I'm trying to configure Boot Mode pins in order to select xSPI Boot Mode as primary boot option (bootstrap SBL from an external NOR flash) and MMC/SD Card as backup boot optio
Can you confirm if you are trying OSPI boot mode or xSPI?
Fot TDA4VM the boot loaders support OSPI mode and not xSPI.
- Keerthy
Hello Keerthy,
Indeed I successfully tested the xSPI node as primary boot on my hardware. I cannot use OSPI with my NOR flash (that is a Cypress
Understood.
Your test looks right. Do you get any logs on the console?
Do you have a CCS JTAG? If yes you can connect to MCU r5f and check the PC.
Keerthy
