I use a YUV camera on TDA4VM and it can output images normally when connected to a display monitor.
But when I switch to a TDA4AL YUV camera, the image cannot be output without a display monitor.
Do I need to change any settings?
P.S. We board TDA4AL hardware has no design display monitor output interface.
The following is the LOG of executing vision_app "p"
~~~~~~~~~~~~~~~~~~~~~TDA4VM~~~~~~~~~~~~~~~~~~~~~
root@j7-evm:/opt/vision_apps# ./run_app_single_cam.sh
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
194.908176 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
194.911822 s: VX_ZONE_INIT:Enabled
194.911834 s: VX_ZONE_ERROR:Enabled
194.911841 s: VX_ZONE_WARNING:Enabled
194.915464 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
194.915669 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
sensor_selection = [0]
ldc_enable = [0]
num_frames_to_run = [1000000000]
is_interactive = [1]
IttCtrl_registerHandler: command echo registered at location 0
IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
IttCtrl_registerHandler: command iss_raw_save registered at location 3
IttCtrl_registerHandler: command iss_yuv_save registered at location 4
IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
IttCtrl_registerHandler: command dev_ctrl registered at location 7
IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
NETWORK: Opened at IP Addr = 0.0.0.0, socket port=5000!!!
194.919847 s: ISS: Enumerating sensors ... !!!
[MCU2_0] 194.920087 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_ENUMERATE
[MCU2_0] 198.828361 s: Fusion1 Board configuration
[MCU2_0] 198.828433 s: Brandon Get i2c addr 1
[MCU2_0] 198.828507 s: I2C status 0
[MCU2_0] 198.828546 s: Do nothing 0
[MCU2_0] 198.828579 s: max96712_cfgScript
[MCU2_0] 198.828615 s: Brandon Get i2c addr 1
[MCU2_0] 198.828642 s: MAX96712 config start
[MCU2_0] 198.828836 s: write Board_gmslMax96712DesInit 1@0x29: 0x040b=0x0000 0
[MCU2_0] 198.829047 s: write Board_gmslMax96712DesInit 1@0x29: 0x0006=0x0000 0
[MCU2_0] 198.829250 s: write Board_gmslMax96712DesInit 1@0x29: 0x04a0=0x0004 0
[MCU2_0] 198.829445 s: write Board_gmslMax96712DesInit 1@0x29: 0x04a2=0x0000 0
[MCU2_0] 198.829634 s: write Board_gmslMax96712DesInit 1@0x29: 0x04aa=0x0000 0
[MCU2_0] 198.829826 s: write Board_gmslMax96712DesInit 1@0x29: 0x04ab=0x0000 0
[MCU2_0] 198.830030 s: write Board_gmslMax96712DesInit 1@0x29: 0x04af=0x005f 0
[MCU2_0] 198.830227 s: write Board_gmslMax96712DesInit 1@0x29: 0x04a7=0x000f 0
[MCU2_0] 198.830422 s: write Board_gmslMax96712DesInit 1@0x29: 0x04a6=0x0042 0
[MCU2_0] 198.830613 s: write Board_gmslMax96712DesInit 1@0x29: 0x04a5=0x0040 0
[MCU2_0] 198.830801 s: write Board_gmslMax96712DesInit 1@0x29: 0x0b08=0x0071 0
[MCU2_0] 198.830996 s: write Board_gmslMax96712DesInit 1@0x29: 0x0c08=0x0071 0
[MCU2_0] 198.831192 s: write Board_gmslMax96712DesInit 1@0x29: 0x0d08=0x0071 0
[MCU2_0] 198.831383 s: write Board_gmslMax96712DesInit 1@0x29: 0x0e08=0x0071 0
[MCU2_0] 198.831581 s: write Board_gmslMax96712DesInit 1@0x29: 0x0b06=0x00ef 0
[MCU2_0] 198.831771 s: write Board_gmslMax96712DesInit 1@0x29: 0x0c06=0x00ef 0
[MCU2_0] 198.831965 s: write Board_gmslMax96712DesInit 1@0x29: 0x0d06=0x00ef 0
[MCU2_0] 198.832159 s: write Board_gmslMax96712DesInit 1@0x29: 0x0e06=0x00ef 0
[MCU2_0] 198.832351 s: write Board_gmslMax96712DesInit 1@0x29: 0x0b0f=0x0001 0
[MCU2_0] 198.832541 s: write Board_gmslMax96712DesInit 1@0x29: 0x0c0f=0x0001 0
[MCU2_0] 198.832732 s: write Board_gmslMax96712DesInit 1@0x29: 0x0d0f=0x0001 0
[MCU2_0] 198.832930 s: write Board_gmslMax96712DesInit 1@0x29: 0x0e0f=0x0001 0
[MCU2_0] 198.833126 s: write Board_gmslMax96712DesInit 1@0x29: 0x0b07=0x0084 0
[MCU2_0] 198.833319 s: write Board_gmslMax96712DesInit 1@0x29: 0x0c07=0x0084 0
[MCU2_0] 198.833512 s: write Board_gmslMax96712DesInit 1@0x29: 0x0d07=0x0084 0
[MCU2_0] 198.833706 s: write Board_gmslMax96712DesInit 1@0x29: 0x0e07=0x0084 0
[MCU2_0] 198.838052 s: write Board_gmslMax96712DesInit 1@0x29: 0x041a=0x00f0 0
[MCU2_0] 198.838257 s: write Board_gmslMax96712DesInit 1@0x29: 0x0b0d=0x0080 0
[MCU2_0] 198.838451 s: write Board_gmslMax96712DesInit 1@0x29: 0x0c0d=0x0080 0
[MCU2_0] 198.838643 s: write Board_gmslMax96712DesInit 1@0x29: 0x0d0d=0x0080 0
[MCU2_0] 198.838833 s: write Board_gmslMax96712DesInit 1@0x29: 0x0e0d=0x0080 0
[MCU2_0] 198.839032 s: write Board_gmslMax96712DesInit 1@0x29: 0x08a3=0x00e4 0
[MCU2_0] 198.839229 s: write Board_gmslMax96712DesInit 1@0x29: 0x040b=0x0042 0
[MCU2_0] 198.839419 s: write Board_gmslMax96712DesInit 1@0x29: 0x040c=0x0000 0
[MCU2_0] 198.839610 s: write Board_gmslMax96712DesInit 1@0x29: 0x040d=0x0000 0
[MCU2_0] 198.839802 s: write Board_gmslMax96712DesInit 1@0x29: 0x040e=0x005e 0
[MCU2_0] 198.839997 s: write Board_gmslMax96712DesInit 1@0x29: 0x040f=0x007e 0
[MCU2_0] 198.840190 s: write Board_gmslMax96712DesInit 1@0x29: 0x0410=0x007a 0
[MCU2_0] 198.840384 s: write Board_gmslMax96712DesInit 1@0x29: 0x0411=0x0048 0
[MCU2_0] 198.840577 s: write Board_gmslMax96712DesInit 1@0x29: 0x0412=0x0020 0
[MCU2_0] 198.840772 s: write Board_gmslMax96712DesInit 1@0x29: 0x0415=0x00ea 0
[MCU2_0] 198.840994 s: write Board_gmslMax96712DesInit 1@0x29: 0x0418=0x00ea 0
[MCU2_0] 198.841192 s: write Board_gmslMax96712DesInit 1@0x29: 0x090b=0x0007 0
[MCU2_0] 198.841388 s: write Board_gmslMax96712DesInit 1@0x29: 0x092d=0x0015 0
[MCU2_0] 198.841581 s: write Board_gmslMax96712DesInit 1@0x29: 0x090d=0x001e 0
[MCU2_0] 198.841772 s: write Board_gmslMax96712DesInit 1@0x29: 0x090e=0x001e 0
[MCU2_0] 198.841964 s: write Board_gmslMax96712DesInit 1@0x29: 0x090f=0x0000 0
[MCU2_0] 198.842158 s: write Board_gmslMax96712DesInit 1@0x29: 0x0910=0x0000 0
198.894690 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
199.179963 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
[MCU2_0] 198.842349 s: write Board_gmslMax96712DesInit 1@0x29: 0x0911=0x0001 0
199.179979 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
199.179985 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
199.179991 s: ISS: Enumerating sensors ... found 4 : OX03C-MAX9295E
[MCU2_0] 198.842540 s: write Board_gmslMax96712DesInit 1@0x29: 0x0912=0x0001 0
199.179996 s: ISS: Enumerating sensors ... found 5 : MAX96712_RAW_TESTPAT
199.180002 s: ISS: Enumerating sensors ... found 6 : AR0233-MAX9295E
199.180007 s: ISS: Enumerating sensors ... found 7 : UB96x_UYVY_TESTPATTERN
[MCU2_0] 198.842733 s: write Board_gmslMax96712DesInit 1@0x29: 0x094b=0x0007 0
199.180013 s: ISS: Enumerating sensors ... found 8 : GW_AR0233_UYVY
[MCU2_0] 198.842929 s: write Board_gmslMax96712DesInit 1@0x29: 0x096d=0x0015 0
Select camera port index 0-11 : [MCU2_0] 198.843126 s: write Board_gmslMax96712DesInit 1@0x29: 0x094
[MCU2_0] 198.843317 s: write Board_gmslMax96712DesInit 1@0x29: 0x094e=0x005e 0
[MCU2_0] 198.843508 s: write Board_gmslMax96712DesInit 1@0x29: 0x094f=0x0000 0
[MCU2_0] 198.843700 s: write Board_gmslMax96712DesInit 1@0x29: 0x0950=0x0040 0
[MCU2_0] 198.843900 s: write Board_gmslMax96712DesInit 1@0x29: 0x0951=0x0001 0
[MCU2_0] 198.844096 s: write Board_gmslMax96712DesInit 1@0x29: 0x0952=0x0041 0
[MCU2_0] 198.844287 s: write Board_gmslMax96712DesInit 1@0x29: 0x098b=0x0007 0
[MCU2_0] 198.844479 s: write Board_gmslMax96712DesInit 1@0x29: 0x09ad=0x0015 0
[MCU2_0] 198.844673 s: write Board_gmslMax96712DesInit 1@0x29: 0x098d=0x001e 0
[MCU2_0] 198.844865 s: write Board_gmslMax96712DesInit 1@0x29: 0x098e=0x009e 0
[MCU2_0] 198.845067 s: write Board_gmslMax96712DesInit 1@0x29: 0x098f=0x0000 0
[MCU2_0] 198.845260 s: write Board_gmslMax96712DesInit 1@0x29: 0x0990=0x0080 0
[MCU2_0] 198.845454 s: write Board_gmslMax96712DesInit 1@0x29: 0x0991=0x0001 0
[MCU2_0] 198.845644 s: write Board_gmslMax96712DesInit 1@0x29: 0x0992=0x0081 0
[MCU2_0] 198.845839 s: write Board_gmslMax96712DesInit 1@0x29: 0x09cb=0x0007 0
[MCU2_0] 198.846039 s: write Board_gmslMax96712DesInit 1@0x29: 0x09ed=0x0015 0
[MCU2_0] 198.846236 s: write Board_gmslMax96712DesInit 1@0x29: 0x09cd=0x001e 0
[MCU2_0] 198.846427 s: write Board_gmslMax96712DesInit 1@0x29: 0x09ce=0x00de 0
[MCU2_0] 198.846618 s: write Board_gmslMax96712DesInit 1@0x29: 0x09cf=0x0000 0
[MCU2_0] 198.846807 s: write Board_gmslMax96712DesInit 1@0x29: 0x09d0=0x00c0 0
[MCU2_0] 198.846999 s: write Board_gmslMax96712DesInit 1@0x29: 0x09d1=0x0001 0
[MCU2_0] 198.847195 s: write Board_gmslMax96712DesInit 1@0x29: 0x09d2=0x00c1 0
[MCU2_0] 198.847389 s: write Board_gmslMax96712DesInit 1@0x29: 0x00fa=0x0033 0
[MCU2_0] 198.847581 s: write Board_gmslMax96712DesInit 1@0x29: 0x0018=0x000f 0
[MCU2_0] 198.878049 s: write Board_gmslMax96712DesInit 1@0x29: 0x040b=0x0040 0
[MCU2_0] 198.878257 s: write Board_gmslMax96712DesInit 1@0x29: 0x0006=0x000f 0
[MCU2_0] 198.888215 s: write Board_gmslMax96712DesInit 1@0x40: 0x0004=0x0087 0
[MCU2_0] 198.888586 s: write Board_gmslMax96712DesInit 1@0x40: 0x000f=0x0081 0
[MCU2_0] 198.888946 s: write Board_gmslMax96712DesInit 1@0x40: 0x0007=0x0084 0
[MCU2_0] 198.889399 s: write Board_gmslMax96712DesInit 1@0x29: 0x0903=0x0080 0
[MCU2_0] 198.889849 s: write Board_gmslMax96712DesInit 1@0x29: 0x0943=0x0080 0
[MCU2_0] 198.890308 s: write Board_gmslMax96712DesInit 1@0x29: 0x0983=0x0080 0
[MCU2_0] 198.890758 s: write Board_gmslMax96712DesInit 1@0x29: 0x09c3=0x0080 0
[MCU2_0] 198.891214 s: write Board_gmslMax96712DesInit 1@0x29: 0x1c00=0x00f4 0
[MCU2_0] 198.891669 s: write Board_gmslMax96712DesInit 1@0x29: 0x1d00=0x00f4 0
[MCU2_0] 198.892120 s: write Board_gmslMax96712DesInit 1@0x29: 0x1e00=0x00f4 0
[MCU2_0] 198.892569 s: write Board_gmslMax96712DesInit 1@0x29: 0x1f00=0x00f4 0
[MCU2_0] 198.893023 s: write Board_gmslMax96712DesInit 1@0x29: 0x1c00=0x00f5 0
[MCU2_0] 198.893473 s: write Board_gmslMax96712DesInit 1@0x29: 0x1d00=0x00f5 0
[MCU2_0] 198.893930 s: write Board_gmslMax96712DesInit 1@0x29: 0x1e00=0x00f5 0
[MCU2_0] 198.894377 s: write Board_gmslMax96712DesInit 1@0x29: 0x1f00=0x00f5 0
[MCU2_0] 198.894420 s: End of MAX96712 config
[MCU2_0] 198.894465 s: Error : max96712_cfgScript returned 0 while configuring DES 0
Invalid entry
. Please choose between 0 and 11
Select camera port index 0-11 : 4
9 registered sensor drivers
a : IMX390-UB953_D3
b : AR0233-UB953_MARS
c : AR0820-UB953_LI
d : UB9xxx_RAW12_TESTPATTERN
e : OX03C-MAX9295E
f : MAX96712_RAW_TESTPAT
g : AR0233-MAX9295E
h : UB96x_UYVY_TESTPATTERN
i : GW_AR0233_UYVY
Select a sensor above or press '0' to autodetect the sensor : Invalid selection
. Try again
a : IMX390-UB953_D3
c : AR0820-UB953_LI
e : OX03C-MAX9295E
g : AR0233-MAX9295E
i : GW_AR0233_UYVY
Select a sensor above or press '0' to autodetect the sensor : i
Sensor selected : GW_AR0233_UYVY
LDC Selection Yes(1)/No(0) : LDC Selection Yes(1)/No(0) : 0
Querying GW_AR0233_UYVY
204.947325 s: ISS: Querying sensor [GW_AR0233_UYVY] ... !!!
204.947796 s: ISS: Querying sensor [GW_AR0233_UYVY] ... Done !!!
YUV Input selected. VISS and AEWB nodes will be bypassed.
204.947814 s: ISS: Initializing sensor [GW_AR0233_UYVY], doing IM_SENSOR_CMD_PWRON ... !!!
204.948242 s: ISS: Initializing sensor [GW_AR0233_UYVY], doing IM_SENSOR_CMD_CONFIG ... !!!
[MCU2_0] 204.947539 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY
[MCU2_0] 204.947617 s: Received Query for GW_AR0233_UYVY
[MCU2_0] 204.947999 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON
[MCU2_0] 204.948073 s: IM_SENSOR_CMD_PWRON : channel_mask = 0x10
[MCU2_0] 204.948418 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG
[MCU2_0] 204.948486 s: Application requested features = 0x100
[MCU2_0] 204.948527 s: Disabling broadcast mode
[MCU2_0] 204.948566 s: UB960 config start
[MCU2_0] 204.948717 s: Error writing 0x1 to UB960 register 0x4c
[MCU2_0] 204.948776 s: UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
[MCU2_0] 204.948813 s: End of UB960 config
[MCU2_0] 204.948842 s: UB960 config start
205.205839 s: ISS: Initializing sensor [GW_AR0233_UYVY] ... Done !!!
[MCU2_0] 205.205084 s: End of UB960 config
[MCU2_0] 205.205142 s: UB960 config start
[MCU2_0] 205.205284 s: Error writing 0x1 to UB960 register 0x4c
[MCU2_0] 205.205341 s: UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
[MCU2_0] 205.205380 s: End of UB960 config
[MCU2_0] 205.205418 s: IM_SENSOR_CMD_CONFIG channel_mask = 10
[MCU2_0] 205.205457 s: Configuring camera # 0
[MCU2_0] 205.205491 s: Configuring camera # 1
[MCU2_0] 205.205525 s: Configuring camera # 2
[MCU2_0] 205.205559 s: Configuring camera # 3
[MCU2_0] 205.205594 s: Configuring camera # 4
[MCU2_0] 205.205632 s: Error : sensor probe failed for channel 4
[MCU2_0] 205.205674 s: IM_SENSOR_CMD_CONFIG returning status = 0
Scaler is disabled
205.218995 s: ISS: Starting sensor [GW_AR0233_UYVY] ... !!!
Demo : Single Camera w/ 2A
p: Print performance statistics
s: Save Sensor RAW, VISS Output and H3A output images to File System
d: sensor debug
e: Export performance statistics
u: Update DCC from File System
x: Exit
Enter Choice:
Unsupported command
d: sensor debug
x: Exit
Enter Choice: [MCU2_0] 205.219290 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_STREAM_ON
[MCU2_0] 205.219398 s: IM_SENSOR_CMD_STREAM_ON: channel_mask = 0x10
[MCU2_0] 205.219450 s: UB960 config start
[MCU2_0] 205.219600 s: Error writing 0x1 to UB960 register 0x4c
[MCU2_0] 205.219664 s: UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
[MCU2_0] 205.219701 s: End of UB960 config
[MCU2_0] 205.219731 s: UB960 config start
[MCU2_0] 205.476085 s: End of UB960 config
[MCU2_0] 205.476140 s: UB960 config start
[MCU2_0] 205.476284 s: Error writing 0x1 to UB960 register 0x4c
[MCU2_0] 205.476340 s: UB960 Error: Reg Write Failed for regAddr 4c, cnt = 0
[MCU2_0] 205.476378 s: End of UB960 config
[MCU2_0] 205.476418 s: max96712_cfgScript
[MCU2_0] 205.476454 s: Brandon Get i2c addr 1
[MCU2_0] 205.476481 s: MAX96712 config start
[MCU2_0] 205.476814 s: write max96712_cfgScript 1@0x29: 0x040b=0x0042 0
[MCU2_0] 205.492193 s: write max96712_cfgScript 1@0x29: 0x08a2=0x00f4 0
[MCU2_0] 205.508193 s: write max96712_cfgScript 1@0x29: 0x08a0=0x0084 0
205.524449 s: ISS: Starting sensor [GW_AR0233_UYVY] ... !!!
get_dcc_dir_size : Could not open directory or directory is empty /opt/vision_apps/dcc/GW_AR0233_UYVY/w
[MCU2_0] 205.524204 s: write max96712_cfgScript 1@0x29: 0xffff=0x0000 0
[MCU2_0] 205.524251 s: End of MAX96712 config
[MCU2_0] 205.525000 s: VX_ZONE_WARNING:[tivxCaptureSetTimeout:796] CAPTURE: WARNING: Error frame n
p
Summary of CPU load,
CPU: mpu1_0: TOTAL LOAD = 0.21 % ( HWI = 0. 4 %, SWI = 0. 0 % )
CPU: mcu2_0: TOTAL LOAD = 7. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
CPU: mcu2_1: TOTAL LOAD = 5. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
CPU: c6x_1: TOTAL LOAD = 0. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
CPU: c6x_2: TOTAL LOAD = 1. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
CPU: c7x_1: TOTAL LOAD = 0. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
HWA performance statistics,
DDR performance statistics,
DDR: READ BW: AVG = 117 MB/s, PEAK = 2881 MB/s
DDR: WRITE BW: AVG = 50 MB/s, PEAK = 1525 MB/s
DDR: TOTAL BW: AVG = 167 MB/s, PEAK = 4406 MB/s
Detailed CPU performance/memory statistics,
DDR_SHARED_MEM: Alloc's: 6 alloc's of 9830660 bytes
DDR_SHARED_MEM: Free's : 0 free's of 0 bytes
DDR_SHARED_MEM: Open's : 6 allocs of 9830660 bytes
DDR_SHARED_MEM: Total size: 536870912 bytes
CPU: mcu2_0: TASK: IPC_RX: 0. 0 %
CPU: mcu2_0: TASK: REMOTE_SRV: 1.94 %
CPU: mcu2_0: TASK: LOAD_TEST: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CPU_0: 0. 0 %
CPU: mcu2_0: TASK: TIVX_V1NF: 0. 0 %
CPU: mcu2_0: TASK: TIVX_V1LDC1: 0. 0 %
CPU: mcu2_0: TASK: TIVX_V1SC1: 0. 0 %
CPU: mcu2_0: TASK: TIVX_V1MSC2: 0. 0 %
CPU: mcu2_0: TASK: TIVXVVISS1: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT1: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT2: 0. 0 %
CPU: mcu2_0: TASK: TIVX_DISP1: 0. 0 %
CPU: mcu2_0: TASK: TIVX_DISP2: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CSITX: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT3: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT4: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT5: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT6: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT7: 0. 0 %
CPU: mcu2_0: TASK: TIVX_CAPT8: 0. 0 %
CPU: mcu2_0: TASK: TIVX_DPM2M1: 0. 0 %
CPU: mcu2_0: TASK: TIVX_DPM2M2: 0. 0 %
CPU: mcu2_0: TASK: TIVX_DPM2M3: 0. 0 %
CPU: mcu2_0: TASK: TIVX_DPM2M4: 0. 0 %
CPU: mcu2_0: HEAP: DDR_LOCAL_MEM: size = 16777216 B, free = 16688896 B ( 99 % unused)
CPU: mcu2_0: HEAP: L3_MEM: size = 262144 B, free = 261888 B ( 99 % unused)
CPU: mcu2_1: TASK: IPC_RX: 0. 0 %
CPU: mcu2_1: TASK: REMOTE_SRV: 0. 0 %
CPU: mcu2_1: TASK: LOAD_TEST: 0. 0 %
CPU: mcu2_1: TASK: TIVX_CPU_1: 0. 0 %
CPU: mcu2_1: TASK: TIVX_SDE: 0. 0 %
CPU: mcu2_1: TASK: TIVX_DOF: 0. 0 %
CPU: mcu2_1: TASK: IPC_TEST_RX: 0. 0 %
CPU: mcu2_1: TASK: IPC_TEST_TX: 0. 0 %
CPU: mcu2_1: HEAP: DDR_LOCAL_MEM: size = 16777216 B, free = 16773376 B ( 99 % unused)
CPU: mcu2_1: HEAP: L3_MEM: size = 262144 B, free = 262144 B (100 % unused)
CPU: c6x_1: TASK: IPC_RX: 0. 0 %
CPU: c6x_1: TASK: REMOTE_SRV: 0. 0 %
CPU: c6x_1: TASK: LOAD_TEST: 0. 0 %
CPU: c6x_1: TASK: TIVX_CPU: 0. 0 %
CPU: c6x_1: TASK: IPC_TEST_RX: 0. 0 %
CPU: c6x_1: TASK: IPC_TEST_TX: 0. 0 %
CPU: c6x_1: HEAP: DDR_LOCAL_MEM: size = 16777216 B, free = 16773376 B ( 99 % unused)
CPU: c6x_1: HEAP: L2_MEM: size = 229376 B, free = 229376 B (100 % unused)
CPU: c6x_1: HEAP: DDR_SCRATCH_MEM: size = 50331648 B, free = 50331648 B (100 % unused)
CPU: c6x_2: TASK: IPC_RX: 0. 0 %
CPU: c6x_2: TASK: REMOTE_SRV: 0. 0 %
CPU: c6x_2: TASK: LOAD_TEST: 0. 0 %
CPU: c6x_2: TASK: TIVX_CPU: 0. 0 %
CPU: c6x_2: TASK: IPC_TEST_RX: 0. 0 %
CPU: c6x_2: TASK: IPC_TEST_TX: 0. 0 %
CPU: c6x_2: HEAP: DDR_LOCAL_MEM: size = 16777216 B, free = 16773376 B ( 99 % unused)
CPU: c6x_2: HEAP: L2_MEM: size = 229376 B, free = 229376 B (100 % unused)
CPU: c6x_2: HEAP: DDR_SCRATCH_MEM: size = 50331648 B, free = 50331648 B (100 % unused)
CPU: c7x_1: TASK: IPC_RX: 0. 0 %
CPU: c7x_1: TASK: REMOTE_SRV: 0. 0 %
CPU: c7x_1: TASK: LOAD_TEST: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P1: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P2: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P3: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P4: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P5: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P6: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P7: 0. 0 %
CPU: c7x_1: TASK: TIVX_C71_P8: 0. 0 %
CPU: c7x_1: TASK: IPC_TEST_RX: 0. 0 %
CPU: c7x_1: TASK: IPC_TEST_TX: 0. 0 %
CPU: c7x_1: HEAP: DDR_LOCAL_MEM: size = 268435456 B, free = 268435200 B ( 99 % unused)
CPU: c7x_1: HEAP: L3_MEM: size = 8159232 B, free = 8159232 B (100 % unused)
CPU: c7x_1: HEAP: L2_MEM: size = 458752 B, free = 458752 B (100 % unused)
CPU: c7x_1: HEAP: L1_MEM: size = 16384 B, free = 16384 B (100 % unused)
CPU: c7x_1: HEAP: DDR_SCRATCH_MEM: size = 385875968 B, free = 385875968 B (100 % unused)
GRAPH: graph_85 (#nodes = 2, #executions = 36)
NODE: CAPTURE2: node_96: avg = 31158 usecs, min/max = 23445 / 49753 usecs, #
NODE: DISPLAY1: node_97: avg = 9277 usecs, min/max = 88 / 16221 usecs, #
PERF: TOTAL: avg = 41897 usecs, min/max = 33279 / 99725 usecs, #executions = 35
PERF: TOTAL: 23.86 FPS
~~~~~~~~~~~~~~~~~~~~~TDA4AL~~~~~~~~~~~~~~~~~~~~~
root@j721s2-evm:/opt/vision_apps# ./run_app_single_cam.sh
APP: Init ... !!!
MEM: Init ... !!!
IPC: Init ... !!!
44.281268 s: GTC Frequency = 200 MHz
44.287348 s: VX_ZONE_INIT:Enabled
44.287378 s: VX_ZONE_ERROR:Enabled
44.287385 s: VX_ZONE_WARNING:Enabled
44.290802 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
44.291947 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
ldc_enable = [0]
44.297919 s: ISS: Enumerating sensors ... !!!
[MCU2_0] 44.298139 s: ImageSensor_RemoteServiceHandler: CMD 0
[MCU2_0] 44.298171 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_ENUMERATE
[MCU2_0] 44.298203 s: AA550
[MCU2_0] 44.298237 s: AA551
[MCU2_0] 44.298257 s: Fusion2 Board Detected, using Fusion2 configuration
[MCU2_0] 44.298302 s: Get CSI 1 i2c addr 0@107
[MCU2_0] 44.298333 s: read open i2c inst 0
[MCU2_0] 44.298355 s: read open i2c inst 1
[MCU2_0] 44.298391 s: read open i2c inst 2
[MCU2_0] 44.298420 s: I2C status 0
[MCU2_0] 44.298445 s: Do nothing 0
[MCU2_0] 44.298470 s: max96712_cfgScript
[MCU2_0] 44.298505 s: Get CSI 1 i2c addr 0@107
[MCU2_0] 44.298528 s: MAX96712 config start
[MCU2_0] 44.298554 s: CSI 0
[MCU2_0] 44.299015 s: write Board_gmslMax96712DesInit 1@0x49: 0x040b=0x0000 0
[MCU2_0] 44.299473 s: write Board_gmslMax96712DesInit 1@0x49: 0x0006=0x0000 0
[MCU2_0] 44.299930 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a0=0x0004 0
[MCU2_0] 44.300384 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a2=0x0000 0
[MCU2_0] 44.300839 s: write Board_gmslMax96712DesInit 1@0x49: 0x04ab=0x0000 0
[MCU2_0] 44.301291 s: write Board_gmslMax96712DesInit 1@0x49: 0x04aa=0x0000 0
[MCU2_0] 44.301745 s: write Board_gmslMax96712DesInit 1@0x49: 0x04af=0x005f 0
[MCU2_0] 44.302201 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a7=0x000f 0
[MCU2_0] 44.302655 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a6=0x0042 0
[MCU2_0] 44.303111 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a5=0x0040 0
[MCU2_0] 44.303566 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b08=0x0071 0
[MCU2_0] 44.304020 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c08=0x0071 0
[MCU2_0] 44.304472 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d08=0x0071 0
[MCU2_0] 44.304927 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e08=0x0071 0
[MCU2_0] 44.305383 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b06=0x00ef 0
[MCU2_0] 44.305837 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c06=0x00ef 0
[MCU2_0] 44.306289 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d06=0x00ef 0
[MCU2_0] 44.306744 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e06=0x00ef 0
[MCU2_0] 44.307200 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b0f=0x0001 0
[MCU2_0] 44.307654 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c0f=0x0001 0
[MCU2_0] 44.308110 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d0f=0x0001 0
[MCU2_0] 44.308564 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e0f=0x0001 0
[MCU2_0] 44.309019 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b07=0x0084 0
[MCU2_0] 44.309472 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c07=0x0084 0
[MCU2_0] 44.309926 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d07=0x0084 0
[MCU2_0] 44.310383 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e07=0x0084 0
[MCU2_0] 44.315508 s: write Board_gmslMax96712DesInit 1@0x49: 0x041a=0x00f0 0
[MCU2_0] 44.315964 s: write Board_gmslMax96712DesInit 1@0x49: 0x0b0d=0x0080 0
[MCU2_0] 44.316417 s: write Board_gmslMax96712DesInit 1@0x49: 0x0c0d=0x0080 0
[MCU2_0] 44.316872 s: write Board_gmslMax96712DesInit 1@0x49: 0x0d0d=0x0080 0
[MCU2_0] 44.317324 s: write Board_gmslMax96712DesInit 1@0x49: 0x0e0d=0x0080 0
44.506472 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
[MCU2_0] 44.317779 s: write Board_gmslMax96712DesInit 1@0x49: 0x08a3=0x00e4 0
44.653135 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
44.653146 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
44.653153 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
[MCU2_0] 44.318231 s: write Board_gmslMax96712DesInit 1@0x49: 0x040b=0x0042 0
44.653159 s: ISS: Enumerating sensors ... found 4 : OX03C-MAX9295E
44.653165 s: ISS: Enumerating sensors ... found 5 : OX08B-MAX9296
44.653171 s: ISS: Enumerating sensors ... found 6 : OX08BA-MAX9296
[MCU2_0] 44.318686 s: write Board_gmslMax96712DesInit 1@0x49: 0x040c=0x0000 0
44.653176 s: ISS: Enumerating sensors ... found 7 : MAX96712_RAW_TESTPAT
44.653182 s: ISS: Enumerating sensors ... found 8 : AR0233-MAX9295E
44.653188 s: ISS: Enumerating sensors ... found 9 : UB96x_UYVY_TESTPATTERN
[MCU2_0] 44.319138 s: write Board_gmslMax96712DesInit 1@0x49: 0x040d=0x0000 0
44.653193 s: ISS: Enumerating sensors ... found 10 : GW_AR0233_UYVY
[MCU2_0] 44.319592 s: write Board_gmslMax96712DesInit 1@0x49: 0x040e=0x005e 0
Select camera port index 0-11 : [MCU2_0] 44.320047 s: write Board_gmslMax96712DesInit 1@0x49: 0x040f=0x007e 0
[MCU2_0] 44.320503 s: write Board_gmslMax96712DesInit 1@0x49: 0x0410=0x007a 0
[MCU2_0] 44.320957 s: write Board_gmslMax96712DesInit 1@0x49: 0x0411=0x0048 0
[MCU2_0] 44.321410 s: write Board_gmslMax96712DesInit 1@0x49: 0x0412=0x0020 0
[MCU2_0] 44.321864 s: write Board_gmslMax96712DesInit 1@0x49: 0x0415=0x00ea 0
[MCU2_0] 44.322317 s: write Board_gmslMax96712DesInit 1@0x49: 0x0418=0x00ea 0
[MCU2_0] 44.322772 s: write Board_gmslMax96712DesInit 1@0x49: 0x090b=0x0007 0
[MCU2_0] 44.323224 s: write Board_gmslMax96712DesInit 1@0x49: 0x092d=0x0015 0
[MCU2_0] 44.323679 s: write Board_gmslMax96712DesInit 1@0x49: 0x090d=0x001e 0
[MCU2_0] 44.324131 s: write Board_gmslMax96712DesInit 1@0x49: 0x090e=0x001e 0
[MCU2_0] 44.324586 s: write Board_gmslMax96712DesInit 1@0x49: 0x090f=0x0000 0
[MCU2_0] 44.325040 s: write Board_gmslMax96712DesInit 1@0x49: 0x0910=0x0000 0
[MCU2_0] 44.325492 s: write Board_gmslMax96712DesInit 1@0x49: 0x0911=0x0001 0
[MCU2_0] 44.325947 s: write Board_gmslMax96712DesInit 1@0x49: 0x0912=0x0001 0
[MCU2_0] 44.326399 s: write Board_gmslMax96712DesInit 1@0x49: 0x094b=0x0007 0
[MCU2_0] 44.326853 s: write Board_gmslMax96712DesInit 1@0x49: 0x096d=0x0015 0
[MCU2_0] 44.327306 s: write Board_gmslMax96712DesInit 1@0x49: 0x094d=0x001e 0
[MCU2_0] 44.327760 s: write Board_gmslMax96712DesInit 1@0x49: 0x094e=0x005e 0
[MCU2_0] 44.328213 s: write Board_gmslMax96712DesInit 1@0x49: 0x094f=0x0000 0
[MCU2_0] 44.328667 s: write Board_gmslMax96712DesInit 1@0x49: 0x0950=0x0040 0
[MCU2_0] 44.329124 s: write Board_gmslMax96712DesInit 1@0x49: 0x0951=0x0001 0
[MCU2_0] 44.329578 s: write Board_gmslMax96712DesInit 1@0x49: 0x0952=0x0041 0
[MCU2_0] 44.330032 s: write Board_gmslMax96712DesInit 1@0x49: 0x098b=0x0007 0
[MCU2_0] 44.330485 s: write Board_gmslMax96712DesInit 1@0x49: 0x09ad=0x0015 0
[MCU2_0] 44.330940 s: write Board_gmslMax96712DesInit 1@0x49: 0x098d=0x001e 0
[MCU2_0] 44.331392 s: write Board_gmslMax96712DesInit 1@0x49: 0x098e=0x009e 0
[MCU2_0] 44.331846 s: write Board_gmslMax96712DesInit 1@0x49: 0x098f=0x0000 0
[MCU2_0] 44.332299 s: write Board_gmslMax96712DesInit 1@0x49: 0x0990=0x0080 0
[MCU2_0] 44.332753 s: write Board_gmslMax96712DesInit 1@0x49: 0x0991=0x0001 0
[MCU2_0] 44.333206 s: write Board_gmslMax96712DesInit 1@0x49: 0x0992=0x0081 0
[MCU2_0] 44.333660 s: write Board_gmslMax96712DesInit 1@0x49: 0x09cb=0x0007 0
[MCU2_0] 44.334113 s: write Board_gmslMax96712DesInit 1@0x49: 0x09ed=0x0015 0
[MCU2_0] 44.334567 s: write Board_gmslMax96712DesInit 1@0x49: 0x09cd=0x001e 0
[MCU2_0] 44.335022 s: write Board_gmslMax96712DesInit 1@0x49: 0x09ce=0x00de 0
[MCU2_0] 44.335474 s: write Board_gmslMax96712DesInit 1@0x49: 0x09cf=0x0000 0
[MCU2_0] 44.335928 s: write Board_gmslMax96712DesInit 1@0x49: 0x09d0=0x00c0 0
[MCU2_0] 44.336381 s: write Board_gmslMax96712DesInit 1@0x49: 0x09d1=0x0001 0
[MCU2_0] 44.336836 s: write Board_gmslMax96712DesInit 1@0x49: 0x09d2=0x00c1 0
[MCU2_0] 44.337288 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a7=0x000f 0
[MCU2_0] 44.337742 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a6=0x0042 0
[MCU2_0] 44.338195 s: write Board_gmslMax96712DesInit 1@0x49: 0x04a5=0x0040 0
[MCU2_0] 44.338649 s: write Board_gmslMax96712DesInit 1@0x49: 0x00fa=0x0034 0
[MCU2_0] 44.339105 s: write Board_gmslMax96712DesInit 1@0x49: 0x0018=0x000f 0
[MCU2_0] 44.370507 s: write Board_gmslMax96712DesInit 1@0x49: 0x0006=0x000f 0
[MCU2_0] 44.380747 s: write Board_gmslMax96712DesInit 1@0x40: 0x0004=0x0087 0
[MCU2_0] 44.381441 s: write Board_gmslMax96712DesInit 1@0x40: 0x000f=0x0081 0
[MCU2_0] 44.382134 s: write Board_gmslMax96712DesInit 1@0x40: 0x0007=0x0084 0
[MCU2_0] 44.382830 s: write Board_gmslMax96712DesInit 1@0x49: 0x0415=0x002a 0
[MCU2_0] 44.383522 s: write Board_gmslMax96712DesInit 1@0x49: 0x0418=0x002a 0
[MCU2_0] 44.384215 s: write Board_gmslMax96712DesInit 1@0x49: 0x041b=0x002a 0
[MCU2_0] 44.384911 s: write Board_gmslMax96712DesInit 1@0x49: 0x041e=0x002a 0
[MCU2_0] 44.384944 s: CSI 1
[MCU2_0] 44.385626 s: write Board_gmslMax96712DesInit 1@0x6b: 0x040b=0x0000 0
[MCU2_0] 44.386320 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0006=0x0000 0
[MCU2_0] 44.387014 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04a0=0x0004 0
[MCU2_0] 44.387708 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04a2=0x0000 0
[MCU2_0] 44.388401 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04aa=0x0000 0
[MCU2_0] 44.389098 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04ab=0x0000 0
[MCU2_0] 44.389792 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04af=0x005f 0
[MCU2_0] 44.390486 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04a7=0x000f 0
[MCU2_0] 44.391179 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04a6=0x0042 0
[MCU2_0] 44.391874 s: write Board_gmslMax96712DesInit 1@0x6b: 0x04a5=0x0040 0
[MCU2_0] 44.392567 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0b08=0x0071 0
[MCU2_0] 44.393260 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0c08=0x0071 0
[MCU2_0] 44.393955 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0d08=0x0071 0
[MCU2_0] 44.394648 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0e08=0x0071 0
[MCU2_0] 44.395341 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0b06=0x00ef 0
[MCU2_0] 44.396036 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0c06=0x00ef 0
[MCU2_0] 44.396729 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0d06=0x00ef 0
[MCU2_0] 44.397422 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0e06=0x00ef 0
[MCU2_0] 44.398112 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0b0f=0x0001 0
[MCU2_0] 44.398807 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0c0f=0x0001 0
[MCU2_0] 44.399500 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0d0f=0x0001 0
[MCU2_0] 44.400193 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0e0f=0x0001 0
[MCU2_0] 44.400888 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0b07=0x0084 0
[MCU2_0] 44.401581 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0c07=0x0084 0
[MCU2_0] 44.402274 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0d07=0x0084 0
[MCU2_0] 44.402969 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0e07=0x0084 0
[MCU2_0] 44.407747 s: write Board_gmslMax96712DesInit 1@0x6b: 0x041a=0x00f0 0
[MCU2_0] 44.408441 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0b0d=0x0080 0
[MCU2_0] 44.409134 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0c0d=0x0080 0
[MCU2_0] 44.409829 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0d0d=0x0080 0
[MCU2_0] 44.410522 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0e0d=0x0080 0
[MCU2_0] 44.411215 s: write Board_gmslMax96712DesInit 1@0x6b: 0x08a3=0x00e4 0
[MCU2_0] 44.411910 s: write Board_gmslMax96712DesInit 1@0x6b: 0x040b=0x0042 0
[MCU2_0] 44.412603 s: write Board_gmslMax96712DesInit 1@0x6b: 0x040c=0x0000 0
[MCU2_0] 44.413296 s: write Board_gmslMax96712DesInit 1@0x6b: 0x040d=0x0000 0
[MCU2_0] 44.413991 s: write Board_gmslMax96712DesInit 1@0x6b: 0x040e=0x005e 0
[MCU2_0] 44.414684 s: write Board_gmslMax96712DesInit 1@0x6b: 0x040f=0x007e 0
[MCU2_0] 44.415377 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0410=0x007a 0
[MCU2_0] 44.416072 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0411=0x0048 0
[MCU2_0] 44.416766 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0412=0x0020 0
[MCU2_0] 44.417459 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0415=0x00ea 0
[MCU2_0] 44.418152 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0418=0x00ea 0
[MCU2_0] 44.418847 s: write Board_gmslMax96712DesInit 1@0x6b: 0x090b=0x0007 0
[MCU2_0] 44.419540 s: write Board_gmslMax96712DesInit 1@0x6b: 0x092d=0x0015 0
[MCU2_0] 44.420233 s: write Board_gmslMax96712DesInit 1@0x6b: 0x090d=0x001e 0
[MCU2_0] 44.420928 s: write Board_gmslMax96712DesInit 1@0x6b: 0x090e=0x001e 0
[MCU2_0] 44.421620 s: write Board_gmslMax96712DesInit 1@0x6b: 0x090f=0x0000 0
[MCU2_0] 44.422314 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0910=0x0000 0
[MCU2_0] 44.423008 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0911=0x0001 0
[MCU2_0] 44.423701 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0912=0x0001 0
[MCU2_0] 44.424395 s: write Board_gmslMax96712DesInit 1@0x6b: 0x094b=0x0007 0
[MCU2_0] 44.425091 s: write Board_gmslMax96712DesInit 1@0x6b: 0x096d=0x0015 0
[MCU2_0] 44.425783 s: write Board_gmslMax96712DesInit 1@0x6b: 0x094d=0x001e 0
[MCU2_0] 44.426476 s: write Board_gmslMax96712DesInit 1@0x6b: 0x094e=0x005e 0
[MCU2_0] 44.427170 s: write Board_gmslMax96712DesInit 1@0x6b: 0x094f=0x0000 0
[MCU2_0] 44.427865 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0950=0x0040 0
[MCU2_0] 44.428557 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0951=0x0001 0
[MCU2_0] 44.429251 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0952=0x0041 0
[MCU2_0] 44.429942 s: write Board_gmslMax96712DesInit 1@0x6b: 0x098b=0x0007 0
[MCU2_0] 44.430635 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09ad=0x0015 0
[MCU2_0] 44.431328 s: write Board_gmslMax96712DesInit 1@0x6b: 0x098d=0x001e 0
[MCU2_0] 44.432023 s: write Board_gmslMax96712DesInit 1@0x6b: 0x098e=0x009e 0
[MCU2_0] 44.432716 s: write Board_gmslMax96712DesInit 1@0x6b: 0x098f=0x0000 0
[MCU2_0] 44.433409 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0990=0x0080 0
[MCU2_0] 44.434106 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0991=0x0001 0
[MCU2_0] 44.434798 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0992=0x0081 0
[MCU2_0] 44.435491 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09cb=0x0007 0
[MCU2_0] 44.436184 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09ed=0x0015 0
[MCU2_0] 44.436879 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09cd=0x001e 0
[MCU2_0] 44.437572 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09ce=0x00de 0
[MCU2_0] 44.438265 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09cf=0x0000 0
[MCU2_0] 44.438960 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09d0=0x00c0 0
[MCU2_0] 44.439653 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09d1=0x0001 0
[MCU2_0] 44.440346 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09d2=0x00c1 0
[MCU2_0] 44.441037 s: write Board_gmslMax96712DesInit 1@0x6b: 0x00fa=0x0033 0
[MCU2_0] 44.441730 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0018=0x000f 0
[MCU2_0] 44.472747 s: write Board_gmslMax96712DesInit 1@0x6b: 0x040b=0x0040 0
[MCU2_0] 44.473441 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0006=0x000f 0
[MCU2_0] 44.483746 s: write Board_gmslMax96712DesInit 1@0x40: 0x0004=0x0087 0
[MCU2_0] 44.484440 s: write Board_gmslMax96712DesInit 1@0x40: 0x000f=0x0081 0
[MCU2_0] 44.485134 s: write Board_gmslMax96712DesInit 1@0x40: 0x0007=0x0084 0
[MCU2_0] 44.485826 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0903=0x0080 0
[MCU2_0] 44.486519 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0943=0x0080 0
[MCU2_0] 44.487212 s: write Board_gmslMax96712DesInit 1@0x6b: 0x0983=0x0080 0
[MCU2_0] 44.487907 s: write Board_gmslMax96712DesInit 1@0x6b: 0x09c3=0x0080 0
[MCU2_0] 44.488600 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1c00=0x00f4 0
[MCU2_0] 44.489293 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1d00=0x00f4 0
[MCU2_0] 44.489988 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1e00=0x00f4 0
[MCU2_0] 44.490820 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1f00=0x00f4 0
[MCU2_0] 44.491513 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1c00=0x00f5 0
[MCU2_0] 44.492207 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1d00=0x00f5 0
[MCU2_0] 44.492902 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1e00=0x00f5 0
[MCU2_0] 44.493595 s: write Board_gmslMax96712DesInit 1@0x6b: 0x1f00=0x00f5 0
[MCU2_0] 44.493628 s: CSI 2
[MCU2_0] 44.494310 s: write Board_gmslMax96712DesInit 1@0x42: 0x02d3=0x0000 0
[MCU2_0] 44.495005 s: write Board_gmslMax96712DesInit 1@0x42: 0x0330=0x0000 0
[MCU2_0] 44.495698 s: write Board_gmslMax96712DesInit 1@0x42: 0x0383=0x0000 0
[MCU2_0] 44.496391 s: write Board_gmslMax96712DesInit 1@0x42: 0x0331=0x0033 0
[MCU2_0] 44.497084 s: write Board_gmslMax96712DesInit 1@0x42: 0x0332=0x00e0 0
[MCU2_0] 44.497779 s: write Board_gmslMax96712DesInit 1@0x42: 0x0333=0x0004 0
[MCU2_0] 44.498471 s: write Board_gmslMax96712DesInit 1@0x42: 0x0308=0x0064 0
[MCU2_0] 44.499165 s: write Board_gmslMax96712DesInit 1@0x42: 0x0311=0x0040 0
[MCU2_0] 44.499859 s: write Board_gmslMax96712DesInit 1@0x42: 0x0318=0x006c 0
[MCU2_0] 44.500665 s: write Board_gmslMax96712DesInit 1@0x42: 0x0002=0x0043 0
[MCU2_0] 44.501358 s: write Board_gmslMax96712DesInit 1@0x42: 0x03f1=0x0001 0
[MCU2_0] 44.502053 s: write Board_gmslMax96712DesInit 1@0x42: 0x03f0=0x0051 0
[MCU2_0] 44.502750 s: write Board_gmslMax96712DesInit 1@0x42: 0x0570=0x0001 0
[MCU2_0] 44.503442 s: write Board_gmslMax96712DesInit 1@0x42: 0x0570=0x0000 0
[MCU2_0] 44.504136 s: write Board_gmslMax96712DesInit 1@0x42: 0x0006=0x00b1 0
[MCU2_0] 44.504830 s: write Board_gmslMax96712DesInit 1@0x42: 0x02bf=0x0060 0
[MCU2_0] 44.505523 s: write Board_gmslMax96712DesInit 1@0x42: 0x02be=0x0090 0
[MCU2_0] 44.506217 s: write Board_gmslMax96712DesInit 1@0x42: 0x02d3=0x0090 0
[MCU2_0] 44.506246 s: End of MAX96712 config
[MCU2_0] 44.506285 s: Error : max96712_cfgScript returned 0 while configuring DES 0
Invalid entry
Select camera port index 0-11 : 7
11 registered sensor drivers
a : IMX390-UB953_D3
c : AR0820-UB953_LI
e : OX03C-MAX9295E
f : OX08B-MAX9296
g : OX08BA-MAX9296
h : MAX96712_RAW_TESTPAT
i : AR0233-MAX9295E
j : UB96x_UYVY_TESTPATTERN
k : GW_AR0233_UYVY
. Try again
a : IMX390-UB953_D3
c : AR0820-UB953_LI
e : OX03C-MAX9295E
f : OX08B-MAX9296
g : OX08BA-MAX9296
i : AR0233-MAX9295E
k : GW_AR0233_UYVY
Select a sensor above or press '0' to autodetect the sensor : g
Sensor selected : OX08BA-MAX9296
Querying OX08BA-MAX9296
50.591860 s: ISS: Querying sensor [OX08BA-MAX9296] ... !!!
[MCU2_0] 50.592032 s: ImageSensor_RemoteServiceHandler: CMD 1
[MCU2_0] 50.592064 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY
[MCU2_0] 50.592104 s: Received Query for OX08BA-MAX9296
50.592243 s: ISS: Querying sensor [OX08BA-MAX9296] ... Done !!!
50.592263 s: ISS: Initializing sensor [OX08BA-MAX9296], doing IM_SENSOR_CMD_PWRON ... !!!
50.592598 s: ISS: Initializing sensor [OX08BA-MAX9296], doing IM_SENSOR_CMD_CONFIG ... !!!
[MCU2_0] 50.592404 s: ImageSensor_RemoteServiceHandler: CMD 2
[MCU2_0] 50.592434 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON
[MCU2_0] 50.592475 s: IM_SENSOR_CMD_PWRON : channel_mask = 0x80
[MCU2_0] 50.592737 s: ImageSensor_RemoteServiceHandler: CMD 3
[MCU2_0] 50.592767 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG
[MCU2_0] 50.592806 s: Application requested features = 0x100
[MCU2_0] 50.592833 s: Disabling broadcast mode
[MCU2_0] 50.592866 s: IM_SENSOR_CMD_CONFIG channel_mask = 80
[MCU2_0] 50.592900 s: Configuring camera # 0
[MCU2_0] 50.592929 s: Configuring camera # 1
[MCU2_0] 50.592958 s: Configuring camera # 2
[MCU2_0] 50.592987 s: Configuring camera # 3
[MCU2_0] 50.593015 s: Configuring camera # 4
[MCU2_0] 50.593044 s: Configuring camera # 5
[MCU2_0] 50.593073 s: Configuring camera # 6
[MCU2_0] 50.593105 s: Configuring camera # 7
[MCU2_0] 50.593139 s: AA55 OX08BA_Probe | sensorI2cAddr 36
[MCU2_0] 50.794644 s: OX08BA_Probe : 0x5801 read at chip ID register 0x300a. Expected 0x5803
[MCU2_0] 50.794678 s: OX08BA Probe Failed
[MCU2_0] 50.895633 s: OX08BA_Probe : 0x5801 read at chip ID register 0x300a. Expected 0x5803
[MCU2_0] 50.895667 s: OX08BA Probe Failed
[MCU2_0] 50.996637 s: OX08BA_Probe : 0x5801 read at chip ID register 0x300a. Expected 0x5803
[MCU2_0] 50.996669 s: OX08BA Probe Failed
[MCU2_0] 51.097637 s: OX08BA_Probe : 0x5801 read at chip ID register 0x300a. Expected 0x5803
[MCU2_0] 51.097671 s: OX08BA Probe Failed
[MCU2_0] 51.198632 s: OX08BA_Probe : 0x5801 read at chip ID register 0x300a. Expected 0x5803
[MCU2_0] 51.198666 s: OX08BA Probe Failed
51.298263 s: ISS: Initializing sensor [OX08BA-MAX9296] ... Done !!!
Scaler is disabled
[MCU2_0] 51.298092 s: Error : sensor probe failed for channel 7
[MCU2_0] 51.298131 s: IM_SENSOR_CMD_CONFIG returning status = 0
51.307103 s: ISS: Starting sensor [OX08BA-MAX9296] ... !!!
d: sensor debug
x: Exit
Enter Choice:
Unsupported command
d: sensor debug
x: Exit
Enter Choice: [MCU2_0] 51.307344 s: ImageSensor_RemoteServiceHandler: CMD 4
[MCU2_0] 51.307388 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_STREAM_ON
[MCU2_0] 51.307436 s: IM_SENSOR_CMD_STREAM_ON: channel_mask = 0x80
[MCU2_0] 51.307469 s: UB960 config start
[MCU2_0] 51.563568 s: End of UB960 config
[MCU2_0] 51.563599 s: UB960 config start
[MCU2_0] 51.820743 s: End of UB960 config
[MCU2_0] 51.820768 s: UB960 config start
[MCU2_0] 52.077566 s: End of UB960 config
[MCU2_0] 52.077601 s: AA55 OX08BA_StreamOn
[MCU2_0] 52.077628 s: max96712_cfgScript
[MCU2_0] 52.077665 s: Get CSI 0 i2c addr 0@73
[MCU2_0] 52.077688 s: MAX96712 config start
[MCU2_0] 52.078379 s: write max96712_cfgScript 1@0x49: 0x040b=0x0042 0
[MCU2_0] 52.079070 s: write max96712_cfgScript 1@0x49: 0x08a2=0x00f4 0
[MCU2_0] 52.095745 s: write max96712_cfgScript 1@0x49: 0x08a0=0x0084 0
[MCU2_0] 52.111745 s: write max96712_cfgScript 1@0x49: 0x08a2=0x00f4 0
[MCU2_0] 52.127741 s: write max96712_cfgScript 1@0x49: 0x08a0=0x0084 0
[MCU2_0] 52.143746 s: write max96712_cfgScript 1@0x49: 0xffff=0x0000 0
[MCU2_0] 52.143774 s: End of MAX96712 config
[MCU2_0] 52.143799 s: max96712_cfgScript
[MCU2_0] 52.143835 s: Get CSI 1 i2c addr 0@107
[MCU2_0] 52.143856 s: MAX96712 config start
[MCU2_0] 52.144541 s: write max96712_cfgScript 1@0x6b: 0x040b=0x0042 0
[MCU2_0] 52.145233 s: write max96712_cfgScript 1@0x6b: 0x08a2=0x00f4 0
[MCU2_0] 52.161744 s: write max96712_cfgScript 1@0x6b: 0x08a0=0x0084 0
[MCU2_0] 52.177745 s: write max96712_cfgScript 1@0x6b: 0x08a2=0x00f4 0
[MCU2_0] 52.193745 s: write max96712_cfgScript 1@0x6b: 0x08a0=0x0084 0
52.209919 s: ISS: Starting sensor [OX08BA-MAX9296] ... !!!
get_dcc_dir_size : Could not open directory or directory is empty /opt/vision_apps/dcc/OX08BA-MAX9296/wdr
[MCU2_0] 52.209744 s: write max96712_cfgScript 1@0x6b: 0xffff=0x0000 0
[MCU2_0] 52.209773 s: End of MAX96712 config
[MCU2_0] 52.210305 s: VX_ZONE_WARNING:[tivxCaptureSetTimeout:796] CAPTURE: WARNING: Error frame not provided u
p
CPU: mpu1_0: TOTAL LOAD = 0.50 % ( HWI = 0. 4 %, SWI = 0. 0 % )
CPU: mcu2_0: TOTAL LOAD = 21. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
CPU: mcu2_1: TOTAL LOAD = 21. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
CPU: c7x_2: TOTAL LOAD = 1. 0 % ( HWI = 0. 0 %, SWI = 0. 0 % )
DDR: READ BW: AVG = 1 MB/s, PEAK = 6092 MB/s
DDR: WRITE BW: AVG = 0 MB/s, PEAK = 1578 MB/s
DDR: TOTAL BW: AVG = 1 MB/s, PEAK = 7670 MB/s
DDR_SHARED_MEM: Alloc's: 5 alloc's of 9830616 bytes
DDR_SHARED_MEM: Open's : 5 allocs of 9830616 bytes
CPU: mcu2_0: TASK: REMOTE_SRV: 0.32 %
CPU: mcu2_0: HEAP: DDR_LOCAL_MEM: size = 16777216 B, free = 16696832 B ( 99 % unused)
CPU: mcu2_0: HEAP: L3_MEM: size = 524288 B, free = 524032 B ( 99 % unused)
CPU: mcu2_1: HEAP: DDR_LOCAL_MEM: size = 16777216 B, free = 16773120 B ( 99 % unused)
CPU: mcu2_1: HEAP: L3_MEM: size = 524288 B, free = 524288 B (100 % unused)
CPU: c7x_1: HEAP: L3_MEM: size = 3964928 B, free = 3964928 B (100 % unused)
CPU: c7x_2: TASK: IPC_RX: 0. 0 %
CPU: c7x_2: TASK: REMOTE_SRV: 0. 0 %
CPU: c7x_2: TASK: LOAD_TEST: 0. 0 %
CPU: c7x_2: TASK: TIVX_CPU: 0. 0 %
CPU: c7x_2: TASK: IPC_TEST_RX: 0. 0 %
CPU: c7x_2: TASK: IPC_TEST_TX: 0. 0 %
CPU: c7x_2: HEAP: DDR_LOCAL_MEM: size = 16777216 B, free = 16772608 B ( 99 % unused)
CPU: c7x_2: HEAP: L2_MEM: size = 458752 B, free = 458752 B (100 % unused)
CPU: c7x_2: HEAP: L1_MEM: size = 16384 B, free = 16384 B (100 % unused)
CPU: c7x_2: HEAP: DDR_SCRATCH_MEM: size = 67108864 B, free = 67108864 B (100 % unused)
GRAPH: graph_85 (#nodes = 1, #executions = 0)
NODE: CAPTURE2: node_96: avg = 0 usecs, min/max = 18446744073709551 / 0 usecs, #ex
PERF: TOTAL: avg = 0 usecs, min/max = 4294967295 / 0 usecs, #executions = 0
PERF: TOTAL: 0. 0 FPS
Hi Jason,
From CSIRX perspective, there is no change in the module, so if you have taken care of deserializer and sensor programming, it should work fine.
Brijesh
Hi Brijesh,
Is there a way to turn off the display_option of TDA4AL singal_cam?
I guess it may be caused by display_option
Hi jason,
It does not look like display issue, even capture seems not working. So i really doubt disabling display will help. Can we get the capture working first?
Can you please make sure that
- sensor and deserializer are configured in streamon callback?
- number of lane and lane speed are matching with deserializer output?
- virtual channel and data type are matching with deserializer output?
Brijesh
