &gic_its 0x0 0x10000>;
    ranges = <0x01000000 0x00 0x68001000 0x00 0x68001000 0x00 0x0010000>,
    <0x02000000 0x00 0x68011000 0x00 0x68011000 0x00 0x7fef000>;
    dma-ranges = <0x02000000 0x0 0x0 0x0 0x0 0x00000010 0x0>;
    pcie0_ep: pcie-ep@f102000 {
    compatible = "ti,am64-pcie-ep", "ti,j721e-pcie-ep";
    <0x00 0x68000000 0x00 0x08000000>;
    reg-names = "intd_cfg", "user_cfg", "reg", "mem";
    num-lanes = <1>;
    clocks = <&k3_clks 114 0>;
    max-functions = /bits/ 8 <1>;
    epwm0: pwm@23000000 {
    compatible = "ti,am64-epwm", "ti,am3352-ehrpwm";
    #pwm-cells = <3>;
    reg = <0x0 0x23000000 0x0 0x100>;
    power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 0>, <&k3_clks 86 0>;
    clock-names = "tbclk", "fck";
    epwm1: pwm@23010000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23010000 0x0 0x100>;
    power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 1>, <&k3_clks 87 0>;
    epwm2: pwm@23020000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23020000 0x0 0x100>;
    power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 2>, <&k3_clks 88 0>;
    epwm3: pwm@23030000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23030000 0x0 0x100>;
    power-domains = <&k3_pds 89 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 3>, <&k3_clks 89 0>;
    epwm4: pwm@23040000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23040000 0x0 0x100>;
    power-domains = <&k3_pds 90 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 4>, <&k3_clks 90 0>;
    epwm5: pwm@23050000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23050000 0x0 0x100>;
    power-domains = <&k3_pds 91 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 5>, <&k3_clks 91 0>;
    epwm6: pwm@23060000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23060000 0x0 0x100>;
    power-domains = <&k3_pds 92 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 6>, <&k3_clks 92 0>;
    epwm7: pwm@23070000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23070000 0x0 0x100>;
    power-domains = <&k3_pds 93 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 7>, <&k3_clks 93 0>;
    epwm8: pwm@23080000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23080000 0x0 0x100>;
    power-domains = <&k3_pds 94 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&epwm_tbclk 8>, <&k3_clks 94 0>;
    ecap0: pwm@23100000 {
    compatible = "ti,am64-ecap", "ti,am3352-ecap";
    #pwm-cells = <3>;
    reg = <0x0 0x23100000 0x0 0x60>;
    power-domains = <&k3_pds 51 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 51 0>;
    ecap1: pwm@23110000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23110000 0x0 0x60>;
    power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 52 0>;
    ecap2: pwm@23120000 {
    #pwm-cells = <3>;
    reg = <0x0 0x23120000 0x0 0x60>;
    power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 53 0>;
    main_rti0: watchdog@e000000 {
    compatible = "ti,j7-rti-wdt";
    reg = <0x00 0xe000000 0x00 0x100>;
    clocks = <&k3_clks 125 0>;
    power-domains = <&k3_pds 125 TI_SCI_PD_EXCLUSIVE>;
    assigned-clocks = <&k3_clks 125 0>;
    assigned-clock-parents = <&k3_clks 125 2>;
    status = "okay";
    main_rti1: watchdog@e010000 {
    reg = <0x00 0xe010000 0x00 0x100>;
    clocks = <&k3_clks 126 0>;
    power-domains = <&k3_pds 126 TI_SCI_PD_EXCLUSIVE>;
    assigned-clocks = <&k3_clks 126 0>;
    assigned-clock-parents = <&k3_clks 126 2>;
    icssg0: icssg@30000000 {
    compatible = "ti,am642-icssg";
    reg = <0x00 0x30000000 0x00 0x80000>;
    power-domains = <&k3_pds 81 TI_SCI_PD_EXCLUSIVE>;
    #size-cells = <1>;
    ranges = <0x0 0x00 0x30000000 0x80000>;
    icssg0_mem: memories@0 {
    reg = <0x0 0x2000>,
    <0x2000 0x2000>,
    <0x10000 0x10000>;
    reg-names = "dram0", "dram1", "shrdram2";
    icssg0_cfg: cfg@26000 {
    compatible = "ti,pruss-cfg", "syscon";
    reg = <0x26000 0x200>;
    #size-cells = <1>;
    ranges = <0x0 0x26000 0x2000>;
    clocks {
    #size-cells = <0>;
    icssg0_coreclk_mux: coreclk-mux@3c {
    reg = <0x3c>;
    #clock-cells = <0>;
    clocks = <&k3_clks 81 0>, /* icssg0_core_clk */
    <&k3_clks 81 20>; /* icssg0_iclk */
    assigned-clocks = <&icssg0_coreclk_mux>;
    assigned-clock-parents = <&k3_clks 81 20>;
    icssg0_iepclk_mux: iepclk-mux@30 {
    reg = <0x30>;
    #clock-cells = <0>;
    clocks = <&k3_clks 81 3>, /* icssg0_iep_clk */
    <&icssg0_coreclk_mux>; /* icssg0_coreclk_mux */
    assigned-clocks = <&icssg0_iepclk_mux>;
    assigned-clock-parents = <&icssg0_coreclk_mux>;
    icssg0_mii_rt: mii-rt@32000 {
    compatible = "ti,pruss-mii", "syscon";
    reg = <0x32000 0x100>;
    icssg0_mii_g_rt: mii-g-rt@33000 {
    compatible = "ti,pruss-mii-g", "syscon";
    reg = <0x33000 0x1000>;
    icssg0_intc: interrupt-controller@20000 {
    compatible = "ti,icssg-intc";
    reg = <0x20000 0x2000>;
    interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
    interrupt-names = "host_intr0", "host_intr1",
    "host_intr2", "host_intr3",
    "host_intr4", "host_intr5",
    "host_intr6", "host_intr7";
    pru0_0: pru@34000 {
    compatible = "ti,am642-pru";
    reg = <0x34000 0x3000>,
    <0x22000 0x100>,
    <0x22400 0x100>;
    reg-names = "iram", "control", "debug";
    firmware-name = "am64x-pru0_0-fw";
    rtu0_0: rtu@4000 {
    compatible = "ti,am642-rtu";
    reg = <0x4000 0x2000>,
    <0x23000 0x100>,
    <0x23400 0x100>;
    firmware-name = "am64x-rtu0_0-fw";
    tx_pru0_0: txpru@a000 {
    compatible = "ti,am642-tx-pru";
    reg = <0xa000 0x1800>,
    <0x25000 0x100>,
    <0x25400 0x100>;
    firmware-name = "am64x-txpru0_0-fw";
    pru0_1: pru@38000 {
    reg = <0x38000 0x3000>,
    <0x24000 0x100>,
    <0x24400 0x100>;
    firmware-name = "am64x-pru0_1-fw";
    rtu0_1: rtu@6000 {
    reg = <0x6000 0x2000>,
    <0x23800 0x100>,
    <0x23c00 0x100>;
    firmware-name = "am64x-rtu0_1-fw";
    tx_pru0_1: txpru@c000 {
    reg = <0xc000 0x1800>,
    <0x25800 0x100>,
    <0x25c00 0x100>;
    firmware-name = "am64x-txpru0_1-fw";
    icssg0_mdio: mdio@32400 {
    compatible = "ti,davinci_mdio";
    reg = <0x32400 0x100>;
    clocks = <&k3_clks 62 3>;
    #size-cells = <0>;
    icssg1: icssg@30080000 {
    reg = <0x00 0x30080000 0x00 0x80000>;
    power-domains = <&k3_pds 82 TI_SCI_PD_EXCLUSIVE>;
    #size-cells = <1>;
    ranges = <0x0 0x00 0x30080000 0x80000>;
    icssg1_mem: memories@0 {
    reg = <0x0 0x2000>,
    <0x2000 0x2000>,
    <0x10000 0x10000>;
    icssg1_cfg: cfg@26000 {
    #size-cells = <1>;
    clocks {
    #size-cells = <0>;
    icssg1_coreclk_mux: coreclk-mux@3c {
    reg = <0x3c>;
    #clock-cells = <0>;
    clocks = <&k3_clks 82 0>, /* icssg1_core_clk */
    <&k3_clks 82 20>; /* icssg1_iclk */
    assigned-clocks = <&icssg1_coreclk_mux>;
    assigned-clock-parents = <&k3_clks 82 20>;
    icssg1_iepclk_mux: iepclk-mux@30 {
    reg = <0x30>;
    #clock-cells = <0>;
    clocks = <&k3_clks 82 3>, /* icssg1_iep_clk */
    <&icssg1_coreclk_mux>; /* icssg1_coreclk_mux */
    assigned-clocks = <&icssg1_iepclk_mux>;
    assigned-clock-parents = <&icssg1_coreclk_mux>;
    icssg1_iep0: iep@2e000 {
    compatible = "ti,am654-icss-iep";
    reg = <0x2e000 0x1000>;
    icssg1_iep1: iep@2f000 {
    reg = <0x2f000 0x1000>;
    icssg1_mii_rt: mii-rt@32000 {
    icssg1_mii_g_rt: mii-g-rt@33000 {
    icssg1_intc: interrupt-controller@20000 {
    interrupts = <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>;
    pru1_0: pru@34000 {
    reg = <0x34000 0x4000>,
    <0x22000 0x100>,
    <0x22400 0x100>;
    firmware-name = "am64x-pru1_0-fw";
    rtu1_0: rtu@4000 {
    <0x23000 0x100>,
    <0x23400 0x100>;
    firmware-name = "am64x-rtu1_0-fw";
    tx_pru1_0: txpru@a000 {
    <0x25000 0x100>,
    <0x25400 0x100>;
    firmware-name = "am64x-txpru1_0-fw";
    pru1_1: pru@38000 {
    reg = <0x38000 0x4000>,
    <0x24000 0x100>,
    <0x24400 0x100>;
    firmware-name = "am64x-pru1_1-fw";
    rtu1_1: rtu@6000 {
    <0x23800 0x100>,
    <0x23c00 0x100>;
    firmware-name = "am64x-rtu1_1-fw";
    tx_pru1_1: txpru@c000 {
    <0x25800 0x100>,
    <0x25c00 0x100>;
    firmware-name = "am64x-txpru1_1-fw";
    icssg1_mdio: mdio@32400 {
    #size-cells = <0>;
    clocks = <&k3_clks 82 0>;
    main_mcan0: can@20701000 {
    compatible = "bosch,m_can";
    reg = <0x00 0x20701000 0x00 0x200>,
    <0x00 0x20708000 0x00 0x8000>;
    reg-names = "m_can", "message_ram";
    power-domains = <&k3_pds 98 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 98 5>, <&k3_clks 98 0>;
    clock-names = "hclk", "cclk";
    interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
    interrupt-names = "int0", "int1";
    bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>;
    main_mcan1: can@20711000 {
    reg = <0x00 0x20711000 0x00 0x200>,
    <0x00 0x20718000 0x00 0x8000>;
    power-domains = <&k3_pds 99 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 99 5>, <&k3_clks 99 0>;
    interrupts = <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>,
    <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>;
    crypto: crypto@40900000 {
    compatible = "ti,am64-sa2ul";
    reg = <0x00 0x40900000 0x00 0x1200>;
    power-domains = <&k3_pds 133 TI_SCI_PD_SHARED>;
    #size-cells = <2>;
    ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>;
    dmas = <&main_pktdma 0xc001 0>, <&main_pktdma 0x4002 0>,
    <&main_pktdma 0x4003 0>;
    dma-names = "tx", "rx1", "rx2";
    rng: rng@40910000 {
    compatible = "inside-secure,safexcel-eip76";
    reg = <0x00 0x40910000 0x00 0x7d>;
    interrupts = <GIC_SPI 168 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&k3_clks 133 1>;
    status = "disabled"; /* Used by OP-TEE */
    gpmc0: memory-controller@3b000000 {
    compatible = "ti,am64-gpmc";
    power-domains = <&k3_pds 80 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 80 0>;
    reg = <0x00 0x03b000000 0x00 0x400>,
    <0x00 0x050000000 0x00 0x8000000>;
    reg-names = "cfg", "data";
    interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>;
    gpmc,num-cs = <3>;
    gpmc,num-waitpins = <2>;
    #size-cells = <1>;
    gpio-controller;
    #gpio-cells = <2>;
    elm0: ecc@25010000 {
    compatible = "ti,am64-elm";
    reg = <0x00 0x25010000 0x00 0x2000>;
    interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>;
    power-domains = <&k3_pds 54 TI_SCI_PD_EXCLUSIVE>;
    clocks = <&k3_clks 54 0>;
  • Hello Abdul,
    Thanks for the DTS and DTSI files.
    I am going through them, please expect responses in few business days.
    Vaibhav
  • Hello Abdul,
    I went through every instance of timers you have enabled in the DTS file.
    Now, according to my understanding you want to access these main timers(lets say MAIN_TIMER2) through omap_timers driver code, is that correct?
    Vaibhav
  • Yes, I have another kernel driver where I need to call omap_timers driver APIs. Suppose if I have enabled TIMER2-TIMER5, I can see omap_timers driver will store timer in linked list. I want to get a way to use omap_timer driver APIs rather doing copy certain functions from omap_timers  in my driver code.
  • Hello Abdul,
    I am checking this internally.
    Vaibhav
  • One more question, I have configured timer4 for pulse input and timer5 for pulse output, I Can see interrupt been happening on timer5 which is configured as a pulse output, But I could not see any pulse on pins.
    timer4_pins_default: timer4-pins-default {
    pinctrl-single,pins = <
    AM64X_IOPAD(0x0258, PIN_INPUT, 4) /* (C17) MCAN1_TX.TIMER_IO4 */
    timer5_pins_default: timer5-pins-default {
    AM64X_IOPAD(0x025c, PIN_OUTPUT, 4) /* (D17) MCAN1_RX.TIMER_IO5 */
    &main_timer4 {
    status = "okay";
    pintctrl-0 = <&timer4_pins_default>;
    &main_timer5 {
    status = "okay";
    compatible = "elpro,el-pulse-ou1";
    pintctrl-0 = <&timer5_pins_default>;
  • Hello Abdul,
    I have assigned this to concerned expert. Please expect responses within few business days.
    Vaibhav
  • Hello Abdul,
    What exactly are you trying to use the dmtimers for here? We can help you find the right tool for the job.
    If the timers are not even defined in the k3-am64-main.dtsi file like they are in the k3-am62-main.dtsi and k3-am62a-main.dtsi files, then that means that the TI developers have not tested drivers for using the dmtimer instances directly from Linux userspace. As of AM64x Linux SDK 9.0, there are no main_timerX instances in that file.
    Thus, creating a reference by using the & symbol will not do anything.
    i.e.,
    &main_timer4{} does not do anything
    if
    main_timer4
    has never even been defined.
    Even IF there was driver support for the dmtimers on AM64x like on AM62x, it does not look like the capture functionality is supported by the timer module drivers. Reference the AM62x SW Buildsheet for SDK 9.0:
    https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/09_00_00_03/exports/docs/devices/AM62X/AM62X_build_sheet_09.00.03.htm
    (which I got from this link: https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM62X )
    Nick
  • Hi Nick,
    The file I have k3-am64-main.dtsi does have timer nodes.  I have attached my k3-am64-main.dtsi file above.  For capture functionality I have configured timer according to the TRM. In TRM there are steps mentioned for configuring the timers for each mode. In below thread I have mentioned  timer functions for both PWM and Capture.
    (+) SK-AM64: Pin configuration for TIMERS using Expansion connector - Processors forum - Processors - TI E2E support forums
    I can see interrupts been happening but no signal coming out at configured pin in device tree
  • What exactly are you trying to use the dmtimers for here? We can help you find the right tool for the job.
    I want to use timer2-timer5 for to capture pulse input, and timer6-timer9 to generate pulse output,
  • For future readers, we might be combining discussions from two of Abdul's other threads into this thread to make it easier to keep track of, since all 3 threads are about the same subject:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1288641/sk-am64-pin-configuration-for-timers-using-expansion-connector
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1284087/am6442-timers-support-in-linux
    Hello Abdul,
    First, let's clarify what we can and cannot support on these forums
    We can answer questions about TI software, running on TI hardware. We can answer basic questions about TI hardware and software concepts. However, we cannot answer questions about code that TI did not write and validate. That means I cannot help you write a custom driver. That also means I cannot help you get a TI driver working, if the TI developers have not tested that the TI driver actually works with the peripheral that you are trying to use.
    If the k3-am64-main.dtsi file that TI provides does not include main_timerX nodes, that tells you that our Linux developers have not tested a Linux driver with the dmtimer peripherals. That means that I cannot support questions about getting a driver working with the dmtimer peripherals, because I cannot guarantee that it would work in the first place.
    In the same way, I cannot answer questions about a custom driver, compatible=elpro,el-pulse-in1. TI did not develop this code, TI did not test this code, and TI cannot guarantee that the code actually works, or ever worked.
    Now, a dmtimer peripheral on AM64x is the same circuit as a dmtimer peripheral on AM62x. So could you get it working on your own? Probably. But you would have to get it working without our assistance.
    Let's discuss your usecase
    There are many different ways to grab an input signal or generate an output signal, you don't need to use the dmtimer peripheral.
    What kind of a pulse output are you trying to generate? For example, why not just use a PWM output?
    What kind of pulse input are you trying to capture? What information is coming in? Who is consuming that information?
    Nick
  • I understood. But I think once the product is released or in the market, it should have support for all the peripheral connected to it before the product released.
    I'm also using PWM as well. It just a pulse input captures the rising edge and count how many pulses been captured and calculate the rate. Its working now. There was a syntax error in device tree pinctrl-name variable.
