Part Number: SK-AM62A-LP
Hii,
After u-boot AM62-LP kernel panic.
i have attached log file.
and in sd card has 2 partition
boot:-
tiboot3.bin
tispl.bin
u-boot.img
rootfs:-
boot
lib -> modules -> etc..
i think rootfile system not properly installed.
for building sdk
i have follow below steps as per documentation.
steps:-
1: build linux kerne PLATFORM=am62xx-lp-evm make linux
2: build u-boot make u-boot PLATFORM=am62xx-lp-evm
3: for install sudo DESTDIR=/media/$USER/rootfs PLATFORM=am62xx-lp-evm make linux_install
4: For install uboot sudo DESTDIR=/media/$USER/boot PLATFORM=am62xx-lp-evm make u-boot_install
Booting log
____________
U-Boot SPL 2023.04-00001-gf5b119738d (Dec 12 2023 - 11:10:36 +0530)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
SPL initial stack usage: 13376 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 00:42:57, Jan 13 2023
U-Boot SPL 2023.04-00001-gf5b119738d (Dec 12 2023 - 11:10:45 +0530)
U-Boot 2023.04-00001-gf5b119738d (Dec 12 2023 - 11:10:45 +0530)
SoC: AM62X SR1.0 HS-FS
Model: Texas Instruments AM62x LP SK
EEPROM not available at 80, trying to read at 81
Board: AM62-LP-SKEVM rev E2
DRAM: 2 GiB
Core: 78 devices, 30 uclasses, devicetree: separate
NAND: 0 MiB
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
## Error: "main_cpsw0_qsgmii_phyinit" not defined
20593152 bytes read in 235 ms (83.6 MiB/s)
57399 bytes read in 15 ms (3.6 MiB/s)
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.33-00001-ge4769b223d98 (praveen@praveen-Precisi on-7770) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 202207 12, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Tue Dec 1 2 10:33:51 IST 2023
[ 0.000000] Machine model: Texas Instruments AM62x LP SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, s ize 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, s ize 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compati ble id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, s ize 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compa tible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, s ize 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatibl e id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, s ize 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compa tible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, s ize 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatibl e id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmi o32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-bo ot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(os pi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.back up),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.fi le-system) root=PARTUUID=12c85bbf-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1838092K/2097152K available (12480K kernel code, 1294K rw data, 4044K rodata, 2176K init, 498K bss, 127988K reserved, 131072K cma-reserved )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->1 9
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000008005000 0
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles : 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 43980 46511102ns
[ 0.008560] Console: colour dummy device 80x25
[ 0.013157] Calibrating delay loop (skipped), value calculated using timer fr equency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023839] pid_max: default: 32768 minimum: 301
[ 0.028615] LSM: Security Framework initializing
[ 0.033476] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, line ar)
[ 0.041062] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.050981] cblist_init_generic: Setting adjustable number of callback queues .
[ 0.058447] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.064752] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.071157] rcu: Hierarchical SRCU implementation.
[ 0.076066] rcu: Max phase no-delay instances is 1000.
[ 0.081683] Platform MSI: msi-controller@1820000 domain created
[ 0.088010] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1 820000 domain created
[ 0.097895] EFI services will not be available.
[ 0.102828] smp: Bringing up secondary CPUs ...
[ 0.108164] Detected VIPT I-cache on CPU1
[ 0.108292] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.108311] GICv3: CPU1: using allocated LPI pending table @0x000000008006000 0
[ 0.108371] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.109099] Detected VIPT I-cache on CPU2
[ 0.109183] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.109198] GICv3: CPU2: using allocated LPI pending table @0x000000008007000 0
[ 0.109234] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.109886] Detected VIPT I-cache on CPU3
[ 0.109971] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.109985] GICv3: CPU3: using allocated LPI pending table @0x000000008008000 0
[ 0.110016] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.110091] smp: Brought up 1 node, 4 CPUs
[ 0.189824] SMP: Total of 4 processors activated.
[ 0.194637] CPU features: detected: 32-bit EL0 Support
[ 0.199911] CPU features: detected: CRC32 instructions
[ 0.205237] CPU: All CPU(s) started at EL2
[ 0.209435] alternatives: applying system-wide alternatives
[ 0.217117] devtmpfs: initialized
[ 0.228893] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.238903] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.250929] pinctrl core: initialized pinctrl subsystem
[ 0.256954] DMI not present or invalid.
[ 0.261556] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.268894] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.276465] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allo cations
[ 0.284579] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic al locations
[ 0.292770] audit: initializing netlink subsys (disabled)
[ 0.298488] audit: type=2000 audit(0.192:1): state=initialized audit_enabled= 0 res=1
[ 0.298987] thermal_sys: Registered thermal governor 'step_wise'
[ 0.306420] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.312608] cpuidle: using governor menu
[ 0.323481] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.330519] ASID allocator initialised with 65536 entries
[ 0.346629] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/ i2c@20010000/sii9022@3b
[ 0.357752] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c @20010000/sii9022@3b
[ 0.368106] KASLR disabled due to lack of seed
[ 0.379881] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.386859] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.393269] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.400208] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.406616] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.413555] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.419962] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.426901] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.435167] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7 e02f] Detected
[ 0.445119] iommu: Default domain type: Translated
[ 0.450140] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.456882] SCSI subsystem initialized
[ 0.461117] usbcore: registered new interface driver usbfs
[ 0.466765] usbcore: registered new interface driver hub
[ 0.472222] usbcore: registered new device driver usb
[ 0.477948] pps_core: LinuxPPS API ver. 1 registered
[ 0.483030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.492382] PTP clock support registered
[ 0.496514] EDAC MC: Ver: 3.0.0
[ 0.500693] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.507832] FPGA manager framework
[ 0.511419] Advanced Linux Sound Architecture Driver Initialized.
[ 0.518666] clocksource: Switched to clocksource arch_sys_counter
[ 0.525180] VFS: Disk quotas dquot_6.6.0
[ 0.529238] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.542330] NET: Registered PF_INET protocol family
[ 0.547651] IP idents hash table entries: 32768 (order: 6, 262144 bytes, line ar)
[ 0.556923] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 1638 4 bytes, linear)
[ 0.565737] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.573679] TCP established hash table entries: 16384 (order: 5, 131072 bytes , linear)
[ 0.581884] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linea r)
[ 0.589972] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.596904] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.603833] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.611400] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.617700] RPC: Registered named UNIX socket transport module.
[ 0.623783] RPC: Registered udp transport module.
[ 0.628592] RPC: Registered tcp transport module.
[ 0.633401] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.639993] NET: Registered PF_XDP protocol family
[ 0.644907] PCI: CLS 0 bytes, default 64
[ 0.649759] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte rs available
[ 0.659882] Initialise system trusted keyrings
[ 0.664756] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.677253] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.683995] NFS: Registering the id_resolver key type
[ 0.689231] Key type id_resolver registered
[ 0.693509] Key type id_legacy registered
[ 0.697676] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.704532] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ...
[ 0.712311] 9p: Installing v9fs 9p2000 file system support
[ 0.752652] Key type asymmetric registered
[ 0.756842] Asymmetric key parser 'x509' registered
[ 0.761882] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 45)
[ 0.769632] io scheduler mq-deadline registered
[ 0.774270] io scheduler kyber registered
[ 0.781680] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.788256] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.801578] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.816594] loop: module loaded
[ 0.821139] megasas: 07.719.03.00-rc1
[ 0.829075] tun: Universal TUN/TAP device driver, 1.6
[ 0.835050] thunder_xcv, ver 1.0
[ 0.838378] thunder_bgx, ver 1.0
[ 0.841709] nicpf, ver 1.0
[ 0.844879] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versio n
[ 0.852269] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.857762] hclge is initializing
[ 0.861173] e1000: Intel(R) PRO/1000 Network Driver
[ 0.866160] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.872079] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.877154] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.883236] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.888757] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.894479] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.900887] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.907077] sky2: driver version 1.30
[ 0.911541] VFIO - User Level meta-driver version: 0.3
[ 0.917642] usbcore: registered new interface driver usb-storage
[ 0.924574] i2c_dev: i2c /dev entries driver
[ 0.931121] sdhci: Secure Digital Host Controller Interface driver
[ 0.937466] sdhci: Copyright(c) Pierre Ossman
[ 0.942420] Synopsys Designware Multimedia Card Interface Driver
[ 0.949009] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.955869] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.962236] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.969208] usbcore: registered new interface driver usbhid
[ 0.974924] usbhid: USB HID core driver
[ 0.980160] optee: probing for conduit method.
[ 0.984766] optee: revision 3.20 (8e74d476)
[ 0.985093] optee: dynamic shared memory is enabled
[ 0.994636] optee: initialized driver
[ 1.000247] Initializing XFRM netlink socket
[ 1.004680] NET: Registered PF_PACKET protocol family
[ 1.010004] 9pnet: Installing 9P2000 support
[ 1.014448] Key type dns_resolver registered
[ 1.019412] registered taskstats version 1
[ 1.023652] Loading compiled-in X.509 certificates
[ 1.037456] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
[ 1.125951] VDDSHV_SDIO: bypassed regulator has no supply!
[ 1.135523] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.143579] pca953x 1-0023: supply vcc not found, using dummy regulator
[ 1.150518] pca953x 1-0023: using AI
[ 1.176802] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.183918] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.189938] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 doma in created
[ 1.198290] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Rout er 3 domain created
[ 1.207532] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator d omain 28 created
[ 1.217476] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.225797] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.236950] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.247137] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.257411] printk: console [ttyS2] disabled
[ 1.261879] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 289, base_baud = 3 000000) is a 8250
[ 1.270781] printk: console [ttyS2] enabled
[ 1.279240] printk: bootconsole [ns16550a0] disabled
[ 1.291788] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.297128] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, O OB size: 128
[ 1.305492] 7 fixed-partitions partitions found on MTD device spi0.0
[ 1.311849] Creating 7 MTD partitions on "spi0.0":
[ 1.316637] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
[ 1.324122] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
[ 1.331947] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
[ 1.340477] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
[ 1.347344] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
[ 1.354803] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[ 1.397640] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[ 1.406610] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.450692] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 10 00000
[ 1.459597] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.467741] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss vers ion 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.480532] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.487660] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.494385] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000 000, add_val:1 pps:0
[ 1.505082] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.516173] mmc0: CQHCI version 5.10
[ 1.523068] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.529845] pca953x 1-0022: using AI
[ 1.540534] debugfs: Directory 'pd:182' with parent 'pm_genpd' already presen t!
[ 1.541555] mmc1: CQHCI version 5.10
[ 1.561351] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64 -bit
[ 1.562186] ALSA device list:
[ 1.571863] No soundcards found.
[ 1.593044] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64 -bit
[ 1.600821] Waiting for root device PARTUUID=12c85bbf-02...
[ 1.649640] mmc0: Command Queue Engine enabled
[ 1.654128] mmc0: new HS200 MMC card at address 0001
[ 1.660891] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.662064] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.672303] mmcblk0: p1 p2
[ 1.673197] mmcblk1: mmc1:aaaa JULIE 29.7 GiB
[ 1.675929] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 1.684710] mmcblk1: p1 p2
[ 1.685838] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 1.693518] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
[ 1.744368] EXT4-fs (mmcblk1p2): recovery complete
[ 1.749230] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.757830] VFS: Mounted root (ext4 filesystem) on device 179:34.
[ 1.766839] devtmpfs: error mounting -2
[ 1.772134] Freeing unused kernel memory: 2176K
[ 1.776854] Run /sbin/init as init process
[ 1.781280] Run /etc/init as init process
[ 1.785406] Run /bin/init as init process
[ 1.789478] Run /bin/sh as init process
[ 1.793365] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[ 1.807509] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.1.33-00001-ge4769b223d98 #1
[ 1.815151] Hardware name: Texas Instruments AM62x LP SK (DT)
[ 1.820884] Call trace:
[ 1.823321] dump_backtrace.part.0+0xdc/0xf0
[ 1.827601] show_stack+0x18/0x30
[ 1.830908] dump_stack_lvl+0x68/0x84
[ 1.834568] dump_stack+0x18/0x34
[ 1.837877] panic+0x184/0x344
[ 1.840926] kernel_init+0x124/0x130
[ 1.844492] ret_from_fork+0x10/0x20
[ 1.848061] SMP: stopping secondary CPUs
[ 1.851978] Kernel Offset: disabled
[ 1.855453] CPU features: 0x00000,00800084,0000420b
[ 1.860317] Memory Limit: none
[ 1.863368] ---[ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance. ]---
