Part Number: TDA4VM
Dear Ti,
The init process uses port 22, but SSH cannot connect to TDA4.
How can I login with SSH?
Which SDK are you using?
Are you using the native linux driver or ethfw as your controller?
Are you able to ping the board.
Tanmay
SDK: ti-processor-sdk-linux-j7-evm-08_06_00_11-Linux-x86-Install.bin
filesystem: tisdk-default-image-j7-evm.tar.xz
using native linux driver.
I can ping the board.
Port 23 can be accessed using telnet, but SSH on port 22 cannot.
Ni Hua
Can you see if port 22 is visible in output of "netstat -tulpn".
Tanmay
Can you provide me the output of "systemctl list-units --all > systemctl-unit-log.txt". I will compare this with my setup and see if any services are inactive.
Please pipe the output to a txt file and share the txt file.
Tanmay
I couldn't see any significant service differences between your setup and mine. I am attaching my log here for your reference:
UNIT LOAD ACTIVE SUB DESCRIPTION dev-disk-by\x2did-mmc\x2dS0J56X_0x2f688aee.device loaded active plugged /dev/disk/by-id/mmc-S0J56X_0x2f688aee dev-disk-by\x2did-mmc\x2dS0J56X_0x2f688aee\x2dpart1.device loaded active plugged /dev/disk/by-id/mmc-S0J56X_0x2f688aee-part1 dev-disk-by\x2did-mmc\x2dS0J56X_0x2f688aee\x2dpart2.device loaded active plugged /dev/disk/by-id/mmc-S0J56X_0x2f688aee-part2 dev-disk-by\x2did-mmc\x2dSC16G_0x5cf2cea6.device loaded active plugged /dev/disk/by-id/mmc-SC16G_0x5cf2cea6 dev-disk-by\x2did-mmc\x2dSC16G_0x5cf2cea6\x2dpart1.device loaded active plugged /dev/disk/by-id/mmc-SC16G_0x5cf2cea6-part1 dev-disk-by\x2did-mmc\x2dSC16G_0x5cf2cea6\x2dpart2.device loaded active plugged /dev/disk/by-id/mmc-SC16G_0x5cf2cea6-part2 dev-disk-by\x2dlabel-boot.device loaded active plugged /dev/disk/by-label/boot dev-disk-by\x2dlabel-root.device loaded active plugged /dev/disk/by-label/root dev-disk-by\x2dlabel-rootfs.device loaded active plugged /dev/disk/by-label/rootfs dev-disk-by\x2dpartuuid-0cf58fbb\x2d01.device loaded active plugged /dev/disk/by-partuuid/0cf58fbb-01 dev-disk-by\x2dpartuuid-0cf58fbb\x2d02.device loaded active plugged /dev/disk/by-partuuid/0cf58fbb-02 dev-disk-by\x2dpartuuid-f65a2e4c\x2d01.device loaded active plugged /dev/disk/by-partuuid/f65a2e4c-01 dev-disk-by\x2dpartuuid-f65a2e4c\x2d02.device loaded active plugged /dev/disk/by-partuuid/f65a2e4c-02 dev-disk-by\x2dpath-platform\x2d4f80000.mmc.device loaded active plugged /dev/disk/by-path/platform-4f80000.mmc dev-disk-by\x2dpath-platform\x2d4f80000.mmc\x2dboot0.device loaded active plugged /dev/disk/by-path/platform-4f80000.mmc-boot0 dev-disk-by\x2dpath-platform\x2d4f80000.mmc\x2dboot1.device loaded active plugged /dev/disk/by-path/platform-4f80000.mmc-boot1 dev-disk-by\x2dpath-platform\x2d4f80000.mmc\x2dpart1.device loaded active plugged /dev/disk/by-path/platform-4f80000.mmc-part1 dev-disk-by\x2dpath-platform\x2d4f80000.mmc\x2dpart2.device loaded active plugged /dev/disk/by-path/platform-4f80000.mmc-part2 dev-disk-by\x2dpath-platform\x2d4fb0000.mmc.device loaded active plugged /dev/disk/by-path/platform-4fb0000.mmc dev-disk-by\x2dpath-platform\x2d4fb0000.mmc\x2dpart1.device loaded active plugged /dev/disk/by-path/platform-4fb0000.mmc-part1 dev-disk-by\x2dpath-platform\x2d4fb0000.mmc\x2dpart2.device loaded active plugged /dev/disk/by-path/platform-4fb0000.mmc-part2 dev-disk-by\x2duuid-0ADA\x2dE689.device loaded active plugged /dev/disk/by-uuid/0ADA-E689 dev-disk-by\x2duuid-8872\x2dFE7C.device loaded active plugged /dev/disk/by-uuid/8872-FE7C dev-disk-by\x2duuid-aa8cc558\x2d16c9\x2d470a\x2d9b00\x2d7d3dbb7055ae.device loaded active plugged /dev/disk/by-uuid/aa8cc558-16c9-470a-9b00-7d3dbb7055ae dev-disk-by\x2duuid-cd08850b\x2d3267\x2d45d0\x2da1c8\x2db63e1cfd5080.device loaded active plugged /dev/disk/by-uuid/cd08850b-3267-45d0-a1c8-b63e1cfd5080 dev-mmcblk0.device loaded active plugged /dev/mmcblk0 dev-mmcblk0boot0.device loaded active plugged /dev/mmcblk0boot0 dev-mmcblk0boot1.device loaded active plugged /dev/mmcblk0boot1 dev-mmcblk0p1.device loaded active plugged /dev/mmcblk0p1 dev-mmcblk0p2.device loaded active plugged /dev/mmcblk0p2 dev-mmcblk1.device loaded active plugged /dev/mmcblk1 dev-mmcblk1p1.device loaded active plugged /dev/mmcblk1p1 dev-mmcblk1p2.device loaded active plugged /dev/mmcblk1p2 dev-mtdblock0.device loaded active plugged /dev/mtdblock0 dev-mtdblock1.device loaded active plugged /dev/mtdblock1 dev-mtdblock2.device loaded active plugged /dev/mtdblock2 dev-mtdblock3.device loaded active plugged /dev/mtdblock3 dev-mtdblock4.device loaded active plugged /dev/mtdblock4 dev-mtdblock5.device loaded active plugged /dev/mtdblock5 dev-mtdblock6.device loaded active plugged /dev/mtdblock6 dev-rfkill.device loaded active plugged /dev/rfkill dev-ttyp0.device loaded active plugged /dev/ttyp0 dev-ttyp1.device loaded active plugged /dev/ttyp1 dev-ttyp2.device loaded active plugged /dev/ttyp2 dev-ttyp3.device loaded active plugged /dev/ttyp3 dev-ttyp4.device loaded active plugged /dev/ttyp4 dev-ttyp5.device loaded active plugged /dev/ttyp5 dev-ttyp6.device loaded active plugged /dev/ttyp6 dev-ttyp7.device loaded active plugged /dev/ttyp7 dev-ttyp8.device loaded active plugged /dev/ttyp8 dev-ttyp9.device loaded active plugged /dev/ttyp9 dev-ttypa.device loaded active plugged /dev/ttypa dev-ttypb.device loaded active plugged /dev/ttypb dev-ttypc.device loaded active plugged /dev/ttypc dev-ttypd.device loaded active plugged /dev/ttypd dev-ttype.device loaded active plugged /dev/ttype dev-ttypf.device loaded active plugged /dev/ttypf dev-ttyS0.device loaded active plugged /dev/ttyS0 dev-ttyS1.device loaded active plugged /dev/ttyS1 dev-ttyS2.device loaded active plugged /dev/ttyS2 dev-ttyS3.device loaded active plugged /dev/ttyS3 sys-devices-platform-bus\x40100000-2800000.serial-tty-ttyS2.device loaded active plugged /sys/devices/platform/bus@100000/2800000.serial/tty/ttyS2 sys-devices-platform-bus\x40100000-2810000.serial-tty-ttyS3.device loaded active plugged /sys/devices/platform/bus@100000/2810000.serial/tty/ttyS3 sys-devices-platform-bus\x40100000-4104000.cdns\x2dusb-6000000.usb-udc-6000000.usb.device loaded active plugged /sys/devices/platform/bus@100000/4104000.cdns-usb/6000000.usb/udc/6000000.usb sys-devices-platform-bus\x40100000-4f80000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0boot0.device loaded active plugged /sys/devices/platform/bus@100000/4f80000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot0 sys-devices-platform-bus\x40100000-4f80000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0boot1.device loaded active plugged /sys/devices/platform/bus@100000/4f80000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0boot1 sys-devices-platform-bus\x40100000-4f80000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p1.device loaded active plugged /sys/devices/platform/bus@100000/4f80000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1 sys-devices-platform-bus\x40100000-4f80000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p2.device loaded active plugged /sys/devices/platform/bus@100000/4f80000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2 sys-devices-platform-bus\x40100000-4f80000.mmc-mmc_host-mmc0-mmc0:0001-block-mmcblk0.device loaded active plugged /sys/devices/platform/bus@100000/4f80000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0 sys-devices-platform-bus\x40100000-4fb0000.mmc-mmc_host-mmc1-mmc1:aaaa-block-mmcblk1-mmcblk1p1.device loaded active plugged /sys/devices/platform/bus@100000/4fb0000.mmc/mmc_host/mmc1/mmc1:aaaa/block/mmcblk1/mmcblk1p1 sys-devices-platform-bus\x40100000-4fb0000.mmc-mmc_host-mmc1-mmc1:aaaa-block-mmcblk1-mmcblk1p2.device loaded active plugged /sys/devices/platform/bus@100000/4fb0000.mmc/mmc_host/mmc1/mmc1:aaaa/block/mmcblk1/mmcblk1p2 sys-devices-platform-bus\x40100000-4fb0000.mmc-mmc_host-mmc1-mmc1:aaaa-block-mmcblk1.device loaded active plugged /sys/devices/platform/bus@100000/4fb0000.mmc/mmc_host/mmc1/mmc1:aaaa/block/mmcblk1 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-40a00000.serial-tty-ttyS1.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/40a00000.serial/tty/ttyS1 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-46000000.ethernet-net-eth0.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/46000000.ethernet/net/eth0 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-47000000.syscon-47040000.spi-spi_master-spi0-spi0.0-mtd-mtd0-mtdblock0.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/47000000.syscon/47040000.spi/spi_master/spi0/spi0.0/mtd/mtd0/mtdblock0 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-47000000.syscon-47040000.spi-spi_master-spi0-spi0.0-mtd-mtd1-mtdblock1.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/47000000.syscon/47040000.spi/spi_master/spi0/spi0.0/mtd/mtd1/mtdblock1 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-47000000.syscon-47040000.spi-spi_master-spi0-spi0.0-mtd-mtd2-mtdblock2.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/47000000.syscon/47040000.spi/spi_master/spi0/spi0.0/mtd/mtd2/mtdblock2 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-47000000.syscon-47040000.spi-spi_master-spi0-spi0.0-mtd-mtd3-mtdblock3.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/47000000.syscon/47040000.spi/spi_master/spi0/spi0.0/mtd/mtd3/mtdblock3 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-47000000.syscon-47040000.spi-spi_master-spi0-spi0.0-mtd-mtd4-mtdblock4.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/47000000.syscon/47040000.spi/spi_master/spi0/spi0.0/mtd/mtd4/mtdblock4 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-47000000.syscon-47040000.spi-spi_master-spi0-spi0.0-mtd-mtd5-mtdblock5.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/47000000.syscon/47040000.spi/spi_master/spi0/spi0.0/mtd/mtd5/mtdblock5 sys-devices-platform-bus\x40100000-bus\x40100000:bus\x4028380000-47000000.syscon-47040000.spi-spi_master-spi0-spi0.0-mtd-mtd6-mtdblock6.device loaded active plugged /sys/devices/platform/bus@100000/bus@100000:bus@28380000/47000000.syscon/47040000.spi/spi_master/spi0/spi0.0/mtd/mtd6/mtdblock6 sys-devices-platform-bus\x40100000-c000000.ethernet-net-eth1.device loaded active plugged /sys/devices/platform/bus@100000/c000000.ethernet/net/eth1 sys-devices-platform-bus\x40100000-c000000.ethernet-net-eth2.device loaded active plugged /sys/devices/platform/bus@100000/c000000.ethernet/net/eth2 sys-devices-platform-bus\x40100000-c000000.ethernet-net-eth3.device loaded active plugged /sys/devices/platform/bus@100000/c000000.ethernet/net/eth3 sys-devices-platform-bus\x40100000-c000000.ethernet-net-eth4.device loaded active plugged /sys/devices/platform/bus@100000/c000000.ethernet/net/eth4 sys-devices-platform-serial8250-tty-ttyS0.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS0 sys-devices-virtual-misc-rfkill.device loaded active plugged /sys/devices/virtual/misc/rfkill sys-devices-virtual-tty-ttyp0.device loaded active plugged /sys/devices/virtual/tty/ttyp0 sys-devices-virtual-tty-ttyp1.device loaded active plugged /sys/devices/virtual/tty/ttyp1 sys-devices-virtual-tty-ttyp2.device loaded active plugged /sys/devices/virtual/tty/ttyp2 sys-devices-virtual-tty-ttyp3.device loaded active plugged /sys/devices/virtual/tty/ttyp3 sys-devices-virtual-tty-ttyp4.device loaded active plugged /sys/devices/virtual/tty/ttyp4 sys-devices-virtual-tty-ttyp5.device loaded active plugged /sys/devices/virtual/tty/ttyp5 sys-devices-virtual-tty-ttyp6.device loaded active plugged /sys/devices/virtual/tty/ttyp6 sys-devices-virtual-tty-ttyp7.device loaded active plugged /sys/devices/virtual/tty/ttyp7 sys-devices-virtual-tty-ttyp8.device loaded active plugged /sys/devices/virtual/tty/ttyp8 sys-devices-virtual-tty-ttyp9.device loaded active plugged /sys/devices/virtual/tty/ttyp9 sys-devices-virtual-tty-ttypa.device loaded active plugged /sys/devices/virtual/tty/ttypa sys-devices-virtual-tty-ttypb.device loaded active plugged /sys/devices/virtual/tty/ttypb sys-devices-virtual-tty-ttypc.device loaded active plugged /sys/devices/virtual/tty/ttypc sys-devices-virtual-tty-ttypd.device loaded active plugged /sys/devices/virtual/tty/ttypd sys-devices-virtual-tty-ttype.device loaded active plugged /sys/devices/virtual/tty/ttype sys-devices-virtual-tty-ttypf.device loaded active plugged /sys/devices/virtual/tty/ttypf sys-module-configfs.device loaded active plugged /sys/module/configfs sys-module-fuse.device loaded active plugged /sys/module/fuse sys-subsystem-net-devices-eth0.device loaded active plugged /sys/subsystem/net/devices/eth0 sys-subsystem-net-devices-eth1.device loaded active plugged /sys/subsystem/net/devices/eth1 sys-subsystem-net-devices-eth2.device loaded active plugged /sys/subsystem/net/devices/eth2 sys-subsystem-net-devices-eth3.device loaded active plugged /sys/subsystem/net/devices/eth3 sys-subsystem-net-devices-eth4.device loaded active plugged /sys/subsystem/net/devices/eth4 -.mount loaded active mounted Root Mount dev-hugepages.mount loaded active mounted Huge Pages File System dev-mqueue.mount loaded active mounted POSIX Message Queue File System * home.mount not-found inactive dead home.mount media-ram.mount loaded active mounted /media/ram run-media-boot\x2dmmcblk0p1.mount loaded active mounted /run/media/boot-mmcblk0p1 run-media-boot\x2dmmcblk1p1.mount loaded active mounted /run/media/boot-mmcblk1p1 run-media-rootfs\x2dmmcblk0p2.mount loaded active mounted /run/media/rootfs-mmcblk0p2 run-user-0.mount loaded active mounted /run/user/0 sys-fs-fuse-connections.mount loaded active mounted FUSE Control File System sys-kernel-config.mount loaded active mounted Kernel Configuration File System sys-kernel-debug.mount loaded active mounted Kernel Debug File System sys-kernel-tracing.mount loaded inactive dead Kernel Trace File System tmp.mount loaded active mounted Temporary Directory /tmp var-volatile.mount loaded active mounted /var/volatile systemd-ask-password-console.path loaded active waiting Dispatch Password Requests to Console Directory Watch systemd-ask-password-wall.path loaded active waiting Forward Password Requests to Wall Directory Watch init.scope loaded active running System and Service Manager session-c2.scope loaded active running Session c2 of User root atd.service loaded active running Job spooling tools * auditd.service not-found inactive dead auditd.service avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack bt-enable.service loaded inactive dead Enable and configure wl18xx bluetooth stack * connman.service not-found inactive dead connman.service console-kit-log-system-start.service loaded active exited Console System Startup Logging containerd.service loaded active running containerd container runtime crond.service loaded active running Periodic Command Scheduler dbus-broker.service loaded active running D-Bus System Message Bus * display-manager.service not-found inactive dead display-manager.service docker.service loaded inactive dead Docker Application Container Engine dropbear.service loaded inactive dead LSB: Dropbear Secure Shell server emergency.service loaded inactive dead Emergency Shell * firewalld.service not-found inactive dead firewalld.service getty@tty1.service loaded active running Getty on tty1 gplv3-notice.service loaded inactive dead Print notice about GPLv3 packages initrd-cleanup.service loaded inactive dead Cleaning Up and Shutting Down Daemons initrd-parse-etc.service loaded inactive dead Reload Configuration from the Real Root initrd-switch-root.service loaded inactive dead Switch Root initrd-udevadm-cleanup-db.service loaded inactive dead Cleanup udev Database ip6tables.service loaded active exited IPv6 Packet Filtering Framework iptables.service loaded active exited IPv4 Packet Filtering Framework irqbalanced.service loaded active running irqbalance daemon kdump.service loaded active exited Reboot and dump vmcore via kexec kmod-static-nodes.service loaded active exited Create List of Static Device Nodes ldconfig.service loaded inactive dead Rebuild Dynamic Linker Cache logrotate.service loaded inactive dead Rotate log files modprobe@configfs.service loaded inactive dead Load Kernel Module configfs modprobe@drm.service loaded inactive dead Load Kernel Module drm modprobe@fuse.service loaded inactive dead Load Kernel Module fuse netperf.service loaded active exited LSB: network benchmark netserver.service loaded active running Netperf Benchmark Server nfs-statd.service loaded active running NFS status monitor for NFSv2/3 locking. ofono.service loaded active running Telephony service * plymouth-quit-wait.service not-found inactive dead plymouth-quit-wait.service * plymouth-start.service not-found inactive dead plymouth-start.service rc-local.service loaded inactive dead /etc/rc.local Compatibility rescue.service loaded inactive dead Rescue Shell resize_rootfs.service loaded active exited Expand the rootfs partition to full size of the boot device. rpcbind.service loaded active running RPC Bind * run-postinsts.service not-found inactive dead run-postinsts.service serial-getty@ttyS2.service loaded active running Serial Getty on ttyS2 strongswan-starter.service loaded active running strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf sync-clocks.service loaded inactive dead Synchronize System and HW clocks * syslog.service not-found inactive dead syslog.service systemd-ask-password-console.service loaded inactive dead Dispatch Password Requests to Console systemd-ask-password-wall.service loaded inactive dead Forward Password Requests to Wall systemd-fsck-root.service loaded inactive dead File System Check on Root Device systemd-fsck@dev-mmcblk0p1.service loaded active exited File System Check on /dev/mmcblk0p1 systemd-fsck@dev-mmcblk0p2.service loaded active exited File System Check on /dev/mmcblk0p2 systemd-fsck@dev-mmcblk1p1.service loaded active exited File System Check on /dev/mmcblk1p1 systemd-hwdb-update.service loaded inactive dead Rebuild Hardware Database systemd-initctl.service loaded inactive dead initctl Compatibility Daemon systemd-journal-catalog-update.service loaded inactive dead Rebuild Journal Catalog systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage systemd-journald.service loaded active running Journal Service systemd-logind.service loaded active running User Login Management systemd-machine-id-commit.service loaded inactive dead Commit a transient machine-id on disk systemd-modules-load.service loaded active exited Load Kernel Modules systemd-network-generator.service loaded active exited Generate network units from Kernel command line * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured systemd-networkd.service loaded active running Network Configuration systemd-pstore.service loaded inactive dead Platform Persistent Storage Archival systemd-quotacheck.service loaded inactive dead File System Quota Check systemd-random-seed.service loaded active exited Load/Save Random Seed systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems systemd-resolved.service loaded active running Network Name Resolution systemd-rfkill.service loaded inactive dead Load/Save RF Kill Switch Status systemd-sysctl.service loaded active exited Apply Kernel Variables systemd-sysusers.service loaded inactive dead Create System Users systemd-timesyncd.service loaded active running Network Time Synchronization systemd-tmpfiles-clean.service loaded inactive dead Cleanup of Temporary Directories systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories systemd-udev-settle.service loaded inactive dead Wait for udev To Complete Device Initialization systemd-udev-trigger.service loaded active exited Coldplug All udev Devices systemd-udevd.service loaded active running Rule-based Manager for Device Events and Files systemd-update-done.service loaded inactive dead Update is Completed systemd-update-utmp-runlevel.service loaded inactive dead Record Runlevel Change in UTMP systemd-update-utmp.service loaded active exited Record System Boot/Shutdown in UTMP systemd-user-sessions.service loaded active exited Permit User Sessions systemd-userdbd.service loaded active running User Database Manager systemd-vconsole-setup.service loaded inactive dead Setup Virtual Console tee-supplicant.service loaded active running TEE Supplicant telnetd.service loaded active running telnetd.service thermal-zone-init.service loaded active exited thermal-zone-init.service user-runtime-dir@0.service loaded active exited User Runtime Directory /run/user/0 user@0.service loaded active running User Manager for UID 0 var-volatile-cache.service loaded inactive dead Bind mount volatile /var/cache var-volatile-lib.service loaded inactive dead Bind mount volatile /var/lib var-volatile-spool.service loaded inactive dead Bind mount volatile /var/spool var-volatile-srv.service loaded inactive dead Bind mount volatile /srv * weston.service loaded failed failed Weston, a Wayland compositor, as a system service -.slice loaded active active Root Slice system-dropbear.slice loaded active active Slice /system/dropbear system-getty.slice loaded active active Slice /system/getty system-modprobe.slice loaded active active Slice /system/modprobe system-serial\x2dgetty.slice loaded active active Slice /system/serial-getty system-systemd\x2dfsck.slice loaded active active Slice /system/systemd-fsck system.slice loaded active active System Slice user-0.slice loaded active active User Slice of UID 0 user.slice loaded active active User and Session Slice avahi-daemon.socket loaded active running Avahi mDNS/DNS-SD Stack Activation Socket dbus.socket loaded active running D-Bus System Message Bus Socket docker.socket loaded active listening Docker Socket for the API dropbear.socket loaded active listening dropbear.socket rpcbind.socket loaded active running RPCbind Server Activation Socket syslog.socket loaded inactive dead Syslog Socket systemd-coredump.socket loaded active listening Process Core Dump Socket systemd-initctl.socket loaded active listening initctl Compatibility Named Pipe systemd-journald-audit.socket loaded active running Journal Audit Socket systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log) systemd-journald.socket loaded active running Journal Socket systemd-networkd.socket loaded active running Network Service Netlink Socket systemd-rfkill.socket loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch systemd-udevd-control.socket loaded active running udev Control Socket systemd-udevd-kernel.socket loaded active running udev Kernel Socket systemd-userdbd.socket loaded active running User Database Manager Socket weston.socket loaded active listening Weston socket basic.target loaded active active Basic System blockdev@dev-mmcblk0p1.target loaded inactive dead Block Device Preparation for /dev/mmcblk0p1 blockdev@dev-mmcblk0p2.target loaded inactive dead Block Device Preparation for /dev/mmcblk0p2 blockdev@dev-mmcblk1p1.target loaded inactive dead Block Device Preparation for /dev/mmcblk1p1 blockdev@dev-root.target loaded inactive dead Block Device Preparation for /dev/root * cryptsetup.target not-found inactive dead cryptsetup.target emergency.target loaded inactive dead Emergency Mode first-boot-complete.target loaded inactive dead First Boot Complete getty-pre.target loaded inactive dead Preparation for Logins getty.target loaded active active Login Prompts graphical.target loaded active active Graphical Interface initrd-fs.target loaded inactive dead Initrd File Systems initrd-root-device.target loaded inactive dead Initrd Root Device initrd-root-fs.target loaded inactive dead Initrd Root File System initrd-switch-root.target loaded inactive dead Switch Root initrd-usr-fs.target loaded inactive dead Initrd /usr File System initrd.target loaded inactive dead Initrd Default Target local-fs-pre.target loaded active active Preparation for Local File Systems local-fs.target loaded active active Local File Systems multi-user.target loaded active active Multi-User System network-online.target loaded active active Network is Online network-pre.target loaded active active Preparation for Network network.target loaded active active Network * networking.target not-found inactive dead networking.target nss-lookup.target loaded active active Host and Network Name Lookups nss-user-lookup.target loaded inactive dead User and Group Name Lookups paths.target loaded active active Path Units remote-fs-pre.target loaded inactive dead Preparation for Remote File Systems remote-fs.target loaded active active Remote File Systems rescue.target loaded inactive dead Rescue Mode rpcbind.target loaded active active RPC Port Mapper shutdown.target loaded inactive dead System Shutdown slices.target loaded active active Slice Units sockets.target loaded active active Socket Units swap.target loaded active active Swaps sysinit.target loaded active active System Initialization * syslog.target not-found inactive dead syslog.target time-set.target loaded active active System Time Set time-sync.target loaded inactive dead System Time Synchronized timers.target loaded active active Timer Units umount.target loaded inactive dead Unmount All Filesystems usb-gadget.target loaded active active Hardware activated USB gadget logrotate.timer loaded active waiting Daily rotation of log files systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporary Directories LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 292 loaded units listed. To show all installed unit files use 'systemctl list-unit-files'.
Can you ssh to the loopbak interface (127.0.0.1)?
Are you able to do iperf/netperf profiling? Do you see any issues with that. What I am going for here is if you are able to have other TCP/UDP traffic? If this is possible, then It might be problem with he ssh binary itself.
Tanmay
Not sure what the could be in this case.
Maybe you can gain more insight in this issue if you reach out to linux community in this case. The TI owned components (Hardware and device drivers) are working as expected here. The issue is elsewhere.
Tanmay
