TDA4VM: select PCIE internal refclk
Part Number: TDA4VM
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1004565/faq-tda4vm-tda4vm-dra829v-routing-pcie-reference-clock-externally
Has patch for 0806 sdk like the link refer. Can setting pcie outpu refclk, not ues external clock circuit.
  • Hi Yang,
    Apologies for not understanding, but I would like some clarification on your query.
    Are you asking for the patches in the FAQ to be ported over to 8.6 SDK version? Or are you seeing an issue when applying the patches to 8.6 SDK?
    If you are seeing an issue after applying patches, then could you share boot log messages?
    Takuma
  • The patch not fix for 8.6 sdk, can not apply the patch.
  • Hi Yang,
    I can try to port over the patch. However, it will take me a while. I can get back to you in one week at the max.
    Takuma
  • Hi Yang,
    If you had applied the patch by hand and saw some serdes error in dmesg, I found recently that there is an extra device tree change that needs to be added for selecting the internel clk.
    With below changes, I was able to get 8.0 SDK working, but still having some trouble with 8.6 SDK.
    To verify if you are also seeing the same issues as me, could you post logs from dmesg?
    Takuma
  • Hi Yang,
    I resolved the issues I was having with 8.6 SDK and updated the FAQ with new patches. Please try out the new changes and let me know if there are further issues:
    Takuma
  • Fixed the patch, a 100M clock can be output, but the amplitude is only 240mV.
    Here is the startup log:
    [    0.614772] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.621205] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
    [    0.629194] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.635615] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
    [    0.643552] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
    [    0.649970] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
    [    0.657909] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.664233] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
    [    0.672180] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
    [    0.678506] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
    [    0.688179] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.696463] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.704700] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.711853] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.720436] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.733882] brd: module loaded
    [    0.740382] loop: module loaded
    [    0.744159] megasas: 07.714.04.00-rc1
    [    0.749905] tun: Universal TUN/TAP device driver, 1.6
    [    0.755364] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.761775] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.767855] sky2: driver version 1.30
    [    0.772213] VFIO - User Level meta-driver version: 0.3
    [    0.777979] i2c /dev entries driver
    [    0.782425] sdhci: Secure Digital Host Controller Interface driver
    [    0.788748] sdhci: Copyright(c) Pierre Ossman
    [    0.793392] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.799759] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.806101] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.813460] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.818023] optee: revision 3.20 (8e74d476)
    [    0.834447] optee: dynamic shared memory is enabled
    [    0.843910] optee: initialized driver
    [    0.848988] NET: Registered protocol family 17
    [    0.853604] 9pnet: Installing 9P2000 support
    [    0.858007] Key type dns_resolver registered
    [    0.862478] Loading compiled-in X.509 certificates
    [    0.875498] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
    [    0.927169] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.933278] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.939359] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.968729] pca954x 3-0071: probe failed
    [    0.972766] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    1.000728] pca954x 4-0070: probe failed
    [    1.004761] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
    [    1.010858] omap_i2c 2050000.i2c: bus 5 rev0.12 at 400 kHz
    [    1.017328] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
    [    1.027315] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
    [    1.036125] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
    [    1.046001] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    1.066312] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    1.074004] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    1.082281] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    1.090557] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.099441] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    1.107118] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    1.115394] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    1.123675] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    2.134455] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
    [    2.140873] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.146479] pci_bus 0000:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
    [    2.156347] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
    [    2.163395] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
    [    2.169534] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    2.179465] pci 0000:00:00.0: supports D1
    [    2.183559] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.191556] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.201684] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.208452] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.213749] pcieport 0000:00:00.0: PME: Signaling with IRQ 60
    [    2.220600] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    2.230482] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    2.237241] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    2.246269] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    2.256423] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    2.263185] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    2.271153] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
    [    2.280595] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 27, base_baud = 3000000) is a 8250
    [    2.289342] printk: console [ttyS2] enabled
    [    2.297780] printk: bootconsole [ns16550a0] disabled
    [    2.308301] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 28, base_baud = 3000000) is a 8250
    [    2.317282] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 29, base_baud = 3000000) is a 8250
    [    2.330697] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    2.376687] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.384331] davinci_mdio 46000f00.mdio: no live phy, scanning all
    [    2.402308] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    2.410320] davinci_mdio 46000f00.mdio: phy[1]: device 46000f00.mdio:01, driver unknown
    [    2.418305] davinci_mdio 46000f00.mdio: phy[2]: device 46000f00.mdio:02, driver unknown
    [    2.426288] davinci_mdio 46000f00.mdio: phy[3]: device 46000f00.mdio:03, driver unknown
    [    2.434272] davinci_mdio 46000f00.mdio: phy[4]: device 46000f00.mdio:04, driver unknown
    [    2.442258] davinci_mdio 46000f00.mdio: phy[5]: device 46000f00.mdio:05, driver unknown
    [    2.450243] davinci_mdio 46000f00.mdio: phy[6]: device 46000f00.mdio:06, driver unknown
    [    2.458227] davinci_mdio 46000f00.mdio: phy[7]: device 46000f00.mdio:07, driver unknown
    [    2.466210] davinci_mdio 46000f00.mdio: phy[8]: device 46000f00.mdio:08, driver unknown
    [    2.474194] davinci_mdio 46000f00.mdio: phy[9]: device 46000f00.mdio:09, driver unknown
    [    2.482177] davinci_mdio 46000f00.mdio: phy[10]: device 46000f00.mdio:0a, driver unknown
    [    2.490251] davinci_mdio 46000f00.mdio: phy[11]: device 46000f00.mdio:0b, driver unknown
    [    2.498323] davinci_mdio 46000f00.mdio: phy[12]: device 46000f00.mdio:0c, driver unknown
    [    2.506398] davinci_mdio 46000f00.mdio: phy[13]: device 46000f00.mdio:0d, driver unknown
    [    2.514476] davinci_mdio 46000f00.mdio: phy[14]: device 46000f00.mdio:0e, driver unknown
    [    2.522608] davinci_mdio 46000f00.mdio: phy[15]: device 46000f00.mdio:0f, driver unknown
    [    2.530691] davinci_mdio 46000f00.mdio: phy[16]: device 46000f00.mdio:10, driver unknown
    [    2.538761] davinci_mdio 46000f00.mdio: phy[17]: device 46000f00.mdio:11, driver unknown
    [    2.546832] davinci_mdio 46000f00.mdio: phy[18]: device 46000f00.mdio:12, driver unknown
    [    2.554901] davinci_mdio 46000f00.mdio: phy[19]: device 46000f00.mdio:13, driver unknown
    [    2.562973] davinci_mdio 46000f00.mdio: phy[20]: device 46000f00.mdio:14, driver unknown
    [    2.571044] davinci_mdio 46000f00.mdio: phy[21]: device 46000f00.mdio:15, driver unknown
    [    2.579115] davinci_mdio 46000f00.mdio: phy[22]: device 46000f00.mdio:16, driver unknown
    [    2.587184] davinci_mdio 46000f00.mdio: phy[23]: device 46000f00.mdio:17, driver unknown
    [    2.595255] davinci_mdio 46000f00.mdio: phy[24]: device 46000f00.mdio:18, driver unknown
    [    2.603325] davinci_mdio 46000f00.mdio: phy[25]: device 46000f00.mdio:19, driver unknown
    [    2.611395] davinci_mdio 46000f00.mdio: phy[26]: device 46000f00.mdio:1a, driver unknown
    [    2.619466] davinci_mdio 46000f00.mdio: phy[27]: device 46000f00.mdio:1b, driver unknown
    [    2.627536] davinci_mdio 46000f00.mdio: phy[28]: device 46000f00.mdio:1c, driver unknown
    [    2.635612] davinci_mdio 46000f00.mdio: phy[29]: device 46000f00.mdio:1d, driver unknown
    [    2.643689] davinci_mdio 46000f00.mdio: phy[30]: device 46000f00.mdio:1e, driver unknown
    [    2.651761] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver unknown
    [    2.659901] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    2.672746] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    2.679953] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    2.686293] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    2.697093] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
    [    2.740687] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.748242] davinci_mdio c000f00.mdio: no live phy, scanning all
    [    2.766350] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
    [    2.774191] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
    [    2.782003] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
    [    2.789814] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
    [    2.797625] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
    [    2.805442] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
    [    2.813253] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
    [    2.821062] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
    [    2.828873] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
    [    2.836684] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
    [    2.844494] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
    [    2.852392] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
    [    2.860289] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
    [    2.868188] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
    [    2.876086] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
    [    2.883990] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
    [    2.891964] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
    [    2.899875] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
    [    2.907772] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
    [    2.915671] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
    [    2.923568] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
    [    2.931467] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
    [    2.939364] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
    [    2.947262] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
    [    2.955159] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
    [    2.963056] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
    [    2.970953] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
    [    2.978849] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
    [    2.986746] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
    [    2.994646] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
    [    3.002547] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
    [    3.010452] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
    [    3.018418] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
    [    3.031098] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
    [    3.044333] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    3.154246] mmc0: CQHCI version 5.10
    [    3.162942] vdd_mmc1: supplied by vsys_3v3
    [    3.167698] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    3.174572] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    3.181419] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    3.188246] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    3.195044] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    3.197634] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    3.212463] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    3.219958] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    3.228041] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    3.236125] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    3.278483] mmc0: Command Queue Engine enabled
    [    3.282927] mmc0: new DDR MMC card at address 0001
    [    3.287993] mmcblk0: mmc0:0001 CJUD4R 59.6 GiB
    [    3.292589] mmcblk0boot0: mmc0:0001 CJUD4R partition 1 31.9 MiB
    [    3.298569] mmcblk0boot1: mmc0:0001 CJUD4R partition 2 31.9 MiB
    [    3.304550] mmcblk0rpmb: mmc0:0001 CJUD4R partition 3 4.00 MiB, chardev (237:0)
    [    3.313755]  mmcblk0: p1
    [    3.346727] j721e-pcie 2900000.pcie: Link up
    [    3.351094] j721e-pcie 2900000.pcie: PCI host bridge to bus 0001:00
    [    3.357351] pci_bus 0001:00: root bus resource [bus 00-ff]
    [    3.362825] pci_bus 0001:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
    [    3.372284] pci_bus 0001:00: root bus resource [mem 0x10011000-0x17ffffff]
    [    3.379167] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400
    [    3.385166] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [    3.394865] pci 0001:00:00.0: supports D1
    [    3.398863] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [    3.406800] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    3.414904] pci 0001:01:00.0: [11ab:0b52] type 00 class 0x020000
    [    3.420933] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
    [    3.427723] pci 0001:01:00.0: reg 0x18: [mem 0x00000000-0x00003fff 64bit]
    [    3.434733] pci 0001:01:00.0: supports D1 D2
    [    3.438992] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
    [    3.445665] pci 0001:01:00.0: reg 0x20c: [mem 0x00000000-0x000fffff 64bit]
    [    3.452525] pci 0001:01:00.0: VF(n) BAR0 space: [mem 0x00000000-0x006fffff 64bit] (contains BAR0 for 7 VFs)
    [    3.462266] pci 0001:01:00.0: reg 0x214: [mem 0x00000000-0x00003fff 64bit]
    [    3.469125] pci 0001:01:00.0: VF(n) BAR2 space: [mem 0x00000000-0x0001bfff 64bit] (contains BAR2 for 7 VFs)
    [    3.490622] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [    3.497239] pci 0001:00:00.0: BAR 14: assigned [mem 0x10100000-0x109fffff]
    [    3.504100] pci 0001:01:00.0: BAR 0: assigned [mem 0x10100000-0x101fffff 64bit]
    [    3.511407] pci 0001:01:00.0: BAR 7: assigned [mem 0x10200000-0x108fffff 64bit]
    [    3.518706] pci 0001:01:00.0: BAR 2: assigned [mem 0x10900000-0x10903fff 64bit]
    [    3.526014] pci 0001:01:00.0: BAR 9: assigned [mem 0x10904000-0x1091ffff 64bit]
    [    3.533312] pci 0001:00:00.0: PCI bridge to [bus 01]
    [    3.538266] pci 0001:00:00.0:   bridge window [mem 0x10100000-0x109fffff]
    [    3.545153] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
    [    3.551370] pcieport 0001:00:00.0: PME: Signaling with IRQ 504
    [    3.558149] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    3.568803] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    3.580679] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
    [    3.624690] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.632334] davinci_mdio 46000f00.mdio: no live phy, scanning all
    [    3.650305] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    3.658326] davinci_mdio 46000f00.mdio: phy[1]: device 46000f00.mdio:01, driver unknown
    [    3.666374] davinci_mdio 46000f00.mdio: phy[2]: device 46000f00.mdio:02, driver unknown
    [    3.674370] davinci_mdio 46000f00.mdio: phy[3]: device 46000f00.mdio:03, driver unknown
    [    3.682354] davinci_mdio 46000f00.mdio: phy[4]: device 46000f00.mdio:04, driver unknown
    [    3.690340] davinci_mdio 46000f00.mdio: phy[5]: device 46000f00.mdio:05, driver unknown
    [    3.698323] davinci_mdio 46000f00.mdio: phy[6]: device 46000f00.mdio:06, driver unknown
    [    3.706307] davinci_mdio 46000f00.mdio: phy[7]: device 46000f00.mdio:07, driver unknown
    [    3.714293] davinci_mdio 46000f00.mdio: phy[8]: device 46000f00.mdio:08, driver unknown
    [    3.722277] davinci_mdio 46000f00.mdio: phy[9]: device 46000f00.mdio:09, driver unknown
    [    3.730260] davinci_mdio 46000f00.mdio: phy[10]: device 46000f00.mdio:0a, driver unknown
    [    3.738330] davinci_mdio 46000f00.mdio: phy[11]: device 46000f00.mdio:0b, driver unknown
    [    3.746401] davinci_mdio 46000f00.mdio: phy[12]: device 46000f00.mdio:0c, driver unknown
    [    3.754471] davinci_mdio 46000f00.mdio: phy[13]: device 46000f00.mdio:0d, driver unknown
    [    3.762542] davinci_mdio 46000f00.mdio: phy[14]: device 46000f00.mdio:0e, driver unknown
    [    3.770616] davinci_mdio 46000f00.mdio: phy[15]: device 46000f00.mdio:0f, driver unknown
    [    3.778693] davinci_mdio 46000f00.mdio: phy[16]: device 46000f00.mdio:10, driver unknown
    [    3.786773] davinci_mdio 46000f00.mdio: phy[17]: device 46000f00.mdio:11, driver unknown
    [    3.794844] davinci_mdio 46000f00.mdio: phy[18]: device 46000f00.mdio:12, driver unknown
    [    3.802915] davinci_mdio 46000f00.mdio: phy[19]: device 46000f00.mdio:13, driver unknown
    [    3.810989] davinci_mdio 46000f00.mdio: phy[20]: device 46000f00.mdio:14, driver unknown
    [    3.819061] davinci_mdio 46000f00.mdio: phy[21]: device 46000f00.mdio:15, driver unknown
    [    3.827131] davinci_mdio 46000f00.mdio: phy[22]: device 46000f00.mdio:16, driver unknown
    [    3.835203] davinci_mdio 46000f00.mdio: phy[23]: device 46000f00.mdio:17, driver unknown
    [    3.843275] davinci_mdio 46000f00.mdio: phy[24]: device 46000f00.mdio:18, driver unknown
    [    3.851348] davinci_mdio 46000f00.mdio: phy[25]: device 46000f00.mdio:19, driver unknown
    [    3.859420] davinci_mdio 46000f00.mdio: phy[26]: device 46000f00.mdio:1a, driver unknown
    [    3.867490] davinci_mdio 46000f00.mdio: phy[27]: device 46000f00.mdio:1b, driver unknown
    [    3.875560] davinci_mdio 46000f00.mdio: phy[28]: device 46000f00.mdio:1c, driver unknown
    [    3.883633] davinci_mdio 46000f00.mdio: phy[29]: device 46000f00.mdio:1d, driver unknown
    [    3.891704] davinci_mdio 46000f00.mdio: phy[30]: device 46000f00.mdio:1e, driver unknown
    [    3.899774] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver unknown
    [    3.907922] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    3.920770] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    3.927977] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    3.934268] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    3.944880] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    3.953383] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    3.960675] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    3.969082] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    3.976398] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    3.983705] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    3.991018] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    4.010020] ALSA device list:
    [    4.012994]   No soundcards found.
    [    4.109903] EXT4-fs (mmcblk0p1): recovery complete
    [    4.115569] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
    [    4.123685] VFS: Mounted root (ext4 filesystem) on device 179:1.
    [    4.129908] devtmpfs: mounted
    [    4.133751] Freeing unused kernel memory: 1856K
    [    4.138380] Run /sbin/init as init process
    [    4.227573] systemd[1]: System time before build time, advancing clock.
    [    4.249712] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    4.271485] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2021.09!
    [    4.304993] systemd[1]: Set hostname to <tda4vm-sk>.
    [    4.422647] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    4.431545] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    4.441015] systemd[1]: /etc/systemd/system/rc-local.service:11: Support for option SysVStartPriority= has been removed and it is ignored
    [    4.492852] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.500950] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    4.520771] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.527926] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    4.548761] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.555813] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    4.576884] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    4.600818] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    4.624807] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    4.644751] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.664737] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    4.684740] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    4.709137] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    4.732834] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    4.754687] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    4.776904] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.802271] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.810626] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.833012] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.853047] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.876975] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.896890] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.918785] systemd[1]: Mounting Huge Pages File System...
    [    4.942767] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.966826] systemd[1]: Mounting Kernel Debug File System...
    [    4.990974] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    5.016882] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
    [    5.032271] systemd[1]: Starting Start psplash boot splash screen...
    [    5.059147] systemd[1]: Starting RPC Bind...
    [    5.076946] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.088984] systemd[1]: Starting Journal Service...
    [    5.111882] systemd[1]: Starting Load Kernel Modules...
    [    5.127193] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.146476] systemd[1]: Starting udev Coldplug all Devices...
             Starting udev Coldplug all Devices...[    5.158744] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
    [    5.169615] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    5.185228] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Huge Pages File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Star…progress communication helper.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
    [    5.412461] systemd-journald[267]: Received client request to flush runtime journal.
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Started Flush Journal to Persistent Storage.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Create Static Device Nodes in /dev.
    [    5.513574] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Reached target Local File Systems (Pre).
    [    5.536843] random: systemd: uninitialized urandom read (16 bytes read)
             Mounting /media/ram...
    [    5.546625] random: systemd-journal: uninitialized urandom read (16 bytes read)
             Mounting /var/volatile...
             Starting udev Kernel Device Manager...
    [  OK  ] Started udev Coldplug all Devices.
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Started udev Kernel Device Manager.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Update UTMP about System Boot/Shutdown...
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Reached target System Time Synchronized.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Print notice about GPLv3 packages...
             Starting set host name as per compatible name...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
             Starting Update pmic regis…fety feature on power rails...
             Starting /etc/rc.local Compatibility...
             Starting rc.pvr.service...
             Starting startwlanap...
             Starting startwlansta...
             Starting Login Service...
    [  OK  ] Started TEE Supplicant.
             Starting Update weston ini… based on the platform name...
    [  OK  ] Started set host name as per compatible name.
    [  OK  ] Started IPv6 Packet Filtering Framework.
    [  OK  ] Started IPv4 Packet Filtering Framework.
    [  OK  ] Started rc.pvr.service.
    [  OK  ] Started startwlanap.
    [  OK  ] Started startwlansta.
    [  OK  ] Started Update pmic regist…safety feature on power rails.
    [  OK  ] Started Update weston ini …ge based on the platform name.
    [  OK  ] Reached target Network (Pre).
             Starting Network Manager...
             Starting Network Service...
             Starting weston.service...
    [  OK  ] Started Login Service.
    [    6.548563] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.560480] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.579223] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Started Network Service.
    [    6.615322] am65-cpsw-nuss 46000000.ethernet eth0: configuring for fixed/rgmii-id link mode
    [    6.625958] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
             Starting Wait for Network to be Configured...
             Starting Network Name Resolution...
    [  OK  ] Started Network Manager.
             Starting Network Manager Wait Online...
             Starting Hostname Service...
    [  OK  ] Started Hostname Service.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
             Starting Network Manager Script Dispatcher Service...
             Starting Avahi mDNS/DNS-SD Stack...
             Starting DNS forwarder and DHCP server...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Permit User Sessions...
    NOTICE: This file system contains the following GPLv3 packages:
            bash-dev
            bash
            cifs-utils
            dnsmasq
            dosfstools
            gdb
            less
            libdw1
            libelf1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgmp10
            libidn2-0
            libreadline-dev
            libreadline8
            libunistring2
            m4-dev
            m4
            nettle
            parted
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Started Print notice about GPLv3 packages.
    [  OK  ] Started Network Manager Script Dispatcher Service.
    [  OK  ] Started Permit User Sessions.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started DNS forwarder and DHCP server.
    [    7.360719] random: crng init done
    [    7.364120] random: 176 urandom warning(s) missed due to ratelimiting
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Network Manager Wait Online.
    [  OK  ] Started weston.service.
             Starting DEMO...
             Starting telnetd.service...
    [  OK  ] Started DEMO.
    [  OK  ] Started telnetd.service.
             Starting LSB: network connection manager...
    [  OK  ] Started LSB: network connection manager.
    Error: device 'enp1s0' not compatible with connection 'default'.
    [FAILED] Failed to start /etc/rc.local Compatibility.
    See 'systemctl status rc-local.service' for details.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Started Serial Getty on ttyS3.
    [  OK  ] Reached target Login Prompts.
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
  • Hi Yang,
    From the dmesg logs, it looks like PCIe is up:
    And based on the class code, it looks like some sort of ethernet controller is connected.
    However, is the device still not coming up under "/usr/sbin/lspci"?
    Takuma
