I booted the rootfs.ext4 through DFU into the EMMC. After logging in, when I type the 'reboot' command in the UART terminal, the reboot worked , but ethernet is not working and the UART log shows the following.
root@am62xx-evm:~# reb[ 45.292173] kauditd_printk_skb: 5 callbacks suppressed [ 45.292203] audit: type=1334 audit(1712898317.820:29): prog-id=12 op=UNLOAD [ 45.304810] audit: type=1334 audit(1712898317.820:30): prog-id=11 op=UNLOAD oot Stopping topping Session c2 of User root... [ OK ] Removed slice Slice /system/modprobe. [ OK ] Removed slice Slice /system/systemd-coredump. [ OK ] Stopped target Graphical Interface. [ OK ] Stopped target Multi-User System. [ OK ] Stopped target Login Prompts. [ OK ] Stopped target RPC Port Mapper. [ OK ] Stopped target Sound Card. [ OK ] Stopped target Timer Units. [ OK ] Stopped Daily rotation of log files. [ OK ] Stopped Daily Cleanup of Temporary Directories. [ OK ] Stopped target System Time Set. [ OK ] Stopped target Hardware activated USB gadget. [ OK ] Closed Process Core Dump Socket. [ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch. Stopping Job spooling tools... Stopping Avahi mDNS/DNS-SD Stack... Stopping Bluetooth service... Stopping Chromium browser service... Stopping containerd container runtime... Stopping Periodic Command Scheduler... [ OK ] Stopped DEMO. Stopping Getty on tty1... Stopping irqbalance daemon... Stopping Reboot and dump vmcore via kexec... Stopping Netperf Benchmark Server... Stopping NFS status monitor for NFSv2/3 locking.... Stopping Telephony service... Stopping PulseAudio Sound System... [ OK ] Stopped Expand the rootfs …full size of the boot device.. Stopping Serial Getty on ttyS2... Stopping Seva Launcher Service... Stopping Simple Network Ma…ent Protocol (SNMP) Daemon.... Stopping strongSwan IPsec …Ev2 daemon using ipsec.conf... Stopping Load/Save Random Seed... Stopping TEE Supplicant... Stopping Telnet Server... Stopping Daemon for power management... Stopping Weston, a Wayland…ositor, as a system service... [ OK ] Stopped Job spooling tools. [ OK ] Stopped Chromium browser service. [ OK ] Stopped Periodic Command Scheduler. [ OK ] Stopped irqbalance daemon. [ OK ] Stopped Telephony service. [ OK ] Stopped PulseAudio Sound System. [ OK ] Stopped Seva Launcher Service. [ OK ] Stopped strongSwan IPsec I…IKEv2 daemon using ipsec.conf. [ OK ] Stopped TEE Supplicant. [ OK ] Stopped Avahi mDNS/DNS-SD Stack. [ OK ] Stopped Netperf Benchmark Server. [ OK ] Stopped NFS status monitor for NFSv2/3 locking.. [ OK ] Stopped Simple Network Man…ement Protocol (SNMP) Daemon.. [ OK ] Stopped containerd container runtime. [ OK ] Stopped Getty on tty1. [ OK ] Stopped Serial Getty on ttyS2. [ OK ] Stopped Weston, a Wayland …mpositor, as a system service. [ OK ] Stopped Bluetooth service. [ OK ] Stopped Daemon for power management. [ OK ] Stopped Reboot and dump vmcore via kexec. [ OK ] Stopped Load/Save Random Seed. [ OK ] Stopped Telnet Server. [ OK ] Stopped Session c1 of User weston. [ OK ] Stopped Session c2 of User root. [ 48.199722] audit: type=1334 audit(1712898320.749:31): prog-id=14 op=UNLOAD [ 48.206996] audit: type=1334 audit(1712898320.749:32): prog-id=13 op=UNLOAD [ OK ] Removed slice Slice /system/getty. [ OK ] Removed slice Slice /system/serial-getty. [ OK ] Stopped target Host and Network Name Lookups. Stopping Save/Restore Sound Card State... Stopping User Login Management... [ 48.357518] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 Stopping User Manager for UID 0... [ 48.369741] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 48.386418] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 48.398477] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 Stopping User Manager for UID 1000...[ 48.410329] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 48.426892] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 48.438660] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 48.450421] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ OK ] Stopped User Manager for UID 1000 48.462226] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 0m. [ 48.479503] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 [ 48.491288] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ OK ] Stopped User Manager for UID 0.[ 48.503440] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 48.520445] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 48.532291] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 48.544168] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 48.555952] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 48.567639] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 Stopping User Runtime Directory /run/user/0 48.579570] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 m... [ 48.596790] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 48.608912] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 48.620666] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 Stopping User Runtime Directory /run/user/1000[ 48.632525] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 ... [ 48.649482] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 48.661814] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 48.673530] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ OK ] Unmounted /run/user/0. [ 48.685333] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 48.701614] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ OK ] Unmounted /run/user/1000. [ 48.713669] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 48.730182] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 48.742022] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 48.753880] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000025] -121 [ 48.765660] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000026] -121 [ 48.777336] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 48.789114] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 48.800792] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 48.812552] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 [ 48.824266] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 [ 48.835993] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 48.847718] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ 48.859483] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ 48.871164] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 48.882904] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 48.894618] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 48.906451] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 48.918136] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 48.929854] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 48.941562] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 48.953419] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 48.965191] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 48.977015] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 48.988692] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ OK ] Stopped User Login Management. [ OK ] Stopped Save/Restore Sound Card State. [ OK ] Stopped User Runtime Directory /run/user/0. [ OK ] Stopped User Runtime Directory /run/user/1000. [ OK ] Removed slice User Slice of UID 0. [ OK ] Removed slice User Slice of UID 1000. Stopping Permit User Sessions... [ OK ] Stopped Permit User Sessions. [ OK ] Stopped target Network. [ OK ] Stopped target Remote File Systems. Stopping Network Name Resolution... [ OK ] Stopped Network Name Resolution. Stopping Network Configuration... [ OK ] Stopped Network Configuration. [ OK ] Stopped target Preparation for Network. [ OK ] Stopped IPv6 Packet Filtering Framework. [ OK ] Stopped IPv4 Packet Filtering Framework. [ OK ] Stopped target Basic System. [ OK ] Stopped target Path Units. [ OK ] Stopped Dispatch Password …ts to Console Directory Watch. [ OK ] Stopped Forward Password R…uests to Wall Directory Watch. [ OK ] Stopped target Slice Units. [ OK ] Removed slice User and Session Slice. [ OK ] Stopped target Socket Units. [ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Closed Docker Socket for the API. [ OK ] Closed dropbear.socket. [ OK ] Closed PC/SC Smart Card Daemon Activation Socket. [ OK ] Closed Network Service Netlink Socket. [ OK ] Closed Weston socket. Stopping D-Bus System Message Bus... [ OK ] Stopped D-Bus System Message Bus. [ OK ] Closed D-Bus System Message Bus Socket. [ OK ] Stopped target System Initialization. [ OK ] Stopped Apply Kernel Variables. [ OK ] Stopped Load Kernel Modules. Stopping Network Time Synchronization... [ OK ] Stopped Network Time Synchronization. [ OK ] Stopped Create Volatile Files and Directories. [ OK ] Stopped target Local File Systems. Unmounting /media/ram... Unmounting Temporary Directory /tmp... Unmounting /var/volatile... [ OK ] Unmounted /media/ram. [ OK ] Unmounted Temporary Directory /tmp. [ OK ] Unmounted /var/volatile. [ OK ] Stopped target Preparation for Local File Systems. [ OK ] Stopped target Swaps. [ OK ] Reached target Unmount All Filesystems. [ OK ] Stopped Remount Root and Kernel File Systems. [ OK ] Stopped Create Static Device Nodes in /dev. [ OK ] Reached target System Shutdown. [ OK ] Reached target Late Shutdown Services. [ OK ] Finished System Reboot. [ OK ] Reached target System Reboot. [ 50.420654] audit: type=1334 audit(1712898322.981:33): prog-id=6 op=UNLOAD [ 50.427940] audit: type=1334 audit(1712898322.981:34): prog-id=5 op=UNLOAD [ 50.434990] audit: type=1334 audit(1712898322.985:35): prog-id=10 op=UNLOAD [ 50.442073] audit: type=1334 audit(1712898322.985:36): prog-id=9 op=UNLOAD [ 50.449039] audit: type=1334 audit(1712898322.993:37): prog-id=4 op=UNLOAD [ 50.455982] audit: type=1334 audit(1712898322.993:38): prog-id=3 op=UNLOAD [ 50.462914] audit: type=1334 audit(1712898323.009:39): prog-id=8 op=UNLOAD [ 50.469868] audit: type=1334 audit(1712898323.009:40): prog-id=7 op=UNLOAD [ 50.501719] watchdog: watchdog0: nowayout prevents watchdog being stopped! [ 50.508810] watchdog: watchdog0: watchdog did not stop! [ 50.540518] systemd-shutdown[1]: Using hardware watchdog 'K3 RTI Watchdog', version 0, device /dev/watchdog0 [ 50.550485] systemd-shutdown[1]: Modifying watchdog timeout is not supported, reusing the programmed timeout. [ 50.560487] systemd-shutdown[1]: Watchdog running with a timeout of 1min. [ 50.577979] systemd-shutdown[1]: Syncing filesystems and block devices. [ 50.591477] systemd-shutdown[1]: Sending SIGTERM to remaining processes... [ 50.614756] systemd-journald[172]: Received SIGTERM from PID 1 (systemd-shutdow). [ 50.624991] audit: type=1335 audit(1712898323.186:41): pid=172 uid=0 auid=4294967295 tty=(none) ses=4294967295 comm="systemd-journal" exe="/lib/systemd/systemd-journald" nl-mcgrp=1 op=disconnect res=1 [ 50.644443] systemd-shutdown[1]: Sending SIGKILL to remaining processes... [ 50.666565] systemd-shutdown[1]: Unmounting file systems. [ 50.675870] [1116]: Remounting '/' read-only with options 'n/a'. [ 50.708213] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none. [ 50.748817] systemd-shutdown[1]: All filesystems unmounted. [ 50.754469] systemd-shutdown[1]: Deactivating swaps. [ 50.759732] systemd-shutdown[1]: All swaps deactivated. [ 50.764979] systemd-shutdown[1]: Detaching loop devices. [ 50.774801] systemd-shutdown[1]: All loop devices detached. [ 50.780455] systemd-shutdown[1]: Stopping MD devices. [ 50.786043] systemd-shutdown[1]: All MD devices stopped. [ 50.791388] systemd-shutdown[1]: Detaching DM devices. [ 50.796988] systemd-shutdown[1]: All DM devices detached. [ 50.802457] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached. [ 50.821053] systemd-shutdown[1]: Syncing filesystems and block devices. [ 50.827975] systemd-shutdown[1]: Rebooting. [ 50.883757] reboot: Restarting system U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:52:36 +0000) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') SPL initial stack usage: 13424 bytes Trying to boot from MMC1 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Loading Environment from MMC... OK init_env from device 9 not supported! Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 05:06:58, Feb 24 2023 U-Boot SPL 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') Trying to boot from MMC1 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted U-Boot 2021.01-g2ee8efd654 (Feb 24 2023 - 05:29:33 +0000) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 0x50, trying to read at 0x51 Board: AM62-SKEVM rev E2 DRAM: 2 GiB MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2 Loading Environment from MMC... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device SD/MMC found on device 0 Failed to load 'boot.scr' ** Unrecognized filesystem type ** 19583488 bytes read in 117 ms (159.6 MiB/s) 61307 bytes read in 6 ms (9.7 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008feee000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.1.80-dirty (repl@repl-HP-EliteBook-840-G4) (aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #2 SMP PREEMPT Wed Apr 3 15:33:34 IST 2024 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, size 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=9e4c5fb1-9e88-5b4d-81e9-b57763f90d65 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 1848068K/2097152K available (11840K kernel code, 1268K rwdata, 3864K rodata, 2048K init, 440K bss, 118012K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008542] Console: colour dummy device 80x25 [ 0.013140] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023822] pid_max: default: 32768 minimum: 301 [ 0.028591] LSM: Security Framework initializing [ 0.033446] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.041029] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.050838] cblist_init_generic: Setting adjustable number of callback queues. [ 0.058290] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.064588] cblist_init_generic: Setting adjustable number of callback queues. [ 0.071984] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.078378] rcu: Hierarchical SRCU implementation. [ 0.083286] rcu: Max phase no-delay instances is 1000. [ 0.088884] Platform MSI: msi-controller@1820000 domain created [ 0.095183] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.104576] EFI services will not be available. [ 0.109498] smp: Bringing up secondary CPUs ... [ 0.114793] Detected VIPT I-cache on CPU1 [ 0.114904] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.114923] GICv3: CPU1: using allocated LPI pending table @0x0000000080060000 [ 0.114982] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.115690] Detected VIPT I-cache on CPU2 [ 0.115761] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.115776] GICv3: CPU2: using allocated LPI pending table @0x0000000080070000 [ 0.115811] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.116419] Detected VIPT I-cache on CPU3 [ 0.116499] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.116512] GICv3: CPU3: using allocated LPI pending table @0x0000000080080000 [ 0.116542] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.116608] smp: Brought up 1 node, 4 CPUs [ 0.196353] SMP: Total of 4 processors activated. [ 0.201166] CPU features: detected: 32-bit EL0 Support [ 0.206436] CPU features: detected: CRC32 instructions [ 0.211753] CPU: All CPU(s) started at EL2 [ 0.215951] alternatives: applying system-wide alternatives [ 0.223484] devtmpfs: initialized [ 0.235265] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.245271] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.257285] pinctrl core: initialized pinctrl subsystem [ 0.263287] DMI not present or invalid. [ 0.267863] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.275047] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.282559] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.290626] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.298810] audit: initializing netlink subsys (disabled) [ 0.304503] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1 [ 0.304992] thermal_sys: Registered thermal governor 'step_wise' [ 0.312435] thermal_sys: Registered thermal governor 'power_allocator' [ 0.318618] cpuidle: using governor menu [ 0.329464] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.336494] ASID allocator initialised with 65536 entries [ 0.352567] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts [ 0.365756] KASLR disabled due to lack of seed [ 0.377063] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.384036] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.390448] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.397388] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.403796] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.410735] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.417142] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.424082] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.431961] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.442719] iommu: Default domain type: Translated [ 0.447739] iommu: DMA domain TLB invalidation policy: strict mode [ 0.454443] SCSI subsystem initialized [ 0.458651] usbcore: registered new interface driver usbfs [ 0.464303] usbcore: registered new interface driver hub [ 0.469761] usbcore: registered new device driver usb [ 0.475408] pps_core: LinuxPPS API ver. 1 registered [ 0.480495] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.489846] PTP clock support registered [ 0.493985] EDAC MC: Ver: 3.0.0 [ 0.498128] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.505164] FPGA manager framework [ 0.508724] Advanced Linux Sound Architecture Driver Initialized. [ 0.515927] clocksource: Switched to clocksource arch_sys_counter [ 0.522432] VFS: Disk quotas dquot_6.6.0 [ 0.526487] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.539439] NET: Registered PF_INET protocol family [ 0.544746] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.554008] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.562817] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.570756] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.578959] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.586953] TCP: Hash tables configured (established 16384 bind 16384) [ 0.593861] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.600793] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.608317] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.614604] RPC: Registered named UNIX socket transport module. [ 0.620694] RPC: Registered udp transport module. [ 0.625503] RPC: Registered tcp transport module. [ 0.630312] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.636904] NET: Registered PF_XDP protocol family [ 0.641818] PCI: CLS 0 bytes, default 64 [ 0.646646] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.656765] Initialise system trusted keyrings [ 0.661614] workingset: timestamp_bits=46 max_order=19 bucket_order=0 [ 0.672629] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.679200] NFS: Registering the id_resolver key type [ 0.684457] Key type id_resolver registered [ 0.688735] Key type id_legacy registered [ 0.692885] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.699740] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.741587] Key type asymmetric registered [ 0.745781] Asymmetric key parser 'x509' registered [ 0.750820] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.758546] io scheduler mq-deadline registered [ 0.763196] io scheduler kyber registered [ 0.770688] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.777236] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.784883] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.797320] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.813622] loop: module loaded [ 0.818035] megasas: 07.719.03.00-rc1 [ 0.825114] tun: Universal TUN/TAP device driver, 1.6 [ 0.831339] VFIO - User Level meta-driver version: 0.3 [ 0.837401] usbcore: registered new interface driver usb-storage [ 0.843950] SPI driver ads7846 has no spi_device_id for ti,tsc2046 [ 0.850276] SPI driver ads7846 has no spi_device_id for ti,ads7843 [ 0.856595] SPI driver ads7846 has no spi_device_id for ti,ads7845 [ 0.862914] SPI driver ads7846 has no spi_device_id for ti,ads7873 [ 0.869495] i2c_dev: i2c /dev entries driver [ 0.875437] sdhci: Secure Digital Host Controller Interface driver [ 0.881808] sdhci: Copyright(c) Pierre Ossman [ 0.886467] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.893076] ledtrig-cpu: registered to indicate activity on CPUs [ 0.899422] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.906375] usbcore: registered new interface driver usbhid [ 0.912079] usbhid: USB HID core driver [ 0.916915] optee: probing for conduit method. [ 0.921507] optee: revision 3.20 (8e74d476) [ 0.921826] optee: dynamic shared memory is enabled [ 0.931359] optee: initialized driver [ 0.936912] Initializing XFRM netlink socket [ 0.941353] NET: Registered PF_PACKET protocol family [ 0.946596] Key type dns_resolver registered [ 0.951409] registered taskstats version 1 [ 0.955638] Loading compiled-in X.509 certificates [ 0.970252] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') [ 1.072783] rtc-m41t80 0-0068: registered as rtc0 [ 1.078077] rtc-m41t80 0-0068: setting system clock to 2024-04-12T05:05:30 UTC (1712898330) [ 1.086690] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.093869] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.101044] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz [ 1.107130] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.116385] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.128840] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.137057] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.148079] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.158099] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.168300] printk: console [ttyS2] disabled [ 1.172761] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 240, base_baud = 3000000) is a 8250 [ 1.181653] printk: console [ttyS2] enabled [ 1.181653] printk: console [ttyS2] enabled [ 1.190110] printk: bootconsole [ns16550a0] disabled [ 1.190110] printk: bootconsole [ns16550a0] disabled [ 1.201610] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.247949] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.258115] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.266225] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver SMSC LAN8710/LAN8720 [ 1.275214] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.288080] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.295208] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.301675] pps pps0: new PPS source ptp0 [ 1.306005] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.316402] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.327637] mmc1: CQHCI version 5.10 [ 1.331878] am65-cpsw-nuss 8000000.ethernet: Failed to create device link (0x180) with 601000.gpio [ 1.341587] pca953x 1-0022: supply vcc not found, using dummy regulator [ 1.348319] pca953x 1-0022: using AI [ 1.376079] pca953x 1-0022: failed writing register [ 1.381164] pca953x: probe of 1-0022 failed with error -121 [ 1.387139] Goodix-TS 2-005d: supply AVDD28 not found, using dummy regulator [ 1.394323] Goodix-TS 2-005d: supply VDDIO not found, using dummy regulator [ 1.425457] Goodix-TS 2-005d: ID 928, version: 1040 [ 1.447667] input: Goodix Capacitive TouchScreen as /devices/platform/bus@f0000/20020000.i2c/i2c-2/2-005d/input/input0 [ 1.461093] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 1.470385] mmc0: CQHCI version 5.10 [ 1.470863] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.483345] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present! [ 1.502419] ALSA device list: [ 1.505436] No soundcards found. [ 1.515348] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.600223] mmc0: Command Queue Engine enabled [ 1.604692] mmc0: new high speed MMC card at address 0001 [ 1.611127] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.621120] mmcblk0: p1 [ 1.624349] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB [ 1.630446] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB [ 1.636379] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (240:0) [ 2.845025] sdhci-am654 fa00000.mmc: Power on failed [ 2.881121] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 2.901417] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Quota mode: none. [ 2.910071] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 2.920180] devtmpfs: mounted [ 2.924447] Freeing unused kernel memory: 2048K [ 2.929113] Run /sbin/init as init process [ 3.337235] NET: Registered PF_INET6 protocol family [ 3.344329] Segment Routing with IPv6 [ 3.348057] In-situ OAM (IOAM) with IPv6 [ 3.399523] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid) [ 3.440446] systemd[1]: Detected architecture arm64. Welcome to Arago 2023.10! [ 3.504844] systemd[1]: Hostname set to <am62xx-evm>. [ 3.623352] systemd-sysv-generator[157]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust. [ 3.870856] systemd[1]: Configuration file /lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 3.965468] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.026712] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.099711] systemd[1]: Queued start job for default target Graphical Interface. [ 4.174747] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 4.199204] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 4.223673] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 4.247427] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 4.274525] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 4.300584] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 4.324809] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 4.344179] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.364330] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 4.384228] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 4.468930] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 4.492527] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 4.531262] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 4.553113] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 4.578114] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 4.601624] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.625993] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.650576] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.674154] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.697668] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.722776] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 4.780625] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.810386] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.844263] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.865403] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.912703] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 4.950850] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 4.980983] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 5.011119] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 5.039856] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 5.151817] fuse: init (API version 7.37) [ 5.161248] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 5.195028] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 5.212541] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/). [ 5.269449] systemd[1]: Starting Journal Service... Starting Journal Service... [ 5.301124] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 5.357148] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network …ts from Kernel command line... [ 5.386490] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 5.411222] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none. [ 5.415386] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 5.443628] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 5.465146] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ 5.891300] systemd-journald[172]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /media/ram... Mounting /var/volatile... [ 6.129422] audit: type=1334 audit(1712898335.548:2): prog-id=5 op=LOAD [ 6.136191] audit: type=1334 audit(1712898335.556:3): prog-id=6 op=LOAD Starting Rule-based Manage…for Device Events and Files... [ OK ] Finished Coldplug All udev Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Rule-based Manager for Device Events and Files. [ OK ] Finished Create Volatile Files and Directories. Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started Network Time Synchronization. [ 6.797167] ads7846 spi1.0: touchscreen, irq 293 [ OK ] Found device /dev/ttyS2. [ OK ] Reached target System Initializatio[ 6.829527] input: ADS7846 Touchscreen as /devices/platform/bus@f0000/20100000.spi/spi_master/spi1/spi1.0/input/input2 n. [ 6.855161] panel-simple panel: supply power not found, using dummy regulator [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files[ 6.900215] mc: Linux media interface: v0.10 . [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ 6.975385] videodev: Linux video capture interface: v2.00 Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ OK ] Listening on PC/SC Smart Card Daemon Activation Socket. Starting Weston socket... Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the [ 7.126371] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000 API. [ 7.136419] random: crng init done [ 7.141712] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ 7.149004] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device [ OK ] Listening on Weston socket.[ 7.160378] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 7.182037] Console: switching to colour frame buffer device 160x50 [ 7.212830] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device [ OK ] Finished Load/Save Random Seed.[ 7.225452] remoteproc remoteproc0: 5000000.m4fss is available [ 7.238586] remoteproc remoteproc0: powering up 5000000.m4fss [ 7.244529] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55016 [ OK ] Finished Reboot and dump vmcore via[ 7.255198] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node m4f-dma-memory@9cb00000 kexec. [ OK ] Reached target Socket Units. [ 7.291641] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7) [ 7.303867] remoteproc remoteproc0: remote processor 5000000.m4fss is now up [ 7.345175] virtio_rpmsg_bus virtio0: rpmsg host is online [ 7.351034] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 7.363669] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ OK ] Started D-Bus System Message Bus. [ 7.404122] rtc-ti-k3 2b1f0000.rtc: registered as rtc1 [ 7.407398] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 7.425838] platform 78000000.r5f: configured R5F for IPC-only mode [ 7.432531] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000 [ OK ] Reached target Basic System. [ 7.442148] remoteproc remoteproc1: 78000000.r5f is available [ 7.454413] remoteproc remoteproc1: attaching to 78000000.r5f [ 7.461138] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 7.469799] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9da00000 [ OK ] Started Job spooling tools. [ 7.523281] virtio_rpmsg_bus virtio1: rpmsg host is online [ 7.523575] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 7.529065] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7) [ 7.537040] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 7.544027] remoteproc remoteproc1: remote processor 78000000.r5f is now attached [ OK ] Started Chromium browser service. [ OK ] Started Periodic Command Scheduler. Starting DEMO... Starting Print notice about GPLv3 packages... [ 7.685471] pvrsrvkm: loading out-of-tree module taints kernel. Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting PulseAudio Sound System... Starting Expand the rootfs…ll size of the boot device.... [ 7.843618] PVR_K: 203: Device: fd00000.gpu [ 7.849679] PVR_K: 203: Read BVNC 33.15.11.3 from HW device registers [ 7.859455] PVR_K: 203: RGX Device registered with BVNC 33.15.11.3 [ OK ] Started Seva Launcher Service. [ 7.888933] [drm] Initialized pvr 23.3.6512818 20170530 for fd00000.gpu on minor 1 [ OK ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf. [ 7.919042] audit: type=1334 audit(1712898337.336:4): prog-id=7 op=LOAD [ 7.929281] audit: type=1334 audit(1712898337.344:5): prog-id=8 op=LOAD Starting User Login Management... [ OK ] Started TEE Supplicant. Starting Telnet Server... [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Finished Telnet Server. [ OK ] Started DEMO. [ OK ] Started Telephony service. [ OK ] Reached target Preparation for Network. Starting Network Configuration... [ 8.375326] Bluetooth: Core ver 2.22 [ 8.379211] NET: Registered PF_BLUETOOTH protocol family [ 8.389176] Bluetooth: HCI device and connection manager initialized [ 8.402736] Bluetooth: HCI socket layer initialized [ 8.423285] Bluetooth: L2CAP socket layer initialized [ 8.430109] Bluetooth: SCO socket layer initialized [ 8.547898] remoteproc remoteproc2: 30074000.pru is available [ 8.573424] remoteproc remoteproc3: 30078000.pru is available [ OK ] Finished Expand the rootfs…full size of the boot device.. [ OK ] Started User Login Management. [ 8.851637] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22 [ 8.887149] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 8.919754] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ OK ] Listening on Load/Save RF …itch S[ 8.927350] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' tatus /dev/rfkill Watch. [ OK ] Reached target Hardware activated USB gadget. [ 9.065060] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 9.071017] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 9.079230] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports [ 9.085401] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000010010 [ 9.095003] xhci-hcd xhci-hcd.3.auto: irq 423, io mem 0x31100000 [ 9.102460] hub 1-0:1.0: USB hub found [ 9.106494] hub 1-0:1.0: 1 port detected [ OK ] Started PulseAudio Sound System. [ OK ] Started Network Configuration. Starting Network Name Resolution... [ 9.364019] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 9.364383] tlv320aic3x 1-001b: Unable to sync registers 0x8-0x9. -121 [ 9.377851] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000005] -121 [ 9.391823] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000006] -121 [ 9.412565] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [SMSC LAN8710/LAN8720] (irq=POLL) [ 9.423010] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rmii link mode [ 9.444897] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 9.454412] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 9.455531] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 9.476352] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 9.488359] tlv320aic3x 1-001b: ASoC: Left Line Mixer DAPM update failed: -121 [ 9.495878] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 9.509271] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 9.524829] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 9.537809] tlv320aic3x 1-001b: ASoC: Left Line Mixer DAPM update failed: -121 [ 9.547035] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 9.560307] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 9.572883] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 9.585514] hub 1-1:1.0: USB hub found [ 9.586146] tlv320aic3x 1-001b: ASoC: Left HP Mixer DAPM update failed: -121 [ 9.589520] hub 1-1:1.0: 4 ports detected [ 9.597812] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 9.612730] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 9.625824] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 9.637931] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 9.649886] tlv320aic3x 1-001b: ASoC: Left HP Mixer DAPM update failed: -121 [ 9.657582] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 9.669472] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 9.681491] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 9.693835] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 9.705971] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 9.718011] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 9.729835] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000004f] -121 Starting Save/Restore Sound Card State... [ 9.837458] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 9.850193] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 9.863491] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 9.878351] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000050] -121 [ OK ] Started Network Name Resolution[ 9.892643] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000002d] -121 . [ OK ] Reached target Network. [ 9.908739] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000034] -121 [ OK ] Reached target Host and Network Nam[ 9.926500] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000049] -121 e Lookups. [ 9.943479] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 9.956396] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000004f] -121 Starting Avahi mDNS/DNS-SD Stack... [ 9.970960] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000051] -121 Starting Enable and configure wl18xx bluetooth[ 9.988396] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000052] -121 stack... [ 9.992069] usb 1-1.3: new low-speed USB device number 3 using xhci-hcd [ 10.005464] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000002e] -121 Starting containerd container runtime... [ 10.025453] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ OK ] Started Netperf Benchmark Server 10.043440] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000056] -121 m. [ 10.059455] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000056] -121 [ OK ] Started NFS status monitor for NFSv[ 10.072015] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000033] -121 2/3 locking.. [ 10.089467] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000033] -121 Starting Simple Network Ma…ent Protocol (SNM[ 10.105841] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000003a] -121 P) Daemon.... Starting Permit User Sessions... [ 10.124883] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ 10.144419] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 10.158514] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 10.176032] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ OK ] Started Getty on tty1. [ 10.188785] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 10.209550] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 10.223300] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 10.224763] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 Starting Synchronize System and HW clocks.[ 10.252044] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 .. [ 10.269227] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 10.269427] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000065] -121 [ 10.293187] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 10.295732] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 10.306028] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 Starting Weston, a Wayland…ositor, as a syst[ 10.329191] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000007] -121 em service... [ 10.346615] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 10.353200] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000002] -121 [ OK ] Started Avahi mDNS/DNS-SD Stack[ 10.370938] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 . [ 10.388537] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000b] -121 [ 10.400713] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000004] -121 [ 10.412543] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000005] -121 [ 10.424476] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000006] -121 [ 10.425534] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000a] -121 [ 10.425890] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 10.437789] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 10.439597] input: Usb KeyBoard Usb KeyBoard as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:C0F4:04F5.0001/input/input3 [ OK ] Finished Save/Restore Sound Card St[ 10.496870] hid-generic 0003:C0F4:04F5.0001: input: USB HID v1.10 Keyboard [Usb KeyBoard Usb KeyBoard] on usb-xhci-hcd.3.auto-1.3/input0 ate. [ OK ] Reached target Sound Card. [ 10.518767] input: Usb KeyBoard Usb KeyBoard Consumer Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:C0F4:04F5.0002/input/input4 [ 10.596534] input: Usb KeyBoard Usb KeyBoard System Control as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.3/1-1.3:1.1/0003:C0F4:04F5.0002/input/input5 [ OK ] Finished Synchronize System and HW [ 10.614347] hid-generic 0003:C0F4:04F5.0002: input: USB HID v1.10 Device [Usb KeyBoard Usb KeyBoard] on usb-xhci-hcd.3.auto-1.3/input1 clocks. [ 10.773418] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 10.785340] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 10.799762] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 10.816341] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 10.824036] usb 1-1.4: new full-speed USB device number 4 using xhci-hcd [ 10.829055] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 10.846499] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 10.858472] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 10.870402] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 10.882227] audit: type=1334 audit(1712898340.300:6): prog-id=9 op=LOAD [ 10.884410] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 10.889811] audit: type=1334 audit(1712898340.308:7): prog-id=10 op=LOAD [ 10.902450] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 10.919105] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 10.931325] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 10.943147] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 Starting User Database Manager... [ 10.956791] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 10.972277] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 10.984263] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 10.996154] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 11.008208] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 11.020292] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 11.032062] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 11.044623] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 11.056892] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 11.069096] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 11.081043] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 11.093169] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 11.106364] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 11.107334] input: Jieli Technology UACDemoV1.0 as /devices/platform/bus@f0000/f910000.dwc3-usb/31100000.usb/xhci-hcd.3.auto/usb1/1-1/1-1.4/1-1.4:1.2/0003:4C4A:4155.0003/input/input6 [ 11.135671] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 11.147656] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 11.159436] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 11.171245] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 11.176404] hid-generic 0003:4C4A:4155.0003: input: USB HID v1.00 Device [Jieli Technology UACDemoV1.0] on usb-xhci-hcd.3.auto-1.4/input2 [ 11.182972] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 11.207107] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 11.219074] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 11.236485] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 11.250666] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 11.262707] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 11.274583] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 11.287831] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 11.299625] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 11.311775] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 11.324433] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 11.341063] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 11.355616] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 11.370379] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 11.384655] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 11.398409] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 11.413141] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 11.425732] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 [ 11.438136] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ OK ] Created slice User Slice of UID 100[ 11.451548] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 0. [ 11.468298] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 11.480425] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 11.488347] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 11.492217] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 11.500883] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 11.513121] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 Starting User Runtime Directory /run/user/1000[ 11.530987] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 ... [ 11.549537] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ OK ] Finished User Runtime Directory /ru[ 11.563074] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 n/user/1000. Starting User Manager for UID 1000... [ 11.581408] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 11.599200] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 11.612427] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 11.616805] audit: type=1006 audit(1712898341.036:8): pid=525 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1 [ 11.618316] usbcore: registered new interface driver snd-usb-audio [ 11.628599] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 11.637999] audit: type=1300 audit(1712898341.036:8): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc5912de8 a2=4 a3=ffffb938a020 items=0 ppid=1 pid=525 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null) [ 11.652384] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 11.654763] audit: type=1327 audit(1712898341.036:8): proctitle="(systemd)" [ 11.682593] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 11.712956] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ 11.724983] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 11.736965] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ 11.752069] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 11.764330] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 11.779132] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 11.792423] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 11.804278] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000065] -121 [ 11.816199] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 11.828247] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000007] -121 [ 11.840161] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000002] -121 [ 11.852149] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 11.864334] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000b] -121 [ 11.876398] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000004] -121 [ 11.888235] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000005] -121 [ 11.900141] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000006] -121 [ 11.912847] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000a] -121 [ 11.924800] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000025] -121 [ 11.936858] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 [ 11.948658] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ 12.043229] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 12.055116] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 12.070691] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000065] -121 [ 12.084546] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 12.098690] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000007] -121 [ 12.112628] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000002] -121 [ 12.126207] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 12.139814] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000b] -121 [ 12.152678] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000004] -121 [ 12.165545] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000005] -121 [ 12.177570] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000006] -121 [ 12.189966] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000a] -121 [ 12.201916] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 12.214054] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 12.226215] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 [ 12.237975] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ 12.249687] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 [ 12.261494] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ 12.274958] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 12.286984] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 12.309016] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 12.320765] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 12.332584] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000065] -121 [ 12.344392] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 12.356379] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000007] -121 [ OK ] Started Simple Network Man…ement [ 12.368882] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000002] -121 Protocol (SNMP) Daemon.. [ 12.385730] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 12.399960] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000b] -121 [ OK ] Started User Manager for UID 1000 12.411778] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000004] -121 0m. [ 12.429027] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000005] -121 [ 12.441018] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000006] -121 [ 12.453488] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000a] -121 [ OK ] Started Session c1 of User weston 12.465357] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 0m. [ 12.475509] audit: type=1006 audit(1712898341.892:9): pid=485 uid=0 old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [ 12.482483] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ 12.495124] audit: type=1300 audit(1712898341.892:9): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffc5912de8 a2=4 a3=ffffb938a020 items=0 ppid=1 pid=485 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/lib/systemd/systemd" key=(null) [ 12.506742] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 [ 12.532829] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 12.532856] audit: type=1327 audit(1712898341.892:9): proctitle="(weston)" [ 12.544591] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ 12.571285] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 [ 12.583067] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ 12.594994] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 12.609831] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 12.623702] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 12.635808] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 12.647639] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 12.659487] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 12.671301] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 12.683794] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 12.696873] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 12.709131] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 12.721568] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 12.733652] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 12.745428] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 12.757305] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 12.769242] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 12.781052] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 12.792802] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 12.804631] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 12.816470] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 12.828182] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 12.840060] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 12.851904] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 12.863678] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 12.875543] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 12.887312] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 12.899207] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 12.910988] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 12.922888] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 12.934633] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 12.946448] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 12.958183] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 12.970108] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 12.981884] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 12.993813] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 13.005780] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 13.017699] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 13.029444] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 13.041218] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 13.052939] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 13.064943] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 13.076885] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 13.088788] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 13.100793] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 13.112758] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000025] -121 [ 13.124606] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 13.136502] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 13.148421] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 13.160332] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 13.172252] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 [ 13.184262] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 13.196489] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 [ 13.208691] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 13.220532] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 13.221814] PVR_K: 485: RGX Firmware image 'rgx.fw.33.15.11.3' loaded [ 13.239494] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 13.251285] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 13.252035] PVR_K: 485: Shader binary image 'rgx.sh.33.15.11.3' loaded [ 13.263403] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 13.281299] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 13.293924] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 13.305726] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 13.317827] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000026] -121 [ 13.329796] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 13.342557] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 13.354623] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 13.367110] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 13.379678] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 13.391860] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ 13.404140] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 13.416350] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ 13.440573] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 13.452449] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000009] -121 [ 13.464442] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000065] -121 [ 13.476503] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 13.489254] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000007] -121 [ 13.501373] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000002] -121 [ 13.513509] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000003] -121 [ 13.526145] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000b] -121 [ 13.532412] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 13.539229] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000004] -121 [ 13.558566] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000005] -121 [ 13.581089] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x00000006] -121 [ 13.594183] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000000a] -121 [ 13.606137] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 13.619034] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 13.635801] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 [ 13.648631] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 [ 13.661122] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ OK ] Started containerd container runtim[ 13.673163] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 e. [ 13.690329] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 13.704727] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 13.720254] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 13.734867] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 13.746637] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 13.758566] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 13.770450] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 13.782232] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000056] -121 [ 13.794035] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000005d] -121 [ 13.806006] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 13.806213] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ 13.829537] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000049] -121 [ OK ] Started Weston, a Wayland …mpositor, as a system service. [ 13.847316] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 13.861682] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 13.874114] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000004f] -121 [ 13.887049] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 13.899455] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 13.913727] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000000c] -121 [ 13.925635] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 13.937658] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 13.949502] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 13.963452] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 13.975319] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 13.987368] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 14.000666] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 14.018130] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 [ 14.036491] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 14.048424] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000033] -121 Starting Bluetooth service... [ 14.064244] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000041] -121 [ 14.080042] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 14.092002] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 14.104045] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 14.115895] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 14.128655] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 14.142064] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 14.157133] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003a] -121 [ 14.169427] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000048] -121 [ 14.184491] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002f] -121 [ 14.200247] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002d] -121 [ 14.220465] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002e] -121 [ 14.235165] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000034] -121 [ 14.249690] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000025] -121 [ 14.261765] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000052] -121 [ 14.274968] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000050] -121 [ 14.288172] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000051] -121 [ 14.301204] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 14.314205] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 [ 14.327504] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 14.340614] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000014] -121 [ 14.354355] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 14.367240] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 14.379903] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 14.392522] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000003b] -121 [ 14.405839] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 14.433608] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 14.448250] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 14.463588] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000042] -121 [ 14.476769] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000026] -121 [ 14.490326] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 14.503000] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 14.516867] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 14.530053] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000057] -121 [ 14.544260] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 14.556863] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ 14.568834] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 14.575612] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 14.593093] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x00000017] -121 [ OK ] Started Bluetooth service. [ 14.815894] audit: type=1334 audit(1712898344.232:10): prog-id=11 op=LOAD [ 14.823690] audit: type=1334 audit(1712898344.240:11): prog-id=12 op=LOAD Starting Hostname Service... _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm - Arago 2023.10 am62xx-evm - am62xx-evm login: [ 16.604557] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 17.409142] audit: type=1334 audit(1712898346.828:12): prog-id=13 op=LOAD [ 17.420080] audit: type=1334 audit(1712898346.836:13): prog-id=14 op=LOAD [ 17.637027] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down *************************************************************** *************************************************************** NOTICE: This file system contains the following GPL-3.0 packages: adwaita-icon-theme-symbolic autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gnu-config grep grub-common grub-editenv grub-e[ 18.440827] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 fi gzip hidapi less libasm1 libatomic-dev libatomic1[ 18.452879] tlv320aic3x 1-001b: ASoC: error at soc_component_read_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 libbfd libdebuginfod1 libdw1 libeigen-dev libelf1 l[ 18.469981] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002b] -121 ibgcc-s-dev libgcc1 libgdbm-compat4 libgdbm-dev libgdbm6[ 18.486988] tlv320aic3x 1-001b: ASoC: error at soc_component_write_no_lock on tlv320aic3x.1-001b for register: [0x0000002c] -121 libgettextlib libgettextsrc libgmp10 libidn2-0 libmpc3 libmpfr6 libopcodes libqt5charts-examples libqt5charts-plugins libqt5charts-qmlplugins libqt5charts5 libqt5sensors-plugins libqt5sensors-qmlplugins libqt5sensors5 libqt5serialport-examples libqt5serialport-plugins libqt5serialport-qmlplugins libqt5serialport5 libqt5svg-examples libqt5svg-plugins libqt5svg-qmlplugins libqt5svg5 libqt5virtualkeyboard-plugins libqt5virtualkeyboard-qmlplugins libqt5virtualkeyboard5 libqt5webchannel-plugins libqt5webchannel-qmlplugins libqt5webchannel5 libreadline-dev libreadline8 libstdc++-dev libstdc++6 libunistring2 m4-dev m4 make nettle parted piglit qt3d-plugins qt3d-qmlplugins qt3d qtbase-examples qtbase-plugins qtbase-qmlplugins qtbase qtconnectivity-plugins qtconnectivity-qmlplugins qtconnectivity qtdeclarative-plugins qtdeclarative-qmlplugins qtdeclarative-tools qtdeclarative qtgraphicaleffects-qmlplugins qtlocation-examples qtlocation-plugins qtlocation-qmlplugins qtlocation qtmultimedia-examples qtmultimedia-plugins qtmultimedia-qmlplugins qtmultimedia qtquick3d-plugins qtquick3d-qmlplugins qtquick3d qtquics-qmlplugins.control qtquics2-plugins.control qtquics2-qmlplugins.control qtquics2.control qtscript-examples qtscript-plugins qtscript-qmlplugins qtscript qtwayland-examples qtwayland-plugins qtwayland-qmlplugins qtwayland tar which If you do not wish to distribute GPL-3.0 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the[ 18.652834] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ 19.516084] ti-udma 485c0100.dma-controller: chan1 teardown timeout! [ 19.614456] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000013] -121 [ 19.626516] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000016] -121 [ 19.679707] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 20.668039] ti-udma 485c0100.dma-controller: chan2 teardown timeout! [ 21.662477] platform regulator-6: deferred probe pending [ 21.668066] platform regulator-7: deferred probe pending [ 21.726617] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 22.760366] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 23.708908] tlv320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on tlv320aic3x.1-001b for register: [0x00000025] -121 [ 23.773125] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 24.806523] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 28.892966] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 29.928035] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 30.940686] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 31.976338] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 34.012981] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 35.045743] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 36.061024] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 37.093251] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 39.133958] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 40.162191] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 41.181082] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 42.216243] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 44.252979] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 45.284997] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 45.308298] audit: type=1334 audit(1712898374.728:14): prog-id=12 op=UNLOAD [ 45.315372] audit: type=1334 audit(1712898374.728:15): prog-id=11 op=UNLOAD [ 46.301021] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 47.336354] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 51.421027] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 52.455753] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 53.469102] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 54.504324] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 56.541016] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 57.576319] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 58.589018] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 59.625322] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 61.661060] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 62.696328] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 63.709037] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 64.744337] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 66.781049] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 67.816238] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 68.829005] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 69.864329] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 73.948977] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 74.984245] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 75.997041] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 77.027414] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 79.068991] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 80.104252] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 81.116470] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 82.152325] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 84.189044] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 85.224335] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 86.237106] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 87.272440] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 91.357012] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 92.392297] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 96.476999] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 97.512358] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 98.525035] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 99.559847] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 101.597787] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 102.632344] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 103.645015] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 104.680467] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 106.717005] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 107.752334] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 108.765083] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 109.800364] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 113.885021] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 114.920363] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 119.004969] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 120.040204] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 121.053006] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 122.088369] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 124.125033] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 125.160224] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 126.173033] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 127.203455] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 129.245913] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 130.280315] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 131.293021] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 132.328514] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 136.413007] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 137.448390] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 138.460994] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 139.496357] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 141.532987] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 142.568326] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 143.581032] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 144.616418] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 146.652963] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 147.688332] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 149.725844] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 150.760398] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 152.796990] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 153.827831] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 154.844997] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 155.880363] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 157.917911] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 158.952321] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 159.965015] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 161.000362] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 163.037055] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 164.072330] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 165.085016] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 166.120326] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 170.205020] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 171.240428] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 172.253007] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 173.288379] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 175.325014] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 176.360341] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 177.373023] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 178.408356] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 180.445809] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 181.480328] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 182.493004] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 183.528396] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 187.612978] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 188.648359] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 192.733020] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 193.768387] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 194.781022] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 195.816337] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 197.852979] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 198.888351] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 199.901033] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 200.936349] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 202.973000] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 204.008377] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 205.021082] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 206.055616] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 210.141016] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 211.176323] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 212.189064] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 213.224373] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 215.261006] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 216.296370] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 217.309039] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 218.344245] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 220.381024] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 221.416385] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 222.429081] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 223.464364] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 225.501015] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 226.536246] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 227.549036] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 228.584371] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 232.669648] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 233.704341] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 234.717005] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 235.752366] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 237.788985] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 238.824275] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 239.836984] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 240.872364] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 242.909013] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 243.937394] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 244.957013] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 245.987342] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 251.100995] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 252.136363] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 254.172993] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 255.202286] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 256.221000] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 257.256354] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 261.341001] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 262.376345] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 266.461002] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 267.496331] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 268.509025] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 269.544359] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 271.581024] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 272.616338] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 273.629040] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 274.664361] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 276.701004] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 277.736367] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 278.749034] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 279.784371] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 283.869903] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 284.902435] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 288.988989] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 290.024372] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 291.037059] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 292.068882] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 294.109044] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 295.144336] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 296.157058] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 297.185285] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 299.229884] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 300.264355] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 301.276984] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 302.312351] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 306.397038] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 307.432322] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 308.445069] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 309.480393] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 311.517779] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 312.551291] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 313.564996] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 314.600327] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 316.636867] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 317.672369] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 318.685029] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 319.720396] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 321.756987] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 322.792309] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 323.804998] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 324.840459] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 328.925875] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 329.960340] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 330.972529] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 332.008356] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 334.044978] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 335.080350] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 336.092953] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 337.127100] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 339.165176] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 340.200223] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 341.212927] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 342.245084] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 346.332635] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 347.368305] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 351.453609] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 352.488912] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 353.501621] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 354.536401] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 356.572981] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 357.608229] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 358.621636] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 359.656223] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 361.693610] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 362.728230] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 363.741690] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 364.776900] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 372.572973] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 373.608235] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 374.620602] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 375.656339] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 377.693681] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 378.729685] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 379.740939] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 380.776349] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 382.812920] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 383.848254] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 384.860964] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 385.896232] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 387.932977] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 388.968330] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 389.981599] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 391.016987] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 395.100934] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 396.137211] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 397.148715] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 398.184358] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 400.221566] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 401.256946] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 412.413569] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 413.448916] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 415.485588] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 416.520276] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 417.532946] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
I think the ethernet is getting reset every time.
Abhijeet
Is this the first time booting the board and using the network with Linux? Has the network interface running Linux been proven out prior to using DFU to boot the board?
Most of the link up link down is related to the PHY not being able to keep the link established with the link partner. The PHY is reporting no carrier and this causes the link down process.
Schuyler
Patton
No this is not the first time the board is being booted many times through DFU in EMMC mode.
This thing happen one in ten attempts of reboot.
Abhijeet
When the condition happens is this line present in the console log?
[ 1.331878] am65-cpsw-nuss 8000000.ethernet: Failed to create device link (0x180) with 601000.gpio
Another question is if the PHY is in interrupt or polled mode operation.
Schuyler
