SK-AM62-LP: Kernel panic - not syncing: No working init found.
Part Number: SK-AM62-LP
Other Parts Discussed in Thread: SK-AM62A-LP,
Hii,
After u-boot AM62-LP kernel panic.
i have attached log file.
and in sd card has 2 partition
boot:-
tiboot3.bin
tispl.bin
u-boot.img
rootfs:-
boot
lib -> modules -> etc..
i think rootfile system not properly installed.
for building sdk
i have follow below steps as per documentation.
steps:-
1: build linux kerne PLATFORM=am62xx-lp-evm make linux
2: build u-boot make u-boot PLATFORM=am62xx-lp-evm
3: for install sudo DESTDIR=/media/$USER/rootfs PLATFORM=am62xx-lp-evm make linux_install
4: For install uboot sudo DESTDIR=/media/$USER/boot PLATFORM=am62xx-lp-evm make u-boot_install
Booting log
____________
U-Boot SPL 2023.04-00001-gf5b119738d (Dec 12 2023 - 11:10:36 +0530)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
SPL initial stack usage: 13376 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty
NOTICE: BL31: Built : 00:42:57, Jan 13 2023
U-Boot SPL 2023.04-00001-gf5b119738d (Dec 12 2023 - 11:10:45 +0530)
U-Boot 2023.04-00001-gf5b119738d (Dec 12 2023 - 11:10:45 +0530)
SoC: AM62X SR1.0 HS-FS
Model: Texas Instruments AM62x LP SK
EEPROM not available at 80, trying to read at 81
Board: AM62-LP-SKEVM rev E2
DRAM: 2 GiB
Core: 78 devices, 30 uclasses, devicetree: separate
NAND: 0 MiB
MMC: mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: eth0: ethernet@8000000port@1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
## Error: "main_cpsw0_qsgmii_phyinit" not defined
20593152 bytes read in 235 ms (83.6 MiB/s)
57399 bytes read in 15 ms (3.6 MiB/s)
Working FDT set to 88000000
ERROR: reserving fdt memory region failed (addr=ff700000 size=8ca000 flags=4)
Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK
Working FDT set to 8feee000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.33-00001-ge4769b223d98 (praveen@praveen-Precisi on-7770) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 202207 12, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 SMP PREEMPT Tue Dec 1 2 10:33:51 IST 2023
[ 0.000000] Machine model: Texas Instruments AM62x LP SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, s ize 128 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, s ize 3 MiB
[ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compati ble id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, s ize 1 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compa tible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, s ize 14 MiB
[ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatibl e id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, s ize 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compa tible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, s ize 12 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatibl e id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff]
[ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff]
[ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000fffc9fff]
[ 0.000000] node 0: [mem 0x00000000fffca000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 19 pages/cpu s38376 r8192 d31256 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmi o32,0x02800000 mtdparts=spi-nand0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-bo ot),256k(ospi.env),256k(ospi.env.backup),98048k@32m(ospi.rootfs),256k@130816k(os pi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.back up),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.fi le-system) root=PARTUUID=12c85bbf-02 rw rootfstype=ext4 rootwait
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1838092K/2097152K available (12480K kernel code, 1294K rw data, 4044K rodata, 2176K init, 498K bss, 127988K reserved, 131072K cma-reserved )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->1 9
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000080040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000008005000 0
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles : 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 43980 46511102ns
[ 0.008560] Console: colour dummy device 80x25
[ 0.013157] Calibrating delay loop (skipped), value calculated using timer fr equency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023839] pid_max: default: 32768 minimum: 301
[ 0.028615] LSM: Security Framework initializing
[ 0.033476] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, line ar)
[ 0.041062] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.050981] cblist_init_generic: Setting adjustable number of callback queues .
[ 0.058447] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.064752] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.071157] rcu: Hierarchical SRCU implementation.
[ 0.076066] rcu: Max phase no-delay instances is 1000.
[ 0.081683] Platform MSI: msi-controller@1820000 domain created
[ 0.088010] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1 820000 domain created
[ 0.097895] EFI services will not be available.
[ 0.102828] smp: Bringing up secondary CPUs ...
[ 0.108164] Detected VIPT I-cache on CPU1
[ 0.108292] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.108311] GICv3: CPU1: using allocated LPI pending table @0x000000008006000 0
[ 0.108371] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.109099] Detected VIPT I-cache on CPU2
[ 0.109183] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.109198] GICv3: CPU2: using allocated LPI pending table @0x000000008007000 0
[ 0.109234] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.109886] Detected VIPT I-cache on CPU3
[ 0.109971] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.109985] GICv3: CPU3: using allocated LPI pending table @0x000000008008000 0
[ 0.110016] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.110091] smp: Brought up 1 node, 4 CPUs
[ 0.189824] SMP: Total of 4 processors activated.
[ 0.194637] CPU features: detected: 32-bit EL0 Support
[ 0.199911] CPU features: detected: CRC32 instructions
[ 0.205237] CPU: All CPU(s) started at EL2
[ 0.209435] alternatives: applying system-wide alternatives
[ 0.217117] devtmpfs: initialized
[ 0.228893] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns
[ 0.238903] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.250929] pinctrl core: initialized pinctrl subsystem
[ 0.256954] DMI not present or invalid.
[ 0.261556] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.268894] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.276465] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allo cations
[ 0.284579] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic al locations
[ 0.292770] audit: initializing netlink subsys (disabled)
[ 0.298488] audit: type=2000 audit(0.192:1): state=initialized audit_enabled= 0 res=1
[ 0.298987] thermal_sys: Registered thermal governor 'step_wise'
[ 0.306420] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.312608] cpuidle: using governor menu
[ 0.323481] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.330519] ASID allocator initialised with 65536 entries
[ 0.346629] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/ i2c@20010000/sii9022@3b
[ 0.357752] platform connector: Fixed dependency cycle(s) with /bus@f0000/i2c @20010000/sii9022@3b
[ 0.368106] KASLR disabled due to lack of seed
[ 0.379881] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.386859] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.393269] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.400208] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.406616] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.413555] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.419962] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.426901] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.435167] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7 e02f] Detected
[ 0.445119] iommu: Default domain type: Translated
[ 0.450140] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.456882] SCSI subsystem initialized
[ 0.461117] usbcore: registered new interface driver usbfs
[ 0.466765] usbcore: registered new interface driver hub
[ 0.472222] usbcore: registered new device driver usb
[ 0.477948] pps_core: LinuxPPS API ver. 1 registered
[ 0.483030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.492382] PTP clock support registered
[ 0.496514] EDAC MC: Ver: 3.0.0
[ 0.500693] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[ 0.507832] FPGA manager framework
[ 0.511419] Advanced Linux Sound Architecture Driver Initialized.
[ 0.518666] clocksource: Switched to clocksource arch_sys_counter
[ 0.525180] VFS: Disk quotas dquot_6.6.0
[ 0.529238] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.542330] NET: Registered PF_INET protocol family
[ 0.547651] IP idents hash table entries: 32768 (order: 6, 262144 bytes, line ar)
[ 0.556923] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 1638 4 bytes, linear)
[ 0.565737] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.573679] TCP established hash table entries: 16384 (order: 5, 131072 bytes , linear)
[ 0.581884] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linea r)
[ 0.589972] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.596904] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.603833] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.611400] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.617700] RPC: Registered named UNIX socket transport module.
[ 0.623783] RPC: Registered udp transport module.
[ 0.628592] RPC: Registered tcp transport module.
[ 0.633401] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.639993] NET: Registered PF_XDP protocol family
[ 0.644907] PCI: CLS 0 bytes, default 64
[ 0.649759] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte rs available
[ 0.659882] Initialise system trusted keyrings
[ 0.664756] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.677253] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.683995] NFS: Registering the id_resolver key type
[ 0.689231] Key type id_resolver registered
[ 0.693509] Key type id_legacy registered
[ 0.697676] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.704532] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ...
[ 0.712311] 9p: Installing v9fs 9p2000 file system support
[ 0.752652] Key type asymmetric registered
[ 0.756842] Asymmetric key parser 'x509' registered
[ 0.761882] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 45)
[ 0.769632] io scheduler mq-deadline registered
[ 0.774270] io scheduler kyber registered
[ 0.781680] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.788256] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.801578] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.816594] loop: module loaded
[ 0.821139] megasas: 07.719.03.00-rc1
[ 0.829075] tun: Universal TUN/TAP device driver, 1.6
[ 0.835050] thunder_xcv, ver 1.0
[ 0.838378] thunder_bgx, ver 1.0
[ 0.841709] nicpf, ver 1.0
[ 0.844879] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - versio n
[ 0.852269] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.857762] hclge is initializing
[ 0.861173] e1000: Intel(R) PRO/1000 Network Driver
[ 0.866160] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.872079] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.877154] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.883236] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.888757] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.894479] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.900887] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.907077] sky2: driver version 1.30
[ 0.911541] VFIO - User Level meta-driver version: 0.3
[ 0.917642] usbcore: registered new interface driver usb-storage
[ 0.924574] i2c_dev: i2c /dev entries driver
[ 0.931121] sdhci: Secure Digital Host Controller Interface driver
[ 0.937466] sdhci: Copyright(c) Pierre Ossman
[ 0.942420] Synopsys Designware Multimedia Card Interface Driver
[ 0.949009] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.955869] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.962236] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.969208] usbcore: registered new interface driver usbhid
[ 0.974924] usbhid: USB HID core driver
[ 0.980160] optee: probing for conduit method.
[ 0.984766] optee: revision 3.20 (8e74d476)
[ 0.985093] optee: dynamic shared memory is enabled
[ 0.994636] optee: initialized driver
[ 1.000247] Initializing XFRM netlink socket
[ 1.004680] NET: Registered PF_PACKET protocol family
[ 1.010004] 9pnet: Installing 9P2000 support
[ 1.014448] Key type dns_resolver registered
[ 1.019412] registered taskstats version 1
[ 1.023652] Loading compiled-in X.509 certificates
[ 1.037456] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.0.5--v09.00.05 (Kool Koala)')
[ 1.125951] VDDSHV_SDIO: bypassed regulator has no supply!
[ 1.135523] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.143579] pca953x 1-0023: supply vcc not found, using dummy regulator
[ 1.150518] pca953x 1-0023: using AI
[ 1.176802] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[ 1.183918] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[ 1.189938] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 doma in created
[ 1.198290] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Rout er 3 domain created
[ 1.207532] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator d omain 28 created
[ 1.217476] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.225797] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.236950] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.247137] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.257411] printk: console [ttyS2] disabled
[ 1.261879] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 289, base_baud = 3 000000) is a 8250
[ 1.270781] printk: console [ttyS2] enabled
[ 1.279240] printk: bootconsole [ns16550a0] disabled
[ 1.291788] spi-nand spi0.0: Winbond SPI NAND was found.
[ 1.297128] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, O OB size: 128
[ 1.305492] 7 fixed-partitions partitions found on MTD device spi0.0
[ 1.311849] Creating 7 MTD partitions on "spi0.0":
[ 1.316637] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
[ 1.324122] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
[ 1.331947] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
[ 1.340477] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
[ 1.347344] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
[ 1.354803] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[ 1.397640] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[ 1.406610] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[ 1.450692] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 10 00000
[ 1.459597] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.467741] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss vers ion 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[ 1.480532] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.487660] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.494385] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000 000, add_val:1 pps:0
[ 1.505082] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 1.516173] mmc0: CQHCI version 5.10
[ 1.523068] pca953x 1-0022: supply vcc not found, using dummy regulator
[ 1.529845] pca953x 1-0022: using AI
[ 1.540534] debugfs: Directory 'pd:182' with parent 'pm_genpd' already presen t!
[ 1.541555] mmc1: CQHCI version 5.10
[ 1.561351] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64 -bit
[ 1.562186] ALSA device list:
[ 1.571863] No soundcards found.
[ 1.593044] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64 -bit
[ 1.600821] Waiting for root device PARTUUID=12c85bbf-02...
[ 1.649640] mmc0: Command Queue Engine enabled
[ 1.654128] mmc0: new HS200 MMC card at address 0001
[ 1.660891] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[ 1.662064] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.672303] mmcblk0: p1 p2
[ 1.673197] mmcblk1: mmc1:aaaa JULIE 29.7 GiB
[ 1.675929] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
[ 1.684710] mmcblk1: p1 p2
[ 1.685838] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
[ 1.693518] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0)
[ 1.744368] EXT4-fs (mmcblk1p2): recovery complete
[ 1.749230] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.757830] VFS: Mounted root (ext4 filesystem) on device 179:34.
[ 1.766839] devtmpfs: error mounting -2
[ 1.772134] Freeing unused kernel memory: 2176K
[ 1.776854] Run /sbin/init as init process
[ 1.781280] Run /etc/init as init process
[ 1.785406] Run /bin/init as init process
[ 1.789478] Run /bin/sh as init process
[ 1.793365] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[ 1.807509] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.1.33-00001-ge4769b223d98 #1
[ 1.815151] Hardware name: Texas Instruments AM62x LP SK (DT)
[ 1.820884] Call trace:
[ 1.823321] dump_backtrace.part.0+0xdc/0xf0
[ 1.827601] show_stack+0x18/0x30
[ 1.830908] dump_stack_lvl+0x68/0x84
[ 1.834568] dump_stack+0x18/0x34
[ 1.837877] panic+0x184/0x344
[ 1.840926] kernel_init+0x124/0x130
[ 1.844492] ret_from_fork+0x10/0x20
[ 1.848061] SMP: stopping secondary CPUs
[ 1.851978] Kernel Offset: disabled
[ 1.855453] CPU features: 0x00000,00800084,0000420b
[ 1.860317] Memory Limit: none
[ 1.863368] ---[ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance. ]---
  • this is for SK-AM62-LP
    yesterday by mistake selected AM62A-LP
  • For SK-AM62-LP, please use the SDK default SD card WIC image linked below.
    https://dr-download.ti.com/software-development/software-development-kit-sdk/MD-PvdSyIiioq/09.00.00.03/tisdk-default-image-am62xx-evm.wic.xz
    The flashing process is the same as I linked in the other thread.
    I will close the other thread.
  • Hello Bin Liu,
    Default image in download section is working fine.
    i want to build the sdk .
    when i was build sdk it is not showing error but after install image the MLO, and Uboot working fine but after it is showing kernel panic. i have  attached log file .
    DRAM: 2 GiB
    NAND: 0 MiB
    In: serial@2800000
    Out: serial@2800000
    Err: serial@2800000
    Starting kernel ...
    and could you share build step.
  • ut after install image the MLO, and Uboot working fine but after it is showing kernel panic.
    How did you install the image to the SD card? Did you update the new images to the SD card with the default WIC image flashed?
    Please share the "exact" commands you used to install the images.
