Part Number: AM625
My customer wants to know Pad diameter of BGA package (ALW).
Please see below diagram.
Could you provide this information?
Thanks and regards,
Koichiro Tashiro
Part Number: AM625
Thanks and regards,
Koichiro Tashiro
Hello Koichiro Tashiro,
Thank you for the query.
Help me understand the use case for the ball diameter.
I need to check internally.
Sreenivasa
Refer below inputs i received.
The ball diameter is 0.3mm
Sreenivasa
Hi Sreenivasa,
Thanks for your reply.
I think 0.3mm is the ball diameter. I thought it is written in datasheet.
What my customer is asking is "pad diameter on IC side".
Thanks and regards,
Koichiro Tashiro
Thank you for the note and understand.
Let me check and update you.
Sreenivasa
Looks like i did not add all the information in the previous message leading to confusion.
Please refer below:
Confirmed that our pkg solder ball pad (substrate pad) is 0.25mm
The recommendation is 1:1 ratio between PCB pad and substrate pad.
Refer below document:
Width/Spacing Proposal for Escapes
https://www.ti.com/lit/an/sprad13a/sprad13a.pdf
The recommendation is to use 0.25mm (10 mil) BGA landing pads to meet the requirements
Please let me know if this helps.
Sreenivasa
